The Great HU Install of 2023
Discussion in 'Audio & Video' started by RainMan_PNW, Aug 19, 2023.
Did you get in on the recent Best Buy clearance frenzy? What did you get?
  1. Alpine ILX-F511
    35 vote(s)
    27.6%
  2. Alpine ILX-F509
    3 vote(s)
    2.4%
  3. Alpine ILX-F507
    0 vote(s)
    0.0%
  4. Kenwood DMX-1037S
    16 vote(s)
    12.6%
  5. Something else (let us know in the thread)
    4 vote(s)
    3.1%
  6. I bought enough to start my own car stereo franchise
    2 vote(s)
    1.6%
  7. No - I was late to the party
    52 vote(s)
    40.9%
  8. No - I didn't need a new head unit
    19 vote(s)
    15.0%
Multiple votes are allowed.
  1. Aug 26, 2023 at 8:08 PM
    #151
    Azblue
    The Dirty T ( ^_^)_且
    Yep. That or I'll catch the truck on fire and burn my house down in the process. Either way, it should be interesting.
  2. Aug 26, 2023 at 8:26 PM
    #152
    bulldog93
    bulldog93 Usually tired...
    Jeff
    Santa Rosa, California
    2020 Super White CM Tundra TRD Pro
    Which dash kit did you get?
  3. Aug 26, 2023 at 8:27 PM
    #153
    Azblue
  4. Aug 26, 2023 at 8:31 PM
    #154
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    And I’m here for it.
  5. Aug 26, 2023 at 8:35 PM
    #155
    ebpgh
    ebpgh .
    PA
    2020 Cement Tundra
    Anyone with a Kenwood have a solution for the xm tuner hook up? Might just leave it be since I don’t use xm anyway.
    TaquitoBandito and MedCityMoto like this.
  6. Aug 26, 2023 at 8:36 PM
    #156
    Azblue
    I'll try to get video unless my phone is in the truck and burns up.
  7. Aug 26, 2023 at 8:36 PM
    #157
    bulldog93
    Jeff
  8. Aug 26, 2023 at 8:39 PM
    #158
    Azblue
    Yeah, the rest of it is fine. There is a kit with metal brackets, but it's double din only, which doesn't work with the Alpine.
  9. Aug 26, 2023 at 8:42 PM
    #159
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    I bought a sheet of ABS and cut a filler plate for mine (threw away the pocket…). I can send you a chunk if you want to go with the Dasaita kit
  10. Aug 26, 2023 at 8:46 PM
    #160
    Azblue
    Thanks but for now I'll just roll with what I got. I'm already tired of figuring out all the harnesses, modules, kits, and adapter and I haven't even taken my truck apart yet.
    And remember, this is from somebody that already kinda knows what the fuck I'm doing. Technology is a PITA sometimes. :annoyed:
  11. Aug 26, 2023 at 8:48 PM
    #161
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    100% this haha. I’ve redone my shit so many times because something that should work doesn’t work the way it should or the way I want it to. I’ve bitched to @BiggHertz a lot over the last week…
  12. Aug 26, 2023 at 8:50 PM
    #162
    Azblue
    Cool, so you mean I can just blame @BiggHertz when my shit doesn't work rather than myself
  13. Aug 26, 2023 at 8:51 PM
    #163
    TRDFerguson
    Jake
    2018 MGM CrüeMax
  14. Aug 26, 2023 at 8:52 PM
    #164
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    TaquitoBandito, Azblue and ToyoMafia like this.
  15. Aug 26, 2023 at 10:20 PM
    #165
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    whoa whoa whoa
    TaquitoBandito and Azblue like this.
  16. Aug 26, 2023 at 10:21 PM
    #166
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    Indeed!
  17. Aug 27, 2023 at 9:06 AM
    #167
    ebpgh
    ebpgh .
    PA
    2020 Cement Tundra
    So does this new head unit run the speakers or is it the same amp under the seat? I have a non jbl. Seams way louder to me, but maybe I’m dreaming.
    Only had to take the thing out 3 or 4 times before I got it. A little tip I found on the Kenwood is that you have to slide the unit up to get the AC control back in if you want it to sit as low as it can. Not a big deal to move only 4 screws. Or you can just have it set high with one screw holding it in the side until you are ready to put it back together.
  18. Aug 27, 2023 at 12:53 PM
    #168
    MedCityMoto
    MedCityMoto SciTech Nerd
    2.5gen CM SR5 TRD OffRoad
    Ah, I lied. I went to put the mic in today and, nope, not happy with the hassle. It was actually easier to run up the A pillar, oddly.
    TaquitoBandito and bulldog93 like this.
  19. Aug 27, 2023 at 12:53 PM
    #169
    AZTundra
    Paul
    Phoenix, AZ
    Ok, so I ordered the USB/HDMI port to install in the bottom tray under the radio (by the USB/12V plugs) which will arrive tomorrow.
    I've been looking at the instructions for the Alpine DVR-320R and I'm not sure I follow how to connect it directly to the ILX-F511. I'm not using the Car Charger Cable, but will be doing the hardwire method instead. I understand plugging in the cameras and the Yellow/Red/Black connections but am lost on the "F CAM" connection as well as the "REMOCON IN" and "REMOCON OUT" and how these connect at the back of the Alpine. Am I going to need the "sold separately" cable noted in the diagram? If so, wonder why Alpine does not include that to integrate with the head unit.
    The Alpine manual however shows that the "Drive Recorder In" and LIN are used for the Dashcam connections. Do I not need to use the "F CAM and the REMOCON In/Out from the dash cam wiring and will be using the 2 LIN Cables instead and plug the yellow rca from the F CAM cord into the Drive Recorder In on the Alpine harness and leave the red/white rca's unattached?
    @BiggHertz any ideas on this one?
    bulldog93 likes this.
  20. Aug 27, 2023 at 1:00 PM
    #170
    MedCityMoto
    Anyone remember if the black connector is XM and the white is GPS, or if I've got that backwards on my 2015 non-JBL?
  21. Aug 27, 2023 at 1:18 PM
    #171
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    IIRC, white connector is GPS and black connector is SAT. Confirm by following the white connector to the GPS antenna that is about 8-10 inches to the left of the center speaker.
  22. Aug 27, 2023 at 1:50 PM
    #172
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    I don’t have any explicit experience with this integration, but in previous generations, some of the Alpine h/u’s previously utilized a combination 1/8” jack that included stereo audio (red + white) and video (yellow), which they simply carried over in their documentation or failed to update it entirely.
    While I’m not certain, I do feel that the signal delivery from the dash-cam DVR to your h/u can be accomplished by utilizing the composite video (yellow RCA) and the LIN connector.
  23. Aug 27, 2023 at 1:53 PM
    #173
    AZTundra
    Paul
    Phoenix, AZ
    Thanks for the response. I'll give that a try when I get ready to install (Using the Yellow RCA and the 2 LIN Connectors).
    TaquitoBandito likes this.
  24. Aug 27, 2023 at 1:55 PM
    #174
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    Unless you’re daisy chaining multiple LIN capable devices. You should only need just the one.
  25. Aug 27, 2023 at 2:13 PM
    #175
    AZTundra
    Paul
    Phoenix, AZ
    Crutchfield just responded to my message as well. They stated to follow the head unit manual instead of the Dash Cam instructions. I was told to utilize the yellow RCA and Lin Connectors and I should be good to go aside from also connecting the battery, acc, and ground connections of course. Hopefully this helps others out too. Not sure if anyone else ordered the dash cam or just me.
  26. Aug 27, 2023 at 2:41 PM
    #176
    RainMan_PNW
    RainMan_PNW [OP] "Oz" SSEM #82 RGBA #4 Unofficial Forum Treasurer Vendor?
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Just letting everyone know I've been buried this week and am now 4 pages behind on this thread. I will hopefully get through it later tonight and get updates and new links added.
  27. Aug 27, 2023 at 3:23 PM
    #177
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    Slacker…:boink:
  28. Aug 27, 2023 at 3:25 PM
    #178
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    So lazy. Classic Casey.
  29. Aug 27, 2023 at 4:36 PM
    #179
    Azblue
    Today I decided to do some prep work on the bench to get ready to install this weekend. A few things.
    1. The Metra dash kit looks fine but is shit. The plastic brackets are total crap and no matter how you try to adjust it, you'll end up with a small 1/16" gap at either the little tray or the top of the HU.
    2. Alpine provides 3 different screws (black hex, silver round, and silver recessed) all the same thread and length with the exact same description in the manual M5x8 and no indication of which goes where.
    3. The real pisser, the screen comes set in the highest position, so unless you want it sticking up 8" above the dash you need to remove 4 tiny screws and adjust it down. Fine, but some idiot on the assembly line at Alpine must have hit them with extra ugga-duggas and some red Loctite. I got 3 out but the last one would not budge. Yes, I was using the proper size and pitch screwdriver, so much so that I had so much down and rotational force that I thought I was going to break the screen. Of course the screw totally stripped. I was quite, ah, irritated, so I put it all away and will tackle it another day. Best advice my late dad gave me is if something is being a bitch , walk away for a while.
    I'll go at it later this week, maybe cut a slot with a Dremel to use a regular screwdriver, or carefully drill off the head of the screw.
    bulldog93, WFD473, AZTundra and 2 others like this.
  30. Aug 27, 2023 at 5:30 PM
    #180
    AZTundra
    Paul
    Phoenix, AZ
    I had issues with one of the four screws as well and it began to strip, but luckily it was still useable. My advice is to adjust the height and put those screws back in, but not completely tightened down because you may need to take them out again for more adjustments. Also found it amusing that when you drop to the lowest height and try to reattach the screen you can't because of the angle. That's why I say not to fully tighten those screws in case more decide to give you trouble. I had to adjust the height, then tilt the angle before I could drop the height some more.
