The Great HU Install of 2023
Discussion in 'Audio & Video' started by RainMan_PNW, Aug 19, 2023.
Did you get in on the recent Best Buy clearance frenzy? What did you get?
  1. Alpine ILX-F511
    35 vote(s)
    27.6%
  2. Alpine ILX-F509
    3 vote(s)
    2.4%
  3. Alpine ILX-F507
    0 vote(s)
    0.0%
  4. Kenwood DMX-1037S
    16 vote(s)
    12.6%
  5. Something else (let us know in the thread)
    4 vote(s)
    3.1%
  6. I bought enough to start my own car stereo franchise
    2 vote(s)
    1.6%
  7. No - I was late to the party
    52 vote(s)
    40.9%
  8. No - I didn't need a new head unit
    19 vote(s)
    15.0%
Multiple votes are allowed.
  1. Aug 27, 2023 at 5:37 PM
    #181
    Azblue
    The Dirty T ( ^_^)_且
    Yeah, it's finicky. I also had to slide it to the "out" position cause as it comes, you can't get the screen all the way on. This one last screw is totally wasted, like I said I'll have to carefully drill it out. I'll swing by Ace and see if I can get a new one or I'll just run it with 3.
    TaquitoBandito and ToyoMafia like this.
  2. Aug 27, 2023 at 6:35 PM
    #182
    MedCityMoto
    MedCityMoto SciTech Nerd
    2.5gen CM SR5 TRD OffRoad
    Successful Kenwood install! I ended up tapping the 12v line off one of my charger ports in the dash to run the cameras, they didn't like drawing power from the headunit. Only the +12V needed linking, the video signal grounds. Ended up doing the SXM tuner because, well, now it's in there and I don't need to go back in for anything ever. HDMI to switch plate is done and works, parking brake bypass works at the -12V ground tap at the headunit KEN1 adapter as pictured. All 4 cameras installed and happy, Maestro RR2 was an absolute bitch to try to flash via Bluetooth but a USB to PC link did everything instantly and I ziptied a USB cable under the driver's side for easy access. Done and done.
  3. Aug 27, 2023 at 6:37 PM
    #183
    MedCityMoto
    I think that there's only 1 thing I didn't get done: the middle button on the steering wheel. Usually that's a start/pause playback button - but it's not mapped and there's no option in the Maestro to do it, weird.
    TaquitoBandito likes this.
  4. Aug 27, 2023 at 6:41 PM
    #184
    GWill
    GWill gods gift to the internet
    Willis
    Don’t know what you’re talking about
    2020 MGM TRD Pro
    I’m getting my butt kicked on this thing.
    Anybody doing this that has the FrAC harness installed? Do I need to uninstall all those harnesses? I can’t remember how any of that is installed.
    Also, I have no idea how you guys crammed all of this wiring back in there. This Maestro dash kit doesn’t seem to fit right in my dash. And my USB adapter to the factory usb port doesn’t fit.
    Patch999 likes this.
  5. Aug 27, 2023 at 6:44 PM
    #185
    polymerhead
    polymerhead New Member
    I left the screen at the height it was delivered at, and did not use the pocket piece from the kit. This allowed a lot of the wiring to fit above the head unit and you can’t see any of it unless you fold the screen down or really peek behind it.
  6. Aug 27, 2023 at 6:54 PM
    #186
    Azblue
    Speaking of height adjustment, WTF are the black stickers that Alpine says you're supposed to put on after adjustment supposed to do?
  7. Aug 27, 2023 at 6:56 PM
    #187
    polymerhead
    They just clean it up a bit by covering the silver screws. And I think one set is a kind of bump stop for when you are adjusting the screen angle.
    Azblue[QUOTED] likes this.
  8. Aug 27, 2023 at 8:19 PM
    #188
    MedCityMoto
    The Dasaita adapter I bought also fits a bit oddly and I'm still not convinced it shouldn't sit a little more flush at the top, but it's not moving either, both button 12mm bolts in place correctly.
    Wiring - I removed the center speaker grille cover and speaker, and stuffed my fat ham mitt into the hole to pull back on the bundles of wiring and shove them to the sides. This worked ok, along with unclipping the main wiring bundle that goes above the radio and pushing that all the way to the back too.
    WFD473 and bulldog93 like this.
  9. Aug 27, 2023 at 8:31 PM
    #189
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    yeah, you are best served with prepping vehicle harness to allow more flexibility where you can land the mating connectors.
    As far as stashing the modules, I banded the maestro module with tesa tape and wedged it between the silver dash trim and the inner passenger air duct, did the same with the SXM tuner module on driver’s side…these steps will place the majority of the related bulk everywhere else other than behind the radio.
  10. Aug 27, 2023 at 9:11 PM
    #190
    RainMan_PNW
    RainMan_PNW [OP] "Oz" SSEM #82 RGBA #4 Unofficial Forum Treasurer Vendor?
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    I kind of like that mic mount location.
    I thought about trying to get the factory mic to work, but it looks like it's more work than I feel like messing with right now.
    ToyoMafia likes this.
  11. Aug 27, 2023 at 9:25 PM
    #191
    RainMan_PNW
    Casey
    Clark County, WA
    That won't work for the factory GPS antenna to the Alpine HU.
    But I'm fairly certain this will:
    SUMI-GT21 Alpine Halo GPS adapter cable for recent Toyota & Lexus
    mine should arrive tomorrow and I'll know better when I receive it
  12. Aug 27, 2023 at 9:38 PM
    #192
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
  13. Aug 28, 2023 at 7:21 AM
    #193
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    A friend has this in the OEM area on his 2020 4Runner, the seller said it fits Tundra/Sequoias, I have it but have not installed it yet.
    https://shop.enfigcarstereo.com/
  14. Aug 28, 2023 at 2:32 PM
    #194
    Tundar the Barbarian
    Tundar the Barbarian New Member
    2020 MGM TRD OffRoad
    Speakers, amp, subs, floorboard lights...and the little step thing under the bumper
    Kept going 'nah, don't need', but kept thinking about how I've got great amp, subs and speakers, but my sounds is bass in the back, mids and highs up front...so, went to a couple Best Buys, they're out. Oh, well, maybe next year...
    bulldog93 likes this.
  15. Aug 28, 2023 at 2:44 PM
    #195
    run4fun
    run4fun New Member
    2018 sr5 trd
    This is my first HU install and I just got everything in to install my Kenwood. does the Maestro RR2 need to be flashed or should it be just plug and play from the box?
  16. Aug 28, 2023 at 2:54 PM
    #196
    ToyoMafia
    Magic carpet.
    Cool slaps and plastiDip
    Start at post one. You need to flash it.
  17. Aug 28, 2023 at 2:55 PM
    #197
    run4fun
    run4fun New Member
    2018 sr5 trd
    Great thanks!
    ToyoMafia[QUOTED] likes this.
  18. Aug 28, 2023 at 4:31 PM
    #198
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    I have finally got the whole thing installed and all parts……I will NEVER touch this stereo again. I have run all the cables, hooked up the usb/hdmi and confirmed everything is working.
    My only issue at the moment is that my wife said she hears horrible feedback when I am on Bluetooth talking to her on the phone……anyone have any ideas how to rod that echo?
  19. Aug 28, 2023 at 4:37 PM
    #199
    ToyoMafia
    Magic carpet.
    Turn the volume down?
    TaquitoBandito and TRDFerguson like this.
  20. Aug 28, 2023 at 4:40 PM
    #200
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Where do you have the mic mounted?
  21. Aug 28, 2023 at 4:45 PM
    #201
    Azblue
    So after walking away and thinking it over I went at it today after getting home from work. I laid down a doubled up towel, layed the screen upside down on it, taped up any holes and grabbed my drill. I (very carefully and slowly) stepped up drill bits until I had cut the head of the screw off. Success and I don't think I fucked the screen up! :yes:
    Like I mentioned in my previous post, I'll swing by Ace Hardware and see if I can get some replacement screws, if not, I'll run that bitch with just 3. I still want to go to the Alpine factory and find the moron that thought it was a good idea to torque down a little tiny screw to roughly that same as a lug nut.
  22. Aug 28, 2023 at 4:54 PM
    #202
    ToyoMafia
    Magic carpet.
    I had the same shit happen. Called @TRDFerguson during that shit show. I just said screw it and installed at the height it was at.
  23. Aug 28, 2023 at 4:57 PM
    #203
    shawn474
    MoCo, Maryland
    up by the sunglasses holder where my map lights are
  24. Aug 28, 2023 at 5:06 PM
    #204
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    If you’ve got the stock dash speakers they’re blasting right at the mic there. There are noise cancelling settings in the HU that you can dig into and see if they help
  25. Aug 28, 2023 at 5:12 PM
    #205
    Azblue
    I'm thinking of installing the screen to leave a small gap at the bottom that leaves the little pocket of the dash kit accessible. Then I can drill a small hole in the pocket to run the wire and mount the mic at the front left of the pocket pointed towards the driver.
  26. Aug 28, 2023 at 5:25 PM
    #206
    AZTundra
    Paul
    Phoenix, AZ
    Your usb/hdmi cover is crooked. :boink:
  27. Aug 28, 2023 at 5:31 PM
    #207
    shawn474
    MoCo, Maryland
    yeah I noticed after I put everything back together. I am not taking it back apart hahahaha
  28. Aug 28, 2023 at 6:37 PM
    #208
    RainMan_PNW
    Casey
    Clark County, WA
    Confirmed that
    1. This cable clips into the back of the Alpine HU at the GPS antenna connector
    2. The other end is the correct shape for the Toyota GPS antenna connector (and is even the same color).
    I won’t be able to confirm actual function until after Labor Day but based on the connectors being right I’d say this is the peice needed to retain factory GPS antenna with the Alpine HU.
    Also, for those needing this adapter and looking to also install XM radio, the same place has the correct XM antenna adapter so you’re not stuck buying the iDatalink set for just one component:
    https://www.discountcarstereo.com/sumi-smb.html
  29. Aug 28, 2023 at 6:41 PM
    #209
    AZTundra
    Paul
    Phoenix, AZ
    Nice job on finding a solution! I would assume that if both ends fit it should work as intended. No shipping notice on mine yet, but I will post up my findings if I get it all installed before you are able to test the functionality of it.
  30. Aug 28, 2023 at 8:23 PM
    #210
    Patch999
    Kyle
    TX
    2017 Bad@$$ TRD Pro
    The gap around the air vents is your friend. I tucked a lot in there before I tried to fit the rest.
