The Stereo Slow-Build Begins
Discussion in 'Audio & Video' started by Danimal86, Oct 12, 2017.
  1. Dec 15, 2017 at 2:49 PM
    #91
    Danimal86
    Danimal86 [OP] Looks clean even when its dirty!
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Thats about the same price i paid. The crimpers and cutters on the inside of the handles work well too.
    Y0TA PR0 and geno0506 like this.
  2. Dec 15, 2017 at 3:13 PM
    #92
    geno0506
    geno0506 New Member
    Michael
    :cheers:
  3. Dec 15, 2017 at 5:33 PM
    #93
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    Nice audio build! Can’t wait for mine to get installed. Got some similar things like yours.
  4. Dec 15, 2017 at 7:12 PM
    #94
    Danimal86
    Daniel
    Sacramento, CA
    Thanks man! It sounds absolutely fantastic. If you got the fix86, make sure you got the drc-200 knob or else you may have some hiss at low volume
    Y0TA PR0[QUOTED] likes this.
  5. Dec 15, 2017 at 7:19 PM
    #95
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    No I didn’t get the fix86. But good to know for the future.
  6. Dec 15, 2017 at 7:25 PM
    #96
    Danimal86
    Daniel
    Sacramento, CA
    what sound processor did you get?
    Y0TA PR0 likes this.
  7. Dec 15, 2017 at 7:30 PM
    #97
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    I don’t think I got one :anonymous:
    Is it mandatory for better sound?
  8. Dec 15, 2017 at 9:10 PM
    #98
    Danimal86
    Daniel
    Sacramento, CA
    The stock head unit applies a sound curve that makes the factory speakers sound the best. Best thing to do is eliminate the curve and flatten it, but not 100% must do. Giver er a try with what you got and can always add one if it doesn't sound right for you
  9. Dec 15, 2017 at 9:36 PM
    #99
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    Sweet will do. If I do ad one I’ll be looking for you. Lol.
    Thanks for the advice
  10. Dec 16, 2017 at 5:34 AM
    #100
    Les7311
    Les7311 Look up, what do you see
    2008 Blue Tundra TRD 4x4
    Scribed
  11. Dec 17, 2017 at 6:49 PM
    #101
    Tundra Fan
    Tundra Fan Got 17's?
    Toby
    Nor Cal (Placer Co.)
    Also subscribed. :thumbsup:
  12. Dec 17, 2017 at 11:22 PM
    #102
    Ricardiac
    Ricardiac New Member
    17' 4x2 5.7L SR5, 04' 4x2 3.6L Stick SR5
    17' color keyed TRD Pro Grill, color keyed handles, chrome mirror backs, TRD Pro Wheels, front and rear swaybar, shifter, tailgate insert (black), 2018 LED headlights and DRLs. 04' Original Owner all stock
    :popcorn:
    could you post pic of speakers with door panel on.. no protrusions? Seems I have yet to find a picture to illustrate...
    Subscribing :)
  13. Dec 18, 2017 at 8:32 AM
    #103
    Danimal86
    Daniel
    Sacramento, CA
    How so? You want to see through the speaker grill? The door panel look exactly the same as when the stock speaker was installed.
    No protrusions.
  14. Dec 18, 2017 at 11:35 AM
    #104
    Ricardiac
    so even with the (up to 1" spacer from what I have read), a new speaker fits inside the panel.. and no visual differences...
    if thats the case.. great.. (was about to take my door panel off to see just how much room there is for spacer.. (have read the clearance to the glass is 2.95")
    thanks
  15. Dec 18, 2017 at 11:36 AM
    #105
    Danimal86
    Daniel
    Sacramento, CA
    No visual differences with the panel, everything fit back to how it was pre-install.
    Ricardiac likes this.
  16. Dec 23, 2017 at 5:12 PM
    #106
    joem1cha3l
    joem1cha3l New Member
    Albany, NY
    2016 Double Cab SR5 Blazing Blue Pearl
    BOSS Suspension, DB Customz Grill, 35's, Spyder, Tint, Color matched corners
    Can you tell me what made you purchase these instead of traditional wire strippers? If Im gonna need them, I'd like to find out now ha
  17. Dec 23, 2017 at 8:32 PM
    #107
    Danimal86
    Daniel
    Sacramento, CA
    if you are going to have to strip more than 1 wire, you will want auto strippers. Good item to add to the tool box.
  18. Mar 25, 2018 at 4:10 PM
    #108
    Heatonrx
    Heatonrx New Member
    Great info here Danimal86. I'm using the Fix86 and C5 speakers too. Wondering how using the factory speaker wire works out. Is it heavy enough w/ your amp? Also any issues mounting the crossovers in the doors? I'm using the C5-650'S in the rear and got a good deal on Ebay for some ZR-650's for the front. You had no room issues in the doors? The ZRs are larger and I'm worried, .25 inches thicker and maybe an inches all the way around. Think they'll fit?
  19. Mar 26, 2018 at 10:47 AM
    #109
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    I checked your link and the product is not a harness but some kind of Bluetooth adapter doohickey.
  20. Mar 26, 2018 at 10:48 AM
    #110
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    I have started using the heat shrink butt connectors and have not had a problem.
    purplenova likes this.
  21. Mar 26, 2018 at 11:23 AM
    #111
    Danimal86
    Daniel
    Sacramento, CA
    What amp are you using for powering the doors. Unless your running a bazillion watts, you should be good with the factory wires going to the door speakers.
    I didn't have any problems mounting the crossovers, it took a couple tries to get the right spot, but if you look at the back side of the door panel, around the big foam block you have some room to work with.
    If the zr's are a bigger diameter, you should still be ok. The factory speaker is a 6x9 in the front so the speaker hole is big.
    I'm not sure about the mounting depth of the ZR's. What you could do, is find a factory replacement speaker, figure out what depth that is, and add 3/8" for your speaker adapters and see if those line up. I feel like there was a little extra room from the speaker to the inside of the speaker grille, so you could add an additional spacer, but ymmv.
  22. Mar 26, 2018 at 11:24 AM
    #112
    Danimal86
    Daniel
    Sacramento, CA
    I used a couple of them on my install. worked ok. I wish they had a tad more solder in them.
  23. Mar 26, 2018 at 11:29 AM
    #113
    Danimal86
    Daniel
    Sacramento, CA
    I didn't use the harness from Amazon. I got one from tech12volts.
    I think tundratex's build had more info on it.
  24. Mar 26, 2018 at 1:56 PM
    #114
    Heatonrx
    Heatonrx New Member
    Not worried about the ZR speakers for space. I have adapters from Tech12volts so good there. Just worried about the crossover size, they're larger. Might mount the front crossovers near my amp since there are already two wires going to the front doors and the C5 crossovers in the rear doors. James from Tech12Volts said the same about the speaker wire size. Thanks for the info.
  25. Mar 26, 2018 at 2:08 PM
    #115
    Danimal86
    Daniel
    Sacramento, CA
    Are they taller or wider?
    There is plenty of room to work with. Worst case is you would need to extend the wires to and from the crossover and mount it further away.
  26. Mar 26, 2018 at 3:01 PM
    #116
    Heatonrx
    Heatonrx New Member
    About .25 in. thicker ...4.7"x5.8"x1.7". The C5'S are 3.36"x4.7"x1.44". I'm using a PDX-V9 Alpine 5 channel amp. Pulled it from my Wrangler before I traded it. Should work good along w/ a Fix-86 w/ DRC-200 and 10" subs. I might try to put the amp and Fix under the back seat. I had it under the seat in the Jeep and never liked it there.
  27. Mar 26, 2018 at 3:29 PM
    #117
    Danimal86
    Daniel
    Sacramento, CA
    You should be able to find a spot to fit them. It may take you a couple tries, but you'll find a spot.
    I bet that pdx is about the same size as the hd, it should fit under the front seat nicely, especially since all the wiring is already there for the stock amp.
  28. Mar 26, 2018 at 3:42 PM
    #118
    Danimal86
    Daniel
    Sacramento, CA
    It takes a little extra work, but you CAN make it work.
  29. Mar 26, 2018 at 4:00 PM
    #119
    birdman076
    birdman076 Bird, bird, bird...bird is the word
    Chuck
    Montana
    2015 Brown Tundra Crew Max Limited
    Airbox with K&N Filter, 2" lift on 33's, Alpine iLX-F309 head unit, Pull out bed tool boxes, brown with black trim, rims, etc, black leather interior, matching topper. Muffler delete (too loud..) 62k miles!!!
    Not sure which link you are referring to. If its Amazon it could have changed..
  30. Mar 26, 2018 at 4:02 PM
    #120
    TuffTundra
    TuffTundra New Member
    Missouri
    2016 MGM SR5
    4" Rough Country Lift - Fuel Assault 20x10 - Nitto Ridge Grapplers 33x12.5x20 - 2018 LED Headlights - LED Lights all around - No Chrome - Tinted Windows & Tail Lights
    anyone familiar with the ACR-2 audio control bass adjuster? Is the knob suppose to just keep spinning or should the knob only suppose to turn so far?
