Thor Build
Discussion in '2.5 Gen Builds (2014-2021)' started by Help, Apr 10, 2018.
  1. Jun 21, 2018 at 1:25 PM
    vanthesupreme
    vanthesupreme I'm Batman
    OKlahoma
    2014 Tundra
    Quick question where did you hook up all the negative cable ends for the circuit block and what brand is the circuit block?
  2. Jun 21, 2018 at 6:13 PM
    Help [OP] New Member
    Ryan
    Tucson, AZ
    2014 Blue DC 5.7 FFV
    Bright pink truck nuts.
    @eccracer104 As far as we can figure, I either A) installed the misalignment spacer in the LCA incorrectly, which caused it to cycle weird, B) Had my clicker set way too low and came down on that side just right - I was playing with those when I broke it, or B) Both A & B
    @krazyTundra The plastic bits of the original bumper are currently sitting in my garage taking up space. They're all just black plastic. I didn't have chrome or color matched caps. If you're interested or know anyone that is, shoot me a PM and I'll clean em up and send pics.
    @vanthesupreme wellllllllll, I got kinda lazy there. I sanded around the actual battery terminal ground on the sidewall - follow the ground wire coming off the negative battery terminal, its only like 5" long. I sandwiched all of the grounds, between some bigger washers, to that same bolt location. Originally I was going to use a bus block, but I couldn't find a spot to mount it properly. The fuse block is made by Blue Sea Systems, Its 30-40$ on Amazon and accepts standard blade fuses.
  3. Jul 9, 2018 at 8:55 AM
    Ryan
    Tucson, AZ
    @boardude and I ran a few trails in SE Tucson yesterday. I even managed to remember to take a couple pics... 1.5 of them turned out ok. The rest Kris is responsible for haha
  4. Jul 9, 2018 at 9:05 AM
    Ryan
    Tucson, AZ
    And two more I shamelessly stole from @boardude (again). These two are from our Mount Lemmon run in Tucson
    TRON, blue16, Ike74 and 3 others like this.
  5. Jul 9, 2018 at 9:11 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    :thumbsup: There's a great place for ground bus under the hood to fender seal/trim. The trim comes off by sliding it in toward the engine. I'm liking the variety of lighting options you have in the bumper. My light bar failed this weekend and I haven't examined the cause yet.
    joonbug and TheBeast like this.
  6. Jul 9, 2018 at 12:48 PM
    Ryan
    Tucson, AZ
    I was planning on adding the bus to that ledge, but I got lazy and ran out of time lol None of my amber is wired up yet. Mid-project I changed my mind on what I wanted to do for a controller. :spending:
    831Tun[QUOTED] and TheBeast like this.
  7. Jul 9, 2018 at 2:38 PM
    Mo_Martz
    Mo_Martz New Member
    Great Country of Texas
    2017 White Tundra CM
    Great looking rig!
    Help[OP] and HighDesertSurfer like this.
  8. Aug 16, 2018 at 2:02 PM
    Ryan
    Tucson, AZ
    Thanks @Mo_Martz!
    Got a big surgery coming up here shortly on the ole truck. :spending::bananadead: #facelift #Botox4Trucks? giggity giggity
    TRON likes this.
  9. Sep 16, 2018 at 9:33 PM
    Ryan
    Tucson, AZ
    I finally remembered I have my own build thread to spam/derail.
    I'll add pics tomorrow, or tuesday, or probably sometime in October :rofl:
    New stuffs:
    -2018 headlights + iHacker harness
    -FINALLY found a color matched surround w/ platinum insert (bulge needs to be paint matched still, so for now Thor has a legit 'stache)
    -Soldered all the connections to my remote start so it stops giving off hood pin errors
    -New front windshield AND 45% tint
    -Carrier bearing drop
    Lots of maintenance for upcoming Colorado and Utah trips:
    -Replaced oil in transfer case, front + rear dif, and engine
    -Checked all fluids and inspected engine bay (yay no leaks)
    -Greased driveline, uniballs, and tightened every bolt i could find a torque spec for
    -Rotate and balance tires
    Next:
    - Hawk LTS brake pads (installing on 9/18)
    After Colorado:
    - Find someone to weld on BMC plates
    - Build bed rails
    - HAM radio - @smslavin I'll be going with a Kenwood TMV71A and AZ507RSP antenna w/ spring
    - Stereo Upgrades
    • Alpine ILX-207SXM
    • Alpine truck accessory controller (yay all my lights will finally be wired up)
    • LCI2 audio control
    • Alpine PDX amp
    • Kicker CS 6.5's w/ component tweeters and 6x9"s
    :dancingbacon:
    TRON and aperezsh like this.
  10. Sep 17, 2018 at 7:25 PM
    Ryan
    Tucson, AZ
    These LEDs are 10000x better than my stock halogens. This is just the new headlights + my rigid fogs:
    #FaceliftTeaser
    blue16 and TRON like this.
  11. Sep 17, 2018 at 8:13 PM
    TRON
    TRON Is LIVE on the GRID.
    Stefen
    Gilbert, Arizona
    IG: @ST3F3NS
    DUROBUMPS Use TRON10 for 10% Off & Free Shipping
    Gunna look all purdy for ColoRADo!:cool:
  12. Sep 18, 2018 at 12:12 PM
    PLC721
    PLC721 New Member
    Patrick
    Chandler, AZ
    2018 Ram 2500 Cummins Laramie
    IG: PLC721
    I get to spend 4 days riding passenger in Thor ;)
    TRON likes this.
  13. Sep 18, 2018 at 3:55 PM
    boardude
    boardude I am Batman
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    you mean on Ryan's lap?!
    TRON, 831Tun and PLC721[QUOTED] like this.
  14. Sep 18, 2018 at 4:03 PM
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    that's a solid little radio. i still need to get mine going but it just fell down the list a notch or two.
    where are you going to be up here?
  15. Sep 18, 2018 at 5:17 PM
    Ryan
    Tucson, AZ
    Mountain Village?
    @boardude you can come with. I have a bench seat so all 3 of us can cuddle while driving
    TRON likes this.
  16. Sep 18, 2018 at 5:22 PM
    Ryan
    Tucson, AZ
    These HAWK LTS pads are thick n juicy. The old ones had some meat on them still, but they were cheap shit put on before I bought the truck
    Giving Ron Jeremy's mustache a run for its money
    JDL17CM4x4 likes this.
  17. Sep 18, 2018 at 5:41 PM
    smslavin
    smslavin New Member
    Hudson Valley
    Some stuff
    ah. telluride. favorite place on the planet. have a good time.
  18. Sep 18, 2018 at 7:05 PM
    Ryan
    Tucson, AZ
    I might not come back home. If its as great as everyone says, I may just drive off into the woods and become a mountain man
    smslavin[QUOTED] likes this.
  19. Sep 18, 2018 at 7:19 PM
    #49
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    I love the zip ties holding the brake line mount to the spindle lol
  20. Sep 18, 2018 at 7:24 PM
    #50
    smslavin
    smslavin New Member
    Hudson Valley
    Some stuff
    I say that every time we go down to visit my aunt and uncle. Some day I’m going to make it happen. Hope it’s sooner rather than later.
    Get in touch if you need any recommendations on anything. We’re there a lot.
  21. Sep 18, 2018 at 8:25 PM
    #51
    Ryan
    Tucson, AZ
    I went ham on that bolt and sheared the head off. I couldn't be bothered to try to extract the rest
  22. Sep 19, 2018 at 9:23 AM
    #52
    MikeCim209
    MikeCim209 Not all those who wander are lost.
    Michael
    Woodbridge, CA
    2018 Barcelona Red Metallic 1794 with TRD Package
    None yet, but soon..
    Awesome build
    Help[OP] likes this.
  23. Sep 20, 2018 at 8:05 AM
    #53
    KevinK
    KevinK SGU - High Speed Overlander
    Back in Arizona. Again.
    SGU - Speed Glampers Uberfahrt
    Tundras to Sedona
  24. Sep 24, 2018 at 10:23 AM
    #54
    Ryan
    Tucson, AZ
    @smslavin I just got home and already want to go back. I could probably spend several weeks there and not do everything I wanted to do. I even took more than my usual 3 pictures.
  25. Sep 24, 2018 at 2:04 PM
    #55
    smslavin
    smslavin New Member
    Hudson Valley
    Some stuff
    :cool: :cheers:
  26. Sep 24, 2018 at 4:12 PM
    #56
    Ryan
    Tucson, AZ
    PHOTO DUMP: Teluride Colorado Sept 2018
    Drove through Monument valley. Took exactly 1 picture
    Imogene: 13114ft
    831Tun, joonbug, TRON and 2 others like this.
  27. Sep 24, 2018 at 4:19 PM
    #57
    KevinK
    Tundras to Sedona
    The sparseness of your photos makes them that much more valuable.
    TRON likes this.
  28. Sep 24, 2018 at 4:29 PM
    #58
    Ryan
    Tucson, AZ
    Black Bear Pass is insane. Taking a full size truck through it was probably even more nuts, but I can officially say:
    I SURVIVED BLACK BEAR PASS!!
    Elevation 12,840ft
    831Tun, Rica25, joonbug and 3 others like this.
  29. Sep 24, 2018 at 4:30 PM
    #59
    Ryan
    Tucson, AZ
    Like Bigfoot or the Loch Ness monster
    KevinK[QUOTED] likes this.
  30. Sep 24, 2018 at 4:42 PM
    #60
    Ryan
    Tucson, AZ
    Almost forgot about Clear Lake. Took Ophir pass up to Clear Lake. That is one hell of a trail.
    joonbug, TRON and smslavin like this.
