Thoughts if v8 will return within 4 years?
Discussion in '3rd Gen Tundras (2022+)' started by Leboxerdog, Jan 12, 2025.
  1. Jan 13, 2025 at 6:34 PM
    #91
    Hella Krusty
    Hella Krusty New Member
    You know it!!
  2. Jan 13, 2025 at 8:21 PM
    #92
    PNW Tundra Mike
    Southern OC, CA
    MX4 Tonneau, Talon's Trans/Cat Shield
    You’re still complaining about less than 1% of all 3rd gen’s on the road failing. I don’t know their numbers but the big 3 would be hard pressed to beat that percentage.
    75tranzam and Ausfahrt like this.
  3. Jan 13, 2025 at 8:26 PM
    #93
    CajunTim
    CajunTim Original Recall Engine Going Strong
    SELA
    22 Platinum CELESTIAL SILVER METALLIC Advanced Package 4x4
    DiamondbackHD, bedrugXLT, Binize, Compustar remote start, 20% all around,
    Large companies will not roll back standards even if the government does. Because if the next administration comes in and changes them back, they have to again change.
    vtown76 likes this.
  4. Jan 14, 2025 at 3:12 AM
    #94
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    This. purposely built - A forced induction v6 does not outperform a forced induction v8.
    these are trucks. mileage should never be mentioned in a truck thread.
    that's what they make Tacomas for.
    I imagine, and have recently pontificated, if Toyota would put the 10 speed on the 5.7L it would get similar mileage to the 3.4 TTv6.
    then...the TRD Pro should/would have a slightly built 5.7L with the Magnuson S/C.
    there, fixed it for you.
    here's the rub...I WANT a dead-nuts reliable v8 Toyota. someone else is telling me what I NEED.
    Truth be told...I still miss the Excursion.
  5. Jan 14, 2025 at 3:37 AM
    #95
    red61cj5
    red61cj5 New Member
    wv
    2017 Limited DC Inferno
    What alot of us tend to forget is that many (most) people don't care what's under the hood, as long as it has the latest streaming facebook porn bluetooth carplay connectivity and heated brake pedal with massaging shifter. "What engine does it have?" "I don't know, but look at the size of the screen!!"
    vtl likes this.
  6. Jan 14, 2025 at 3:47 AM
    #96
    nodak67
    nodak67 New Member
    JR
    because the profit margin is way to high vs any other vehicle the big 3 sell. they just use the other vehicles to bring the cafe standard high enough to get around the penalty.
  7. Jan 14, 2025 at 4:39 AM
    #97
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler
    At 24k miles there should be no sight/thought of issues.
    Hard to tell what the future holds on resale values with these next generation trucks (all markets). A vehicle is bought for generally 1-2 things, transportation and utility/work. Of today's general consumer, initial purchases (1st buyer) has led focus on technology, comforts, "shiny", as a result placing transportation, work, reliability (increased profit margins) second. The 2nd or 3rd consumer of that same truck is likely to place more importance on transportation and reliability/longevity. Essentially what can this truck do for me. A truck in/out of the shop, recalls, etc. will likely not promote positive resale. Time and convenience to the consumer will take king.
    IMO, we may see a shift decrease in resale values overall as technology and comforts increase to take forefront over something that goes A to B. For example, trading a cell phone in how much is that worth? Vehicle manufactures are making large, disposable cell phones.
    Toyota had a hiccup in the road that we all hope is short-lived.
    nobodyintexas and vtl like this.
  8. Jan 14, 2025 at 5:31 AM
    #98
    75tranzam
    75tranzam New Member
    Midlothian, Va
    2024 Midnight Black 1794 Limited Edition #751
    The Asian culture doesn't think short term like the Western culture does, especially in business practices. They are not going to make a short term decision based on 4 years.
  9. Jan 14, 2025 at 6:20 AM
    #99
    Warreng
    Warreng New Member
    One only has to look to the motorsports world to realize small engines can make mucho power.
    You would also be a fool to think that power does not come at a cost.
    That cost is extra maintenance and a shorter life span.
  10. Jan 14, 2025 at 6:25 AM
    #100
    Smaller engines are more efficient by nature. Smaller combustion chamber (fewer combustion chambers also) needs less fuel. But power is power. Power requires fuel. It’s why I get 9mpg towing my 7000# trailer, regardless of what I pull it with. It’s takes that much energy (fuel) to move that thing. The smaller engine is only more efficient if you’re not producing large power. Once you ask for 400+ hp, you’re forcing more air and fuel in there to make it. Put that motor in a Tundra and it gets the same fuel economy as the bigger motors when doing any work. Motorsport has little to do with consumer engine needs. It’s a great proving ground for new tech, but a race motor wouldn’t last very long in a consumer application.
  11. Jan 14, 2025 at 6:29 AM
    #101
    eharri3
    eharri3 New Member
    2021 F150 Powerboost
    I think they could be getting 450-500 hp easy out of half ton V8s in a few years or they can be averaging 18mpg but but would not be able to happen. It is the demand for both at the same time that makes fewer cylinders with forced induction the easy out
  12. Jan 14, 2025 at 6:33 AM
    #102
    kbahus
    kbahus New Member
    MI
    2015 MGM Tundra Limited Crewmax
    Toyota is falling suit with all of the other manufacturers, nothing surprising here. We are to the point where you can't afford to own a vehicle that is not under factory warranty, even Toyota is on that boat now (which is a tragedy). The thing that really gets me is the Euro market was like this in the early 2000's with Audi/VW, BMW etc. I can't help but think of the Audi S4, a twin turbo V6 with lots of issues, but a beast of a motor. Maybe the 3g guys can swap one of those in. Ultimately we have made no progress forward in my eyes.
  13. Jan 14, 2025 at 6:43 AM
    #103
    David713
    David713 New Member
    2023 Tundra Platinum
    King shocks, TRD UCAs, Hellwig rear bar, 295/60-20 tires on 20x9 Sparcos
    I prefer the V6TT. More power and torque than the V8 in a smaller package. A friend has a new ZR2 Chevy. We traded trucks for a test drive and I fully expected to walk away wishing I'd gotten the 6.2 liter Chevy with Multimatic shocks. I was not impressed. I found my Tundra with King shocks had better power, road better and handled better. My friend even asked what I'd done to the engine which is nothing.
    Of course if my engine fails I may be singing a different tune but if it happens and the dealer treats me well, I'm sure I'll still prefer the V6.
    22whatwedo likes this.
  14. Jan 14, 2025 at 6:43 AM
    #104
    Frank_TRD23
    Frank_TRD23 New Member
    2023 Tundra TRD Mag grey
    1.5 Wescott lift 20" wheels on 37s Stillen Trucontroller
    Following. No. All the others have V8 and now V6. What is the real reason Toyota removed V8 from the list. Not fuel economy or power. As we can see in ford's 5.0 fuel same power same as a tt v6.
    What's the cost to manufacture a v6 to v8? Then the replacement parts.
  15. Jan 14, 2025 at 6:46 AM
    #105
    pursuit2550
    pursuit2550 New Member
    2020 Tundra SR5 Maggie 1900
    Yes. How many previous Toyota engines had catastrophic engine failure? How many of the big 3 also had the same? People keep focusing on 1%, when the reality is that possibly all the engines are faulty. I know I would be pissed if my engine had to be replaced, wasn't on the recall list and Toyota would tell me to go pound sand after my warranty was up.
    Just like the Toyota GR6. Oil starvation because of excessive silicone on oil pan. Toyota has denied several customers because they got the ECM data and saw "apparent abuse". But let's not forget that Toyota offers a free track day when you buy a GR6. Wonder if you did what Toyota did in their tundra commercials , would they also void your warranty. Ford did the same with the Raptor when it came out and the bent frame issues. Tacos also having trans issues.
    But we have ourselves to blame. We keep buying overpriced inferior products because like Toyota says, keeping up with the Jones is more important.
  16. Jan 14, 2025 at 6:51 AM
    #106
    Terndrerrr
    Terndrerrr 927000 miles to go
    Music City
    6UR-FE
    This explains much of the current state of the segment to me. All the old turbo Euro guys are truck guys now, and they want their trucks to feel the same way behind the wheel. Half-tons are twisting themselves in knots trying to be all things to all people now that trucks are no longer utilitarian vehicles. Lots of money to be made if all the auto journos tout your truck as the most advanced and most comfortable option in the segment.
    Grown-ass men now demand on-pavement handling and huge useless iPads in their full size trucks. American truck buyers skew older, and most older men are overweight with low back pain and/or sciatica due to decades of working 60+ hrs/week in an extremely sedentary career, so the seats better be extra comfy, too. Hey, what about massaging seats?
    Massaging seats? Tell me you won’t survive the winter without a grocery store nearby without telling me. :crapstorm:
  17. Jan 14, 2025 at 7:08 AM
    #107
    kbahus
    kbahus New Member
    MI
    Perhaps that is where they are winning, the excess costs are simply rolled right down the line to our own pocket books. The bean counters make darn sure they don't lose money, the service departments are able to stay busy with work, and even the optics look great with a more "economical" V6. Corporations as whole don't make money making the worlds most reliable vehicle.
  18. Jan 14, 2025 at 7:11 AM
    #108
    huh
    Terndrerrr and nobodyintexas like this.
  19. Jan 14, 2025 at 7:18 AM
    #109
    Warreng
    Warreng New Member
    I would say decreasing engine size and increasing power output has a lot to do with the motorsport industry and this is where we are headed with todays consumer engines.
    Hella Krusty likes this.
  20. Jan 14, 2025 at 7:31 AM
    #110
    kbahus
    kbahus New Member
    MI
    I can't argue that. Maybe some day we will find the real reason they switched to V6's. I know I can't sell a single new Tundra to my friends. They all are in awe at the mileage of my vehicles, but my examples are 5.7's. They all drive F-150's and don't want the V6 Ecoboost or another twin turbo anything, most are going to Chevy.
    Terndrerrr and CaptRussia253 like this.
  21. Jan 14, 2025 at 7:35 AM
    #111
    iforceAZ
    iforceAZ New Member
    Within 4 year...Zero chance
  22. Jan 14, 2025 at 7:36 AM
    #112
    DIYReid
    DIYReid New Member
    KC
    2024 Ice Cap Tundra Limited
    Most likely not, there isn't a need since the Tundra doesn't have a heavy-duty model.
  23. Jan 14, 2025 at 7:56 AM
    #113
    TRDoffroadPRO
    TRDoffroadPRO New Member
    2023 Hybrid CM Limited TRD OFR
    I would say if you have a 5-10-15 year old Toyota and love it then keep it till it is no longer feasible. Trust me I get it, I hate truck payments too and mine will be paid for by the end of this year. I don't want a truck payment and look forward to paying the Tundra off.
    The thing of it is at some point even your 300-400k mile truck will need to be replaced. Then what are your options?
    If you don't like the new Toyota motors and choices, then you can pick something else. This is America still and you can buy and pay for what you want with your money. The 5.7 liter is a slow gas guzzling dinosaur just like the 3-4 liter v6 Toyota drove straight into the ground. No one is making you all buy a 3rd gen Tundra and or any other Toyota ever.
  24. Jan 14, 2025 at 7:59 AM
    #114
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    The 3.4 is not a slouch but it’s also not that impressive as far as power output in relation to the pressure ratio it operates at. The turbokits stock 5.7 test truck put down a max 337whp stock, and the stage 1 did a max 439whp and 500wtq on a measly 4.5psi which is a 1.31 pressure ratio. That’s 58.79hp/L/PR. You could likely slap an oversized pulley on a SC and drop the boost and get similar results, but nobody runs them at that boost level.
    The Berger JB4 stock test truck with the 3.4 non hybrid did 321whp at the stock boost level they recorded as 10psi, and their +5psi tune did 369whp and 410wtq at 15psi. That’s a 2.02 pressure ratio and 53.75hp/L/PR.
    Even if we generously gifted the 3.4 another 31whp to 400whp to account for possible differences in the dynos it’s still a lower hp/L/PR output.
    Im pretty confident the 5.7 would run damn near indefinitely at 4.5psi. V8s respond very well to just a little boost, especially the old 5.7. I’m sure Toyota could do even better with today’s technology as well (but I know they won’t even try) which I also understand why they don’t.
  25. Jan 14, 2025 at 8:03 AM
    #115
    TRDoffroadPRO
    Doode, the Tundra Hybrid makes almost 700 ft lbs of torque. It produces as much torque as do some smaller displacement diesels. Toyota did alright with adding the Hybrid system to the truck.
  26. Jan 14, 2025 at 8:17 AM
    #116
    Silver17
    Eastern PA
    580 is a far cry from 700 don’t you think? I’m not saying they aren’t impressive numbers on paper especially. They don’t seem to translate to real world performance though. I’m pretty sure even the non hybrid ecoboost and the standard output ram hurricane would be quicker.
  27. Jan 14, 2025 at 8:22 AM
    #117
    borla123
    borla123 The Pits
    Ontario
    18 Tundra TRD OR - '17 4Runner Torsen Full Time 4wd
    Driver Grip Handle Borla Dual, Line X, ESP Underseat
    Well, I am an "old" Euro car guy - and I still own it - the 3.6 Liter n/a engine is bigger than the Tundra's engine, and at probably half the weight. And I have always had utility vehicles for towing and hauling. Early years all brands - later years all Toyota. No illusions here. All the talk on these forums of speed/horsepower/torque is well, entertaining, but none of these vehicles can corner or stop worth a shit. Actually, maybe I should stop putting my foot in my mouth, since my car's model turbo brother is called the "widow maker".
    My wife says to me - whats a grown ass man like you doing with a car like that. I tell her ....I can't sell it because its doing alot better than any of my stocks. But that also means you become scared to drive it...
    fwiw
    Unfortunately - just like old Two Stroke bullet proof polluting Yamaha outboards, which you can still buy today on the other side of the planet. Both my 5.7 and the 4.0 in my 4Runner are just too polluting - too many bad particles in the air. If they did bring the 5.7 back - it would look so different with all the new computer/mechanical management closing half the cylinders whenever possible. The old Unicorn days are over, except on the other side of the planet.
    vtl likes this.
  28. Jan 14, 2025 at 8:34 AM
    #118
    pursuit2550
    2021 Tundra Pro 2023 Pro
    0-60 6.8 sec. 6.5 sec
    1/4 15.2 sec. 15 sec
    Both times from Motor Trend articles. And considering most owners aren't getting close to the Toyota advertised MPG, well.
    szabo101, vtl and CaptRussia253 like this.
  29. Jan 14, 2025 at 8:36 AM
    #119
    CaptRussia253
    CaptRussia253 New Member
    Ruslan
    Toyota always focused on prioritizing longevity and smooth operation over raw horsepower. That's why all their NA motors(specifically in the trucks and SUVs) had less hp than the competition, but they'd outlast all of them. I don't see the V6TT lasting anywhere near their older NA motors. Is the power nice? Sure. But you'll never see longevity with a twin-turbo engine. I don't care who makes it.
    Terndrerrr and pursuit2550 like this.
  30. Jan 14, 2025 at 8:37 AM
    #120
    CaptRussia253
    Ruslan
    Damn that's pretty close. :eek:
