Throttle body coolant bypass
Discussion in 'Performance and Tuning' started by Tundracollector, Oct 23, 2019.
  1. Nov 3, 2020 at 12:28 PM
    #61
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    All the pictures in this thread are from S/C'd trucks and the TB is rotated 180° in that application.
  2. Nov 3, 2020 at 12:36 PM
    #62
    Tortuga83
    Tortuga83 New Member
    Tortuga
    Now that makes sense..Thanks!
  3. Nov 3, 2020 at 3:07 PM
    #63
    Professional Hand Model
    Hand Protectors
    1) 1st Gen Tundra coolant runs right around 180-185° at normal use.
    2) Air flow over the MAF is about 5 gallons a second at idle. Much more at higher RPMS.
    3) How can a 185° piece of metal (Throttle Body heated by Engine Coolant) heat up 5 gallons of air per second flowing across it and have much negative effect on air temp?
    4) Does one think that the Engine Coolant ‘TB heater’ may be to keep the TB metal from freezing as its air is compressed at a high flow rate over itself? Air, when compressed, can be made colder even in warm ambient temps.
    5) Conclusion: Keep TB heater running through TB.
    Saltyhero13 likes this.
  4. Nov 4, 2020 at 5:17 AM
    #64
    Rebel Tundra Man
    Rebel Tundra Man New Member
    Tyler
    Western Kentucky
    2016 Black Limited CM
    4" RCX Lift, 20x10 Fuel Coupler's, 35x12.50x20 Nitto Ridge Grappler's, Color Match Front End, LED Bulbs, RCX Tube Steps, Green LED Underglow
    You ever messed with engines much? colder the air = more the ponies. go read about a turbo on a diesel engine, and read why they added intercoolers instead of straight piped into the intake.
  5. Nov 26, 2020 at 4:37 PM
    #65
    Midnite72
    Midnite72 Anything DIRT !!
    Bill
    Northern MD
    18 SR 5.7 4x4
    2” level P&P sliders
    I know I’m a little LATE to the party
    I live in Northern Maryland were temps range from teens - to - 100’s -so I really like the idea of a ball valve so I’m able to switch back and fourth with this mod
    Have either of you successfully installed this ball valve setup ???
    If so can I see pics and info / problems or issues
    THX- appreciate anything you got
  6. Nov 26, 2020 at 4:57 PM
    #66
    Hand Protectors
    You can check my build page for your answer.
    I wasn’t discussing Turbos in my post, but an actual Throttle Body on a 1st Gen or Turd Gen for that matter. TOYOTA ran the Coolant Fluid through the Throttle Body for a reason... to keep the TB warm in cold temps.
    Back to my point: The amount of air sucking past the TB in warm temps is not going to negatively affect it as the temp will max at 185° (coolant temp max). Highest I’ve seen my intake air temp is around 140°-160° when crawling in traffic. Much less to near ambient temps when at higher speeds.
  7. Nov 26, 2020 at 4:59 PM
    #67
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    I like the idea and was merely conceptualizing if I were to make use of this modification...They're hard to find, like really hard, but you need micro ball valves...I cannot find tees past 1/4" but 1/8" is considered micro. I think 1/8" would be sufficient for this purpose...I too am in the cold temps and want the ability to change back to winter running mode...I haven't given up on it but have been distracted on other endeavors now...
    Midnite72 likes this.
  8. Nov 26, 2020 at 5:18 PM
    #68
    PhearCVBz
    PhearCVBz New Member
    2021 Black Tundra DC, 2024 Black Tundra CrewMax
    Does seem to make sense to keep it unless there is some sort of real evidence there is more of a benefit in getting rid of it.
    Although I am a fan of these sorts of mods....remember doing the carbon filter mod way back when I bought my brand new '07.
  9. Nov 26, 2020 at 5:26 PM
    #69
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    I think you guys are retarded, but out of curiosity what is the temperature drop? Because even if you have a pretty huge temperature drop, your actual density increase is a couple percent at most.
    Ideal gas law can be simplified to V is proportionate to T , so your "horsepower increase" you could approximate as proportionate to your temperature change (or decrease if you're heating it in this case). Increase temperature, increase volume, don't increase air mass, so density goes down. But the "issue" with that is temperature has to be taken in Kelvin/Rankine, which is based on absolute zero.
    So with some unit fuckery to keep things simple, if it's ~70F coming into the intake then you'd use ~293K, and then let's pretend the TB heats the air up by 40F, which is ~313K..... Well your volume increase/density decrease is just the ratio, so 313/293 which is ~7% change.
    And you may say 7% is a lot, that's like 25hp! Well that's with a 40F increase in temperature! Idk about you guys, but I monitor my intake temperature constantly with the TorquePro app, and for normal cruising I see at most 20F increase in temperature (and with a shitty cone filter, which I'm currently replacing, so not even the stock cold air intake). So for sure this mod does "something", but I would be surprised if there was any significant difference if you actually tested the truck back to back. Course there's the argument for sitting in traffic and wanting all that power and perhaps more heat from less airflow making its wait into the intake, but I'd still be surprised if there's that huge of a temperature change from just the TB.
    I think you'd have more luck wrapping the whole intake hose and box in a space blanket and insulation, but curious to see people's results.
  10. Dec 9, 2020 at 7:40 PM
    #70
    stuckinohio
    stuckinohio MGM Crue
    Mark
    oHIo
    2018 SR5 Crewmax
    If you life in a climate that doesn't see freezing temps there is no point in having coolant flowing through your TB.
    Heat does not need to be added to your housing to ensure the servo motor on the butterfly does not stick. There is no benefit.
    Based on your calculations, you must be aware aluminum is a great material to dissipate heat.
    The throttle body is made of aluminum and dissipates the heat from the coolant flowing through it.
    This radiant heat is dissipated from the entire housing, both inside and outside the TB valve, therefor increasing intake air temps.
    When your Torque Pro app provides IAT, do you actually know where it is sampling the air temp? Pre or post TB?
    Assuming the IAT sensor is at the MAF location, it wouldn't actually report the heat added to the system by the TB.
    This mod would be no different than a stand-alone trans cooler in the fact that it isolates one system to not increase thermal load on another system.
    For the cost of a union and 2 plugs, it is essentially a free mod to reduce heat sources on the intake.
    Your suggestion of wrapping the intake hose and box in a space blanket would not be as cost effective as the bypass mod.
    But curious to see you prove me wrong.
  11. Jan 12, 2021 at 11:02 PM
    #71
    Tundracollector
    Tundracollector [OP] New Member
    16 Dc trd pro, 04 Dc, 08 rcsb
    Hadn’t visited this thread in a while.........
    y’all guys got too technical and should have just left it up to the bro science lol
  12. Jan 15, 2021 at 11:29 AM
    #72
    RX7
    RX7 New Member
    2021 Tundra TRD Pro
    Did anyone measure before/after air temps? Or is this all theory?
  13. Feb 8, 2021 at 4:02 PM
    #73
    JeffMac
    JeffMac 2 Words, 1 Finger
    Jeff
    South Florida
    2015 Black Tundra OVTUNE
    Suspension: Bilstein 6150 Front Max Setting CB Shim 2x Driver 1x Passenger Bilstein 5160 Rear CB +3 Shackles Firestone Airbags w/ Daystar Craddles Engine: OVTUNE - 87 w/ Torque Modifier SABM w/ K&N Filter TB Coolant Bypass Fumoto Drain Plug Wheels/Tires: ProComp Bandidos 0mm Offset Nitto Exo Grappler AWT 285/70/18 Exterior: TRD Pro Grille Spyder Headlights/Taillights Ecoological Bumpershellz LED everything Tinted windows Bakflip MX4 Tonneau Cover K-Source Tow Mirrors Interior: Pioneer AVH-W4500NEX Radio 2x 10” Pioneer Subwoofers 1200W Pioneer Mono Amp 2000W Pioneer 4 Channel Amp
    Does anybody know the size of the ID of the tube? I’m planning to get 2x 3-way ball valves (one for before TB and one for after) and an extra piece of tube for bypass during winter. Thanks.
    MTRock likes this.
  14. Feb 9, 2021 at 3:26 PM
    #74
    crewmaxlmt
    crewmaxlmt How dare you!
    scott
    2020 Crewmax Limited
    If you have a set of drills, use the chucking end as a gauge to measure your tubing.
    JeffMac and HulkSmurf14 like this.
  15. Feb 9, 2021 at 6:00 PM
    #75
    HulkSmurf14
    2014 Tundra Limited
    5/16" IIRC
    Edit: I actually think they're 1/4" and that's where I ran I to problems as the ball valves become micro ball valves...
    JeffMac likes this.
  16. Feb 10, 2021 at 10:17 AM
    #76
    JeffMac
    Jeff
    South Florida
    Lets hope its 5/16 because I have those valves. If it does work I’ll take some pictures and post. I’ll try to get it done tonight.
    HulkSmurf14[QUOTED] likes this.
  17. Feb 10, 2021 at 10:26 AM
    #77
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    What size drill bit do I need to perform this mod?
  18. Feb 10, 2021 at 10:28 AM
    #78
    HulkSmurf14
    2014 Tundra Limited
    None?!
    hagrid likes this.
  19. Feb 10, 2021 at 10:44 AM
    #79
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Damn, I just tripped over this thread right here..... I may just jump on this mod.... does freezing temperature include that morning frost that builds up on roof tops, and sometimes your windshield and roof?? Or a couple inches of powder on the ground, and I don't mean the nose candy type.... Bay area Nor Kal type weather.. I'm just curious, now...
  20. Mar 30, 2021 at 12:15 PM
    #80
    Bikeric
    Bikeric New Member
    Eric
    2007 DC 5.7
    Blown Engine.....
    :boink:
    This aged horribly....
    Did you have any issues with the Tundra in the Texas freeze of 2021?
    fuzzamungus and TheBeast like this.
  21. Nov 7, 2021 at 10:07 AM
    #81
    ErikTRDTUNDRA
    ErikTRDTUNDRA New Member
    Erik
    2018 Tundra crewmax 1794
    Just spending a rainy day watching football and reading the Tundra forum. Stumbled on this one and seems fairly simple and logical. Has anyone actually seen noticeable gains? Seems many people have very deep opinions on if this mod actually proves gains but not many people posting real experiences.
  22. Nov 7, 2021 at 10:11 AM
    #82
    JeffMac
    Jeff
    South Florida
    Honestly I have seen 0 gains with my real world ass dyno or mpg. I swapped back to heating due to temps getting cold.
  23. Dec 24, 2021 at 2:06 PM
    #83
    F0X672
    F0X672 Durability Tester
    NEPA
    2016 Tundra TRD Pro
    Real experiences? No ill side effects and this will be my second Northeast PA winter with this bypass done. Gains? Probably, but nothing to break your neck. How much horsepower do I think it gained? No clue but we can guess a number lol; 1hp, 10hp, .1hp.
    Honestly, thinking logically, cooler air = denser air = more power at the end of the day. What the engine does with that is it's business, I didn't tune it, I just delivered the goods (cooler air).
    ErikTRDTUNDRA[QUOTED] likes this.
  24. Dec 31, 2021 at 7:54 PM
    #84
    JeffMac
    Jeff
    South Florida
    You run yours bypassed throughout the winter? I read something before about possible moisture build up in the throttle body by not having it warmed up.
    Moving down to FL at the end of the month and I’ll be swapping mine back. Even though I didn’t feel a difference cooler always is better.
    HulkSmurf14 likes this.
  25. Dec 31, 2021 at 9:25 PM
    #85
    F0X672
    NEPA
    2016 Tundra TRD Pro
    No problems here. My 2011 ram hemi had a fly by wire throttle body with no coolant plumbed through it from factory, no issues. If there's moisture build up I'd speculate another issue is happening. Can't say it's to keep the throttle from freezing either since the butterfly opens at idle (there's no IAC valve). I'm not an engineer or factory trained tech but my guess is to heat the incoming air as the engine is warming up to increase combustion temps to heat up the after treatment system up faster to get the system running efficiently as fast as possible... Catalytic converters lol, sorry I work on diesels as a truck mechanic.
  26. Jan 4, 2022 at 12:08 PM
    #86
    JeffMac
    Jeff
    South Florida
    I’ll swap mine back sometime before my drive down south. Not trying to get under my hood in this 10 degree weather. Soon I’ll never have to worry about freezing temps again. :amen:
  27. Jan 8, 2022 at 9:36 AM
    #87
    SpeshulED
    SpeshulED New Member
    Sandy Eggo/Chula Vista, So Cal.
    2015 Mag Gry Ltd. CM TRD Tundra
    TRD Pro Grill | AMP Steps | Husky Floor Mats | SnugTop Sportsman Super Sport Shell | 55w 5k HID Headligts | Method Racing NV Bronze 18x9 | BFG KO2 35x12.5r18
    where did you get the rubber caps to cap off the coolant pipes?
  28. Jan 8, 2022 at 9:46 AM
    #88
    blanchard7684
    blanchard7684 New Member
    Cool thread. I've often wondered about this very old school system on the Tundra.
    Back in the day there was all sorts of thermostatically controlled devices not to mention carburetors sitting on hot cast iron intakes with a little spacer...
    However at wot the carburetor system actually cools the incoming charge substantially through several thermodynamic mechanisms. JT effect and heat transfer from phase change in gasoline.
    on this system with port fuel injection, the MAF measures the mass of air incoming and also the intake air temp. Combined with throttle position, cam position, crank position, and rpm, the ECU calculates the timing, phasor position, injector pulse width, and in general transmission shifting strategy.
    So counterintuitively they routed engine coolant to the throttle body.
    At wot throttle this system may not be adding as much heat as you'd think.
    The throttle blade is basically parallel with throttle body. Air flowing over this is removing heat from the blade (at least until the two are the same temperature). There isn't much surface area for convection. Many other throttle body systems don't have this feature of a coolant passage. The throttle body temp rises and falls with engine temp.
    So accounting for the heat transfer, there is heat transfer from the aluminum housing to the atmosphere. And then there is heat transfer to the internal air flow going through the aluminum housing/casing.
    Looking at the inlet and outlet of the coolant flow it appears to be a very small area that gets the coolant flow.
    So it doesn't look to me like there would be a huge convective heat transfer into the air flow.
    It must be for something else...
    Looking at other throttle bodies they don't have an electrical heater nor do they have engine coolant passages. But they do seem to have the throttle body machined differently and also positioned differently. Most non toyota throttle bodies seem to be thicker in many areas.
    The Tundra and other toyota throttle bodies look to have a very small air gap when closed. No matter if the blade is brass or aluminum.
    And the coolant passages seem to land right at where the air gap is positioned.
    I'm thinking this is to maintain some dimensional integrity of the housing. For part load conditions under closed loop, this will ensure the throttle body will have a steady "orifice size" which then allows for less variation in air flow.
    With engine at cold conditions or at wot the engine control regime is open loop and running off feed forward program based on maf flow and tps.
    Saltyhero13 and KingKong like this.
  29. Jan 15, 2022 at 8:21 PM
    #89
    Tundracollector
    Any auto parts store should have them.
  30. Apr 1, 2022 at 8:47 AM
    #90
    Elroy_unlimited
    Elroy_unlimited New Member
    Eric
    Murfreesboro TN
    2017 limited crew max
    What size are those hoses? Are they 3/8” or 7/16”
