Ticking noise when accelerating
Discussion in '1st Gen Tundras (2000-2006)' started by SDSurfing, May 24, 2020.
  1. Apr 1, 2021 at 6:03 PM
    des2mtn
    des2mtn On the scenery looking at the road
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    I've just started noticing this tick recently. Doesn't really bother me and it's intermittent. Maybe I'm noticing it only because I read about it on here?
    I'ma start with the steering shaft seal first.
    FrenchToasty likes this.
  2. May 25, 2022 at 3:08 PM
    FNG2004
    FNG2004 New Member
    1st Gen Tundra
    I have the exact same issue it sounds like. Tick matches the RPMs and only when moving. When the truck shifts the tick slows down and then speeds up again with RPMs. Silent on idle and if you stop accelerating and drop it into neutral while coasting down the road and rev it up, no tick. I'm leaning towards something in the transmission. Did you ever figure out the issue?
  3. May 25, 2022 at 4:57 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Stuff some pink fiberglass into the steering shaft if the boot is ripped. $5 fix; disaster abated.
  4. May 25, 2022 at 6:23 PM
    Alltimehigh
    Alltimehigh New Member
    same
    Jack McCarthy likes this.
  5. May 26, 2022 at 3:04 PM
    remington351
    remington351 New Member
    2006 SR5 DoubleCab
    So exhaust manifold is the cause of this? Mine has been doing this since I bought 20k miles ago. Never got louder so I just figured it was part of the Tundra's patina. I may snoop around someday and look for an exhaust trail but I'm not in a hurry.
  6. May 26, 2022 at 5:07 PM
    I dunno, a few of us have posted about it, several of us have it, high-mile, low-mile, and medium-mile engines. I've heard several causes cited, including noisy injectors, valvetrain (sounds like a ticking valve to me), exhaust manifold bolts (in earlier models) and a few other things.
    But normally you don't hear it in the cab unless your steering shaft steel is shot.
  7. May 26, 2022 at 7:13 PM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Mines done it since I bought it. At 182k now. Only does it for the first couple minutes of running then goes away so I don't worry about it. I assume that due to metal expansion from heat that seals the cracks.
  8. May 27, 2022 at 11:03 AM
    Jack McCarthy
    Bill
    North of Boston
    Mine is like that and usually shows up on cold days as well. If you can hear it with the windows open it’s most likely an exhaust leak. If it’s only in the cab, it’s the valve train noise which is an easy fix IMO.
  9. May 27, 2022 at 12:29 PM
    Fix being to re-seal at the steering shaft?
  10. May 27, 2022 at 12:34 PM
    Jack McCarthy
    Bill
    North of Boston
    Or stick fiberglass in there like I did. :rofl:
    shifty`[QUOTED] and FrenchToasty like this.
  11. Jun 6, 2022 at 7:10 AM
    Paladin
    Paladin New Member
    Andy
    Arizona
    06 Tundra DC & 13 4Runner Trail
    The dreaded exhaust leak from the manifolds.I just fixed mine with doug Thorley short tube headers, new gaskets and new exhaust pipe flange gaskets
  12. Jun 6, 2022 at 7:29 AM
    Source of the dreaded exhaust tick on factory manifolds.
    Jack McCarthy, FirstGenVol and BubbaW like this.
  13. Jun 6, 2022 at 7:37 AM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Ouch :mad:
  14. Jun 6, 2022 at 7:42 AM
    Paladin
    Paladin New Member
    Andy
    Arizona
    Damn that had to be loud haha. Way worse than mine was, but it was still constant ticking for me
  15. Jun 6, 2022 at 7:48 AM
    dlowry81
    dlowry81 New Member
    Doug
    2004 Tundra Doublecab
    I'll throw this out there. I have a ticking which is not constant. I can't really pin point it being related to hot or cold or any other variable, but I can say when the tick is present I can tell a somewhat noticeable difference in acceleration and power. Leads me to believe it is a manifold leak that for whatever reason is worse at times.
  16. Jun 6, 2022 at 3:07 PM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    My 2000 started ticking when cold from a cracked left manifold. It actually seems to do so less over the years. About 10 years ago JBA shorty headers were the rage to fix this. They are a pain to install.
  17. Jun 6, 2022 at 3:14 PM
    dlowry81
    dlowry81 New Member
    Doug
    I want them so bad, but that repair might be the first that is beyond my ability.
  18. Jun 6, 2022 at 3:25 PM
    DSTundra
    DSTundra New Member
    Dave
    Albuquerque, NM
    2017 Tundra Platinum
    Nahhh... it's actually surprisingly easy unless everything is really rusty. I replaced the factory manifolds on my 2001 Tundra with JBAs back in 2005 and it wasn't bad at all. You just need extensions and a good fine tooth 14mm ratcheting wrench. I was lucky in that the flanges on my set were good to go, but I've seen some folks have issues. I also used new factory manifold gaskets if I remember correctly.
    Dave
  19. Aug 30, 2023 at 4:03 PM
    #49
    Bowzer
    Bowzer New Member
    Just posted about this on my '19 4.6L. Only under load w heavy acceleration. Happened today when getting on expressway. Will not do it sitting still but definitely tied to the rpms when driving.
    Scared the life outta me that I had lifter issues coming on. Odd to me that cracked manifold exhaust would make a tapping noise.
    Gonna look some more around it. Sure don't like it!
  20. Aug 30, 2023 at 5:22 PM
    #50
    Not big deal, but this thread is posted in the 2000-2006 forum, so slightly different engine.
    Nice dog!
  21. Aug 30, 2023 at 10:16 PM
    #51
    NickB_01TRD
    Nick
    KY
    It does this because the crack is sometimes around just one cylinder so the tick only happens when that cylinder fires.
    shifty` likes this.
