Time for front brakes- vendor recommendations?
Discussion in '2.5 Gen Tundras (2014-2021)' started by frichco228, Oct 13, 2020.
  1. Oct 27, 2020 at 3:21 PM
    #61
    19crewmaxTRD
    19crewmaxTRD Tundra Enthusiast
    Seth
    2019 white tundra crewmax
    I’m getting r1 geomet slotted rotors and their oep pads installed today. I’ll post up some initial review when I get my truck back this evening.
  2. Oct 28, 2020 at 4:32 PM
    #62
    19crewmaxTRD
    Seth
    Initial report is rotors are smooth, can’t feel the slotting at all. Initial bite and travel of the pedal are a little softer than stock, but hard braking is a lot stronger and the pedal stiffens up nice. Again these are the r1 concept geomet slotted calipers and their oep pads
  3. Oct 29, 2020 at 6:26 AM
    #63
    Northbound Train
    Northbound Train Masshole
    Glenn
    Western MA
    Black 2016 SR5 Double Cab 4x4 5.7
    Anyone use the EBC 7000 series Greenstuff pads. They are pricey, are they worth it??
  4. Oct 29, 2020 at 4:59 PM
    #64
    Crunch527
    Iowa
    TRD Supercharger/BAM
    I put these on my truck about 6 months ago. I am disappointed in the stopping performance. Rotors seem fine but when the brakes are cold they dont have as much stopping power as the OEM.
    I’m going back to OEM rotors and pads, enough of the bullshit.
  5. Oct 29, 2020 at 8:45 PM
    #65
    westmsm93
    westmsm93 New Member
    Yes, every rotor and brake pad combo will feel different. I think the powerstop brake isn't too bad, it probably works best once it get to the optimum temperature. I had a similar result with my Wrangler a couple of years ago.
    By any chance, did you bleed you brakes? When I first swapped out my OEM rotors to the R1, my brakes felt extremely mushy. My friend helped me bleed the brakes and to my surprise, there was air pockets in the line. But after I bled them, they felt much better. The OEM setup had a solid feel to them and a great initial bite. So I have no idea how the air got into the lines? The reason I swapped out to Akebonos was due to the heavy dusting that the R1 off road pads created. The Off road pads had an okay bite and zero brake fade during my baja runs. I was just tired of the dark dust against my bronze wheels. Let us know how to OEP pads do! So far, the Akebono ASP works well with the R1 Geomet rotors. I am about 440 miles in since the brake job. Initial bite is 7/10, Dusting is low. Noise is non existent.
    19crewmaxTRD[QUOTED] likes this.
  6. Oct 29, 2020 at 8:59 PM
    #66
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
  7. Oct 29, 2020 at 9:15 PM
    #67
    19crewmaxTRD
    Seth
    I had a shop due my brakes, I just don’t have time to work on my own stuff with how busy works been. It doesn’t feel like there is any air in the lines, i think because there is less surface area due to the slots that it just takes a bit more pressure to get the bite you get with blank rotors. Under hard braking they are a huge improvement over stock even with bigger tires.
  8. Nov 3, 2020 at 3:07 PM
    #68
    Hightide
    chadington von banks
    Abalama
    Magic School Bus
    Do fronts only.
    It’s well worth the investment.
    Twice the mileage and not the shimmy.
  9. Nov 3, 2020 at 4:18 PM
    #69
    Uhhhh....
    Uhhhh.... New Member
    Dave
    2016 Silver Limited DC
    7” BDS, 37s
    How’s the dust with the Hawk ceramic? And how would you rate the stopping ability with those rotors/pads compared to oem?
  10. Nov 3, 2020 at 5:13 PM
    #70
    The Patriot 1776
    The Patriot 1776 Asskick Fabrication: Shit Is Sick!
    Great State Of TEXAS
    '16 TSS CM 4x4
    W/out going down the "warped rotor" rabbit-hole, make sure y'all are torquing your lug nuts evenly. That's pretty much the only way these rotors will warp. Pad transfer is often confused w/ "warped rotor".
    :crapstorm::crapstorm::crapstorm::crapstorm::crapstorm::crapstorm::crapstorm::crapstorm:
  11. Nov 3, 2020 at 5:48 PM
    #71
    bft305
    bft305 New Member
    2016 tundra limited
    I went with raysbestos specialty performance rotors for my front with raysbestos element3 pads. So far they have been an improvement and I like them.
    KingKong and WILLINH like this.
  12. Nov 18, 2020 at 10:05 PM
    #72
    Tundyfundy
    Bay Area, CA
    I just pulled the trigger on Stoptech Cryo Treated Slotted rotors and stainless brake lines. Ill report back once I get some miles on them. Ill be pairing them with a new set of TRD brake pads I got from the 40% off TRD sale.
    Hightide likes this.
  13. Nov 18, 2020 at 10:07 PM
    #73
    Tundyfundy
    Bay Area, CA
  14. Mar 1, 2021 at 10:55 AM
    #74
    kevine0001
    kevine0001 New Member
    Kevin
    just curious, any issues with dirt and mud getting into the slots or holes and causing premature wear?
    Uhhhh.... likes this.
  15. Mar 1, 2021 at 11:01 AM
    #75
    Uhhhh....
    Dave
    7” BDS, 37s
    Pretty good question. I've been planning on getting drilled/slotted when it's time to change pads...never thought of them getting clogged up.
  16. Mar 1, 2021 at 11:03 AM
    #76
    kevine0001
    Kevin
    A friend of mine just mentioned that he read an article about it. But i live in So Cal, in area that's hot AF for several months out of the year. and despite the hunting/camping I do, 90% of my driving is on pavement (getting to camp, etc.). I'll be trying the powerstop kit when my brakes are due, but curious if anyone has had an issue with dirt/mud getting stuck on the rotors
  17. Mar 1, 2021 at 12:15 PM
    #77
    intr3nsic
    intr3nsic New Member
  18. Dec 25, 2021 at 3:45 AM
    #78
    RToad
    RToad New Member
    South Carolina
    Thank you for this breakdown. I just ordered pads and rotors for front and rear using your links provided.
    Merry Christmas!
  19. Dec 25, 2021 at 11:28 AM
    #79
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Some of the best rotors are made by DBA...they are priced fair and will boast a noticeable improvement over stock...carbon-metalic pads will be great with DBA rotors too and show less dust
  20. Feb 11, 2023 at 8:39 PM
    #80
    KingKong
    KingKong New Member
    Asher
    2008 Super White Double Cab Long Bed 4x4
    I've been running Hawk LTS pads and Advics rotors (OEM supplier) now for a while and can guarantee you would be hard pressed to find a better combo if braking performance is you top desire. They do wear faster than most pads and they are noisier than normal pads but when it comes to bringing your truck to a stop this combo is amazing. My morning commute consists of exiting I-20 in Atlanta at 80-90 MPH on a downhill off ramp with a stoplight at the bottom. Never once have I ever experienced brake fade OR any sort of "warpage" with 50k miles on this combination.
    My perception is most people who think they have "warped" OEM rotors actually have pad deposits from using ceramic pads. These rotors are of a high carbon metallurgy and have fantastic heat dissipation characteristics, as well as being a considerable amount of thermal mass to absorb and dissipate heat. Here's an excerpt from an article on Motortrend:
    "Modern asbestos-free and nonmetallic brake pads contain different resins in addition to the actual brake material itself. Some of these resins and materials transfer themselves to the rotor face so that there will be adherent (sticky) braking in addition to abrasive braking. In a nutshell, when a brake system is properly bedded in, there’s a thin layer of pad material on the rotors. When you use the brakes hard, such as when coming down a steep grade, the heat buildup causes these resins to loosen. When you stop the vehicle completely, such as at a red light at the bottom of an off-ramp after that steep hill, you actually make an imprint of the brake pad on the rotor, creating a high spot. By the time you get gas or stop for lunch (or whatever) the rotors have had a chance to cool off, but that high spot is still there. As little as 0.0004 inch can be felt through the pedal, and 0.001 inch can be downright annoying. Repeated use just leaves more material on the high spots, making the shudder worse."
    My suggestion is to ditch the so-so ceramic pads for quality ones or just step up to semi-metallics. From the same Motortrend article:
    "Buy the best-quality brake pads you can afford and stick with reputable name brands if possible. For heavy applications such as yours, a semimetallic pad is a good choice because they rely more on abrasive braking than adherent braking, and they have a higher maximum operating temperature."
    Also, stick to high carbon rotors. Advics are one example. Hawk Talon, DBA, Stoptech, Brembo, and the Raybestos R-300 rotors that @bft305 has are high carbon rotors. There are others as well, these are just some off the top of my head.
    At some point I may give the Raybestos EHT Element3 pads a try as I've heard great things about them, but for now I'm plenty satisfied with the Hawk LTS/Advics combo.
    Link to the Motortrend article: https://www.motortrend.com/how-to/1808-nuts-and-bolts-warped-rotor-myth/
    coldcanuk, RToad, Philogynist and 3 others like this.
  21. Feb 18, 2023 at 1:44 AM
    #81
    RToad
    RToad New Member
    South Carolina
    I second the Advics. I replaced all 4 of mine with Advics from RockAuto.com. I used Akebono ceramic pads because I have had great success with that brand as well. This combo is 2 years old and no complaints.
    WILLINH likes this.
  22. Feb 20, 2023 at 4:53 AM
    #82
    WILLINH
    WILLINH New Member
    BILL
    NEW HAMPTON, NH
    2019 TUNDRA
    Just picked up front OEM rotors and pads. Rotors made in USA. 74,000 no warped factory rotors.
    Wallygator and omgboost like this.
  23. Jul 3, 2023 at 7:05 AM
    #83
    Erozfish
    Erozfish New Member
    2007 Tundra SR5, 4x4 5.7 V8
    The cheapest I could find the ADVICS A6F048 is around $75 +shipping. ModernToyota has OEM for around $65 and free shipping right now. Do you guys feel that they are basically the same rotor? If so, makes more sense to buy the OEM for less. Just worry about where they’re made, because I see some OEM that are made in China. I was also looking at some Raybestos 980583: https://www.rockauto.com/en/cart/. I will be replacing pads with some of the suggestions on here. Any feedback on rotor choice would be greatly appreciated!
    WILLINH likes this.
  24. Jul 3, 2023 at 7:51 AM
    #84
    WILLINH
    WILLINH New Member
    BILL
    NEW HAMPTON, NH
    2019 TUNDRA
    I bought OEM rotors and they were labeled advics. I also used toyota pads. They have some cheaper ones $50 or so-and some pads for $90-100 I used the expensive one as my friend at parts recommended them. He used the same for his truck. I never had a problem with original or my replacements.
  25. Jul 3, 2023 at 8:26 AM
    #85
    Erozfish
    Erozfish New Member
    Thanks for the reply. I see you were the last one to post in February, so how have they been holding up? I bought my Tundra used back in February, and has recently been pulsing when I hit the brakes hard in the front. Not sure when the guy before me had the brakes replaced, but it looks like they are power stop drilled and slotted. The holes have a lot of brake dust in them so I’m looking to go back to the originals. Also, The Toyota dealer is running a great discount for the 4th, so I’m wondering if it’s worth replacing the shims and spring clips as well? I did see two different sets of pads but the more expensive one said it’s only for the 2018 to 2022 Tundra. Do you know the part number for the pads you got? Thanks.
  26. Jul 3, 2023 at 8:34 AM
    #86
    WILLINH
    WILLINH New Member
    BILL
    NEW HAMPTON, NH
    2019 TUNDRA
    Sorry I do not have any part numbers. I did replace pins and all hardware as they love to salt the roads in NH.I only have about 3500 miles on them and they are good. The original rotors never warped on me. Plus I do not tow.
  27. Jul 4, 2023 at 2:11 AM
    #87
    Jack_A_Lope
    Jack_A_Lope New Member
    Aaron
    Santa Barbara County, CA.
    2019 Tundra 4X4 SR5 TRD Sport
    Pro Comp Lift, Tires & Wheels, Steel front bumper with LED lighting, Cross bed tool box, bed rails, custom aftermarket sound system
    I think the pads are the same for 2007 maybe? The Toyota OEM part numbers for 2019 brake pads are front 04465-02440 and rear 04466-02340. If you need the parking brake pads the number for those are 46530-34010. You can verify these numbers by going to the Toyota parts web page and searching for your vehicle.
  28. Jul 4, 2023 at 4:24 AM
    #88
    MedCityMoto
    MedCityMoto SciTech Nerd
    2.5gen CM SR5 TRD OffRoad
    EBC slotted & dimpled rotors just went on front and rear, with the Yellowstuff pads. Man, what a nice upgrade. At around $150/wheel I'm very happy, smooth grippy brakes, and adjusting the parking brake while I was at it was totally worth it.
    WILLINH and HulkSmurf14 like this.
  29. Jul 6, 2023 at 8:41 PM
    #89
    ThiRdChoice
    ThiRdChoice New Member
    Tommy
    Hopefully ModernToyota is legit...just ordered pads and rotors for a total of $402. Couldn't find anywhere else cheaper :D
