Timing belt quote
Discussion in '1st Gen Tundras (2000-2006)' started by Aaol1, Sep 22, 2023.
  1. Sep 25, 2023 at 1:16 PM
    #61
    kayaklabguy
    kayaklabguy New Member
    2005 Tundra SR5 Stepside V8
    This was me two weeks ago. The dealer told me my truck needed $15k worth of work. The helpful individuals on this page helped me realize those were insane numbers and did the work myself. Got into this with a max number you want to invest and stick to it if you can. It can all add up quickly.
  2. Sep 27, 2023 at 5:03 AM
    #62
    dt325ic
    dt325ic Member
    GA
    2019 TRD Sport
    I did the timing belt on a 2003 a few years ago (family). It was the first change, low mileage. Due to the low miles, I did not replace the fan bracket. It had no play and the bearing was smooth.
    Fast forward to today, truck has 140k miles, so roughly halfway through the interval. The fan has a wobble now, so I get to replace the fan bracket soon. Since the idler pulley is mounted to the fan bracket, I'll get a new one of those as well.
    Rolled the dice on this one and lost. My old 2004 had the original at 216k miles and was still fine. You just never know. At least replacing them all now gives you new quality parts, and you can decide on the next timing belt change which parts you feel comfortable with letting ride.
    Good luck.
  3. Sep 27, 2023 at 7:28 AM
    #63
    Baller
    Baller New Member
    '05 Tundra SR5 DC
    I'm not trying to hijack the thread but, no, it never got stickied. I remember mentioning at some point that it would be useful but, that didn't seem to go anywhere. Seems like it would be a good idea as it's such a predictable and significantly involved maintenance for these rigs.
  4. Sep 27, 2023 at 10:22 AM
    #64
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    It has been done.
    Weagle likes this.
  5. Sep 27, 2023 at 12:12 PM
    #65
    Baller
    Baller New Member
    '05 Tundra SR5 DC
    I've finally made it! :thumbsup:
  6. Sep 28, 2023 at 8:14 AM
    #66
    KTM_AJ421
    KTM_AJ421 New Member
    AJ
    2006 SR5 DC 2WD 4.7
    265/75r17 M/T Baja Boss AT 17x8.5 -10mm SCS Ray 10’s Bilstein 5100’s 2nd notch
    I paid $2k for mine to be done at the dealer. It was a lot but I can walk to the dealership from my house and the truck was at 157k
    shifty` likes this.
  7. Sep 29, 2023 at 3:09 PM
    #67
    Bergmen
    Bergmen New Member
    Ukiah, California
    2018 Blazing Blue Pearl DC 4X2 SR5
    I replaced my timing belt (along with all of the associated parts) twice on my 2006 at the recommended intervals. Always used the Aisin kit (second one had more replacement parts than the first, idlers, etc.). Honestly, I had to be careful to keep the new belt separate from the one removed since they both looked identical. Removed belt had no wear marks, cracks or any indication that it had been used at all.
    PITA job but I took my time and did everything correctly.
