To stubby antenna or not to stubby antenna?
Discussion in 'Audio & Video' started by pacman_gptx, Apr 25, 2015.
  1. May 3, 2015 at 6:31 AM
    I think most of these aftermarket antennas will work fine for most folks. I tested these antennas in a tough area to get any decent reception on a good day. Sometimes GPS reception drops completely out in several places along Clear Creek. I keep my OEM antenna in my cargo storage for backup anyways.
  2. May 3, 2015 at 5:21 PM
    dandailey
    dandailey King Tundra
    Dan D
    Newport News Va.
    2015 TRD 4x4 DC Tundra 5.7 Blue Ribbon
    Bakflip Revolver X2 ,Nestahedition Firestalk antenna, TRD dual exhaust, WeatherTech liners, in channel deflectors, 20% tint front, Tundra bed mat.AFE pro dry s filter,SA XDM 3.8 compact 9mm., Wheel to wheel N-Fab 3 steps.Lamin-X yellow on fogs, Bilstein 6112's top setting, BFG KO2's 275/70-18.Pioneer HU, JL RD amp, Focal speakers everywhere.
    Installed my 13" AntennaX . Looks good and can not tell any difference from stock 30" reception wise.
  3. May 3, 2015 at 5:22 PM
    pacman_gptx
    pacman_gptx [OP] New Member
    Paco
    2012 5.7L Magnetic Grey Metallic Crewmax SR5 Texas Edition
    Interior LEDs, Cargo/Reverse LEDs, Foot Well LEDs, McGard Tailgate Anti-Theft, Pilot Stubby Antenna
    I keep mine under the back seat in case of an impromptu fencing match.
  4. May 3, 2015 at 5:57 PM
    Got to be prepared for anything. You never know.
  5. May 4, 2015 at 3:28 AM
    pmedic048
    pmedic048 Pull away from the herd, drive a Tundra!
    SC
    2008 SR5 Dbl Cad, 2015 SR5 CrewMax 4x4 and 2016 TRD Limited 4x4
    3" front spacer lift and 2" rear spring lift. 20" Fuel rims with BF Goodrich G2 33.5s and Volant cold air intake.
    I had gotten a stubby for both my wife's 2013 SR 5 4runner and my 2015 SR5 Tundra and the reception sucked. I'm sure there are ones out there that are good, but the ones I bought off eBay were not. A guy at the dealer told me to find one that has the wire wrapped around it like the stock one does. Good luck and let us know if and which one you got.
  6. May 4, 2015 at 6:02 AM
    What makes it hard choosing after market knock off stubbies is that they may or may not have the inductive coil (wire) wrapped around the mast. The inductive coil is not always visible as it is on the OEM antenna and the coil can be of different gauge wire. (A smaller gauge wire inductive coil wrapped around the mast will allow more flexibility for instance) It is hard to determine manufacturing quality from a picture online although Amazon seems to be a good source for antennas such as AntennaX. Pretty much trial by error.
    pmedic048 likes this.
  7. May 4, 2015 at 6:34 AM
    You could always sharpen the tip and use it for survival spear fishing. Possible thread "Pointless uses for your no longer needed stock antenna" Ha-Ha
    bandit likes this.
  8. May 4, 2015 at 5:59 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    I first purchased a billet solid aluminum stubby antenna that was around 4" tall for my Tacoma. It was total junk. Reception was bad and it ended up breaking off in the car wash.
  9. May 4, 2015 at 6:12 PM
    dandailey
    Dan D
    Newport News Va.
    You do know you are supposed to remove the antenna before the car wash?
  10. May 4, 2015 at 6:25 PM
    Mike Tread lightly.
    south carolina
    Why I like power antennas the best. I did it to my tacoma conversion. Im up in the air on my tundra still.
  11. May 4, 2015 at 6:54 PM
    rr3311
    rr3311 Tundra Magic
    Ohio
    2015 Bronze Tundra Limited Dbl cab 4x4
    Added Extang Solid fold tonneau cover Replaced backup lights with projector LEDs Cab LEDs Taconsha P3 brake controller mounted in dash
    Great 'non-scientific' write up. That helps a lot. The Raptor is certainly a good price considering your results. It is really flexible, so would stand up to off road as well as the car wash demons. I am not too sure I like the wind bending, but for that price.....
  12. May 4, 2015 at 7:10 PM
    csuviper
    Broomfield, CO
    Never had a problem except for that one.
  13. May 5, 2015 at 7:25 AM
    The wind bending is kind of weird. Hell the antenna is weird. I am tempted to buy another Raptor and dissect it to what gives. You can do what I did. Just hit up whatever auto part stores are in your area. Pick out some different antennas and test them out for yourself. Return the the ones that don't cut it. Report.
    UPSed likes this.
  14. Jan 9, 2016 at 2:31 PM
    Captainvfr
    Captainvfr New Member
    2016 Platinum -Midnight Black
    LED Interior
    I have a 13" Antennax I bought on eBay and I live 30 miles south of Boston. No HD channels come in until I am closer to the city...
  15. Feb 21, 2016 at 11:27 AM
    camu77
    camu77 New Member
    Robert
    2010 Crewmax Tundra
    I put a 5 Inch TRD on mine no issues at all it was 6 bucks on eBay.IMG_20160221_142133768_HDR.jpg
  16. Feb 21, 2016 at 11:39 AM
    My adapter seal broke off and water got to the bolt. It rusted so bad the ar wash broke it off and I couldn't get it out with an extractor. I had to replace the entire assembly. I replaced it with a smaller stubby with what appears to be a slightly better rubber seal. I'll keep an eye on it.
    Trust86 likes this.
  17. Feb 27, 2016 at 11:03 AM
    dandailey
    Dan D
    Newport News Va.
    Reception with the 13" AntennaX sucked so went to this.. much better.
  18. Feb 27, 2016 at 2:33 PM
    JB445
    JB445 New Member
    Jeremy
    2015 White Tundra TRD Offroad
    I like the long attena for clearance purposes but dont like it when off roading and it finds every tree.
  19. Jun 7, 2016 at 9:53 AM
    #49
    TheBeast The Beach
    just installed the antennaX 13" last night. Love the look however it seems the threads are a bit long ( maybe 1/8") so it's not fully sealed. Granted I live in Southern California where it never rains, I'd like it to be flushed. any tips ?
  20. Jun 7, 2016 at 9:58 AM
    #50
    TheBeast The Beach
    here is a great picture I found on Amazon reviews.
  21. Jun 7, 2016 at 1:24 PM
    #51
    ToyotaTundraMike
    2015 Tundra
    Ran into this same problem. A black rubber grommet should do the trick, or a washer (if you don't want to cut it).
  22. Jun 7, 2016 at 1:30 PM
    #52
    Asw278
    Asw278 Magnetic Money Pit
    2016 MGM Tundra TRD SR5
    Victory 4x4 Rock Sliders Victory 4x4 Bed Rack Tint TRD PRO Grill and Hood Bulge TRD Rear Sway Bar Nfab MRDS Front Bumper GoRhino BR20 Rear Bumper RCI skid plates Rough Country 40" curved light bar Razir 30" light bar AntennaX 13" antenna A1 Auto tow mirrors Spyder headlights & tailights AFe catback exhaust Salex tray organizer WeatherTech front and rear mats AJT Designs shift knob, fob case, vent rings, control knobs Black Rhino Razorback wheels Cooper STT Pro's @achoup center console logo Elka 2.5DC resi’s JBA Off-road UCA’s Coachbuilder +3 shackles
    I also had the same problem. Emailed them and they sent spacers. Sealed up nice now. No issues with reception but I've only been city driving since installing.
    TheBeast likes this.
  23. Jun 7, 2016 at 2:27 PM
    #53
    TheBeast The Beach
    good to know. I'll email them.
  24. Jun 7, 2016 at 5:46 PM
    #54
    For what it's worth, I now keep 3 spare antenna's of different wave lengths in my under seat storage. I seem to find myself at different altitudes, etc. There is no perfect antenna. Only takes a couple of minutes to swap out. Just sayin. Haven't tried this setup yet. Looks promising though:
    khunk, Inferno16 and ToyotaTundraMike like this.
  25. Jun 7, 2016 at 5:52 PM
    #55
    Know doubt need "Erector Set" experience as a child to build something like this.^^^^ ( I had the Erector set along with my Lincoln Logs and a kids chemistry set that would be banned now for sure with our safe zone kids parents.) I fear for our future. :rasta:= safe zone/ then there is reality. What a concept.
  26. Jun 7, 2016 at 7:54 PM
    #56
    Tracker
    Tracker New Member
    Shane
    Colorado, Denver Burbs
    2016 Silver Tundra SR5 Lifted
    I think if the Toyota's all came with stubbys everyone would want the longer ones for certain better performance lol
    Black Wolf and TheBeast like this.
  27. Jun 7, 2016 at 8:47 PM
    #57
    Word of advice:
    Get the shortest stubby u can. That 13" ended up having rubber rot out, which exposed the bolt which then rusted- which caused me to have to tare the truck apart to replace the entire antenna assembly.
  28. Jun 7, 2016 at 9:56 PM
    #58
    dandailey
    Dan D
    Newport News Va.
    Had the same problem wuth the antennaX I had. Hack saw works great.
  29. Jun 7, 2016 at 10:34 PM
    #59
    bj46-taco-tundra
    bj46-taco-tundra New Member
    Mark
    Bj46 taco and now a tundra
    Put my 13" antenna-x on and once I hit the hiway the thing whistled. I'm 1.5 hrs away from a main center and I was surprised that I was able to pick up some of the stations that I once did. As a result of the whistle..., while its still on for now.
  30. Jun 8, 2016 at 5:43 AM
    #60
    That had to suck.
