TOTAL CHAOS - Stock Length Lower Control Arm (LCA) - Should I upgrade?
Discussion in 'Suspension' started by TOTAL CHAOS, Jul 9, 2018.
  1. Jul 11, 2018 at 12:05 PM
    Hattori
    Hattori STOP SHIMMING COILOVERS!!!!
    Tommy
    Nashville
    2012 Tundra CM TRD
    Me.......
    Per long time conversations with Rob @ TC, this is my final upgrade to finish my MT setup. I run the secondary setup on my truck and it's by FAR exceeded what I do with my truck, so I'm expecting no less on these arms. Keep in mind this complete setup will rival if not surpass a factory tuned and or lightly modded raptor suspension on rebound, compression and overall wheel travel.
    asmall23, joonbug and dcsleeper408 like this.
  2. Jul 11, 2018 at 12:21 PM
    TOTAL CHAOS
    TOTAL CHAOS [OP] WWW.CHAOSFAB.COM Vendor
    Corona, CA
    We've found the 5/8" Grade 8 bolt to be more than strong enough for supporting the bypass. The coil over takes the majority of vehicle load which is another reason why we didn't add additional tabs.
    TOTAL CHAOS
    WWW.CHAOSFAB.COM
  3. Jul 11, 2018 at 12:24 PM
    lionix
    lionix The Grey Moose!
    Cape May, New Jersey
    2017 Tundra TRD Pro CM Cement
    BD Lights, Any Time Fog, Coachbuilder, Pelfreybilt, Bakflip, Custom Bed Rack w/ Tent
    It will get me a LT LCA. Not a full setup. I understand I will need a whole myriad of parts to go with it.
  4. Jul 11, 2018 at 12:25 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Good to know, thanks
  5. Jul 11, 2018 at 3:10 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    We have one through a supporting vendor. Hit up Joey at SDHQ.
  6. Jul 12, 2018 at 8:44 AM
    Bailey
    Bailey Enjoy Every Sandwich
    CO
    2011 DCSB Limited 4x4 “Clifford”
    When my Tundra LCAs start doing this, I'll be upgrading
    (this was on my FJ... one year after replacing the LCAs)
    https://youtu.be/dyfNoxhx2cA
    TheBeast, T-Rex266 and Watt maker like this.
  7. Aug 3, 2018 at 3:15 PM
    TOTAL CHAOS
    Corona, CA
    Boxed Race Series Lower Control Arms + Optional Sway Bar Upgrade
    The tubular LCA set up is great. However with the added cab weight of the 4 door we wanted to reduce some of the body roll at high speeds for flatter cornering. Adding the Sway-Bar-System gave the Tundra much better on and off road handling without sacrificing wheel travel or articulation.
    MORE INFO
  8. Aug 3, 2018 at 8:01 PM
    lionix
    Im starting to like the idea of the upper and lower together.
  9. Aug 8, 2018 at 10:15 AM
    TOTAL CHAOS
    Corona, CA
  10. Aug 8, 2018 at 10:56 AM
    papasmurf
    papasmurf Savage Fabrication
    Bruce
    San Diego
    2007 4x4 Tundra
    07 Silver Sky 4x4 | Total Chaos LT | 2.5 King Coil overs & Bypasses | Camburg Bed Cage | 3.0 King Bypasses | 2.0 King Bumps | Custom Deavers | Nitro 4.88's | ARB Locker | Demello Sliders | 17" Double Standards | BFGKO2 37's |
    ummmmm yeah no... 3800$ for the tubular lowers and uppers, plus another 650 for axles (hidden cost of 2-400$ to swap them into the factory cv's, bypass hoops are 525 and then a vast addition of things like camtab gussets and spindle gussets should be considered required... dont forget you need all new coilovers and bypasses as well.. so throw in another 3-4k$ for that
    oooorrr....
    3k$ for the stock length ones and use all the factory parts and have a bad ass mid travel rig and you are good to go... and id bet you can do 80% of what the LT guys do with no issues.
    sorry but LT and full mid travel are nothing to compare when it comes to cost comparisons. Wanna know how I know... cause ive had bracket lift, been mid travel and built my own full long travel truck.
    @TOTAL CHAOS thoughts here?
    lionix[QUOTED] likes this.
  11. Aug 8, 2018 at 11:53 AM
    TOTAL CHAOS
    Corona, CA
    Mid Travel and Long Travel aren't far off from each other if you buy everything at once. Here are two "complete packages"
    Mid Travel:
    Upper Control Arm - $816.64
    Lower Control Arm - $3088.97
    Coil Over Shocks - $1594.95 (FOX 880-02-367)
    Shock Hoops, Spindle Gussets, Cam Tab Gussets - $728.39
    Bypass Shocks - $1499.90
    TOTAL Parts Cost: $7,728.85
    Long Travel:
    +2.5" Long Travel Kit - $3548.03
    Coil Over Shocks - $1594.95 (FOX 880-02-949)
    Shock Hoops, Spindle Gussets, Cam Tab Gussets - $674.29
    Bypass Shocks - $1699.90
    LT Swaybar Link - $231.75
    LT Axle Shafts - $649.15
    TOTAL Parts Cost: $8,398.07
    Pricing will vary depending on the desired components for the coil over and bypass shocks. I'll start a Long Travel Thread soon for discussion on LT and it's benefits over mid travel. It'll be a good place to discuss this
    TOTAL CHAOS
    WWW.CHAOSFAB.COM
    Yota100, TRD15559, Watt maker and 7 others like this.
  12. Aug 8, 2018 at 12:05 PM
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    cool thanks for that, maybe i didnt clarify, i was just saying for someone who already has most midtravel parts, ie coilovers and uppers, just upgrading lowers and bypass and tubes is much cheaper, than ditching a midtravel coilover setup w uppers to then switch to a full LT setup'
    hope that makes sense
    TheBeast and lionix like this.
  13. Aug 8, 2018 at 12:22 PM
    lionix
    :thumbsup:
  14. Aug 8, 2018 at 12:24 PM
    lionix
    I still think down the line I will stick with the mid travel just because I like the width. More tight technical stuff near me. Less wide open, unless you are on a dirt road.
    At that point you couldn't keep up with me whether you had mid or long travel. Lol
  15. Aug 8, 2018 at 12:28 PM
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    Btw I know totally believe in the buy once cry once theory... if it’s a 500$ diff between MT and LT setup go LT if you don’t mind the wider track width ...
    Again this is if you are going from nothing to all out full retard ...
    But if you add on and go mid travel than LT you may as well just go LT from the get go.. you could get some $ back by selling MT parts but it’s not $ for $ more like 50% of what you paid ..
    Hope I’m making sense either way w TC stuff it’s all awesome I along w many others run their LT setup and mash hard and no issues what so ever . You won’t be disappointed either way!!!
    chugs and lionix like this.
  16. Aug 8, 2018 at 12:29 PM
    TOTAL CHAOS
    Corona, CA
  17. Aug 8, 2018 at 12:35 PM
    TOTAL CHAOS
    Corona, CA
    No worries. Thanks :thumbsup:
    papasmurf[QUOTED] and lionix like this.
  18. Aug 8, 2018 at 12:45 PM
    n2deep
    n2deep Pavement Princess
    Crazy that the MT UCA and LCA cost more ($3905.61)than the LT kit ($3548.03)which includes UCA, LCA, limit straps and brake lines.
    That is what most balk at as they feel it should be less.
    TexasTundra27 likes this.
  19. Aug 8, 2018 at 1:15 PM
    #49
    TheBeast The Beach
    I like those maths :)
    papasmurf likes this.
  20. Aug 8, 2018 at 3:06 PM
    #50
    TOTAL CHAOS
    Corona, CA
    There are a few reasons for the price difference;
    - Different manufacturing costs. The Stock Length LCA is a more intricate design and takes more time to build. Lower volume of units being made too.
    - Stock Length Lowers include Heim Sway Bar Upgrades ($231.75 value) which is not included in the LT Kit.
    TOTAL CHAOS
    WWW.CHAOSFAB.COM
  21. Aug 21, 2018 at 4:24 AM
    #51
    Strokelessone
    Strokelessone New Member
    Beaver PA
    The price difference is a little more than what you have here. You also have to take into account all the body modifications, fenders and such. There can be a couple grand right there just in body work and fenders.
    14burrito likes this.
  22. Aug 21, 2018 at 10:55 AM
    #52
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    yeah thats true, aftermarket fenders are 400$ + paint or wrap, body mount chop, the cost to swap axles over from stock CV's
    thats all i can think of right now but there could be more
    14burrito and dcsleeper408 like this.
  23. Aug 21, 2018 at 11:05 AM
    #53
    TOTAL CHAOS
    Corona, CA
    We didn't include those details since there are many variables in pricing for fiberglass, paint, DIY vs. Shop build, etc. DIY customers will save lots of money compared to paying a shop to install everything.
    More info and discussion on our Long Travel Kits can be found here.
    TOTAL CHAOS
    WWW.CHAOSFAB.COM
    T-Rex266 and papasmurf[QUOTED] like this.
  24. Aug 21, 2018 at 11:08 AM
    #54
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    totally understand... just want to make sure people are not just seeing small diff in $ and thinking its not much differance, i did DIY for my full LT front and rear, and saved tons of $$
  25. Aug 21, 2018 at 11:10 AM
    #55
    TOTAL CHAOS
    Corona, CA
  26. Aug 21, 2018 at 11:11 AM
    #56
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    thats one pretty tundy and of course great Midtravel setup!
  27. Aug 21, 2018 at 11:16 AM
    #57
    Rextinkleton93
    Rextinkleton93 New Member
    Kyle
    Chandler, AZ
    2018 Superwhite 4x4
    @TOTAL CHAOS does fox have a spec’d bypass as a secondary for midtravel?
  28. Aug 21, 2018 at 12:03 PM
    #58
    TOTAL CHAOS
    Corona, CA
    TRD15559, Watt maker and papasmurf like this.
  29. Sep 5, 2018 at 8:51 AM
    #59
    14burrito
    2014 SR5 CM 4x4 5.7
    Hit up Don from AZTG, he has fox secondaries on his mid travel.
  30. Sep 5, 2018 at 8:55 AM
    #60
    14burrito
    2014 SR5 CM 4x4 5.7
    @Rextinkleton93
    Stolen from his FB page, factory lowers
    Sorry for the bunny trail TC
