Tow+ Drive Mode
Discussion in '3rd Gen Tundras (2022+)' started by Taikowaza, Sep 6, 2022.
  1. Aug 6, 2024 at 6:51 AM
    Deer Hunter
    Deer Hunter New Member
    2024 Limited 4x4 6.5' bed - MGM/Black
    Good to know, thanks!
  2. Aug 6, 2024 at 6:51 AM
    Breathing Borla
    Northern Illinois
    O ya, your missing something , 0 torque reduction, beast mode.
    hit tow haul button , spin dial, booooooost .
  3. Aug 6, 2024 at 7:45 AM
    BlackNBlu
    BlackNBlu Justa Member
    Rich
    MN
    24 Limited CM 5.5 Blueprint TRD OR
    5100's, 285/75/18, Air Lift bags, bits and bobs
    AKA wheelspin mode, AKA Raped Ape mode, AKA Toyota's version of Ludicrous mode. (At least when you're not towing.)
  4. Aug 6, 2024 at 8:11 AM
    buckeyeman11
    buckeyeman11 New Member
    2024 Tundra Limited
    Is tow+ as fun as sport mode if youre not hauling anything?
  5. Aug 6, 2024 at 8:20 AM
    Breathing Borla
    Northern Illinois
    more, it has less torque restrictions
    pwpblue likes this.
  6. Aug 6, 2024 at 8:47 AM
    RiverSherpqa
    RiverSherpqa New Member
    2024 Limited IMax Hybrid
    After market Airbags
    2024 Limited tongue weight is just under 1900lbs. I stay as light as I can when traveling... dump all tanks, pack lightly. We don't bring everything and the kitchen sink from home. EAZ-lift Recurve3 WD with sway control. Tundra TSC/TCS off (Tow Haul setting option when programming trailer) so I don't get any surprises from the Tundra when passing or getting passed. I don't tow in radar cruise for the same reason, but I don't travel far or often. Rear airbags help level the truck and maximize WD effectiveness. If you move locations a lot or are a full-timer, my setup is not for you. My rig sits in one spot for the summer and then back into storage. The shorter and lighter the better with the Tundra if you are on the move... or get an Airstream I guess.
  7. Aug 6, 2024 at 8:49 AM
    Breathing Borla
    Northern Illinois
    your tongue weight is 1900lbs? that can't be right
  8. Aug 6, 2024 at 8:49 AM
    Black widow TRD
    Black widow TRD New Member
    Manuel
    2023 Black Tundra SR5/TRD
    Love, love this mode !!
  9. Aug 6, 2024 at 8:50 AM
    buckeyeman11
    2024 Tundra Limited
    I think i may drive home in tow + today just for fun.
    Breathing Borla likes this.
  10. Aug 6, 2024 at 8:50 AM
    Black widow TRD
    Manuel
    It’s literally a blast!
  11. Aug 6, 2024 at 9:07 AM
    Breathing Borla
    Northern Illinois
    hell ya, boost spools quicker than shit, LOL
  12. Aug 6, 2024 at 11:31 AM
    buckeyeman11
    2024 Tundra Limited
    Yea that was fun.
  13. Aug 6, 2024 at 4:01 PM
    steveh
    steveh New Member
    '24 Tundra Limited
    Nothing Yet!
    Learning a lot in this thread as a Newby to Tundras. I have to say though, adjusting anti-sway is the key to towing a large trailer. If you have it set right, the lateral pull on the trailer is offset by the direction change, whether by side wind or a large rig nearby. Had a few trailers in the past...
    Also, wind resistance is a cubic function, but acts more like (and easier to calculate) speed times mpg is a constant on highways. E.g. increase your speed by 10% and your mpg will go down by 10%.
  14. Aug 6, 2024 at 4:47 PM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    Finally someone with a Gen 3 Tundra has 1900 lbs (of payload?) tongue weight. I have been waiting for this day to come. We know that Toyota has been advertising a number like this but we have never been able to find a Tundra with this capacity. You would be the first! It might have something to do with the Hybrid option.
    Thanks for chiming in and letting us know that this is possible. When we got our Tundra, we were expecting a payload like this but all we got was 1390 lbs according to the yellow sticker on the door jam.
    Do you think it would be possible to take a pic of that yellow sticker to share with us this rather good payload number?
  15. Aug 7, 2024 at 2:35 PM
    303Gen3
    303Gen3 Old enough to know better. Young enough to try
    Golden Colorado
    '23 MGM SR5 CrewMax 4x4
    Nitrogen filled tires!
    ??? I always thought tongue weight was 10% on the trailer weight - or there abouts. Guess his trailer weights 19,000 lbs or almost 10 tons. That is one big bad ass trailer. Must have 6 big screen TV's, four bathrooms, marble center island, double oven, microwave, full cook top and 1000 gallon water tank, along with a few other glamping features! Manufacturer, model and pics please. BTW no way in hell I'm going to rent, purchase or tow it.
  16. Aug 7, 2024 at 2:43 PM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    I would use a number closer to 15% so that would put the trailer weight at around 12,667 lbs. That sounds more like it and totally doable for the beefy Gen 3 Tundra. Of course, the airbags would need to be pumped up to 40 psi and the WDH cranked up to the max. ;)
  17. Aug 7, 2024 at 5:14 PM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    Totally agree, something is out of place with the reported tongue weight of 1,900 lbs so we were playing around with that. I really can't see anyone trying to tow a trailer that heavy with a Tundra.
    As a point of discussion, I run 12% tongue weight (500 lbs) on my 4,100 lbs loaded Airstream which seems to suit the Tundra quite well. I purposely move contents forward to get this number and find it very stable.
    opfor and (deleted member) like this.
  18. Aug 7, 2024 at 5:16 PM
    303Gen3
    Golden Colorado
    I'd buy a double axle 350 1 ton before using a single axle 1/2 ton to pull that load every day of the week. One flat tire on the camper of that size or truck with that load and you are on a life (not for the good) change.
  19. Aug 7, 2024 at 5:19 PM
    #49
    303Gen3
    Golden Colorado
    big difference between 4,100 lbs and 12,667. 4,100 yes on our Tundra. 12,667 no way.
  20. Aug 7, 2024 at 5:23 PM
    #50
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    Yes, the posts were more sarcastic and joking than real. If someone was pulling that big a trailer, or even 19,000 lbs which was in the post right above mine, the cops would need to be called!
    303Gen3[QUOTED] likes this.
  21. Aug 7, 2024 at 5:28 PM
    #51
    303Gen3
    Golden Colorado
    Only 68 years of observed and behind the driver seat experience here. I've seen it all - until I haven't. Unfortunate and sickening on the "until I haven't" experiences. Better safe than sorry and six feet under. JMO.
  22. Aug 8, 2024 at 5:46 PM
    #52
    steveh
    steveh New Member
    '24 Tundra Limited
    Nothing Yet!
    I've always figured 2/3 of max towable weight for long distance towing.
  23. Aug 9, 2024 at 6:52 AM
    #53
    Eurodriver
    Eurodriver New Member
    My SR did not have any driving modes and had ~40hp less than a regular Tundra.
    Tow+ mode with more HP is definitely raped ape mode.
  24. Aug 9, 2024 at 7:17 AM
    #54
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    yall need to experience tow+ and map 5 on a JB4
  25. Aug 9, 2024 at 7:19 AM
    #55
    Black widow TRD
    Manuel
    That’s what I’m talking about!! That’s how I roll !! With my S&B intakes! Sounds like a diesel!
  26. Aug 9, 2024 at 7:25 AM
    #56
    Eurodriver
    Tell me more.
    My understanding is that just driving these trucks results in complete destruction of the engine
  27. Aug 9, 2024 at 7:46 AM
    #57
    BlackNBlu
    Rich
    MN
    I've heard #1 main bearing will spontaneously combust while parked, no driving needed.
    Blufin likes this.
  28. Aug 9, 2024 at 8:01 AM
    #58
    TundraFl83
    TundraFl83 New Member
    Now here’s the next question
    tow+ mode in 2h or 4h?
  29. Aug 9, 2024 at 8:48 AM
    #59
    eddiefromcali
    Eddie
    100% Stock
    I'm 2wd so I have no choice :)
  30. Aug 9, 2024 at 5:46 PM
    #60
    Breathing Borla
    Northern Illinois
    says the guy with no snow , woohoo lol
    eddiefromcali[QUOTED] likes this.
