Tow hitch receiver
Discussion in '2.5 Gen Tundras (2014-2021)' started by Part_time, Jan 21, 2018.
  1. May 14, 2018 at 5:37 PM
    mgm16trdpro
    Northern NJ
    2016 mgm trd pro crewmax
    Maybe get a large drop like 10 like u said. You can always come up from bottom. You can go any longer down if you don't have it.
    ColoradoTJ likes this.
  2. May 14, 2018 at 5:43 PM
    mgm16trdpro
    Northern NJ
    My advice, try to find a cheap 10 inch adjustable drop. Prob is with that much drop they probably ain't gonna be cheap. More drop = more money. But at least that way you can adjust depending on what u towing. Different height trailers are what can adjust the drop you need. But imo better to have a larger drop and not need than to need and not have. See if you can borrow a smaller drop from a friend at 1st. If it works on couple trailers then get a smaller drop. That way u don't pay for what u don't need and can figure out by borrowing. If u not gonna borrow then go with like 10. Like I said u can always come up. But u can't go further down if u don't got it.
    Jsena likes this.
  3. May 14, 2018 at 5:45 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Thanx bros
    mgm16trdpro[QUOTED] likes this.
  4. May 14, 2018 at 5:58 PM
    I think you all have it covered bud.
    NewImprovedRon likes this.
  5. May 14, 2018 at 6:14 PM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Measure the coupler height when the jet ski trailer is level. Then measure the height to your hitch and subtract to get diff. I have 2" balls on 2" drop and on 3-1/4" for boat and utility trailer. I refuse to buy anything with a 1-7/8". When I bought the utility trailer it had a 1-7/8". I made the dude change the coupler to a 2 before I bought it. I have seen 1-7/8" on some utility trailers and pop up campers but that is it.
    Jsena[QUOTED] likes this.
  6. May 14, 2018 at 6:15 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Thank bro
  7. May 14, 2018 at 6:21 PM
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
    7" lift w/37's. I have a 6" drop hitch thats adjustable in 1" increments. One ball is 2" and can flip to 2 5/16
  8. May 14, 2018 at 6:28 PM
    mgm16trdpro
    Northern NJ
    Yeah def 2 and 2 &5/16 are my most common used. 2 inch boat, log splitter, and the 2 & 5/16 is for my tandem big trailer. However I do have a 1 7/8 on something I just can't remember. Chances are if your're planning to tow smaller things like jet ski I'm guessing it will be 2. But it don't hurt to have a reversible ball. That's what I got, then I have a separate 1 7/8 hitch for the once in blue moon other.
    Jsena likes this.
  9. May 14, 2018 at 6:31 PM
    mgm16trdpro
    Northern NJ
    Same here but only have about 4 inches of lift on almost 35s.
    trayday[QUOTED] and Jsena like this.
  10. May 14, 2018 at 6:35 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    What’s the name of brand model of that..have any pics of it ??
  11. May 14, 2018 at 6:36 PM
    This is the adjustable hitch I have and love it I pull three different trailers alot and can just pull a pin and put it where it needs to be. It's made from Billet aluminum has two stainless steel balls and also rated for 10,000lbs.IMG_20180413_073833162.jpg
    mgm16trdpro likes this.
  12. May 14, 2018 at 6:39 PM
    birdman076
    birdman076 Bird, bird, bird...bird is the word
    Chuck
    Montana
    2015 Brown Tundra Crew Max Limited
    Airbox with K&N Filter, 2" lift on 33's, Alpine iLX-F309 head unit, Pull out bed tool boxes, brown with black trim, rims, etc, black leather interior, matching topper. Muffler delete (too loud..) 62k miles!!!
    Andersen rapid hitch ftw. Comes with 2&2-5/16 ball mount or the optional 1-7/8-2” combo. Adjustable up to 10” in different configurations and 10k weight rating. Sold a ton of them when I worked at the local trailer dealer. Never had any issues.
    https://andersenhitches.com/Catalog/rapid-hitch.aspx
    Mootball and mgm16trdpro like this.
  13. May 14, 2018 at 6:42 PM
  14. May 14, 2018 at 6:47 PM
    mgm16trdpro
    Northern NJ
    Tons of options good luck. Took me about a month to find mine and be happy. Depends all on your specific situation.
  15. May 14, 2018 at 6:59 PM
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
    20180514_185454.jpg8" Trimax hitch, model #TRZ8AL
    mgm16trdpro and Jsena[QUOTED] like this.
  16. May 14, 2018 at 7:04 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Ok, that one might work for me.. what size lift are you running ?
  17. May 14, 2018 at 7:09 PM
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
    7" BDS with Deaver K37 springs, no blocks.
  18. May 14, 2018 at 7:11 PM
    Alloutdrs1
    Alloutdrs1 New Member
    Andrew
    Virginia Beach, VA
    These look pretty good, not badly priced either.
  19. May 14, 2018 at 7:20 PM
    #49
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Does that Deaver bring you up 4inches in Rear ? Since you’re not using blocks or are you sagging ?
  20. May 14, 2018 at 7:31 PM
    #50
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
    No, it's a custom build for the lift. Rear sits a tad higher than the front. I'm buying a trailer on Wed that'll settle the leaf's when towed, then I can figure what size of shackles to buy to help smooth out the ride.
  21. May 14, 2018 at 7:36 PM
    #51
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Nice man
    trayday[QUOTED] likes this.
  22. May 15, 2018 at 4:38 AM
    #52
    nodak67
    nodak67 New Member
    JR
    could try one of these but they are really $$$
    comes with the following :
    drop length : 4", 6", 8", 10"
    shaft size : 2", 2.5", 3"
    1- Drawbar
    1- Slider with Gauge
    1- 2″ Ball
    1- 2-5/16″
    1- Ball Retaining Pin
    1- Lock Plate Key Assembly
    1- Dust Lock Cover
    https://www.weigh-safe.com/product/weigh-safe-drop-hitch/
    Prostar 190 likes this.
  23. May 15, 2018 at 5:07 AM
    #53
    This is what I have minus the gauge really love the hitch.
  24. May 15, 2018 at 5:43 AM
    #54
    Cement Pro
    Cement Pro New Member
    2017 Toyota Tundra Pro
    Stock
  25. May 15, 2018 at 5:49 AM
    #55
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    You mentioned camper, what's the tongue weight of the things you're expecting to pull? If it's significant, you'll want to use a WDH with dual sways so your back end doesn't sag to the ground and it's not as squirrelly going by transport trucks. The WDH usually comes with a drop hitch.
    A Blue Ox WDH has proprietary shank, I'm 5" over stock with 2.5" suspension gain and 2.5" taller tires, it works for me.
    If you're 4"-6" lift, adding bigger tire height too, you might be better off with an Equalizer WDH which can use whatever height Curt shank if the stock one isn't low enough.
    No WDH and say a camper with high TW, you'll end up needing Airbags, SumoSprings or Timbrens, and I think that's fixing backend stress you can prevent with a WDH.
  26. May 15, 2018 at 6:03 AM
    #56
    mgm16trdpro
    Northern NJ
    Oh I didn't notice u say looking to tow camper. I thought just small things like jet skis. In that case might not want to go cheap. Get something decent if towing serious weight.
  27. May 15, 2018 at 6:21 PM
    #57
    GeoJoe
    GeoJoe 2018 Tundra SR 4x4 5.7L Looooooooong Bed
    3/1 lift on 20" OZs with KOs, LED fogs, steps and a handle
    Prostar 190 and mgm16trdpro like this.
  28. May 15, 2018 at 7:14 PM
    #58
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    If you buy one those high $$$$ hitches you will need a lock. I have a Bolt keyed to my ignition key. I had one on my Tacoma that froze up. I had to take a hammer to it. Bolt replaced for free. I noticed replacement had some white grease in it. Good idea to remove now and then and regrease. I like not having to carry an another key.
  29. May 16, 2018 at 9:39 AM
    #59
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
    20180516_092216.jpgLetting the 4.88's cool after the first tow. 7" lift w/37's and the 8" drop on the last setting. Truck squatted prob less then 2" on the progressive leafs. I think the 10" drop hitch would've been better incase I ever tow a smaller trailer or go to a larger tire.
  30. May 16, 2018 at 10:09 AM
    #60
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Well the truck looks good.. you have to let truck cool when towing? What’s that setup weigh?
