Tractors...
Discussion in 'Off-Topic Discussion' started by ColoradoTJ, Sep 27, 2017.
  1. Sep 18, 2019 at 5:57 AM
    #181
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    2wd tractors have a hell of a time backing up ramps as more weight transfers to the front axle backing up a slope.
    TomC843 and ColoradoTJ[OP] like this.
  2. Sep 18, 2019 at 7:34 AM
    #182
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Something to think about, depending on what type of implements you're thinking of running most of the 6/800 series don't have live/independent PTO.
    landphil likes this.
  3. Sep 18, 2019 at 9:06 AM
    #183
    Windsor
    Windsor Why do I do this to myself?
    Homeless in Oregon
    2008 Tundra Crewmax 5.7L
    Some.
    Trailer is 16ft deck with 4ft dovetail ramps with 4ft pull out ramp extensions.
    Tractor tires arent filled (made sure to ask), so that saves me some weight.
    I actually dont plan on using pto much, if at all. I will probably trade/sell the brush hog and get an angle blade. Brush hog wont do too much good with the sagebrush and dirt. Really only need the fel and an angle blade, so the drag box and cultivator will probably go away also.
    What I was thinking for transport is to drop the drag box off and put the brush hog on. Load nose first and flip the bucket down to get a little more clearance and have the brush hog on the ramps. Then figure out where to put the box and cultivator.
    Thoughts?
  4. Sep 21, 2019 at 8:19 PM
    #184
    Windsor
    Homeless in Oregon
    Some.
    Got home about an hour ago.
    I could tell it was back there on accelleration and maintaining speed downhill. But, balance was pretty much ideal. Zero sway, boucing from bumps was barely more noticable than without a trailer. Kept it at 55-60 for 172 miles and was a very comfortable drive.
    Going to weld some D ring tie downs onto the bucket. Lifting the box on was a PITA because the chain kept slipping being wrapped around the bucket.
  5. Sep 24, 2019 at 9:48 PM
    #185
    Windsor
    Homeless in Oregon
    Some.
    Mmmm. Milkshake.
    aperezsh and NE_WARRIOR like this.
  6. Sep 24, 2019 at 10:08 PM
    #186
    ColoradoTJ [OP] Certified tow LEO Staff Member
    No Bueno.
  7. Sep 24, 2019 at 11:28 PM
    #187
    Windsor
    Homeless in Oregon
    Some.
    Drip pan is the transmission. The fill plug gasket is cracked and chunked out and the boot seems to be a recent replacement.
    Bucket is the hydraulic section (milk shake) and the rear diff (mostly dark with a little milk). Hydraulic had the same gasket failure as trans, and the dipstick want wall the way in. Rear diff had a good non-gasket seal on the fill plug. Think the milk in it came from either sloshing over the separating rib, or through the seal.
    Engine was nice and black with only a little contamination on the pickup screen.
    Got 10 gallons of UTF to do a clean/flush. Will do a diesel scrub & flush then put in a "better" UTF after running it for a few hours.
    aperezsh and ColoradoTJ[OP] like this.
  8. Sep 25, 2019 at 6:23 AM
    #188
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    Ready to move some dirt.
  9. Sep 25, 2019 at 6:47 AM
    #189
    DaBoro54
    DaBoro54 Beach Fisher
    Leveling kit, 285/70R18 EXOs
    Does this count as a tractor. Flex track with a fire plow on the back. It was my ‘work’ truck when I was with the NC forest service. Damn I miss fighting fire
    GODZILLA, aperezsh, RangerBP and 2 others like this.
  10. Nov 11, 2019 at 3:32 AM
    #190
    PermaFrostTRD
    Northern NY
    Just picked up a new (to me) Deere. It will be strictly for my driveway in the winter. We average 120-150” snow every year and can get into the upper 200’s some years depending on the lake effect blasters.
    54” mower deck also and a weight bucket to attach to the 3point. The mower will probably only get used as a backup to the zero turn. But I’ll probably get a brush hog for the 3point at some point.
  11. Nov 11, 2019 at 4:05 AM
    #191
    Worriedman50
    Worriedman50 New Member
    Richard
    West TN
    2015 Tundra Crewmax
    TRD Rear Sway Bar , 6112 front 5160 rear shocks, Retrofit Projector Headlights, Rear LED bumper lights lights, FRAC harness and front camera, TRD Pro Grill and color matched hood bulge.
    L2800, tiller, rotary brush cutter, front bucket to go with loader and the most used, root grapple.
  12. Nov 14, 2019 at 6:56 PM
    #192
    Bappa
    Bappa Off the grid
    Bo
    Arizona
    2018 Tundra CrewMax
    Coil overs (3”) and 295 tires, ESP storage, grab bar; RCI skids; tinted windows; rear air bags
    Go Orange!
  13. Nov 14, 2019 at 8:06 PM
    #193
    A little update.
    We now have around 50 hours on the tractor, and still enjoying it.
    going to do the 50 hour maintenance on it next week. Ordered all Kubota filters.
    I have broke something minor. The radiator overflow tank cap is not cold weather friendly, and it broke the cap. 6.00 and had it shipped to my address.
  14. Nov 15, 2019 at 3:06 PM
    #194
    Please let us know how you like your new tractor this winter. Looks to be in great shape.
    Bad ass machine...
    http://www.tractordata.com/farm-tractors/005/4/6/5468-john-deere-2305.html
    PermaFrostTRD[QUOTED] likes this.
  15. Nov 15, 2019 at 3:10 PM
    #195
    7.62Tundra
    7.62Tundra Chromeaphilliac
    SA Texis
    2015 5.7 Crewcab
    3025 JD here. For 5 acres it does fine. Only 45 hours in 2 1/2 years. But it sure comes in handy. I'm always amazed at how a 25HP diesel has so much torque versus a gasser
    Saw this today and oh well looks like the timing belt broke
  16. Nov 15, 2019 at 4:46 PM
    #196
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Should be warranty. He was just driving along...
    ColoradoTJ[OP] likes this.
  17. Nov 17, 2019 at 5:09 PM
    #197
    PermaFrostTRD
    Northern NY
  18. Nov 19, 2019 at 10:02 PM
    #198
    easleycrawler
    Travis
    Easley, South Carolina
    17 Tundra SR5 DC Black 5.7
    Must have been a power stroke. Lol
  19. Jan 27, 2020 at 7:00 PM
    #199
    PermaFrostTRD
    Northern NY
    Update for the 2305 Deere:
    mid/front PTO had a busted part on the shaft. The outfit I bought it from kept repairing it poorly (I didn’t know about the shaft issue). Essentially wasn’t functional for more than 20 minutes. (My driveway takes 45-1hr to plow). This is after repeated attempts and requests to “just fix it, if I need a new attachment, etc. whatever I just need it to work.”
    Finally get fed up, take it to the local Deere dealer (explaining everything), they call back asking me if I repaired it (I’d let them know ahead of time my lack of wrench turning ability LOL) and finally fixed it to the tune of $700. Big money but it’s an absolute tank now. “Runs like a Deere“ as the saying goes now. Slings snow, slush whatever. Most fun I can have with my clothes on. Now I’m looking at a cab. Gets a bit chilly in that hour I’m out there if the wind is hucking just right.
  20. Feb 7, 2020 at 12:39 PM
    #200
    Damn! That sucks @PermaFrostTRD
    Glad you got it fixed. Your driveway must be huge.
  21. Apr 9, 2020 at 9:12 PM
    #201
    TomC843
    TomC843 The wheel weaves as the wheel wills.
    Tom
    Charleston, SC
    16, 4X4, 4U3, Katzkins, Flowmaster, ARE MX, Swing cases, TRD skid plate, Volant CAI....
    This is a thank God I got my small tractor post. I used my one row plow to help trench a water line I ran from the pump house to the new garage over a 120' away, and right at the end of the only possible route to the pump house is super roots that I thought I paid to have stump grinded 3 years ago. That's a size 12 shoe, no way this job could have happened otherwise.
  22. Apr 11, 2020 at 10:13 PM
    #202
    Boosted4runner
    Boosted4runner Join the NRA please.
    WA
    2015 DC MGM TRD Tundra, Kings, 5.7, 2018 front end
    Resi Kings, 35” Trail Grapplers on 18” Methods, ICON Delta Upper Arms, Front-Runner bed rack, Yakima SkyBox16, 2018 honeycomb grill, 2018 LED headlights, plastidipped bumper covers
    Love the orange :D
    Kubota MX5100D (50hp, manual trans)
    She’s done a LOT more than I should have ever asked her to do. Moved a few thousand yards of dirt around a few years back. :D
    landphil, JC303, Toyotoholic and 6 others like this.
  23. Apr 11, 2020 at 10:36 PM
    #203
    Windsor
    Homeless in Oregon
    Some.
    Wheres the putting green?
  24. Apr 12, 2020 at 4:08 AM
    #204
    Northbound Train
    Northbound Train Masshole
    Glenn
    Western MA
    Black 2016 SR5 Double Cab 4x4 5.7
    Used the forks on my tractor to make it easier upgrading to a 38 gallon tank!
  25. Apr 12, 2020 at 9:57 PM
    #205
    Boosted4runner
    WA
    If I golfed I’d have one. Father in law wants a driving range lol.
    aperezsh and TomC843 like this.
  26. Apr 12, 2020 at 10:03 PM
    #206
    Jengel451
    Jengel451 Misanthropist
    The Bitterroot, MT
    2017 Barcelona TRD Limited CrewMax
    3/1.5 Toytec/Icon AAL, 17" Rebounds, 317-70-70 ST Maxx's
    Put this together over winter. Have 10 acres of Timothy pasture and an arena to groom. Love this little thing.
    1948 8n
    Njmike13, KB Voodoo, don3032 and 10 others like this.
  27. Apr 13, 2020 at 1:45 AM
    #207
    niedejb
    niedejb New Member
    Sumter, SC
    '17 Platinum
    That's a good looking 8n sir. You have to be proud.
  28. Apr 13, 2020 at 6:23 AM
    #208
    Nice job!
  29. Apr 13, 2020 at 6:38 AM
    #209
    K9Lonzo
    K9Lonzo New Member
    Kris
    2019 Silver Sky Platinum
    ECC79289-70CD-48BC-8DF6-DC4A35B12ECE.jpg Here is my work horse. Grew up working on a 40hp New Holland TLB, and thought I needed something that big. I came across a smoking deal on a BX24 and haven’t looked back. It’s a little beast and a lot more fun to work with than the larger machine. It’s done everything I’ve asked it to do and then some. C59CD896-D57F-4933-9E3E-B2B908448612.jpg
  30. Apr 13, 2020 at 6:55 AM
    #210
    Lake.Life24
    Lake.Life24 New Member
    Shawn
    Upstate, NY
    2021 GMC Sierra 3500HD Gasser
    Just realized we had a tractor thread. I picked up this bad boy last fall LS 4145HC. Any tips on cleaning? It is a muddy mess right now in the northeast. Also waiting on the stone quarry to open back up so I can finish the pad and get cement in.Tractor.jpg
