Transfer Case Lubrication requirements, 2014 and above
Discussion in '2.5 Gen Tundras (2014-2021)' started by btanchors, Jan 25, 2017.
  1. Mar 11, 2018 at 4:10 AM
    #61
    excel8951
    excel8951 New Member
    Dave
    2014 Tundra DoubleCab SR5 Reg Bed
    Also, for the ATF I'll use Valvoline MaxLife ATF full synthetic.
    For the diffs I'll use Valvoline SynPower 75w-90.
  2. Mar 15, 2018 at 6:14 PM
    #62
    15whtrd
    15whtrd Mr. Blonde
    So where did we end up on this? Is ravenol good enough to put in the transfer case or what? It looks almost identical in the test that was done here. I really don’t know how to read those charts but someone said it was missing something that the Toyota version has.
  3. Oct 16, 2018 at 1:05 PM
    #63
    15whtrd
    15whtrd Mr. Blonde
    Here’s a little update. When I first bought my truck I changed the transfer case lube and differentials over to 75-90 royal purple. Everything seemed to work fine. But I did notice that 4 x 4 high would not disengage completely until I made a turn. This slowly presented itself. It would work fine although it seemed to pull to the right. I noticed this when doing the typical exercising my 4 x 4 on a straight piece of road on the way to work. Just to keep everything well lubed like the manual says. Would not fully disengage with the four high light blinking until I made a turn.
    I changed the oil this weekend to 75 Ravenol.
    Instantly I could tell the difference. It engages in disengages perfectly and no longer pulls to the right. I may change it again in a few thousand miles just to make sure I got all the old shit out of there.
  4. Oct 16, 2018 at 1:23 PM
    #64
    15whtrd
    15whtrd Mr. Blonde
    My mistake was going off of a second generation DIY right up. I figured why would they change that LOL. Well they did! I should’ve realized that when the drain and fill plugs are completely different.
    BTBAKER likes this.
  5. Jan 24, 2019 at 8:55 PM
    #65
    acmesupply
    acmesupply New Member
    2018 SR5 CM Silver TRD
    I was looking for more compatible oils and found that the latest RedLine oil 70/75w shows as a oem compatible replacement for Toyota transfer case oil. In the meantime I did a voa of Belrey 75w and that's a bust.
    Here's the link. https://www.redlineoil.com/mt-lv-70w75w .I am currently using Ravenol 75w. I will try to contact them for a actual voa on the additives. I know in the past that they said nothing was compatible but if you look at the site and click on OEM its list Toyota 08885-81001.
  6. Aug 18, 2019 at 4:29 PM
    #66
    Snellums
    Snellums New Member
    I bought a 2014 used with 128K on the clock. As I usually do when I buy a used vehicle, I changed the fluids in the diffs, transfer case and the tranny. The engine oil, coolant, PS and brake fluids were all new. I used Valvoline SYN power 75w-90 in the gear boxes and transfer, and Valvoline Max Life synthetic in the tranny. I've had no issues so far. When I read the oil analysis of the gear oils and the viscosity and additive differences, a thought occurred to me: What if the additive metals are so high in the Toyota 75W to make up for the very low comparative viscosity? Since gear oils have always been thicker than engine oils to resist the shear and compression forces of meshing gears, maybe these higher levels of additive metals are to compensate for the much less viscous fluid? Any ideas?
  7. Aug 18, 2019 at 8:38 PM
    #67
    Bigbird57
    Bigbird57 New Member
    At less than two quarts, I am using the Toyota 75w gear oil. I have seen it for sale at $56 to $60 per qt. Obscene, yes! It is not worth the risk until a boutique oil company reverse engineers the product.
    Amsoil did this for Transyd used on the Allison tranny.
  8. Aug 21, 2019 at 9:54 AM
    #68
    crabbymcnab
    crabbymcnab New Member
    2016 Inferno SR5
    Without having my manual in front of me, how many quarts of diff fluid should I get for front and rear diffs?
  9. Aug 21, 2019 at 10:26 AM
    #69
    15whtrd
    15whtrd Mr. Blonde
    WAtundra4x4 likes this.
  10. Aug 21, 2019 at 10:47 AM
    #70
    crabbymcnab
    2016 Inferno SR5
    15whtrd[QUOTED] likes this.
  11. Aug 25, 2019 at 1:39 PM
    #71
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    I changed my diffs and T-case on Friday.
    I have a couple observations and one underwear filling moment I thought I would share so that someone else doesn’t do the same thing.
    First, I did use Ravenol in the T-case. The quart bottles come with a pour tube built into them. On my first bottle the tube broke free and I thought it slipped into the T-case. I lost a 1/4 quart on the ground and was freaking. Luckily it broke and went back into the bottle. Man, what a relief. It seems like a cool design but it’s not all that great for controlling into the fill hole. I highly suggest pouring into an empty diff quart bottle and pumping it in. Second, I hate the design of the 3/8 plugs they use on the T-case. I hate something I can’t torque. I suggest taking note of the threads before removal and going back to the same spot. The rest of the job was pretty straight forward. I also dumped the oil and installed a Fumoto.
    WAtundra4x4 and 14burrito like this.
  12. Aug 25, 2019 at 5:13 PM
    #72
    fundratss
    fundratss Send it!
    Joe
    Colorado Springs
    2016 Magnetic Grey Tundra TSS
    Toytec 2.5” Coilover boss suspension 3/1 lift w/camburg uca’s Morimoto xb headlights Morimoto fog Rough country grill 2 RC blacked light bars Volant air intake system Rear air bags (for towing) I’m sure there’s more but I’m lazy
    BC748E49-9D29-4D1A-93F3-BBFA7F13EBB7.jpg 87625BA7-24EB-41F5-AE1E-7DA647737C9E.jpg
    Here’s what’s in Toyota transfer case gear oil lf75w.
    Tsb states to put it in there. If top of the line amsoil doesn’t even make it then I’d just stick with this stuff. I use everything amsoil and ima slap Toyota oem t-case fluid back in at correct intervals. Buying it with only 1.5 quart full spec is a lot cheaper than problems from buying $50 in fluid vs $100 in fluid. Too bad amsoil or anyone else doesn’t show an “equivalent” t-case 75w.
    But hey, as a dealer tech and now service manager. I’ve seen ppl cheap out on a lot of stuff and in the end. It’s your vehicle not mine lol.
    Bigbird57 likes this.
  13. Aug 25, 2019 at 6:45 PM
    #73
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    Not sure what your saying? I think what your saying is to buy the OEM 75W? But, many on here have confirmed that their dealer sticks in 75-90 because the OEM is to expensive. Pretty F-ing shady but I really wouldn’t expect any less from a dealer. I at least ran the “equivalent” viscosity.:thumbsup:
  14. Aug 25, 2019 at 6:48 PM
    #74
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    BTW, the Ravenol 75W has Toyota’s OEM spec code on the bottle.
    fundratss, B737, 15whtrd and 2 others like this.
  15. Aug 25, 2019 at 7:15 PM
    #75
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    It has Toyota’s part number on the bottle. Now, that may not mean much but to me it means “equivalent”. The word Toyota has put in their service manual. I just got done reading a thread where many owners were saying the dealer looked at them like they were nuts with the 75W viscosity and told them they just run gear oil they get in a 55 gallon drum. Sounds about right.
    I feel very confident that Ravenol is a solid replacement fluid in the T case.
  16. Aug 26, 2019 at 5:32 AM
    #76
    W///
    W/// New Member
    Greenville, SC
    2016 Barcelona Red Platinum
    Doing all the fluids during Labor day weekend. My truck is at 74k miles but I don't have records whether these were changed or not, just regular engine oil.
    Going with Mobil1 and OEM filter, Royal Purple for diffs, Ravenol for T-case and OEM ATF (just going to do flush and fill). Planning on keeping this truck for a while
    BTBAKER and Watt maker like this.
  17. Aug 26, 2019 at 11:32 AM
    #77
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Just drain the ATF and refill, do not flush...or perhaps you meant refill...
  18. Aug 26, 2019 at 11:38 AM
    #78
    W///
    W/// New Member
    Greenville, SC
    Correct, that's what I meant
    HulkSmurf14[QUOTED] likes this.
  19. Aug 27, 2019 at 11:28 AM
    #79
    megatundavid
    megatundavid New Member
    David
    Norcal
    2014 Tundra crewmax 4x4
    Magnusen supercharger and Bullydog tuner TRD PRO Grille with ENVE Grill insert. ICI Magnum front bumper with LED driving lights Radium Engineering dual catch cans 2018 factory LED headlights Firestone airbags with in cab controller Banks catback exhaust system Baer Brakes front drilled and slotted brake rotors All seats have had seat covers most of their lives Ready Lift 6" suspension lift 18" KMC wheels with 35" Cooper STT PRO's AMP Research power side steps Spray in bed liner IPT modified valve body for transmission Factory tow mirrors Light tint on front windows Hypertech speedometer calibrator. Husky floor liners.
    Ive serviced my 14 with 75-90 with no issues from it
  20. Aug 28, 2019 at 9:49 AM
    #80
    Vector W8
    Vector W8 Old guy with a lot of expensive habits.
    FFV, TRD Supercharger, Bullydog FFV Tune, 2014 Fit Kit, TRD Dual Exhaust, Sequoia Front Sway Bar, TRD Rear Sway Bar, TRD Skid Plate, TRD Pro Grill, 040 White Mirror Covers, 040 White Door Handles, Ready Lift 3"/2", Anzo 3rd Brake Light, Winjet LED Tail Lights, LED Fog Lights, LED Rock Lights, Axle Vent Mod, SDHQ Hidden Winch Mount, 12,000lb Winch. Storm Trooper Shift Knob. BMF BATL Wheels.
    I only use the Toyota 75W oil. It prevents the solenoid from sticking and not allowing the T-case to disengage when you select 2wd.
    Bigbird57 and Wynnded like this.
  21. Sep 7, 2019 at 6:10 PM
    #81
    Bigbird57
    Just bought 2 qts of the Toyota transfer fluid LF 75W. $129 ttl.
    Too nervous to try anything different.
    Amsoil and Redline have not cloned this seemingly magical elixir.
    Rider0120 likes this.
  22. Sep 10, 2019 at 6:50 AM
    #82
    Bigbird57
    I called the Amsoil tech line to see if they plan to reverse engineer the Toyota Transfer Case Gear Oil 75W LF. Sadly there are not enough Tundra owners to be worth their time.
    This is not the same company since Big Al stepped down. The children are in charge now.
    jtwags and (deleted member) like this.
  23. Nov 10, 2019 at 1:55 PM
    #83
    acmesupply
    After all voa's and actual tests of time, clunkiness, and return from 4lo to 2wd plus cost and availability, I'm sticking to Redline 70/75w as i mentioned in the previous posts. Its definitely more fortified than Ravenol. But I like synthetic oils. Stock LF was like a totally fortified smelly mineral oil. Would love to use it all the time but for much shorter drain intervals. So the best fortified synthetic I can find is Redline.
  24. Nov 10, 2019 at 7:05 PM
    #84
    jtwags
    jtwags Concrete jungle
    League City, TX
    2018 Tundra CM
    Undercover Elite LX, Xact Contour
    I hear that. I gave up my old amsoil dealer membership not too long ago as it seems to be headed a different direction, bean counter decision making vs engineering driven. Too bad as i bet the chemists their would love to figure out what makes the toyota 75w work so well in the Tundra. Heck it may prove to work great in all the Ford borg and warner transfer cases out there too, which ironically had an oil type fiasco and now have a special branded Transfer Case oil that must be used (pretty sure it is just old mercon v).
  25. Nov 11, 2019 at 9:21 AM
    #85
    Highsierraguy
    Highsierraguy New Member
    Nor Cal
    So I just want to make sure that the 75w is also recommended for the 4.6 liter? And that it's the same transfer case? I called my local Toyota parts center and he said 75-90 is what they use for the transfer case.
  26. Nov 12, 2019 at 9:08 PM
    #86
    MNBighead
    MNBighead New Member
    2015 CREWMAX TRD OFF ROAD
    I have a 2015, 60K miles, and I've been using Ravenol 75W. I live in MN and the truck is in 4x4 often, sometimes days at a time. No issues. Smooth engagements. Fluid always looks good when changed out. I'm an engineer and researched this topic both on the forum and on my own.
    COTundra23, Finch and 15whtrd like this.
  27. Nov 13, 2019 at 12:26 AM
    #87
    Bigbird57
    I agree wholeheartedly! Not the same company. They just blew me off. I was a loyal user for years. I still use their tranny fluid and grease. I like Pennzoil Ultra when I can find it. It is scarce as Unicorn tears.
    jtwags[QUOTED] likes this.
  28. Apr 19, 2020 at 9:23 PM
    #88
    Paxrom
    Paxrom New Member
    2020 Tundra SR5
    Leds
  29. May 29, 2020 at 3:59 PM
    #89
    DaCro210
    DaCro210 New Member
    2018 4x4 CM Cement
    I see some of y’all using the ravenol 75w.. but I only see the ravenol 75w MTF-3.. is that what y’all are using? I see the last couple numbers are different. That’s on the bottle of ravenol.. This is the part number for the 75w Toyota oil 08885-81080. below are the numbers ravenol replaces. And also found this from RedLine also.. seems pretty good.
    1. TOYOTA 08885-81001
    2. TOYOTA 08885-81081
    3. these two are what comes on ravenol replaces
    From RedLine oils below
    MT-LV 70W/75W GL-4 GEAR OIL
    • Popular in Toyota/Lexus LF 75W, BMW X-Drive and other transfer cases transfer cases calling for Shell TF0870
    • Recommended for Mercedes 235.10, Dodge/Fiat BOT 350 M3, GM BOT 303 mod, Toyota/Scion Manual Transmissions Gear Oil LV, VW/Audi and BOT270A Graziano Transaxle for Aston Martin, Audi & Lamborghini.
    • Offers quicker shifts, a perfect synchronizer coefficient of friction
    • Safe for brass synchros, as it lacks the reactive sulfurs found in most GL-5 oils that cause damage
    • High performance gear protection and longer synchro life
    • Eliminates notchy shifting, even when cold
    • Low fluid friction to improve power transfer
    • Satisfies the gear oil viscosity requirements of 70W & 75W
    Recommended for GL-1, GL-3 and GL-4 applications as well as where most special synchromesh fluids are specifies
    sorry to hear a dead horse but currently at 30k miles and gonna do the fluid changes this week. ​
  30. May 29, 2020 at 4:15 PM
    #90
    Bigbird57
    Not sure about the ravenol ,seems sketchy but Redline makes a fine product
