Transferring TPMS sensor to new wheel?
Discussion in 'Wheels & Tires' started by idahowiseguy, Oct 9, 2018.
  1. Dec 17, 2018 at 1:13 PM
    danz75
    danz75 New Member
    Everett, WA
    18' Cement SR5
    OEM LED headlights, Rigid SAE foglights, Go Rhino RB10 running boards, ARE Classic CX
    I would call discount tire or any other tire shop to see if their tool can read the IDs off the sensors. if not, you'll have to break the bead to get the IDs that are printed on the sensor.
  2. Dec 17, 2018 at 1:57 PM
    tundracrazy
    tundracrazy New Member
    Wisconsin
    I was told by some, that a scan tool can be used to program them without the serial numbers.
  3. Dec 17, 2018 at 1:59 PM
    tundracrazy
    Wisconsin
    I was also told that there is some type of TPMS wireless device that could obtain the serial numbers without breaking the bead.
    JohnLakeman likes this.
  4. Dec 18, 2018 at 6:20 PM
    tundracrazy
    Wisconsin
    Well there is a wireless tool to capture the sensor info to download. Unfortunately, it didn't work on my 19.
  5. Dec 18, 2018 at 6:22 PM
    tundracrazy
    Wisconsin
    Shop stated truck could read the new sensors and provided a procedure using reset button. That didn't work either.
  6. Dec 19, 2018 at 6:41 AM
    tundracrazy
    Wisconsin
    Correction; after a few attempts and some time, the truck has learned the new sensors. No serial numbers or special tools needed.
    TOYOTRD8 likes this.
  7. Dec 19, 2018 at 12:09 PM
    tundracrazy
    Wisconsin
    Here is procedure:
    1. Press TPMS reset button 3 times. Warning light will blink 3 times. When relearning, light will flash for about 1 minute.
    2. Drive at 25 mph or more for 10 to 30 minutes. Relearn is complete when light goes off and pressures are displayed.
  8. Dec 20, 2018 at 5:17 PM
    TOYOTRD8
    TOYOTRD8 New Member
    Utah
    2017 TUNDRA SR5 TRD OFF-ROAD
    TRD Pro Grilled, Color match bumper end caps, OEM LED headlights, MX4 Bed cover, GoRhino RB20,TRS LED Fog Lights, Camburg leveling kits, SR8 wheels, STT Pro tires 295/70/18 and heritage decal.
    @tundracrazy i bought a new set of tpms for my new wheels from Toyota. Does it still work with 4 new and one old one in the spare tire? Discount tires already installed them on my new wheels but I haven’t put them on my truck yet. But I’m hoping it works after I get my leveling kit installed. Thanks in advance!
  9. Dec 20, 2018 at 5:53 PM
    tundracrazy
    Wisconsin
    The spare doesn't have TPMS.
  10. Dec 20, 2018 at 5:59 PM
    TOYOTRD8
    TOYOTRD8 New Member
    Utah
    I guess I should be fine with 4? As long as they resets it should work?
  11. Mar 24, 2019 at 5:20 PM
    robbb38
    robbb38 New Member
    Rob
    18 limited crewmax
  12. Mar 25, 2019 at 9:40 AM
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
    What wheels are those? Does it have two valve stem holes? They should sit directly on the lip and point outwards like this:
    Some wheels will have two valve stem holes. One for the sensor, and one for an additional valve stem.
  13. Mar 25, 2019 at 9:45 AM
    Jerry311SD
    Jerry311SD New Member
    Jerry
    Ramona San Diego CA
    05 Tundra
    I put my TPMS in My Methods. they work just fine
  14. Mar 25, 2019 at 10:34 AM
    robbb38
    robbb38 New Member
    Rob
    18 limited crewmax
    Mine are the icon rebounds. I’ll take another look later when I’m home.
    Roman[QUOTED] likes this.
  15. Mar 25, 2019 at 5:33 PM
    robbb38
    robbb38 New Member
    Rob
    18 limited crewmax
    Just checked again and these aren’t sitting flush. How is Toyota of Cool Springs return policy? :(
  16. Mar 26, 2019 at 9:57 AM
    Roman
    Roman
    Franklin, TN
    That's weird. That would be the first time I've seen an aftermarket wheel that did not accept factory sensors.
    If you do need to return them, just make sure they are in the original packaging and we'll shoot you a refund once they make it back here.
  17. May 22, 2019 at 12:05 AM
    SL2019
    SL2019 New Member
    2017 Black tundra dclb
  18. May 22, 2019 at 9:04 AM
    Roman
    Roman
    Franklin, TN
    No, you would need the aluminum wheel TPMS from a 2014-17 model. The ones you quoted in my previous post is what you'll need.
  19. May 22, 2019 at 1:54 PM
    #49
    SL2019
    SL2019 New Member
    Thank you Roman!
    Once I get the sensors installed, will the ecu automatically recognize them? Or will I need to reset using tech stream?
  20. Jun 3, 2019 at 7:29 AM
    #50
    americanaaron
    americanaaron USA
    North Carolina
    2019 Tundra
    I purchased aftermarket TPMS on Amazon and installed the on new wheels. After tire shop mounted new treads on wheels, I was able to register the new sensors via tpms instructions in the manual.
  21. Jun 3, 2019 at 9:47 AM
    #51
    TrooperDC4x4
    TrooperDC4x4 New Member
    Nor Cal
    2017 BBP Double Cab 5.7L TRD 4X4 OR
    Bilstein 5100 2.5", 1.5"
    Can you link the ones you used?
  22. Jun 3, 2019 at 10:50 AM
    #52
    americanaaron
    americanaaron USA
    North Carolina
    2019 Tundra
  23. Jun 11, 2019 at 2:14 PM
    #53
    ktmhauler
    ktmhauler New Member
    GA
    2019 SR5 Dbl 4wd 5.7
    Anyone know if the sensors from a 2019 SR5 with the steel wheels will work with TRD Sport (SR5 with TRD off road package) wheels?
    Picked up a set of those wheels on ebay that are supposed to be off a 2019, but after learning I need new lug nuts, now wondering about the sensors. Wish I just had bought new aftermarket wheels at this point
    #53
  24. Jun 11, 2019 at 2:36 PM
    #54
    TOYOTRD8
    TOYOTRD8 New Member
    Utah
    From what I know. They will not fit perfectly due to the angle of tpms sensor.
    @Roman he can confirm. Thanks!
    #54
    Roman likes this.
  25. Jun 11, 2019 at 2:39 PM
    #55
    Roman
    Roman
    Franklin, TN
    That is correct. TPMS from a steel wheel will not work on the aluminum wheels.
  26. Jul 11, 2020 at 10:05 AM
    #56
    Yoyo
    Yoyo New Member
    VA
    2020 Tundra TRD SR5 CrewMax
    Fuel Assault Gloss Black, 20x9, +20 offset, Toyo Proxes ST, OEM Black Running Boards, Black Fender Flares, Pedal Commander.
    Well, sorry for reviving this post but I'm going through a similar but weird dilemma.
    I have a 2020 Tundra TRD Sport. I recently bought and installed a full set of wheels and tires including new TPMS sensors. After swapping the OEM with the next set, I proceeded per the instructions given (also in the owners manual) but it does not seem to work.
    So, I first took it to a local shop to make sure the new TPMS sensors were working. They told me that they are able to read the new TPMS sensors and load to the truck but for some reason, the truck is still looking for the previous TPMS codes which (according to them) cannot be erased (don't even know if that makes sense).
    Then, I followed the instructions in the owner's manual for reset (press the reset button for three seconds while in "ON"....the light will blink....and ...so...on) and also tried the relearn procedure (press the reset button three times..... and...so...on) but neither seem to be working.
    So, I am wondering if there is a way to reset and/or erase all TPMS codes and start from scratch? OR, should I just take it to the dealership?:confused::confused::confused:
  27. Jul 11, 2020 at 10:27 AM
    #57
    thomasbus337
    thomasbus337 New Member
    2020 TRD Sport DC
    Do you happen to know the part number of the new sensors you installed? There are three different part numbers for the 20 Tundra
  28. Jul 11, 2020 at 11:17 AM
    #58
    Uhhhh....
    Uhhhh.... New Member
    Dave
    2016 Silver Limited DC
    7” BDS, 37s
    The instructions in the owners manual is only for resetting the air pressure threshold for the sensors. It is not for programming new sensors into the truck. In order to do that, you’ll have to take it to a dealer, or an auto shop. The one you already took it to are a bunch of morons, because, yes, you can erase the old sensors in the truck.
    If you wanted to do it yourself, you’ll need a programming tool. I bought an Autel TS508 off of eBay and it worked great for me. (Some of the Autel models only read sensor data and don’t program new sensors into vehicles - make sure you get the 508 to do both. And make sure it’ll program a 2020, not sure about that.) It programmed the new sensor I put in my full size spare tire. Pricey, but I do a five-wheel rotation and I don’t keep the spare in the bed. So it saves me in the long run from spending $100 or so to get the truck reprogrammed for the different sensors every time I rotate my tires.
    If this is just a one-and-done sensor reprogram for you, and you won’t need to do it regularly like me, you’re probably better off taking it to a shop and having them program it for you. It’ll be cheaper than the ~$275 tool. Call ahead first to make sure they’re not morons. Lol
    #58
    ElNopal likes this.
  29. Jul 11, 2020 at 11:27 AM
    #59
    Yoyo
    Yoyo New Member
    VA
    Well, the guy I bought them from the internet sent me this part number (ALG-030187) however, don't know if that is an internal part number from his shop or a public one as I cannot find that exact part on the internet.
  30. Jul 11, 2020 at 11:38 AM
    #60
    Yoyo
    Yoyo New Member
    VA
    :thumbsup::thumbsup::thumbsup: I honestly thought about that. How was it even possible that a shop that is supposed to work with Tires and wheels on daily basis cannot do that? :)monocle:)....
    I was also leaning towards keeping both sets and swap them during winter/summer so, I guess I'll consider getting that tool. What you are saying makes total sense...!!!:thumbsup::thumbsup:
    Let me search in Autel website to see if the tool works on the 2020 model...
    Below are some before and after pictures...!!!
    #60
