Transferring TPMS sensor to new wheel?
Discussion in 'Wheels & Tires' started by idahowiseguy, Oct 9, 2018.
  1. Jul 12, 2020 at 12:42 PM
    #91
    thomasbus337
    thomasbus337 New Member
    2020 TRD Sport DC
    Glad you got it all squared away
    rebmo and Yoyo like this.
  2. Jul 12, 2020 at 1:33 PM
    #92
    rebmo
    Rural SE Wisconsin
    2020 CM LImited 5.7L V8 4WD
    Thomasbus all the credit to you on this solution being the first to get the absolute right P/N for the sensors. I hear you about great not having to hookup techstream To swap tires. This should be advertised by Toyota IMO as a great feature. Not sure how the other 1/2 ton pickup mfgs accomplish this but it can’t get much easier to swap wheel sets on new tundras.
    Yoyo likes this.
  3. Jul 12, 2020 at 2:01 PM
    #93
    Yoyo
    Yoyo New Member
    VA
    2020 Tundra TRD SR5 CrewMax
    Fuel Assault Gloss Black, 20x9, +20 offset, Toyo Proxes ST, OEM Black Running Boards, Black Fender Flares, Pedal Commander.
    SORRY, SORRY, SORRY about that...!! my mistake... Just corrected. Credit to Thomasbus337 ...!!!
    Still, Thanks so much everyone for pointing me in the right direction...!!!
  4. Jul 12, 2020 at 2:11 PM
    #94
    rebmo
    Rural SE Wisconsin
    NP I was just passing the credit along. we all try to help each other here.
    Yoyo[QUOTED] likes this.
  5. Jul 12, 2020 at 2:13 PM
    #95
    thomasbus337
    2020 TRD Sport DC
    Well, I can't take all the credit. I did some previous searching and a member named Montana Mike made the discovery last December. I did however take notice that it was the same sensor I had installed in my 2019 Camry last winter for my snow tires. I looked back through my pics and noted the PMV-C015 code.
    I replaced the stock steel wheels on my 2019 GMC Sierra 2500 with OEM take off wheels that already had the stock sensors in them. To program those to the truck I had to access a few on screen menus then place a $20 TPMS trigger tool at each corner and push a button, just as easy as the newer Tundra
    Yoyo likes this.
  6. Jul 12, 2020 at 2:13 PM
    #96
    Yoyo
    Yoyo New Member
    VA
    :cheers:
  7. Jul 16, 2020 at 12:24 PM
    #97
    Roy17185
    Roy17185 New Member
    Utah
    2020 MGM Tundra TRD Off Road
    @thomasbus337 , @rebmo and @Yoyo THANK YOU!! I have been looking EVERYWHERE for the correct TPMS part number for my 2020 Tundra. Thanks to the info you guys posted I have found it! I'll finally be able to get my new Methods installed! Thanks again guys!
    glowblue, rebmo and Yoyo like this.
  8. Sep 25, 2020 at 7:36 PM
    #98
    so_juanderful
    so_juanderful New Member
    Honolulu, HI
    2017 Cement Tundra TRD Pro
    I have the same problem, what was your solution to this? I got the 20 degree one that everybody said was for alloy wheels. Doesn’t fit flush with my Method wheels.
  9. Sep 26, 2020 at 5:28 AM
    #99
    Yoyo
    Yoyo New Member
    VA
    Even though I was not the one who did the install, I believe the second picture is the correct one.
  10. Sep 26, 2020 at 9:30 AM
    #100
    so_juanderful
    Honolulu, HI
    This is how it’s sits with the 20 degree sensor.
    doesn’t look right
  11. Sep 26, 2020 at 9:52 AM
    #101
    I'm getting ready to go through the same thing with my 2020. I am moving my wheel package over from my 2013 after the lift is done and the sensors in them won't work on the 2020. They are a few years old. Where did you end up purchasing yours from? The 0C091 that you referenced is what I need as mine in non-push start.
  12. Sep 28, 2020 at 12:10 PM
    #102
    Roy17185
    Roy17185 New Member
    Utah
    I installed Method wheels on my Tundra back in July and I went with TPMS PN:42607-06030 and they worked perfectly fine with my wheels.
    Here's a pic of what mine look like. I've read that it's important that they say PMV-C015 on them.
    Tundra234 likes this.
  13. Sep 30, 2020 at 7:52 PM
    #103
    so_juanderful
    Honolulu, HI
    Ended up getting the 40 degree version and it sits a lot better
  14. Oct 10, 2020 at 6:04 PM
    #104
    rebmo
    Rural SE Wisconsin
    Installed my 2012 TRD aluminum wheels on my 2020 Limited today for winter with the PMV-C015 TPMS sensors. Pushed the TPMS reset button 3X to register the 4 wheels. It worked great. Had to drive around for about 10 minutes before the PSI showed for the new wheels/sensors. It couldn't be easier now swapping wheels for summer/winter. No more having to use techstream to register TPMS IDs. Confirmed it works.
  15. May 21, 2021 at 12:02 PM
    #105
    TeamHall
    TeamHall New Member
    Sam
    Cincinnati, OH
    2016 Toyota Sequoia SR5 PRO
    Blacked out grill and wheels 2nd row bench seat middle seat removed for captains chairs Remote start
    @Roman will my TPMS assembly off of my 2016 Sequoia premium aluminum wheels work with the 2019 TUndra TRD pro BBS Forged wheels or do I need to buy a new assembly? Thanks in advance!
  16. May 25, 2021 at 11:49 PM
    #106
    Noeyes
    Noeyes New Member
    Shawn
    2021 tundra sr5
    Hello Roman. New tundra owner and new to the site. I've been sifting through these threads about tpms and I'm lost. I have a 2021 sr5 with steel 18 inch wheels. My friend has a like new set of 20 inch alloys of his platinum that I can have but I have to buy new sensors for them before I order tires. Would you happen to know which particular ones I would need to work? I have the keyed ignition and not push button start if it matters.
  17. Sep 5, 2021 at 9:10 AM
    #107
    Tallyn91
    Tallyn91 New Member
    2014 Super White Tundra SR
    Did you ever get an answer on this? Just got a good deal on a set of bbs pro wheels and wondering the same thing on my 14 sr with aluminum wheels
  18. Oct 19, 2021 at 8:22 PM
    #108
    FitsofRage88
    FitsofRage88 real eyes realize real lies.
    Hill Country, Texas
    2019 FFV CM (3URFBE) 2Gen
    Blackhawk(0CU00) Working on it!
    What would the part number be for a 40 degree tpms sensor per a 2019 toyota tundra..
  19. Feb 16, 2022 at 6:02 PM
    #109
    BettyWhite20
    BettyWhite20 New Member
    2020 DC SR5 4X4
    I'm having problems getting mine to read. I have a 2020 Double Cab SR5 4X4 that originally had 18" steel wheels and I have aftermarket 20" aluminum wheels now with part #42607-0C091. Discount Tire, Toyota Dealership, Tire Engineers, and a local Tire Shop have tried getting them to work. Still shows "Tire Pressure Recalibrating Please Wait until Complete"
    Toyota Brand Advocate tells me I have the right part #. Spark Parts say I need the one ending with 06030. Another Toyota Dealership tells me I need 0C101.
    Sparks says 0C091 is for '18 - '19 and the tire shops have put in 2019 for their scanners to pick them up, so maybe I do need the 06030??? But I thought those were for higher trim levels eith smart key & Push to Start???
