TRD Pro Wheel Well Camo Trim
Discussion in '3rd Gen Tundras (2022+)' started by Buellride, Aug 9, 2022.
  1. Nov 28, 2023 at 4:09 PM
    #571
    Driverwanted
    Driverwanted New Member
    2025 Limited TRD-Off Road Long Box
    Thanks for the responses , it looks like it’s t taps for the front :) really appreciate the detailed response ty.
    Savagesawyer and ryanwgregg like this.
  2. Dec 9, 2023 at 10:32 AM
    #572
    brutalitybob
    brutalitybob New Member
    Where you able to remedy this with a heat gun? I have the same issue after installing a CBI stealth winch bumper...I cant tell if i bent the flares out of alignment or the ends of the front bumper need to be pulled back out? I noticed there may be a way to adjust this with the small brackets on the upper sides by the headlights. Ive pulled my bumper on and off about 5 times now to fix and everytime i cringe thinking im going to make it worse as the plastic is never the same each time...looking for a solution before i continue to mess with it more
  3. Dec 9, 2023 at 1:05 PM
    #573
    WITCHBANE
    WITCHBANE New Member
    Joseph
    2024 Tundra Platinum TRD Off Road
    The picture showing the TRD Pro flares doesn't appear to have the weather stripping, which goes between the flare and the truck body. It may just be the picture, but that would fill the gap if it is indeed missing.
  4. Dec 9, 2023 at 1:08 PM
    #574
    WITCHBANE
    Joseph
    Not sore then, sorry.
    ryanwgregg likes this.
  5. Dec 10, 2023 at 12:35 PM
    #575
    G-Eazy
    G-Eazy New Member
    Derek
    2022 Black Tundra SR5 TRD Sport
    Decked Drawer System Wescott Designs 3/1 preload collar lift kit Method MR706 18x9” +35mm offset Toyo Open Country ATIII 35x12.5x18
    I actually ended up taking the pro flares off and putting the stock flares back on. I don’t have too much poke with +35 offset. The paint match stock flares look much more streamlined on my truck in my opinion. So, while the gap did bother me, didn’t like the camo as much as I had hoped. Win some, lose some.
  6. Dec 13, 2023 at 7:29 AM
    #576
    WITCHBANE
    Joseph
    So to revisit this darn wiring of the flares, ‍. I'm wanting to use them with the DRLs and attempted to utilize trailer hitch wiring harness on my Diode Dynamics Hitch Light. Based on the diagram, "Brown" would be the DRLs and the "White" would be the ground. When connected for testing, I got flickering on the fender flare marker light, not solid operating as intended.
    I'm also wanting to wire all fender, tailgate, grill, and fender the marker lights in one with disconnects for each section. This assuming the trailer wiring works and should support all the small LED lighting.
  7. Dec 21, 2023 at 6:52 PM
    #577
    Taikowaza
    Taikowaza New Member
  8. Dec 23, 2023 at 5:16 AM
    #578
    Rafael707B
    Rafael707B New Member
    Rafael
    2023 Toyota Tundra Platinum
    Stock
    This looks so good. Congratulations how did you end up wiring them. I noticed you have premium headlights. Thanks for any advice I have a platinum and the fender flairs just sitting in my garage.
    Taikowaza[QUOTED] likes this.
  9. Dec 23, 2023 at 7:32 AM
    #579
    Ipaddick
    Ipaddick New Member
    Canada
    Platinum hybrid w/advanced package
    He used an add a fuse into the fuse box. Look at his fifth picture.
    Taikowaza likes this.
  10. Dec 27, 2023 at 9:09 PM
    #580
    dOnkei
    dOnkei New Member
    2023 SR5 Off Road
    sourced the connectors from Japan and wired them up, will be selling em on eBay if anyone interested
    ryanwgregg and Goobax like this.
  11. Dec 27, 2023 at 9:39 PM
    #581
    Goobax
    Goobax New Member
    2024 SR5 4x4 Tundra
    Link?
  12. Dec 28, 2023 at 11:17 AM
    #582
    dOnkei
    dOnkei New Member
    2023 SR5 Off Road
  13. Dec 28, 2023 at 12:26 PM
    #583
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    These might be pricey but they do mean much less dicking around with the seal and waterproofing/heat shrink which the Rave system is all about.
    I would get them if I hadn’t already bought the Rave kit.
  14. Dec 28, 2023 at 2:22 PM
    #584
    Taikowaza
    Thank you! I used the Trailhunters kit. I agree with Ryan that it does a great job. I used this link https://thetrailhunters.com/shop/exterior/2022-tundra-trd-pro-fender-flare-marker-light-plugs-kit/ make sure that you select the complete "plugs and quick disconnect connectors" option.
    I am thrilled with the lighting now working it looks amazing and comes on when ignition is on. As Ipaddick mentioned I used an add a fuse in the location recommended by Trailhunter earlier in this thread. I encourage anyone with the flares that are not yet wired to go for it. The marker lights just add a ton to our vehicles IMHO, the effect is outstanding.
    [​IMG] [​IMG]
  15. Dec 28, 2023 at 3:22 PM
    #585
    Rafael707B
    Rafael
    Stock
    awesome thank you for helping out. Do they turn on with lights being turned on or just ignition and always stay on?
  16. Dec 28, 2023 at 3:30 PM
    #586
    GilFavor
    GilFavor New Member
    2023 silver tundra 1794
    Do these plug into the fuse box or do you need to do the add a fuse thing?
  17. Dec 28, 2023 at 3:59 PM
    #587
    dOnkei
    dOnkei New Member
    2023 SR5 Off Road
    Took the idea from the TTap style and made a jumper plug and play harness, I have the poverty model NON LED headlighhts. If I want to bring it back to stock I just unplug and back to normal. Also in Hawaii, corrosion is no joke when you I live with on shore air daily reason I didn't TTap
  18. Dec 28, 2023 at 5:55 PM
    #588
    Taikowaza
    The fuse location selected above (see previous fuse location attachment) functions with ignition only.
    Turning on lights, or fog lights does not activate the marker lights if the ignition is off. While the ignition is running, even if turning off lights and/or fog lights, the marker lights stay on.
    I consider the marker lights wired in this way as ignition lights. While driving with them lit, the overall effect in tandem with fog lights and headlights together is impressive.
    This also gives other vehicles a better sense of the width of the truck especially when driving at night on the highway for example. They are awesome. I am very happy with this mod.
  19. Dec 28, 2023 at 9:11 PM
    #589
    GilFavor
    GilFavor New Member
    Sorry for being so dense, electrical is not my strong suit…so with the kit your selling on eBay you hard wire to the fender lights and then have the connector to plug into…where?
  20. Dec 29, 2023 at 3:38 AM
    #590
    dOnkei
    dOnkei New Member
    2023 SR5 Off Road
    just a DIY kit with the OEM connectors vs custom connectors out there, but then run wire TTap into blinkers or wire your own power like others did that's all
  21. Dec 30, 2023 at 9:53 AM
    #591
    shocker88
    shocker88 New Member
    2024 Tundra Platinum Hybrid TRD off road+ TRD 3" Lift (MGM)
    amp research power running boards, method wheels 18x9, toyota dashcam, TRD skid plate, vent shades, bed step, toyota swing storage boxes rear, voodoo blue tundra inserts front and tailgate; Future mods: TRD PRO fender flares, bumper cover, ditch lights, TRD pro Grill, and tail gate lights, light bar upper and lower, Covert front bumper, retrax cover
    man wish I had seen this before buying the rave off road kit.
    I used the 7pin add a 4 pin y adapter behind the bumper. Works great and with parking light they come on. I did add a fuse link to the power for all of them. Works great.
    Taikowaza[QUOTED] and ryanwgregg like this.
  22. Dec 31, 2023 at 5:34 AM
    #592
    Hunter1699
    Hunter1699 New Member
    So I guess I am little confused. Going to add the flares soon and got the trailhunters connectors already. Thought, through reading here, that power could be obtained either from a trailer adapter from a 4pin connector or from t-tap to the front fuse box. Not both-what am I missing? Sorry being dense
  23. Dec 31, 2023 at 3:57 PM
    #593
    shocker88
    Depends on how you want them to come on? When truck is running always? Or with just when lights are on, even DRLs can be cut off (on my platinum).
    connect to fuse block I only found one or two spots in my hybrid that were on when truck is. So I went with idea found on here for tap into the tow hitch 7pin connector, but added a waterproof fuse holder and ran 16-18ga wire along frame front to rear both sides and tied all in, but I used water tight plugs also from Amazon to enable unplug for replacement or removal for wrapping or work?
    brown and white wires I think can’t remember. But mine come on with parking lights using this method and no issues so far.
    WITCHBANE, ryanwgregg and Hunter1699 like this.
  24. Dec 31, 2023 at 5:44 PM
    #594
    Hunter1699
    Tracking all. Thanks for the clarification and I am going to do what you described above. Thought I was missing something and wan5ed to be sure.
  25. Jan 1, 2024 at 10:58 AM
    #595
    WITCHBANE
    Joseph
    I did this method, the trailer wiring harness and used the flat 4-pin for the DRL option. No issues so far and loving it.
    Taikowaza and ryanwgregg like this.
  26. Jan 1, 2024 at 1:10 PM
    #596
    Taikowaza
    Are you running an RSI Smartcap?
  27. Jan 1, 2024 at 9:39 PM
    #597
    WITCHBANE
    Joseph
    No, @Taikowaza that is the Kuat Ibex bed rack system. It's pretty awesome!
    To add how I wired my lights, here's my best description on the process for anyone reading this.
    I'll get some pictures and upload them as soon as I can too. Basically I had already bought the Rave connections for the front, rear, and all fenders. I then heat shrunk the connections onto all the lights. I then used and heat shrunk a Deutsch DT 2-Pin LED male pigtail on each connection for the front. I then used a 4 female into 1 male Deutsch DT 2-Pin harness. Once all the lights were connected to the harness, I ran single female to male Deutsch DT 2-Pin wire harness to the rear.
    With the rear section I utilized the CURT 55384 harness and 58030 4-Pin harness. I then connected the CURT 55384 harness and connected the CURT 58030 4-pin to the CURT 55384 harness. I used only the brown (DRL) and white (ground) wires on the CURT 58030 4-Pin harness and heat shrunk a male Deutsch DT 2-Pin connection to them. I then heat shrunk a male Deutsch DT 2-Pin pigtail on the rear tailgate marker lights and both fender flares. I used a 4 female into 1 male Deutsch DT 2-pin harness to bring it all together. Utilized some handy zip ties and electrical tape to ensure all the connections were good to go. Finally, I used flex tubing to protect it all and double checked my wiring to ensure the wires were connected and safe.
  28. Jan 4, 2024 at 8:55 AM
    #598
    Meangreen
    Meangreen New Member
    JC
    2017 1794 Sunset Bronze
    Did you ever end up painting the flares in the windchill pearl! I saw the mesquite and considered ordering for my wcp 1794.
  29. Jan 4, 2024 at 8:57 AM
    #599
    Meangreen
    JC
    I apologize in advance for my ignorance, what process was used to still show the cammo pattern? I’m thinking on doing this for my WCP.
  30. Jan 4, 2024 at 11:34 AM
    #600
    Bailey1794
    Bailey1794 New Member
    Houston
    2023 Smoked Mesquite Hybrid 1794 Tundra
    Diode Dynamics Ambassador & Talons Garage Affiliate (See Below for discounts) Use code Bailey for Diode Dynamic free shipping Current Build & Pics Instagram.com/Bailey1794 Discounts & Affiliate links below https://linktr.ee/bailey_1794?fbclid=PAZXh0bgNhZW0CMTEAAaYH-pwfNz76E_oAQekLat2ZdcSY0VrV7a8O3_UxaU15mlBifUGV3lGaU4s_aem_Aamyw5XakyTlp6h_WyGSA8wBSO-cFzK1Z0t3EQBBaXEgDCnQI49fSwGFqQNWOCNd5OxDNGhVrMYRcfs_DEuuCXSy
    Just paint & clear coat no special process.
    Meangreen[QUOTED] and ryanwgregg like this.
