TRD Pro Wheel Well Camo Trim
Discussion in '3rd Gen Tundras (2022+)' started by Buellride, Aug 9, 2022.
  1. Nov 3, 2022 at 1:11 PM
    #151
    Buellride
    Buellride [OP] New Member
    Olympia
    THE BOULDER
    BD Lights, Banks PM, Fuel Vector 18" on 295/70R18 Cooper AT3 XLTs, Black-Out badges, TRD front grill
    The parts teams got it right, picking up my right rear/passenger flare in about an hour.
    Carguy912 and ryanwgregg like this.
  2. Nov 3, 2022 at 2:26 PM
    #152
    Carguy912
    Carguy912 New Member
    2022 Tundra trd offroad
    Wheels, tires, grill, lift, ceramic tint, heretic fog lamps and debadged.
    Mine says ups delivering tomorrow. I hope they checked. I forgot to remind them.
  3. Nov 3, 2022 at 4:14 PM
    #153
    Buellride
    Olympia
    THE BOULDER
    Thankfully my parts department demanded that before they shipped the part that they open it at the warehouse.....supposedly that is how they were able to ensure the correct part was delivered. Good luck!
    ryanwgregg and Carguy912[QUOTED] like this.
  4. Nov 4, 2022 at 4:23 PM
    #154
    Gobstopper
    Gobstopper New Member
    These wider flares would be nice on a non Pro truck but can’t stand the camo. Could they be painted matte black? Not sure if they are textured or etched.
  5. Nov 4, 2022 at 4:27 PM
    #155
    Carguy912
    I will knownin 35 minutes when I get home.
    ryanwgregg likes this.
  6. Nov 4, 2022 at 5:01 PM
    #156
    Carguy912
    Mine arrived. Wow. These silly bastards at Tpyota distribution sent Mr ANOTHER left rear fender. What's worse is the return label was inside the box for the other left rear fender. So they checked at the dealership And still got it WRONG! Whatever......
  7. Nov 4, 2022 at 6:01 PM
    #157
    Buellride
    Olympia
    THE BOULDER
    I installed the rear fenders this afternoon. Of note, the front fender/flare markers wired perfectly to the green wire at the headlight plug and grounding to a nearby ground/bolt. What was interesting is the rear taillights didn't have a green wire in the left rear taillight. But after some fussing with a multi-meter and probes I determined that the DRL/hot wire was the Green/White striped wire and the White/Black striped wire was the negative (see photo).
    You can't just ground the LED markers to a known ground (like the front) in the rear for some reason. On the right rear taillight there is a 4th wire that is solid green. I chose NOT to wire into the solid green and just mirrored the same wiring as the left side. When you wire the lights and probe the beige or cream colored wire the marker WILL light up, but is very dim. The marker lights are tied to the parking/DRL lights and illuminate when you have DRL selected on the column or when you just select parking lights. Of course when you have your headlights on the markers are on as well.
    See finished pics of the markers/flares/truck....YES it is raining in the Pacific Northwest.
  8. Nov 4, 2022 at 6:22 PM
    #158
    Carguy912
    Good work! Looks great!
    Buellride[QUOTED][OP] likes this.
  9. Nov 6, 2022 at 12:08 PM
    #159
    Unitdosed
    Unitdosed New Member
    '22 Celestial Silver SR5, CREW CAB TRD OR 4X4
    None, yet
    Nice job! Thank you for the detail and photos.
    Buellride[OP] likes this.
  10. Nov 6, 2022 at 12:10 PM
    #160
    Unitdosed
    None, yet
    What do you have in mind when you say "better headlights"? My SR5 TRD OR seems to have pretty awesome headlights.
  11. Nov 6, 2022 at 12:13 PM
    #161
    Unitdosed
    None, yet
    Did you have to splice the wires?
  12. Nov 6, 2022 at 12:45 PM
    #162
    Buellride
    Olympia
    THE BOULDER
    Tap into the wires with a T-tap.
  13. Nov 14, 2022 at 6:26 PM
    #163
    22Tundraplat253
    22Tundraplat253 New Member
    Chanh
    2022 Tundra Platinum
    Wheels,lift,air level std stuff
    Bringing this back..so I've only was able to install the left side till now..opened the last two box's rf is a go...ummm got another LR flare that's supposed to be the RR...DAMMIT, would someone please take a picture of the RR flares pn to confirm..please..thanks
  14. Nov 14, 2022 at 6:58 PM
    #164
    Buellride
    Olympia
    THE BOULDER
    The better question is: What is the part number of the physical fender you received compared to the part number on the sticker outside of the box the fender came in? The part numbers referenced in this thread are the correct part numbers. The problem I was having was the part number on the fender itself didn't match the part number on the sticker on the box. Only until the dealership demanded that the distribution warehouse open the box to confirm the fender/box number match before shipping did it get sorted.
  15. Nov 14, 2022 at 7:10 PM
    #165
    22Tundraplat253
    Chanh
    I'll check in the morning..what is the part number for the RR?
  16. Nov 18, 2022 at 1:47 PM
    #166
    curttel
    curttel New Member
    Any have an extra PT8713422002 (right front) they want to sell me or perhaps its at your local dealer?
    The dealers around me cannot seem to get the 2002. Rather they get boxes with 2002 on the outside and a 2102 inside.
    Sort of frustrating.
    -c
  17. Nov 18, 2022 at 3:28 PM
    #167
    Prohit
    Prohit New Member
    2024 Sequoia Platinum
    You must be in the NE. Have your dealer order from the IL warehouse.
  18. Nov 18, 2022 at 8:50 PM
    #168
    22Tundraplat253
    Chanh
    Looks like this is a on going issues toyota outsourcing parts and having I correct parts boxed...I have a factory worker located at the Texas plant that heads assembly of trd pro tundras and its been a mess he says...it's not just us..the factory production is having the same issues with incorrect parts....so bare with them till they sort this out...I have the correct part coming but he is over seeing I get the correct part..lol
  19. Nov 19, 2022 at 8:36 AM
    #169
    GTundra2022
    GTundra2022 New Member
    2022 Tundra 4x4 Limited
    Do you have the LED headlights? Trying to decide if I want to t-tap in; or embark on figuring out the wiring harnesses. Or just not wire them up? .
  20. Nov 19, 2022 at 8:48 AM
    #170
    Buellride
    Olympia
    THE BOULDER
    Your question is more so whether your headlights are controlled via CAN bus. All of the Tundras come with LED headlights, my SR5 doesn't use CAN bus for its headlights. Unless you want to try to decode the computer, I would recommend running wire for the marker lights directly from the DRL or parking light fuse (if you can determine which fuse that is in the boxes).
  21. Nov 22, 2022 at 8:28 AM
    #171
    GTundra2022
    Really happy with these. I put one on last night, (I have 3, one is backordered) but there is a dramatic difference in size both width and height compared with the stock ones. I have the upgraded LED headlights so haven’t figured out the wiring yet. Going to see what I can find for factory plug and play wiring harnesses, or just leave them unwired as reflectors essentially.
  22. Nov 22, 2022 at 9:11 AM
    #172
    Buellride
    Olympia
    THE BOULDER
    Nice! They do a great job of rounding out the wheels/wheel wells, especially if you have a little poke from aftermarket wheels and tires
    GTundra2022[QUOTED] likes this.
  23. Nov 22, 2022 at 9:16 AM
    #173
    GTundra2022
    Agree. It makes the offset of the wheels and tires perfect. Look at the difference from one side to the other.
  24. Nov 22, 2022 at 7:36 PM
    #174
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    Can you take more identical pictures? Like same angle? Also what’s your wheel/ tire spec?
    Unitdosed likes this.
  25. Nov 28, 2022 at 6:33 PM
    #175
    YotaGang0404
    YotaGang0404 New Member
    James
    South Florida
    2022 Tundra SR 4X4
    Took these at the dealer the other day.
    Taikowaza and ryanwgregg like this.
  26. Nov 28, 2022 at 6:52 PM
    #176
    GTundra2022
    I’ll take some more pics tomorrow in the light. I’m running 18” methods +18 offset with Nitto 35”, RC 3.5” lift w/coil-overs.
  27. Nov 29, 2022 at 7:58 AM
    #177
    Yota802
    Yota802 New Member
    2023 Tundra Hybrid Limited CM WP
    Any luck wiring the PRO fenders? I have them in my order “inbox” waiting to hit send once I figure out how to wire.
  28. Nov 29, 2022 at 10:01 AM
    #178
    pneffkell
    pneffkell New Member
    This is on my wish list but I don't want to tap into wires. We need to design a harness plug
    Tornado likes this.
  29. Nov 29, 2022 at 11:06 AM
    #179
    Unitdosed
    None, yet
    What is TIS?
  30. Nov 29, 2022 at 11:24 AM
    #180
    Ullose272
    Ullose272 New Member
    Boise, Id
    22 Tundra SR5 TRD OR
    we ordered mine out of the arizona hub, all were correct first time.
    as for wiring, i ran a 4 pin trailer harness up to my bed for my sled deck lighting using adapter from the 7 pin, like what is used for tailgate light bars. i plan on getting power from that harness for my lights. just wish i could find connectors for the lights
