TRD Skid Plate Question
Discussion in '2.5 Gen Tundras (2014-2021)' started by Anthony605, Aug 19, 2021.
  1. Sep 8, 2021 at 5:26 PM
    #61
    Anthony605
    Anthony605 [OP] New Member
    Anthony
    2020 Limited Double Cab
    Pretty cool. Did it come with all of the hardware too?
  2. Sep 8, 2021 at 5:29 PM
    #62
    Phantom Lord
    Phantom Lord New Member
    Byron
    2017 MGM CM Limited
    Yes
  3. Sep 15, 2021 at 11:06 AM
    #63
    AGSport
    AGSport New Member
    PA
    21’ AG Sport
  4. Sep 15, 2021 at 2:33 PM
    #64
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    I have the TRD plate but had to trim it to run lower control arm skids.
  5. Sep 15, 2021 at 2:44 PM
    #65
    pandapro
    pandapro New Member
    Do you have the RCI LCA skid? Any photos of how much/where you trimmed? I was thinking about just trimming the LCA skid itself instead.
  6. Sep 15, 2021 at 7:16 PM
    #66
    Mountaineer
    Mountaineer New Member
    TN
    2019 MGM Platinum
    Got mine today! Quality seems pretty good. Did all of the mounting holes line up? Tufskinz letters should get here tomorrow.
    #66
  7. Sep 16, 2021 at 4:33 PM
    #67
    Phantom Lord
    Byron
    2017 MGM CM Limited
    Everything lined up perfectly on the one I bought. I thought about ordering the Tfskinz a while ago, but I couldn't tell if they needed the original TRD letter to adhere to or if they stuck directly to the plate. Let me know how it goes.
  8. Sep 18, 2021 at 10:38 AM
    #68
    AGSport
    AGSport New Member
    PA
    21’ AG Sport
    Did anyone install rubber washers to prevent creaking with this skid plate?
  9. Sep 19, 2021 at 11:02 AM
    #69
    LittleTundra
    LittleTundra New Member
    Oregon
    Something to think about if it was mentioned before. If you ever plan on doing a diff drop, you can just get the RCI with the diff drop option and still use it without a diff drop until you decide to get one later after lifting it. However, with the TRD Pro skid plate, its harder and more costly to get a diff drop kit.
  10. Sep 19, 2021 at 3:21 PM
    #70
    Alphagunner
    Alphagunner New Member
    Robert
    Oklahoma
    2018 4x4 crewmax. White
    Leather seats. 3/1 ready lift. 17in vision wheels wrapped in 285/75/17 Yokohama mt
    Will the TRD plate work on 6in lift trucks
  11. Sep 19, 2021 at 5:22 PM
    #71
    LittleTundra
    Oregon
  12. Sep 20, 2021 at 5:45 PM
    #72
    Mountaineer
    TN
    2019 MGM Platinum
    Finally got the letters today. Quality is very good. Only issue was the legs of the R were a little too long for the recess. I trimmed about 1/16" of an inch off each end. You'll never noticed it under there, just wanted to make sure the adhesive was flat against the plate.
    Phantom Lord[QUOTED] likes this.
  13. Sep 23, 2021 at 8:00 AM
    #73
    mms
    mms New Member
    these ones from ebay are they actual TRD plates or did some one make a knock off?
    #73
  14. Sep 23, 2021 at 8:25 AM
    #74
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    I would bet that they are probably knock offs, especially if the price is really low.
    #74
  15. Sep 23, 2021 at 8:31 AM
    #75
    mms
    mms New Member
    Price isn’t that much different it’s shipping that’s nuts $311 vs $345
  16. Sep 23, 2021 at 10:56 AM
    #76
    Mountaineer
    TN
    2019 MGM Platinum
    The $311 one on ebay is not a genuine Toyota plate. The main reason I bought it was for access to the filter and the price. I was going to get the aluminum RCI since the Toyota one has gotten pricey but came across this one and decided to try it out.
    #76
  17. Sep 23, 2021 at 11:18 AM
    #77
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Another steel RCI here. I have a thick alu skid plate on my other allroader, it has to come off regularly for the sledge hammer work.
  18. Sep 23, 2021 at 11:20 AM
    #78
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Frame antirust coating does a double favor of protecting the metal and terminating all the creaks and road noise :)
    AGSport[QUOTED] likes this.
  19. Sep 24, 2021 at 11:48 AM
    #79
    300BLK
    300BLK New Member
    2014 Tundra SR5 - Black
    Is the ebay plate the same gauge aluminum as the OEM?
    #79
  20. Sep 24, 2021 at 11:51 AM
    #80
    Phantom Lord
    Byron
    2017 MGM CM Limited
    It’s about 1/4” thick aluminum.
    #80
  21. Sep 24, 2021 at 11:59 AM
    #81
    Phantom Lord
    Byron
    2017 MGM CM Limited
    I’m not sure if they’re genuine or not. Mine looks identical to a TRD plate and the quality is good. It even came with this box spacer piece like the OEM (not my picture).1AF33491-840E-41F0-B801-3CA0AA5C3995.jpg
    #81
  22. Sep 25, 2021 at 4:06 PM
    #82
    Amateur Guy
    Amateur Guy New Member
    Make sure steel shims above the crossmember are orientated correctly and TORQUED properly. It will never squeak.
  23. Sep 27, 2021 at 4:29 AM
    #83
    Jsnake89
    Jsnake89 New Member
    Dane
    2019 Tundra TSS SR5 8W2
    Bilstein 5100 3/1 Pro Comp 1" Blocks, 12Volt Remote start.
    Well this is just great ever time I long into this forum I end up
    Buying something. Although I did need a new one as the factory one on my TSS is rubbing on my wider tires and the extensions. RCI for the w!!
  24. Sep 29, 2021 at 3:58 PM
    #84
    GCanuck
    GCanuck Member since 2020
    Gary
    BC,Canada
    2020 Tundra DC MGM TRD Sport
    TRD Swaybars. Line-X bed liner. Toyota Tri-fold Tonneau. N-fab side bars. TRD cold air. AMP bed extender. Rough Country Level kit. BFG A/T K02. RCI Skids. OEM Tow mirrors. TRD exhaust
    What do people use for a 2020 TRD Sport skid plate as the TRD one won't fit my specific model.
  25. Sep 29, 2021 at 5:40 PM
    #85
    sportbikenut
    sportbikenut New Member
    Chuck
    Pittsburgh Region, PA
    2021 Tundra Limited DC MGM 4x4 (New Oct 2021)
    Traded in 2016 Tundra Limited DC Silver 4x4
    Looks good. Do you have access to the oil drain plug after it is installed? Thx.
    #85
  26. Sep 29, 2021 at 6:22 PM
    #86
    Phantom Lord
    Byron
    2017 MGM CM Limited
    Yes, access to the filter and plug without removing skid.
    The RCI or TRD PRO skid plate should fit on your truck.
    GODZILLA likes this.
  27. Sep 29, 2021 at 6:30 PM
    #87
    sportbikenut
    Chuck
  28. Sep 29, 2021 at 6:44 PM
    #88
    Phantom Lord
    Byron
    2017 MGM CM Limited
    They are metal and come press-fit in. You unscrew the bolts with an allen key to access the filter. You do not have to take off the plate for an oil change
    sportbikenut[QUOTED] likes this.
  29. Sep 30, 2021 at 8:09 AM
    #89
    AGSport
    AGSport New Member
    PA
    21’ AG Sport
    I just put the EBay TRD plate on my 21’ sport. Everything fit fine. Some of the hardware wasn’t included. Luckily I had some extra washers laying around.
    #89
  30. Sep 30, 2021 at 11:02 AM
    #90
    GCanuck
    Gary
    BC,Canada
    Thanks all for the suggestions. I have to wait for the border to open so I can drop ship to Blaine.
