TRD Sway Bar 2023 1794
Discussion in '3rd Gen Tundras (2022+)' started by LouALouA, Mar 23, 2023.
  1. Dec 12, 2023 at 9:09 AM
    #61
    machd08
    machd08 New Member
    CLARENCE
    Sumter, South Carolina
    2025 Land Cruiser/Land Cruiser
    Just ordered sway bar and links from my local dealer, should be here tomorrow
    ryanwgregg likes this.
  2. Dec 16, 2023 at 12:40 PM
    #62
    machd08
    machd08 New Member
    CLARENCE
    Everything installed and torqued. Seems rude and stir better, feels like firmer steering, but that could be in my head too. Only thing I noticed was the end links that came with the TRD OR Kit seems to be beefier than the ones that you need to have for the sway bar.
  3. Jan 24, 2024 at 2:46 PM
    #63
    Stimleck
    Stimleck New Member
    Hi guys, can I get some clarity here for my 1794? Are you guys adding a sway bar because the truck doesn't come with one or are you adding a better quality stiffer heavier bar to improve performance?
  4. Feb 5, 2024 at 4:59 PM
    #64
    tundratracey
    tundratracey New Member
    Can you post a pic of the bar installed and the end links?
  5. Feb 6, 2024 at 5:46 AM
    #65
    machd08
    machd08 New Member
    CLARENCE
    Best pics I have on my phone at the moment
  6. Feb 26, 2024 at 9:06 AM
    #66
    MoeChins
    MoeChins New Member
    Various rattles
    did you lift the truck off the ground when you installed it or did you you leave it on the ground?
  7. Feb 26, 2024 at 9:13 AM
    #67
    tundratracey
    It was on the ground
  8. Feb 26, 2024 at 9:34 AM
    #68
    machd08
    machd08 New Member
    CLARENCE
    On the ground
  9. Feb 26, 2024 at 7:23 PM
    #69
    MoeChins
    MoeChins New Member
    Various rattles
    First drive impressions:
    deff feels firmer in the front. Deff a bit harsher and bumps seem to be noticeable even the small ones
  10. Mar 3, 2024 at 8:56 PM
    #70
    WrapCO
    WrapCO New Member
    Eagle , CO
    2022 Toyota Tundra 6.5’ CM
    Westcott lift, Method 316 17” wheels, 35x12.5x17 Toyo Open Country AT3
    Is the TRD Pro front sway bar the exact same shape as stock black one? Current tire is rubbing on oem TRD OR swaybar. It’s been dropped with icon swaybar relocation.
  11. Mar 4, 2024 at 8:05 AM
    #71
    WrapCO
    WrapCO New Member
    Eagle , CO
    I'll do some more digging now that I know this. Thanks boss.
    ryanwgregg[QUOTED] likes this.
  12. Mar 17, 2024 at 12:08 PM
    #72
    Ipaddick
    Ipaddick New Member
    Canada
    Platinum hybrid w/advanced package
    Was swapping it worth it? Also can you take a picture from the front of your truck? Thinking about doing this as well as the red axels.
  13. Mar 17, 2024 at 12:52 PM
    #73
    machd08
    machd08 New Member
    CLARENCE
    To me it is more stable especially in the corners. I believe it's worth it. I will get you some pictures, maybe tomorrow
    Ipaddick[QUOTED] and ryanwgregg like this.
  14. Mar 25, 2024 at 3:57 PM
    #74
    az 3rdGen
    az 3rdGen New Member
    Arizona
    2022 Black Tundra SR5
    For those of you that upgraded from the stock sway bar.. did you reuse all the hardware (nuts and bolts) or did you order the following two components? Trying to figure out if these are needed for a stock height truck or not. TIA!!
    Cap, Link Adapter (TRD 3-inch Suspension Lift Kit Component)
    PT983-34340 x2
    Bolts (TRD 3-inch Suspension Lift Kit Component)
    90105-A0232 x2
    BDATundra likes this.
  15. Mar 25, 2024 at 4:50 PM
    #75
    az 3rdGen
    Arizona
    Thanks Ryan. My TRD sway bar was delivered and I was kind of amazed at how they shipped it. scratched up a bit.. might need to paint match it lol
  16. Mar 26, 2024 at 9:14 PM
    #76
    LunarRckplati
    LunarRckplati New Member
    Tundra hybrid Platinum
    TRD 3 inch on 35's looking for TRD pro wheels!!
    I have the tier 3-in lift and with the sway bar relocation brackets my 35s on 18s rubbed the sway bar we had to remove the brackets and put the sway bar in stock orientation but when I drive now it has a lot more body roll. It doesn't handle the way I'd like it too so it's a big disappointment. Icon makes a spacer that's a little bit thinner than the 3-in TRD relocation bracket so I might try that to see if it works but I have no idea if it's going to work with the TRD skid plate. I don't want the sway bar sitting outside of the skid plate I feel like that defeats the whole purpose. You could run a zero offset on the wheels to make it not rub for my understanding but when I asked Toyota what offset to do they told me plus 18 so I got method 305s and plus 18 and it doesn't clear. I was curious if the TRD sway bar is different from the OEM black one in the sense that it would clear my tires with the relocation bracket. I hear people are running the TRD skid plate and not using the bracket and still going with a 3-in lift but that seems stupid since it's sloppy on the highway.
    If anybody has any advice please share!
  17. May 25, 2024 at 7:05 PM
    #77
    The Dutch Man
    The Dutch Man New Member
    Anyone find an answer to the tire rub with the 3” lift?
  18. Jun 9, 2024 at 7:37 AM
    #78
    Ipaddick
    Ipaddick New Member
    Canada
    Anyone mind listing everything I would need. Not lifting my truck. Sorry to be a pita.
  19. Jun 9, 2024 at 7:46 AM
    #79
    az 3rdGen
    Arizona
    This is what I bought for my TRD swaybar upgrade. no lift either. You are going to reuse the mounting nuts and bolts that are already on the truck too.
    1X Bar Sub-Assy, FR Stabilizer
    Part Number: 48804-0C020
    1X Link Assy, FR Stabilizer, LH
    Part Number: 48810-0C030
    Part Number: 48820-0C030
    2X Cap, Link Adapter
    Part Number: PT983-34340
    2X Bolts
    Part Number: 90105-A0232
    BDATundra and Ipaddick[QUOTED] like this.
  20. Jul 26, 2024 at 4:43 AM
    #80
    Kyleelkins89
    Kyleelkins89 New Member
    Kyle
    2024 Tundra Platinum 4x4
    I have read these and I apologize but I'm a bit confused..
    I have a 2024 platinum 4x4 with the trd off road package and the 3 inch lift. Does mine not have an upgraded front sway bar as well?
    I'd like the trd rear and front sway bar but I'd like to know which specific parts I need to order. I was wanting the trd skid plate too but unless there's a bracket kit that fully works with my truck will have to wait on it(unless someone's nice enough go tell me where I can buy pre-made spacers. I noticed the Amazon link kit isn't for my year vehicle).
    Could I get a parts number list of which items I'd need for the install of the following..
    -Front sway bar(unless the one I have on it is already the heavy duty trd one)
    -rear sway bar
    -trd skid plate
    Keep in mind that I do have the trd off road package as well as the trd 3" lift from the factory.
    I appreciate it if you're able to do that.
  21. Jul 26, 2024 at 5:42 AM
    #81
    machd08
    machd08 New Member
    CLARENCE
    Going off memory here from my 23 I had, that I put the TRD lift on and put TRD sway bar on.
    You do not have the front TRD Sway bar, it will be red, you will need it, look under your truck, where the sway bar mounts to the frame, there should be 2 drop blocks (spacers) between the sway bar and where it mounts. You will need them if you don’t have them already, you will need to bushings and mount bolts for where it bolts near the lower control arm, bolts are the OEM without TRD lift and bushings, I can see if I still have the part numbers.
    The rear sway bars are the same.
    Skid plate, that U don’t know, I have the stell plate from Talons garage. They have front specifically for 3” lift.
  22. Jul 28, 2024 at 4:36 PM
    #82
    Kyleelkins89
    Kyle
    Anyone else able to chime in on my question? I wanted to order and do the install myself because my local dealership really let me down on my foglight and grille install
  23. Aug 6, 2024 at 1:19 PM
    #83
    maldo012
    maldo012 23 tundra hybrid
    Eric
    Chicago
    23 Tundra Hybrid-Limited
    3inch dobinsons ims struts w/Rough Country 1.5inch spring/M1 shocks in the rear— Icon Uca — Hostile maniac 20inch w/general grabber atx tires — Perry parts front bumps - alpharex luxx headlights— swapped many parts with trd body components— race off-road trd grill etc
    Anybody got the torque specs for the front sway bar bracket?
  24. Aug 6, 2024 at 1:40 PM
    #84
    sudobash
    sudobash New Member
    55 ft.-lb. for 11/2021 through 04/2024
    61 ft.-lb. for 05/2024 onward
  25. Aug 8, 2024 at 12:07 PM
    #85
    maldo012
    Eric
    Chicago
    thanks I appreciate it. By chance got the specs for the front links aswell?
  26. Aug 9, 2024 at 12:13 PM
    #86
    sudobash
    sudobash New Member
    111 ft.-lb.
    BoomBoomGanoom likes this.
  27. Aug 9, 2024 at 12:28 PM
    #87
    maldo012
    Eric
    Chicago
    right on is that for what attaches to the lower control arm? Or the sway bar?
  28. Aug 9, 2024 at 12:33 PM
    #88
    sudobash
    sudobash New Member
    Both.
  29. Aug 9, 2024 at 12:38 PM
    #89
    maldo012
    Eric
    Chicago
    Oh shit thank you soo much!! Last question is that for the trd front sway bar links or it am doesn’t matter just needs to be 110 for the links
  30. Aug 9, 2024 at 12:40 PM
    #90
    sudobash
    sudobash New Member
    111 ft.-lb. no matter what.
    Tundrastruck91 likes this.
