Tundra Screensaver start up screen
Discussion in 'Audio & Video' started by CJ21, Oct 4, 2016.
  1. Mar 25, 2018 at 5:35 PM
    #61
    k3vinryl3
    k3vinryl3 New Member
    Anyone know the dimension of the image we can put? Thanks
  2. Mar 25, 2018 at 6:17 PM
    #62
    k3vinryl3
    it didnt show the dimension sir on that post
  3. Mar 25, 2018 at 6:19 PM
    #63
    Darth Tundra
    Curt
    17 CM TRD Black
  4. Mar 25, 2018 at 6:45 PM
    #64
    k3vinryl3
    I mean what size length/height/width is the image.
    Skippy likes this.
  5. Mar 25, 2018 at 6:58 PM
    #65
    k3vinryl3
    Sorry for the confusion. Got your point Thanks
    NewImprovedRon likes this.
  6. Mar 25, 2018 at 7:11 PM
    #66
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    Too many…scratch that…not done yet.
    Just to add to @RowdyRon comments. The overall dimensions don't matter as much as the file size. So long as the file size doesn't exceed the Kb or Mb limits, you're fine.
    Imagine your computer screen as your headunit display. If you want the image to take up the full screen on the head unit, crop or resize it on your computer so that it fills up the screen at 100% of the zoom in/out. From there, make sure the image size is under the Kb/Mb limit.
    My start up image is 95 Kb. On my computer, when I open it, it takes up my whole screen.
  7. Mar 26, 2018 at 11:19 AM
    #67
    slab
    slab New Member
    2018 Gray Tundra LImited Crew Cab TRD Offroad
    I have 2 images loaded in the Tundra. I see the Start up image but I have yet to see the display off screen. When does that show up?
  8. Mar 26, 2018 at 11:33 AM
    #68
    Nike21
    Nike21 New Member
    2018 SR5 CrewMax TSS 4X4 Black Beast
    I believe when you turn the display off?
    bulldog93 and (deleted member) like this.
  9. Mar 26, 2018 at 11:44 AM
    #69
    ChucklesToy
    ChucklesToy Retired
    Chuck
    Georgetown , TX
    2024 Honda Ridgeline Black Edition
    For details, go to post #3 and watch the video...
    The Display Off shows by going to the Home screen, press the gear in the upper right corner to go to Settings and you will see "Screen Off" at the bottom of the screen; press it to display the Screen Off pic. To return to Home or other screens, press any button.
    It does not show up when you turn the radio off...
  10. Mar 26, 2018 at 12:24 PM
    #70
    slab
    slab New Member
    So when would you use this?
  11. Mar 26, 2018 at 12:35 PM
    #71
    JeremyGSU
    JeremyGSU New Member
    Jeremy
    2016 Tundra
    You can use it whenever you want. You can still play the radio while your image is being displayed and when you change the station it will notate the station you are changing to. The only thing I don't like that you lose is the clock. But at night it's nice if you have a dark image as it reduces the glare from the screen.
    bulldog93 and ChucklesToy like this.
  12. Mar 26, 2018 at 1:38 PM
    #72
    ChucklesToy
    ChucklesToy Retired
    Chuck
    Georgetown , TX
    This^^^ and sometimes I drive around with the radio off and just my Screen Off picture instead of my home screen, mainly at night, since my picture is dark and my home screen has audio, weather and navigation showing all of the time whether the radio is on or off..
    bulldog93 likes this.
  13. Mar 23, 2019 at 8:52 PM
    #73
    Major
    Major TTC #0181
    Josh
    NC
    2017 CM Attitude Black Platinum
    Stock.
  14. Mar 24, 2019 at 8:58 PM
    #74
    netranger6
    netranger6 New Member
    Jeremy
    2021 Crewmax. 4x4, SR5, Blacked Out package
    None. Keeping this one stock.
  15. Mar 25, 2019 at 7:23 AM
    #75
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    bulldog93 and G2G like this.
  16. Mar 25, 2019 at 8:32 AM
    #76
    Scotty Dive
    Scotty Dive New Member
    Connecticut
    I am next to do this. Is it only one image or will the system remember a handful
  17. Mar 25, 2019 at 9:33 AM
    #77
    silverhack
    silverhack New Member
    Sacramento, CA
    2018 CrewMax Inferno
    only one image
  18. Mar 25, 2019 at 10:00 AM
    #78
    Boerseun
    Ferdie
    Sarasota Florida
    You can upload 3, and chose between them at any time. There is a fourth one (first one actually) that is the default Toyota logo. On the screen off options it is just a blank screen for the default plus 3 personalized options.
    You have to go into the setup screen though to chose, so it takes a few strokes, but fairly easy.
    bulldog93 and silverhack like this.
  19. Mar 25, 2019 at 10:59 AM
    #79
    AxeHeadTradition
    AxeHeadTradition New Member
    2018 Tundra Crewmax
    Thanks. Finally a mod that didn't cost $$$.
    bulldog93 and Major like this.
  20. Mar 25, 2019 at 11:16 AM
    #80
    Scotty Dive
    Connecticut
    Thanks you sir!
    Boerseun[QUOTED] likes this.
  21. Mar 26, 2019 at 8:32 PM
    #81
    JH5370
    JH5370 Member
    Josh
    Eastern WA
    2017 White DC TRD PRO
    I did this and it only flashes my image for a second after showing the Toyota image first and then going to the entune screen.
  22. Mar 27, 2019 at 12:06 PM
    #82
    Ronin73
    Ronin73 New Member
    2019 Tundra Crewmax SR5 4x4 5.7 Magnetic Grey Metallic
    Because that is how it is supposed to work. if you want it to stay on, you have to go into apps, select setup, and select Turn Screen Off at the bottom.
  23. Mar 27, 2019 at 2:24 PM
    #83
    ncorry
    ncorry New Member
    Nic
    Little Rock, AR
    2019 CM SR5 TSS
    bulldog93 and k9shag like this.
  24. Mar 27, 2019 at 2:38 PM
    #84
    Hey Sean, @smslavin got any real cool pictures?
    smslavin likes this.
  25. Mar 27, 2019 at 4:04 PM
    #85
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    does a bear poop in the woods?
  26. Mar 27, 2019 at 4:05 PM
    #86
    Look for a very cool picture .;)
    smslavin[QUOTED] likes this.
  27. Mar 27, 2019 at 4:06 PM
    #87
    smslavin
    smslavin New Member
    Hudson Valley
    Some stuff
    i'll dig around
  28. Mar 27, 2019 at 4:08 PM
    #88
    :thumbsup:
  29. Mar 27, 2019 at 5:42 PM
    #89
    Major
    Major TTC #0181
    Josh
    NC
    Stock.
  30. Mar 27, 2019 at 5:44 PM
    #90
