Ultimate OEM Toyota Parts Thread for 2nd gens (2007-21)
Discussion in 'Toyota of Cool Springs Parts' started by Roman, Feb 16, 2017.
  1. Apr 27, 2022 at 12:16 PM
    #3691
    TucsonTundra1794
    Anthony
    Tucson, AZ
    2023 1794 Edition TRD Package
  2. Apr 29, 2022 at 10:06 AM
    #3692
    dugfur
    dugfur New Member
    doug
    2016 limited DC
    Hello Roman, Can you tell me if the plastic step pads on the Toyota Factory running boards( part# PT2123407C) are available to purchase separately. They have a part number but when i search nothing comes up. Thank you and welcome back.
  3. Apr 29, 2022 at 12:02 PM
    #3693
    Roman
    Roman [OP] Toyota Parts Master Vendor
    Roman
    Franklin, TN
  4. Apr 29, 2022 at 12:05 PM
    #3694
    TucsonTundra1794
    Anthony
    Tucson, AZ
  5. Apr 29, 2022 at 12:09 PM
    #3695
    Roman
    Roman
    Franklin, TN
  6. Apr 30, 2022 at 4:03 PM
    #3696
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Hey @Roman... Sorry to bother you again, but it looks like I'm going to need to order some front brake parts as well. Can you shoot me links to front rotors and also links (to compare pricing) for pads/hardware vs. loaded calipers for a 2008 Tundra 5.7 SR5 4WD Crewmax... Let me know if you need any other info. Thank you!
  7. May 1, 2022 at 8:47 AM
    #3697
    Uhhhh....
    Uhhhh.... New Member
    Dave
    2016 Silver Limited DC
    7” BDS, 37s
    @Roman can I get a part number for the fuse box cover please? Did some searching but couldn’t find it. The one in the engine compartment next to the battery. 2016. Thanks!
  8. May 2, 2022 at 9:52 AM
    #3698
    Roman
    Roman
    Franklin, TN
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-disc-brake-rotor-front-435120c020
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-brake-pads-front-044650c020
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-shim-kit-anti-squeal-front-049450c040
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-disc-brake-anti-rattle-clip-set-049470c030
    Toyota does not sell loaded calipers. The calipers are by themselves with no pads or anything.
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-disc-brake-caliper-right-front-477300c030
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-disc-brake-caliper-left-477500c030
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-cover-relay-block-826610c301
    Uhhhh....[QUOTED] likes this.
  9. May 2, 2022 at 10:45 AM
    #3699
    Tripleconpanna
  10. May 4, 2022 at 4:16 PM
    #3700
    easleycrawler
    Travis
    Easley, South Carolina
    17 Tundra SR5 DC Black 5.7
    @Roman
    I need a link for left and right lower ball joint assemblies for 99 tacoma 4x4.
  11. May 5, 2022 at 7:50 AM
    #3701
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
    @Roman
    Couple questions on the Predator steps.
    Can I get just a hardware kit for these?
    Can I buy replacement end caps?
    Also do they fit 07-21 only differences being cab size?
    Thanks
    Randy Morton likes this.
  12. May 5, 2022 at 3:35 PM
    #3702
    YotaTruckLtd
    YotaTruckLtd Secret Squirrel
    2014 MGM Limited CM
    Bilstein 6112/5160 Boss 4x4 shims Boss 4x4 shackles Fuel Off-Road Vector wheels 20X9 Nitto Terra Grappler G2 35" tires SPC UCAs OEM TRD Pro Grille OEM 2020 LED headlights and OEM LED fog lights OEM color matched mirror caps and door handles OEM black exhaust tip Ecoological color matched front and rear bumpershellz V3 Go Rhino RB20 running boards XPEL Prime XR Plus ceramic tint 30% front 15% rear 70% windshield BAKFlip MX4 tonneau cover Dasaita 13in Vivid Headunit AJT interior chrome delete black kit AJT climate control black knobs AJT V3 shift knob TVD exterior emblem black inlays 3BMakers Yota hitch cover Husky front and back floormats K&N Select engine air filter GTR Lighting Armor Series LEDs Reverse lights Cargo lights 3rd brake light License plate lights
  13. May 5, 2022 at 4:01 PM
    #3703
    easleycrawler
    Travis
    Yes it will, I had the exact tip on mine.
    Assuming you have the 5.7?
  14. May 5, 2022 at 4:23 PM
    #3704
    YotaTruckLtd
    2014 MGM Limited CM
    Yes I do..thanks.
    easleycrawler[QUOTED] likes this.
  15. May 6, 2022 at 8:49 AM
    #3705
    Roman
    Roman
    Franklin, TN
    https://parts.toyotaofcoolsprings.c...nsion-ball-joint-right-front-lower-4333039815
    https://parts.toyotaofcoolsprings.c...ension-ball-joint-left-front-lower-4334039585
    Yes.
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-tun-tub-stp-hwk-ccab-pt92534182hk
    Yes.
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-tube-step-end-cap-pt92535160ec
    Yes.
  16. May 6, 2022 at 10:03 AM
    #3706
    easleycrawler
    Travis
    @Roman
    Link for left and right upper ball joints, 99 tacoma 4x4. Get it all at once. Thanks
  17. May 6, 2022 at 10:13 AM
    #3707
    Roman
    Roman
    Franklin, TN
  18. May 6, 2022 at 10:57 AM
    #3708
    easleycrawler
    Travis
  19. May 6, 2022 at 5:19 PM
    #3709
    Shanet421
    San Diego,CA
  20. May 7, 2022 at 5:02 PM
    #3710
    bulldog93
    bulldog93 Usually tired...
    Jeff
    Santa Rosa, California
    2020 Super White CM Tundra TRD Pro
    @Roman
    I'm looking at replacing the plastic oil filter cover with the aluminum. 2020 TRD Pro. Seems like 15620-31060 is correct, but all of the parts sites show that it doesn't fit.
    1. [​IMG]
  21. May 7, 2022 at 6:36 PM
    #3711
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Technically, “it doesn’t fit” because it’s not made for the Tundra.
    You will have to swap out the inside perforated tube that is in your plastic filter housing for the one that is in the metal housing because the one that comes in the metal housing is too short for the Tundra filter. But that’s an easy process to do (Bend the tab with a flat screw driver, twist and wiggle to remove, then reverse for install).
    Roman[OP] and bulldog93[QUOTED] like this.
  22. May 7, 2022 at 9:20 PM
    #3712
    bulldog93
    Jeff
    Thanks! That's easy. Is there one actually made for the Tundra?
  23. May 8, 2022 at 7:05 AM
    #3713
    RainMan_PNW
    Casey
    Clark County, WA
    Not that I know of. Jowett makes one that has a drain valve built in and some other features, but I’ve never seen it in stock and it requires you to swap your inner metal tube into it as well
    bulldog93[QUOTED] likes this.
  24. May 8, 2022 at 7:10 AM
    #3714
    bulldog93
    Jeff
    I haven't seen the Jowett one in stock for a while. Thanks for the info. I'll grab one of these.
  25. May 8, 2022 at 7:29 AM
    #3715
    Blang805
    Blang805 New Member
    Central Coast California
    2010 CrewMax Platinum 4x4
    Build in Signature
    Im on a mission to find an exhaust tip for my 5.7l 2010 CM for some reason. i dont know why but links (black chrome/chrome) for them say they wont fit :notsure:
    Arent all the tail pipe sections the same for the 5.7s from 2007-2021?
  26. May 8, 2022 at 1:51 PM
    #3716
    Whittle
    Whittle New Member
    2021 Magnetic Gray Tundra TRD Pro
    CD4F938B-D650-4ADF-A9E9-A71D249951CA.jpg E09EEDA5-7063-4912-95C0-9D84CD4203C5.jpg @Roman ; I’m looking for the metal clips that hold the headliner grab handles in place. First pic is it removed (see broken clip for why I’m replacing it) and second pic is the handle with the other metal clip on it. Thanks!
  27. May 9, 2022 at 12:15 PM
    #3717
    Roman
    Roman
    Franklin, TN
    Which position is it in the truck?
  28. May 9, 2022 at 12:38 PM
    #3718
    Whittle
    Whittle New Member
    Drivers side, rear, crew cab. Thanks!
  29. May 9, 2022 at 12:41 PM
    #3719
    jerbear
    jerbear New Member
    Jerry
    Alden, New York
    2020 Black SR5 CM
    None, yet.
    Hi Roman,
    I am looking to get the "Pro" grille for a new to me 2020 Tundra. I don't know the paint code, but will get it if needed. It is black with some metallic flake to it.
    Thanks
    Jerry
  30. May 9, 2022 at 2:06 PM
    #3720
    Roman
    Roman
    Franklin, TN
    Should come with this:
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-grip-handle-front-cover-7461106110b1
    I'll look at it when it comes in. If it's not on that part, it may come with the entire handle.
    I've got those listed in the first post. Your paint code should be 218.
