Under seat storage
Discussion in '2.5 Gen Tundras (2014-2021)' started by 14crewmax, Oct 1, 2020.
  1. Jan 13, 2021 at 4:50 PM
    ryan2828
    ryan2828 New Member
    I just did this mode. Very very easy. I cut my floor mats so the bins go over the mat.
  2. Jan 13, 2021 at 5:00 PM
    Squeaky
    Squeaky New Member
    Wisconsin
    ‘19 White TRD Pro
    I had originally picked up a set of weathertech to use with my ESP lockable long box, but didn’t want to cut them up. I sent them back and ordered a set of Husky mats and they fit perfectly without cutting. Love my Husky’s.
  3. Jan 14, 2021 at 6:18 AM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler
    Nice mod. Can you take the mat out easily or is that just not an option anymore?
  4. Jan 14, 2021 at 7:10 AM
    Nighthawk
    Nighthawk New Member
    Keith
    Frederick Md.
    2018 Tundra Limited crewmax
    linex bed Truxedo Pro F-15 Tonneau,Weathertech mats,TRD exhaust,Matt Geckco bed lights,hood light,shorty antenna, all LED lights inside, Fomoto oil drain valve,
    I just bought some foam at Wal-mart and cut it to fit.Under $40
  5. Jan 14, 2021 at 7:16 AM
    OHwendTrd
    Josh
    21 SR5 3UR-FE
    ATF Cooler
    Too bad they don't have those foam pads in black!
  6. Jan 14, 2021 at 7:49 AM
    Nighthawk
    Keith
    Frederick Md.
    Once you drop seat bottoms you only see a little bit of foam. I guess you could paint edges.
  7. Jan 14, 2021 at 10:13 AM
    Nighthawk
    Keith
    Frederick Md.
    You could just spray them with paint I guess. Once I lower seat bottom I don’t see much of them.
  8. Jan 14, 2021 at 1:51 PM
    ryan2828
    ryan2828 New Member
    Definitely can take the mat out. Just pull the storage bin up and mat can be pulled out. The storage bin just sits in the holes you cut in the floor so it can be pulled out whenever.
    biebs96 likes this.
  9. Jan 15, 2021 at 10:03 AM
    RX7
    RX7 New Member
    2021 Tundra TRD Pro
    I took the inexpensive route and am very pleased with the result. There are wires under the foam so be careful!
  10. Jan 15, 2021 at 10:04 AM
    RX7
    RX7 New Member
    2021 Tundra TRD Pro
    FYI - The factory foam appears to be pretty durable stuff, so I am fine using it as the walls for my storage.
    Boerseun likes this.
  11. Jan 15, 2021 at 5:46 PM
    Minarets
    Minarets New Member
    Nashville
    2021 TRD PRO
    Can’t decide if I want to get creative or buy the ESP storage.
  12. Jan 15, 2021 at 6:18 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    Minarets[QUOTED] likes this.
  13. Jan 15, 2021 at 7:06 PM
    Squeaky
    Squeaky New Member
    Wisconsin
    ‘19 White TRD Pro
    The ESP is easily the best mod I’ve made. You won’t regret it.
  14. Jan 17, 2021 at 6:04 PM
    OHwendTrd
    Josh
    21 SR5 3UR-FE
    ATF Cooler
  15. Jan 17, 2021 at 6:36 PM
    Minarets
    Minarets New Member
    Nashville
    2021 TRD PRO
    That’s likely the route I’ll go
    I know many have said it doesn’t affect road noise in the vehicle, but it seems like it would when cutting out that amount of foam right where it’s located. .
    Don’t the ‘20 and ‘21 have a wire in the middle area that can effect the storage bin?
  16. Jan 17, 2021 at 6:41 PM
    Bodizaffa
    Bodizaffa New Member
    Calgary Canada
    2020 tundra crewmax
    Heritage grill. Black badging on exterior Leer 100xr campy color matched cement grey. AJT black out interior. Painted center surround. 275 70 r18 KO2s Spray bed liner Ellis precision shifter on way Blistein 6112 front and 5160 rear on way Charging tray on way Box led lighting on way Sill protectors on way Kat skinz once my kids stop destroying my stuff Any advice on custom bed storage. It's in the plans
    Question. Do you think by cutting carpet and foam you reduce R value of cab if it even matters and any increase in road noise..
  17. Jan 17, 2021 at 6:44 PM
    Blueknights75
    Ron
    Clayton, NC
    No increase in road noise whatsoever and no negative issues with R value. Only thing I did was used the cut out carpet pieces underneath the bins before I put the unit in.
    TaquitoBandito and Minarets like this.
  18. Jan 17, 2021 at 6:57 PM
    Bodizaffa
    Calgary Canada
    2020 tundra crewmax
    Cheers.. couple more beer and I’ll start cutting
  19. Jan 17, 2021 at 7:05 PM
    #49
    OHwendTrd
    Josh
    21 SR5 3UR-FE
    ATF Cooler
    Agreed. :drunk:
    Minarets and Blueknights75 like this.
  20. Jan 17, 2021 at 7:19 PM
    #50
    Blueknights75
    Ron
    Clayton, NC
    Not sure if your year model has wires going through that area...just an fyi...
  21. Jan 17, 2021 at 8:33 PM
    #51
    Minarets
    Minarets New Member
    Nashville
    2021 TRD PRO
    Doesn’t the 2020 and 2021 have the wires in the middle section?
  22. Jan 17, 2021 at 9:41 PM
    #52
    Safar85
    Safar85 New Member
    Ed
    Corona, Ca
    2021 SR5 CM
    More than a few.....
    Thought this was only if you have the smart key.
  23. Jan 18, 2021 at 3:46 AM
    #53
    Minarets
    Minarets New Member
    Nashville
    2021 TRD PRO
    I do
  24. Jan 26, 2021 at 11:45 AM
    #54
    WhiteStar20
    WhiteStar20 New Member
    Dennis
    Okotoks, AB., Canada
    2020 Tundra Platinum CM
    Rockstar XD 20” rims, BAK Bed cover, TRD Dual Exhaust, etc., etc...
    So... no noticeable noise from the drivers seat. What about the rear passenger seat, where they do sit on top of the actual reconstructed area?
  25. Jan 26, 2021 at 1:15 PM
    #55
    GeckoMobile
    GeckoMobile New Member
    Eric
    Dunkirk, MD
    2017 White Tundra SR5 TRD CrewMax
    XD Wheels 33x12.5 Toyo Open Country Leveled
  26. Jan 26, 2021 at 5:25 PM
    #56
    theomedic
    theomedic New Member
    Theo
    2016 Tundra SR5
    Stock so far
    How deep is the area you cut out?
  27. Jan 26, 2021 at 8:40 PM
    #57
    L_S_SHOE
    L_S_SHOE New Member
    SE Louisiana
    2021 MGM TRD Pro
  28. Jan 26, 2021 at 9:32 PM
    #58
    marcelo73
    marcelo73 New Member
    So Cal
    2016 Toyota Tundra Crewmax TRD PRO QUICKSAND
    295/70 18 Coopers
    Make sure and post photos of that inverter, I am really interested in this addition.
  29. Jan 27, 2021 at 1:04 AM
    #59
    7dgoat
    7dgoat Member
    NJ
    2025 Terra Platinum Off-road
    Does anyone know of a promo code for the esp storage bin? I'm thinking about getting one and it would be nice to save a few dollars.
  30. Jan 27, 2021 at 9:49 AM
    #60
    panicman
    panicman Everyone remain calm.
    Eric
    2018 SR5 CM TRDoffroad MGM
    The 3-bin ESP storage unit was the second mod I made to the truck. (2018 CM)
    It has a factory appearance, does not increase road noise for any occupant, and it does not interfere with the installation of a sub. It offers plenty of storage for small items, but is not good if you want to store a rifle.
    I applied DynaMat to the bottom of each well at the time I upgraded the sound system and applied the material all over the truck. I can’t honestly say that it made a difference because I never heard any road noise from the cut outs BEFORE applying the DynaMat.
    I got mine as a Christmas gift, so the $ didn’t bother me at all. (And honestly this is one of the less expensive upgrades amongst my addict-like spending on this beast)
    The included installation template is spot-on.
    I think (do your research) that they make one for 20-21 that installs right over the wire at center.
    Trooper2 and GODZILLA like this.
