Under seat storage
Discussion in '2.5 Gen Tundras (2014-2021)' started by 14crewmax, Oct 1, 2020.
  1. Jan 29, 2021 at 5:10 PM
    #91
    ElNopal
    Willis TX
    19 Cavalry Blue CM
    My understanding is that yes. For the push start, 2020+ models have wiring in the middle between the rails. That space is adjusted to accommodate the wiring harness.
  2. Jan 29, 2021 at 5:43 PM
    #92
    grandmabetty
    grandmabetty New Member
    MN
    2021 Barcelona Red SX
    I live in MN. Any issues with drafts or cold air with the ESP? I mean you are removing 2" of insulation and replacing it with thin plastic and an empty cavity
  3. Jan 29, 2021 at 6:03 PM
    #93
    WhiteStar20
    WhiteStar20 New Member
    Dennis
    Okotoks, AB., Canada
    2020 Tundra Platinum CM
    Rockstar XD 20” rims, BAK Bed cover, TRD Dual Exhaust, etc., etc...
    From what I’ve been reading here on tundras.com you can install a thin insulation and/or sound barrier underneath the ESP products to help suppress noise and control cool air variations
  4. Jan 29, 2021 at 6:04 PM
    #94
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    I notice you also added in some LEDs...nice touch!
    ElNopal[QUOTED] likes this.
  5. Jan 29, 2021 at 6:26 PM
    #95
    ElNopal
    Willis TX
    19 Cavalry Blue CM
    Thank you Casey! :hattip:
    They are wired to the dome light circuit and turn on when the doors open or with the “on” position with the factory switch.
    57998C79-382C-4A92-84D6-CE570CCCA95D.jpg C1000632-B802-4A28-8F99-94DF26276D5F.jpg
  6. Jan 29, 2021 at 6:32 PM
    #96
    RainMan_PNW
    Casey
    Clark County, WA
    I can see you do things like me - that looks factory...loomed and all!
  7. Jan 29, 2021 at 6:55 PM
    #97
    Squeaky
    Squeaky New Member
    Wisconsin
    ‘19 White TRD Pro
    None whatsoever. I live in WI.
    grandmabetty[QUOTED] likes this.
  8. Jan 29, 2021 at 7:05 PM
    #98
    ElNopal
    Willis TX
    19 Cavalry Blue CM
    Amen brother, father sure did his part to make sure I would do tinkering “right”. He always said to make it “look like it grew there”. He is still very meticulous with his stuff even today. It feels good to know that all my mods (err um our mods - ya know, the child labor crew of mine, that Adam @AzureNightmare exposed earlier in the thread) have all been “passed off” as acceptable by my old man...
    For you to notice, well that is just the “Good Schtuff” right there...
    GODZILLA and RainMan_PNW[QUOTED] like this.
  9. Feb 7, 2021 at 8:59 AM
    #99
    havasubud
    havasubud Owner ESP Truck Accessories Vendor
    Earl
    Corona, California
    2022 Tundra CrewMax Limited TRD OR 4x4
    Factory Tube Steps, TraiFX tri fold tonneau cover
    The long box already sits higher than the sensor due to the seat brackets.
    GODZILLA and ElNopal like this.
  10. Feb 7, 2021 at 9:03 AM
    #100
    havasubud
    Earl
    Corona, California
    That's pretty cool. Love the idea. Might have to look into that. How did you do the plug?
  11. Feb 7, 2021 at 9:07 AM
    #101
    RainMan_PNW
    Casey
    Clark County, WA
    My bet is he used an OEM male/female 2-pin set of connectors, and the other side is tapped into the wires for the cargo light that are running in the floor gutter along the side of the cab before they head up the C-pillar to the light
    ElNopal likes this.
  12. Feb 7, 2021 at 9:19 AM
    #102
    grandmabetty
    MN
    I own a 2021 SX that does not come with remote start. I assume i dont need to worry about a sensor?
  13. Feb 7, 2021 at 9:20 AM
    #103
    ElNopal
    Willis TX
    19 Cavalry Blue CM
    Yes, I pilfered a set of OEM 2-pin connectors from my RAV4 parts car and ran the wires through underneath the foam and on underneath the scuff plates up through the fire wall kick plate and up to the factory dome light switch.
    26203545-40BE-4DDD-8CAF-2C1F2565F273.jpg E914B7F1-BB22-443A-BC5F-C9F6ED9390BC.jpg 9B1B62C0-15FD-4355-B4AF-3EDD03AE3BA5.jpg
    RainMan_PNW[QUOTED] likes this.
  14. Feb 7, 2021 at 10:23 AM
    #104
    GODZILLA Introverted Troglodyte
    It's not just the remote start, IIRC. It has to do with the smart handles, push button start, and such. 99% sure that connection under the back seat is in all 2020+ trucks.
  15. Feb 8, 2021 at 3:01 PM
    #105
    WhiteStar20
    Dennis
    Thanks Earl.
    I also noticed, in the thread comments, the triple storage option gives you two of three different depths. Does the long box storage option give you a continuous depth across? What is it? My apology for all these questions.
  16. Feb 8, 2021 at 3:25 PM
    #106
    grandmabetty
    MN
    My truck doesn't have any of those things but ill assume it probably has the wiring for some reason or another. Thanks!
  17. Feb 14, 2021 at 7:59 AM
    #107
    havasubud
    Earl
    Corona, California
    The long box is one continuous depth at 3 5/8 and 3/16" more with the lid
  18. Feb 14, 2021 at 9:36 AM
    #108
    WhiteStar20
    Dennis
    Thanks Earl, :hattip:
  19. Feb 14, 2021 at 9:37 AM
    #109
    havasubud
    Earl
    Corona, California
    You're welcome! Don't forget to use code TNDRASDTCM for the discount
  20. Mar 6, 2021 at 4:34 PM
    #110
    SomethingClever
    SomethingClever New Member
    2020 Tundra TRD Off-Road 4x4
    This is the one I REALLLLY want but I just can't get myself to drop this much money on it.
  21. Mar 6, 2021 at 4:43 PM
    #111
    ElNopal
    Willis TX
    19 Cavalry Blue CM
    I understand. However, the TNDRASDTCM promo code helps a bit with $75 off and still has free shipping...
    Cry once...
  22. Mar 8, 2021 at 7:39 AM
    #112
    havasubud
    Earl
    Corona, California
    If your truck does not have push start then the wiring is not there. The installation of the box does not interfere with any of the functions.
  23. Mar 8, 2021 at 7:57 AM
    #113
    Phrog Driver
    Phrog Driver New Member
    2021 Silver Sky Crew Max TRD Off Road
    This was from my recent install. I was concerned about the center section wiring, but it was no biggee. Just cut the foam insulation very slowly and you will feel it. ESP box install 3.jpg
    WFD473 and itsmerh85 like this.
  24. Mar 8, 2021 at 4:48 PM
    #114
    Minarets
    Minarets New Member
    Nashville
    2021 TRD PRO
    The drop in plastic doesn’t hit it?
  25. Mar 8, 2021 at 6:31 PM
    #115
    Phrog Driver
    Nope. Center section is not as deep as the two outside sections. Fits good. ESP box install 4.jpg
    Minarets[QUOTED] likes this.
  26. Mar 8, 2021 at 7:07 PM
    #116
    Minarets
    Minarets New Member
    Nashville
    2021 TRD PRO
    Thanks
    Phrog Driver likes this.
  27. Mar 8, 2021 at 9:23 PM
    #117
    panicman
    panicman Everyone remain calm.
    Eric
    2018 SR5 CM TRDoffroad MGM
    Nice Phrog! Looks good.
