Undercarriage Treatment?! Yay or Nay?! Pros & Cons?!
Discussion in '2.5 Gen Tundras (2014-2021)' started by Spyker, Dec 5, 2021.
  1. Dec 9, 2021 at 2:17 PM
    #61
    sd172
    sd172 New Member
    South Dakota
    2021 Sequoia Nightshade
    Wool Wax will get pretty soft in summer, and then it will creep into pinch welds etc. I would go with Fluid Film if I had to do it now and the outside temps are below 70 F. You can always re-apply Wool Wax on top of FF later.
    classiccat likes this.
  2. Dec 9, 2021 at 2:27 PM
    #62
    classiccat
    classiccat New Member
    2017 Tundra Limited SuperWhite
    Yay on undercoating. No Cons...Many Pros.
    My dirty girl is going on her 5th salt-belt winter and still like new...if you can look past the grime & slime.
    Apply Amsoil MPHD to everything while things are relatively new (before rust has formed)
    - Consider this a foundation.
    - I probably wouldn't spray this on existing rust. My truck was a year old when purchased (1 winter unprotected) and some welds had rust starting, the next season, amsoil was gone on the rust spots.
    Annually:
    Protected areas (Body/Door Panels, rockers, engine compartment, hood, tailgate, inside of cross members and control arms):
    - Spraybomb fluid film with the wand for body/door panels.
    - Open your doors and you'll see a rubber flap at the bottom of the front quarters, pull that back and remove the trapped leaves/debris...then light that cavity up.
    - Unscrew the tailgate panel and spray the crap out of the entire tailgate.
    - before spraying, put a coat of silicone gel on the weather stripping...I didn't and they're a little deformed at the drain holes.
    Semi-protected areas (quarter panels / wheel wells, inside of frame, underside of bed.)
    - Bulk fluid film (1gal/5gal cans) with an undercoating gun kit with wands (I use Kelsport...the gun, nozzle & straight wand are OK but the 360 wand is kind of lame)
    - drop the spare and get hit the bed, spare tire and tire lift.
    - you can get good access to the inner bedsides & wheel wells by removing the tail lights.
    Areas of high exposure (external frame, axles/diffs, suspension)
    - Woolwax or Blaster surface shield.
    - It's my 1st season using surface shield spraybomb on the Tundra.
    -- the spraybomb cans are finicky...you want to be light on the trigger and apply a mist rather than have it pile-up & drip.
    -- I used 6 cans and felt like I could've used more.
    -- I just bought a bulk 5gal bucket of surface shield; I'll be hitting my daughter's '09 Matrix with it this weekend with my undercoating gun.
    - Woolax held up great however I don't believe that it's as good as FF for creeping into crevices &/or seeping into existing rust.
    - Jury is still out for surface shield...the bulk material has a very low viscosity (better creep?). How it reacts with existing rust is a big unknown.
    Tundra1078, sd172 and Spyker[OP] like this.
  3. Dec 9, 2021 at 3:01 PM
    #63
    Corrosivetendency
    Corrosivetendency New Member
    Nate
    2016 plain-jane d-cab
    Does this guy do Mobil applications as well?
  4. Dec 9, 2021 at 3:09 PM
    #64
    RusPro21
    RusPro21 Pro is gone! But I’m still here.
    Don
    Pa.
    2021 Pro!! Nitto’s Tyger blades, Arc audio!
    Nate, What is the Mobil? Not familiar with that.
  5. Dec 9, 2021 at 4:13 PM
    #65
    dpast88
    dpast88 New Member
    Dennis
    Furlong, PA
    2015 Tree
    Damn. Another place 2 hours away lol. After they do the fluid film does the truck have to sit awhile before you can drive it?
  6. Dec 9, 2021 at 4:39 PM
    #66
    RusPro21
    Don
    Pa.
    No. You can drive it home. Which I think is better since guys are posting that it smells. I don’t smell it in my garage. 2 years ago the guy local to me was not doing it at the time. I found a guy in NJ and drove a little over 2 hours each way to have it done. He ask me again and I told him I have someone local and he understood. But I sent him some business I know someone in NJ and he sent his friends.
  7. Dec 9, 2021 at 4:51 PM
    #67
    dpast88
    dpast88 New Member
    Dennis
    Furlong, PA
    2015 Tree
    Where is there NJ guy? Maybe he is closer haha
  8. Dec 9, 2021 at 4:57 PM
    #68
    RusPro21
    Don
    Pa.
    Just google this Dennis maybe he is. Summit NJ 07901.
  9. Dec 9, 2021 at 4:59 PM
    #69
    RusPro21
    Don
    Pa.
    I coming up Dennis just little over hour? I have his number if you need it.
  10. Dec 9, 2021 at 4:59 PM
    #70
    dpast88
    dpast88 New Member
    Dennis
    Furlong, PA
    2015 Tree
    Just a bit over an hour. Can you send me the specific contact info! Thanks Don
  11. Dec 9, 2021 at 5:02 PM
    #71
    RusPro21
    Don
    Pa.
    Let me get the info off my phone I will send it private message.
    Spyker[OP] likes this.
  12. Dec 9, 2021 at 5:07 PM
    #72
    RusPro21
    Don
    Pa.
    Just sent the info.
    Spyker[OP] and dpast88[QUOTED] like this.
  13. Dec 9, 2021 at 5:34 PM
    #73
    Spyker
    Spyker [OP] I’m a dude,playin a dude,disguised as another dude
    ^ people helping people! Gotta love this forum! :cheers:
    RusPro21 likes this.
  14. Dec 9, 2021 at 6:02 PM
    #74
    Corrosivetendency
    Nate
    I tried to get a guy in that area to do mine, he had a mobile application service.
  15. Dec 9, 2021 at 6:06 PM
    #75
    RusPro21
    Don
    Pa.
    Oh ok. No this guy has a detailing business but also does the fluid film. Let me know if you need his contact info.
  16. Dec 9, 2021 at 6:06 PM
    #76
    Bergy24
    Bergy24 New Member
    2021 Cement Crewmax Limited TRD 4X4
    Can you message me the info on this place? I live in the York area.
  17. Dec 9, 2021 at 6:14 PM
    #77
    AGSport
    AGSport New Member
    PA
    21’ AG Sport
    Message sent.
  18. Dec 9, 2021 at 7:37 PM
    #78
    MeetJoe
    MeetJoe New Member
    Maryland
    2021 CrewMax SX
    OEM TRD Pro Led Headlights OEM LED Fog lights iHacker Harness OEM Tube Step OEM trifold hard tonneau OEM Driverside Grab Handle and Pillar OEM Exhaust tip Wireless CarPlay CarLinkit 3.0 Snack Crumbs
    Can you elaborate on how you applied? Where you applied? Where you didn’t? Any details appreciated. Total noob at diy undercarriage spray.
  19. Dec 9, 2021 at 10:22 PM
    #79
    odymar
    odymar New Member
    Marcus
    South Carolina
    21 SW CM SR5 4WD
    A lot of good discussion. I have yet to apply anything to my Tundra since I bought it 6 months ago but will be soon. Prior to the Tundra I drove a Jeep. I tried Fluid Film but didn’t like how thick it was and felt like I was just caking it on sometimes.
    I have since used a product called ACF-50 to spray everything down. It’s super thin, safe on electrical connectors and components, and evens out to a nice thin layer after applied. Super messy when working under the vehicle, but I prefer it over rust. I also use it on my boat to keep hardware and the motor free of corrosion. I have had good experiences.
  20. Dec 10, 2021 at 5:43 AM
    #80
    GT87
    GT87 New Member
    Greg
    Western NY
    White 2021 SR5 O/R CM
    295/60r20 Toyo ATIII, 20x9 XD 820, 3/1 ReadyLift Carven Exhaust
    Very happy to read this comment. I had krown undercoating on my last truck and liked it. But I got a 2021 earlier this year and am getting the corrosion free treatment done. Mainly because the shop right next to my work now offers corrosion free. The krown guys are all the way across town.
    tundra121[QUOTED] and Spyker[OP] like this.
  21. Dec 10, 2021 at 6:57 AM
    #81
    backinit
    backinit New Member
    2007 Salsa Red Pearl Crewmax Limited
    My mechanic told me that if I was going to keep my truck to start treated the underside. I asked him about used synthetic oil. He said do it. That is what I used. 4/5s used 5w-20, 1/5 diesel through a garden sprayer. It was a little stinky for 2 weeks. The cost was right.
    kleiker0303 likes this.
  22. Dec 10, 2021 at 1:18 PM
    #82
    Hugemoose
    Hugemoose New Member
    David
    Philly
    2016 Tundra Crewmax
    Not enough....
    Yet another vote for Krown. It's not real big in the states compared to Canada, so I got to the southern most location that does the application, in York PA. I've gone 3 years in a row now. It's the best $150 I spend all year. I spot treat my other cars with Fluid film, but for the truck I love that the Krown treatment gets in all of the body panels as well.
    All year long streaks of the oil lightly seep out the door handles and tailgate handle lol. I love it because I know it's working and continuing to stay viscous. And yeah working under the truck is now a slightly dirtier process, but I'll take that any day of the week over rust. My last Tundra (2001) had the frame replaced. Never again.....
    TheDanimal and tiogajoe like this.
  23. Dec 10, 2021 at 1:38 PM
    #83
    BearcatScott
    BearcatScott New Member
    I did my 2021 Tundra with Wool Wax in the driveway last week. Used 6 aerosol cans with the sprayer attachment. I was disappointed in the coverage, it seemed to come out of the nozzle in clumps because it was so thick. It was probably because I didn't warm it up first, it had been sitting in my garage for about a month with temps at night in the 30s and 40s. I read afterwards that you should let it sit in warm water before applying. Also as others have said, wear old clothes. The stuff does not wash out easily.
  24. Dec 10, 2021 at 4:31 PM
    #84
    Abos
    Abos Long live 5.7L V8
    2014 SR5 Crewmax
    How long have you had that solution on the underside of your truck? I'm curious to know how that pans out. I saw some video comparisons on different products and the used motor oil did not do very well but they did not mix with diesel so I'm curious to see how that holds ho for you. In the videos I saw, the used oil dripped off super easily and even more easily in the spots where water hits but I can't remember what viscosity they used. Did he offer any feedback on why mixing it with diesel was helpful?
  25. Dec 10, 2021 at 5:41 PM
    #85
    FortyNorth
    FortyNorth New Member
    Northern ON
    2014 Tundra Super White SR5
    There isn’t much you can hurt with FF. It just burns off the exhaust. Smells great, smells like...... Fall;)
  26. Dec 15, 2021 at 9:41 AM
    #86
    jac70
    jac70 New Member
    Southern N.H.
    2021 TRD Off Road
    Little trick I use with the FF to help out with the creeping and application in general, this is only for those that have bought the kit to use with an air compressor. Get yourself a Fry Daddy from Walmart and a large spoon scoop/laddle as well, use the scoop to transfer the FF from the gallon container to the Fry Daddy, I usually use a paint stirrer to keep it moving while it's heating up, only takes about a minute and then I can pour it into my container using a funnel. It's almost like water at this point and goes on really nice. It will creep well and then start to congeal again if done in the colder months (October for me in N.H.).
    I do agree, FF does seem to wash away easily in areas that get direct contact with water spray. I may try WW next year or the PB Surface Shield, we'll see
    SpyderRC, Spyker[OP] and classiccat like this.
  27. Dec 15, 2021 at 2:19 PM
    #87
    SpyderRC
    SpyderRC New Member
    2021 Limited Nightshade
    Thank you for that awesome idea. I’m going to pick up a fry daddy and try that next time.
  28. Dec 15, 2021 at 2:43 PM
    #88
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    Tundra812 likes this.
  29. Dec 15, 2021 at 2:57 PM
    #89
    backinit
    backinit New Member
    He didn't offer advice about mixing. I decided to do that to keep the mix thin and easier to spray. I plan on doing it 2 to 3 times a year. I've only done it once. I change the oil on 3 cars with synthetic oil so there is never a shortage.
  30. Dec 16, 2021 at 6:26 AM
    #90
    jac70
    jac70 New Member
    Southern N.H.
    2021 TRD Off Road
    I used to use bar and chain oil, that stuff is thicker than Ron Jeremy. Heat it up well and it will go on easy, as soon as you're done you need to take it down a dirt road and allow it to get covered in dust, this will help keep it intact.
    backinit likes this.
