Upgrading the audio in 2025 TRD Pro
Discussion in 'Audio & Video' started by turbohardtop, Jan 10, 2025.
  1. Jan 17, 2025 at 7:19 AM
    Snert
    Snert New Member
    2021 SR5
    Nice setup, my current setup uses an RD900/5, great amps for the money. How do you like the TW3's? My current sub is an 8w7, but I'm going to need to get a shallow sub in the near future as the 8w7 is in a center console extender box. Always like to hear people's opinions on the pros/cons of their setups.
  2. Jan 17, 2025 at 7:28 AM
    Goobax
    Goobax New Member
    2024 SR5 4x4 Tundra
    thanks! I think the TW3s perform amazingly well for a slim sub. They are certainly no w7 level of bass but have been very happy with how I’ve got everything dialed in for more of a SQ approach. I have no complaints to speak of and I am pushing them quite hard at times and never feel like I have to back off due to any reduction in performance.
  3. Jan 17, 2025 at 7:30 AM
    2020TundraVooDooBlue
    2020TundraVooDooBlue New Member
    Black@Blue19 likes this.
  4. Jan 20, 2025 at 8:56 AM
    Bobby Zee
    Bobby Zee New Member
    Bobby
    2025 Tundra 4X4 Limited
    Installing all new speakers, 10" sub, equalizer and bad ass Amp. BOSS Audio Systems PV3700 5 Channel Car Stereo Amplifier – 3700 High Output, 5 Channel
    I did look at T A C O T U N E S and realized I could save over 50% and have better sound. Every component I installed was an upgrade over TT and I didn't have to eliminate the rear plastic liner against the rear of the cab in order to put a larger than needed enclosure for a 10" sub. Glad you like your TT system.
  5. Jan 20, 2025 at 2:33 PM
    turbohardtop
    turbohardtop [OP] New Member
    I might have to build my own box for a single 10" sealed. Does anyone know where I could get a set of seat spacers similar to ones offered by TT or Fox Acoustic with their boxes.
  6. Jan 20, 2025 at 2:38 PM
    Bobby Zee
    Bobby
  7. Jan 20, 2025 at 2:50 PM
    Bobby Zee
    Bobby
    Now, you can spend several hundred dollars on a high-end subwoofer, but the one I purchased laps the TT one and it can shake the glass in the truck when you boost a 1500 watt sub with the amp I purchased. I used 1X2 furring strips, which I painted black, and adhered velcro strips to the back and to the plastic seat frame in the rear to allow sound to exit the rear seat rather than forcing it straight up through the rear seat. Dat thump, thump, thump is what you add the sub for in the first place.
  8. Jan 20, 2025 at 2:53 PM
    turbohardtop
    Could you share the speaker connectors and the mounting brackets for the front and rear?
  9. Jan 20, 2025 at 2:59 PM
    Bobby Zee
    Bobby
  10. Jan 20, 2025 at 8:21 PM
    turbohardtop
    Thanks Bobby. I am still trying to figure out my front door set. I would like to keep it simple by going with passive 2 way 6.5-6.7" components. I have a BNIB set of CDT HD62 that I plan on using for the read doors. These will be powered by a JL HD900/5.
  11. Jan 21, 2025 at 4:28 PM
    turbohardtop
    anyone have more information on the JL Stealthbox for the 22+ crewmax? I am hoping that it sits in the factory sub location.
  12. Jan 22, 2025 at 7:19 PM
    turbohardtop
    well, I decided to start collecting some gears....got PAC Audio AP4-TY14, JL HD900/5, CDT wideband system 4B for fronts, CDT HD62 for the rears, going to build a sub box with JL10W6v3 to sit on the foot area in the middle of rear seats. This will be temporary until i could find a better sub solution.
  13. Jan 22, 2025 at 7:34 PM
    Bobby Zee
    Bobby
    A marine amp? Well, some salesman at Crutchfield will be happy. Top end stuff for sure. When you get it all hooked-up, this is the song that will rattle your cab like no one's business. https://youtu.be/fXXuq4VGgBo
    Chemical Brothers, Under the Influence. My neighbors think I'm 16 when I crank it up.:yes::nuclear:
    BlackNBlu likes this.
  14. Jan 23, 2025 at 7:10 AM
    turbohardtop
    The marine series has the M designation. I just got the HD900/5. I did not get the integrated DSP since I did not want to add complication. I guess if I need DSP, I could add an external one later.
  15. Jan 23, 2025 at 8:58 AM
    Goobax
    Goobax New Member
    2024 SR5 4x4 Tundra
    IMO, you should absolutely get a DSP. Integrated makes your life easier but would not skip that purchase
  16. Jan 23, 2025 at 9:40 AM
    turbohardtop
    Thanks Goobax. I will try without the DSP to see how it sounds then add the DSP if I could not get it to sound right. I have not used a DSP before and was wondering how easy/hard to tune it correctly.
    Goobax likes this.
  17. Jan 23, 2025 at 10:01 AM
    blenton
    blenton New Member
    There are advantages to both, but I wouldn't automatically discount your non-DSP setup. DSP is simply a tool; tools are great for many things but unnecessary for other things. No need for a CNC mill when a pocket knife will open up your packages just fine.
    I'm not discounting the power of DSP, either, but good sound comes from clean signal and amps, quality drivers, and thoughtful installs. DSP can improve on that, but not fix it if it's poor quality to begin with.
    My daily has zero DSP and is very pleasing to my somewhat discerning ear (maybe just picky instead of discerning...). My sequoia has DSP but I wouldn't say it's leaps and bounds better, possibly not even marginally better. But it was a tool I was able to use for that particular setup.
  18. Jan 23, 2025 at 10:41 AM
    bailey bulldog
    bailey bulldog New Member
    I have a hybrid and was going to install a 5 channel amp @ 2400 watts. Is that to big? I have the none JBL system now.
    Also, does the factory 14" radio have a full range signal from the front speakers?
  19. Feb 3, 2025 at 9:56 AM
    #49
    turbohardtop
    I think with the hybrid, most installers want to keep it around 1000W.
    bailey bulldog likes this.
  20. Feb 3, 2025 at 9:57 AM
    #50
    turbohardtop
    Does anyone know what is the volume range for the JBL audio system? I need to figure out the 3/4 volume level number so I could adjust might amp correctly.
  21. Feb 3, 2025 at 12:28 PM
    #51
    bailey bulldog
    I think after talking w/them more, this is the max watts. Their idea is to put in a big amp and turn it down so it's more efficient and cuts down on distortion, so that makes sense. I guess we will see what happens. I'm still waiting on my hybrid box from ********* before we get going on the install.
  22. Feb 3, 2025 at 1:02 PM
    #52
    turbohardtop
    did you upgrade your door speakers? I have the JBL and am having a hard time finding the tweeter harness.
  23. Feb 3, 2025 at 1:45 PM
    #53
    bailey bulldog
    I will be, but I have the non-JBL.
