VF Tuner 3UR Support - Development Tools
Discussion in 'Performance and Tuning' started by OVTune, Apr 25, 2019.
Thread Status:
Not open for further replies.
  1. May 31, 2020 at 8:46 AM
    #3691
    shellshock
    shellshock Guy who drives a lot
    Iowa
    2019 TRD PRO
    I believe the tunes are read locked, so reads will fail.
    if the flash said it completed successfully, you’ve got it loaded. There’s really no way to verify though unless mat uses a custom ECU ID that shows up
    When you hit identify but I’m not sure if he’s still doing that or not.
    Wynnded likes this.
  2. May 31, 2020 at 9:15 AM
    #3692
    4firemandan
    4firemandan Superduper Member
    SWFL
    2016 Crewmax 4x4, 5.7
    TRD Supercharger, Ported SC inlet, RCF TB, 4.5” intake, WMI, 2.38 pulley, custom tune, DW660 inj, aeromotive fpr, msd boost-a-pump
    Ok well thats hopeful. Thanks.
    So how can I confirm this is an OVTune with the shifting? Whats something I can try that a stock ecm would do differently?
    (Doesnt that seem stock?)
  3. May 31, 2020 at 10:30 AM
    #3693
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Gotta ask the question, did you request Gear Lock and is there a "GL" in the file name? Also, I'm pretty sure that Direct Shift is not out for the masses yet.
  4. May 31, 2020 at 11:13 AM
    #3694
    4firemandan
    SWFL
    Yeah I don't think I specifically requested it this truck.
    It was there in my previous truck from him because he added it automatically back then (it was kind of the demo phase).
    Maybe now he doesn't without asking?
    I was under the impression you get it unless you request it not to be there. (Could be wrong though).
    I'll have a wideband soon enough... But until then I would really like to be sure it took.. going from n/a to SC I can't use my seat of the pants gauge to say the tune feels different. Lol.
  5. May 31, 2020 at 12:11 PM
    #3695
    Ericsopa
    Ericsopa Old man and the sea
    Are you sure it downshifted to 4, or just unlocked the TC? Sometimes kind of hard to tell. Mine's not S/C, of course, but if mine's going to actually downshift (with tow/haul off) the TC unlocks first for a second or so, then it downshifts. Two distinct movements..... unless I really stomp on it, then it's instantaneous, and usually from 50 mph drops to 3rd.
    4firemandan[QUOTED] likes this.
  6. May 31, 2020 at 12:23 PM
    #3696
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Definitely doesn't sound like you have gearlock, but from what people have said and my experience you need to explicitly ask for any features such as gear lock. You can get a blue tooth obd2 adapter and use torquepro or other apps to monitor afr. It's less range than a stand alone wideband, but all you really need to know is if you're running lean anyways. It'd be a cheap and easy way to monitor until you get a gauge.
  7. May 31, 2020 at 1:38 PM
    #3697
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I strongly suspect that it will be something you'll be able to add yourself when the vF software is out.
    Try 50mph in S4 and note your RPMs, bump it up to S5 and let it shift. Make sure you're at 50mph again then prompt it to downshift like you did before, when it does note the RPMs again. If they match then no GL. The difference between 5th locked/unlocked is kinda subtle, 5th to 4th is quite a bit less so, you probably know your truck well enough to tell the difference and you don't have GL, this is just a way to be a bit more certain.
    4firemandan[QUOTED] and Ericsopa like this.
  8. May 31, 2020 at 3:29 PM
    #3698
    4firemandan
    SWFL
    Thanks for the tips guys. I will try this out tomorrow on the way home (at fire department today).
    I do have the BT OBD2 reader but im not sure if that has access to the wideband O2's, I think its just the narrowband that are only good at 14.7.
    Ill double check the shifting again and just wait for Matt. Thanks again for the input everyone.
    Wynnded and Ericsopa like this.
  9. Jun 1, 2020 at 9:50 PM
    #3699
    4firemandan
    SWFL
    Ok so a little update on my story...
    It seems I DO have the OV flash working.
    Tonight I found that cruising in S mod with tow/haul Off ...I do have gear lock AND direct shift.
    With t/h ON , even in Sport, it DOES downshift. That's what was throwing me off.
    I did also get a Maf dash light and a pending lean dash light (pic attached).
    Not sure what's up with that.
    Cleared the code and will keep an eye on it tomorrow.
    HulkSmurf14 likes this.
  10. Jun 1, 2020 at 11:32 PM
    #3700
    CTPlatinum
    CTPlatinum New Member
    2020 Tundra Platinum 4x4
    None Yet
    Was there any backfiring? Did you check your plugs? I would be very careful, leaning out a supercharged engine is one of the best ways I know of to grenade your motor.
    snivilous and HulkSmurf14 like this.
  11. Jun 2, 2020 at 4:43 AM
    #3701
    4firemandan
    SWFL
    No backfire, havent checked the plugs yet.
    I definitely agree. Going to scan some and send it in to Matt.
    HulkSmurf14 and CTPlatinum like this.
  12. Jun 2, 2020 at 6:39 AM
    #3702
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Yep, I think that your priority would be to get Mat some data logs.
  13. Jun 2, 2020 at 3:27 PM
    #3703
    OVTune
    OVTune [OP] New Member
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    are you using a non SC tune on a SC?
    email me asap
    TruckyTruck and HulkSmurf14 like this.
  14. Jun 3, 2020 at 12:48 PM
    #3704
    Jbtaco2002
    Jbtaco2002 Almost a Tundra
    San Diego
    nothing cool
    ^ this shouldn't even be possible....
    HappyGilmore and osidepunker like this.
  15. Jun 3, 2020 at 2:23 PM
    #3705
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    ...but is.
  16. Jun 3, 2020 at 4:23 PM
    #3706
    shellshock
    Iowa
    2019 TRD PRO
    Not sure how you could prevent it. You could slap a SC on a stock truck..
  17. Jun 3, 2020 at 5:36 PM
    #3707
    4firemandan
    SWFL
    Thanks Matt @OVTune ,
    I sent you some logs and the info you requested.. email is sent. (#5357, Daniel Hardman)
  18. Jun 4, 2020 at 2:18 AM
    #3708
    Cuban11182
    Cuban11182 New Member
    Hope Mills, NC
    2018 Tundra Limited
    Kings w/ adjusters, Icon Rebound with Discover AT3 LT 285/75/R17, Airlift bags, ARB dual compressor, OV Tuning,
  19. Jun 4, 2020 at 5:29 AM
    #3709
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    Thanks for the emails, we are looking into it. I do owe a few of you updates, plan to this weekend.
    Also BREAKING NEWS.
    we now can flash 2019 ECUs, Support right over OBD. No ECU swapping.
    Full support in vF Tuner coming Friday
  20. Jun 4, 2020 at 5:38 AM
    #3710
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    :thumbsup:
  21. Jun 4, 2020 at 6:07 AM
    #3711
    Kung
    KG, VA
    No 2020's.... :oops: Goodbye cruel world....
    *throws self off cliff*
    Ok maybe not, but still, 2020 support would be awesome.
    pnw.tundra likes this.
  22. Jun 4, 2020 at 6:42 AM
    #3712
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    We need a 2020 ECU for a day or two
  23. Jun 4, 2020 at 6:57 AM
    #3713
    2Tall
    2Tall New Member
    Chance
    South MS
    2020 Super White CM SR5 4x4
    :fingerscrossed:hopefully I’m in that group for the updates!
  24. Jun 4, 2020 at 7:53 AM
    #3714
    MR TRD PRO
    MR TRD PRO New Member
    Queens, NYC
    2019 VooDoo Blue Tundra TRD Pro
    HP Tuned
    This is great news! I've been waiting for this for a long time. I guess its better than swapping in a 18' ECU
    Is the software easy enough that my local dyno tuner can work on it?
  25. Jun 4, 2020 at 8:56 AM
    #3715
    OVTune
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    2019 FFV 3UR-FBE support with proper Ethanol 4D axis / content scaling.
    Any professional dyno tuner should feel right at home with our software.
  26. Jun 4, 2020 at 10:28 AM
    #3716
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    I'd like for my 2013 to have some type of ethanol improvement. Do you think it would be worth it for a N/A truck?
  27. Jun 4, 2020 at 11:05 AM
    #3717
    pnw.tundra
    pnw.tundra PNW Tundra
    Paul
    PDX
    2022 TRD Pro | Prev 2020 Tundra aka Blue Whale
    Let me know how I can help you. I have a 2020. (formerly with OV and VF Tuner for my Taco)
  28. Jun 4, 2020 at 12:01 PM
    #3718
    MSU Tundra
    MSU Tundra Numerous rodeos experienced
    Mississippi
    2017 Tundra and 2013 LC200
    I notice you say 2019 "FFV". What about Non-FFV with Magnuson Supercharger?
  29. Jun 4, 2020 at 12:05 PM
    #3719
    shellshock
    Iowa
    2019 TRD PRO
    yesssssss :bananadance::bananadance::bananadance::bananadance::bananadance:
    now I just need my tuning for dummies guide and ill be set lol
  30. Jun 4, 2020 at 2:17 PM
    #3720
    19PlatinumCrew
    19PlatinumCrew New Member
    Dave
    MGM 19 Platinum Crew
    Toytec 3" coilover lift,295/75/18 on Method Nv,Nitto tires,Retrax cover,spray liner.
    So is this ANY 2019 both ffv and non-ffv…...do you have a cost yet?
Thread Status:
