VIPER CUT:lower front bumper
Discussion in '2.5 Gen Tundras (2014-2021)' started by PaulROahu, Feb 7, 2023.
  1. Mar 18, 2023 at 3:31 PM
    BoysandHisToys
    BoysandHisToys New Member
    Central Virginia
    2013 Tundra Crewmax Limited
    12” Bulletproof Lift, AFE CAI, AFE Exhaust, rock lights, Fas-Top tonneau and soft topper, Dasaita 10.2” radio, light bar, ditch lights, LED headlights and fog lights, LED interior lights, Amp Research rear bumper step, dashcam, BT ODBII reader and Torque app on radio
    That looks awesome! I’ve searched but couldn’t find anything, do you know if anyone as some instructions or photos of this on a 2nd Gen?
    Not sure if the lines of the 2nd Gen would look as good, but I rub at full lock in reverse and also want to move up to 40’s next tire purchase.
  2. Mar 18, 2023 at 4:22 PM
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
    Agreed great work OP. Looking for the same detailed info for my 2nd gen.
  3. Mar 18, 2023 at 5:48 PM
    PaulROahu
    PaulROahu [OP] New Member
    Paul
    Kaneohe, Hawaii
    2017 5.7 Tundra Platinum 4x4 MGM
    what i did was cut the bumper first then took the inner plastic and measured the same with an inch longer as you will push the inner plastic fender all the way forward as possible and secure to fog lamp bracket and lower bumper brace, then drill holes for the zip ties to attach so lower fender doesn’t flap in the wind and start cracking. so far it’s pretty solid with minor flex. most importantly it looks factory from inside the fender well
    Nic146 and AggiePhil like this.
