Was I duped (rust)?
Discussion in '1st Gen Tundras (2000-2006)' started by DTAG10, Nov 18, 2024.
  1. Nov 19, 2024 at 5:02 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    No one has mentioned it yet, but you might want to replace those saggy-ass springs
  2. Nov 19, 2024 at 5:38 AM
    I couldn't get past that bizarre looking overload spring, I'm wondering if are aftermarket leafs the PO replaced, chaeap aftermarket crap?
    Beyond that @DTAG10, you need to be aware, the previous owner removed the bump stops (or they sheared off, I see their bracket in that pic) that should be held to the top of the spring by the U-bolts, and that's a recipe to rip the lower shock mount right off the axle! You cannot get the OEM bump stops anymore (discontinued), but you can get the slightly taller one for a Toyota Hilux which fits our trucks. The part number is 48306-35110. You need something up there, and I've recommend replacing the U-bolts while you're at it.
    G_unit3000 likes this.
  3. Nov 19, 2024 at 5:41 AM
    noahrexion
    noahrexion New Member
    Washington
    2005 4WD DC
  4. Nov 19, 2024 at 6:44 AM
    DTAG10
    DTAG10 [OP] New Member
    04 White DC Tundra TRD
    Y’all are life savers. I’ll have $4-$5k in this pretty quick. Kinda hard to fathom being at $22k for a 20 year old truck. But 10x better than the stuff out there today.
  5. Nov 19, 2024 at 6:50 AM
    DTAG10
    It’s got 152k miles. Hopefully this will help it get to 300k without much else.
  6. Nov 19, 2024 at 8:11 AM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Someone here bought these and shortened them if I remember right.
  7. Nov 19, 2024 at 8:20 AM
    I dunno, the ATS flavored bumps at ATS @noahrexion linked look damn good for the $$
