"Watt" Portable Power Station and/or solar panel combo are you using?
Discussion in 'Off-Topic Discussion' started by Black Wolf, Jun 7, 2022.
  1. Jun 13, 2022 at 6:45 PM
    #91
    Black Wolf [OP] Bigfoot Hunter, Sasquatch too, but not Yeti
    Aurora CO
    The more I look at this the more I'm impressed.... Tight!
    Warreng[QUOTED] likes this.
  2. Jun 13, 2022 at 8:37 PM
    #92
    NoCoToyo
    NoCoToyo New Member
    Northern Colorado
    2019 Long Bed 4x4
    it's coming
    Really nice setup!
    Just per Renogy, that Rover should be installed vertically and well vented...
    Warreng[QUOTED] and FrenchToasty like this.
  3. Jun 13, 2022 at 8:46 PM
    #93
    FrenchToasty
    FrenchToasty The Desert rat, 6 lug enthusiast
    Mo
    The SoAz….. big surprise
    Bone stock
    I assume the vertical mounting is for “waterproofing”
    Just like some light ballasts call for inside engine bays. Helps keep the water down vs coming up or across into it. if he’s in a box, I bet it would be ok.
    Wallygator likes this.
  4. Jun 13, 2022 at 9:10 PM
    #94
    NoCoToyo
    NoCoToyo New Member
    Northern Colorado
    2019 Long Bed 4x4
    it's coming
    I'm pretty sure he's fine too, but this is what Renogy says:
    1. Choose Mounting Location—place the controller on a vertical surface protected from
    direct sunlight, high temperatures, and water. Make sure there is good ventilation.
    2. Check for Clearance—verify that there is sufficient room to run wires, as well as clearance
    above and below the controller for ventilation. The clearance should be at least 6 inches (150mm).
    3. Mark Holes
    4. Drill Holes
    5. Secure the charge controller.
  5. Jun 14, 2022 at 7:46 AM
    #95
    Warreng
    Warreng New Member
    thanks for the tip!
  6. Jun 19, 2022 at 8:47 PM
    #96
    Aurora CO
    Just scored this quite new model Bluetti EB3A for $239 Father's Day deal off their website! LiFeP04 battery. 600W/1200W peak..... 268wh. Crazy price considering the specs....It can accept up to a 200W solar input. Combined with AC charger....400W input charge! Bluetooth a plus!
    porkitt, Wallygator, Warreng and 2 others like this.
  7. Jun 23, 2022 at 5:37 PM
    #97
    Aurora CO
    Just got my "Renewd" 240wh Rockpals power station. $96 with Father's Day sale. Basic but quite decent. No display. Basic. Came 60% charged. Lots of various cables. Excellent deal! Pretty much the same as my Jackery 240 that was $180 refurbished but does have a decent display. Will connect a solar panel tomorrow to time top off from 60%. This will go in my underseat storage. Renewd 240wh's are now $107. Still a decent price point. My Bluetti EB3A won't ship until the 30th. I'm gonzo on July 1st..damnit
  8. Jun 25, 2022 at 10:22 PM
    #98
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    Anyone going to preorder an ecoflow wave? Looks pretty neat and I’m sure more makes/models will be coming out. Between that and a diesel heater, camping is starting to get pretty plush..
    Black Wolf[OP] likes this.
  9. Jun 26, 2022 at 5:39 AM
    #99
    Aurora CO
    I'm thinking that Wave is going to sell quite well.
    Wallygator and Mater[QUOTED] like this.
  10. Jun 26, 2022 at 10:37 AM
    #100
    BayRunner
    2017 Tundra Platinum
    Actually, I’ve been looking at in in depth lately. My thoughts are:
    Pros:
    • It looks like a good design and the smart mode looks very nice to expand battery life
    Cons:
    • It’s big and heavy (38 lbs)
    • The battery designed to work with it (attaches to the bottom) is expensive and only provides just over 3 hours run time. Hardly enough for a night of camping.
    • If you want to use an external battery pack it only works with the Delta series batteries and requires additional cables to plug into the proprietary plugs. If you wish to use some other battery pack other than the Delia series, you have to plug the wave into the AC outlets on the battery. This mode uses significantly more wattage than the straight DC connection. (200-300 watts DC, 400-500 watts AC), So unless you have the Delta battery (expensive) you loose all efficiency and are screwed.
    • The exhaust pipe hose is massive at 8” in diameter
    In summary, I think it’s looks solid but is not really designed for the average camper or at least tent camper. Instead, the following Amazon air condition is cheaper and seems more appropriate for tent camping
    https://www.amazon.com/dp/B09TDXWC4Q/?coliid=I1Y21YD5Y56CNS&colid=2XGG9ZCRUXEA1&ref_=lv_ov_lig_dp_it
  11. Jun 26, 2022 at 11:56 AM
    #101
    BayRunner
    To follow up, here is another reason. Why I think the Amazon air conditioner is better suited for tent camping. They designed it so the rear is smaller and can easily vent the heated air out the tent with no hoses.
    Black Wolf[OP] and Wallygator like this.
  12. Jun 26, 2022 at 2:09 PM
    #102
    Aurora CO
    Definitely a very nice option.....
  13. Jun 26, 2022 at 4:24 PM
    #103
    BayRunner
  14. Jun 26, 2022 at 4:28 PM
    #104
    Aurora CO
    Kuul...pun intended! Definitely post up a review. I'm certainly interested. I don't mind cooling off a hot tent. I use various tents on my property depending on how long I'm there. Got a very big cabin tent that can get quite hot inside even with the windows opened.
  15. Jun 26, 2022 at 4:54 PM
    #105
    BayRunner
    The RoofNest I have can get quite warm making it difficult to sleep. Was about to shelve camping until the Fall, but this may save the Summer.
  16. Jun 26, 2022 at 4:56 PM
    #106
    Aurora CO
    I just showed my grandson the Amazon link.........damnit!!:thumbsup:
  17. Jun 26, 2022 at 5:37 PM
    #107
    BayRunner
    Ha Ha, I notice the “left in stock” number has reduced by 1. :rofl:
  18. Jun 27, 2022 at 7:15 AM
    #108
    Warreng
    Warreng New Member
    looking forward to your thoughts. This little AC could be pretty sweet for keeping your furry friends cool in the car when unattendedx
    I have used my remote start in the past to keep the AC on but it only runs for 15min
  19. Jun 27, 2022 at 7:22 AM
    #109
    BayRunner
    Will do! Your idea may be useful but just remember to vent the heated air out of the window.
  20. Jun 27, 2022 at 7:26 AM
    #110
    BayRunner
    It’s also funny and not sure if people were watching this thread and then purchased one of these last night. I’ve been watching and reading the Amazon page for several days and the inventory count was the same. After mentioning it yesterday, 6 sold within a couple hours.
    Black Wolf[OP], Wallygator and Mater like this.
  21. Jun 30, 2022 at 6:39 AM
    #111
    BayRunner
    @Black Wolf Did you order one of these AC units off Amazon? Just curious because mine still has not shipped even though Amazon was the fulfillment and not 3rd party. There were plenty in stock when I ordered, but now says unavailable.
  22. Jul 8, 2022 at 1:23 PM
    #112
    BayRunner
  23. Jul 8, 2022 at 1:36 PM
    #113
    FrenchToasty
    Mo
    Bone stock
    I kinda skimmed your detailed review, and saw the pictures of it in your tent; why don’t you have the return air vent inside so it’s not pulling hot moist air from outside, and angle your exhaust away from it if you do have to run it that way.
    or are those both exhaust ports that are out the back of the tent?
  24. Jul 8, 2022 at 1:43 PM
    #114
    BayRunner
    Im not, but I can see how it’s easily confused. There are 4 air flow ports. Two in the front and 2 in the rear.
    Front 2: inside air flows in and cool air goes out
    Rear 2: outside air flows in over the condenser fins (similar to your home outside unit) and heated air flows out.
    This pic is a better explanation.
    Black Wolf[OP], Mater and Wallygator like this.
  25. Jul 8, 2022 at 1:54 PM
    #115
    FrenchToasty
    Mo
    Bone stock
    That makes a lot more sense, thanks
  26. Jul 14, 2022 at 7:55 AM
    #116
    Aurora CO
    I bought a 2 pack of the 100W compact design Renogy solar panels on Prime Day for $154. The set is 16% off now on Renogy's site for $210. I saved $56 which is nice. I also ordered two pair of Renogy 10ft 10AWG solar extension cables to mate up with the Rockpals mc4/Anderson parallel Y cable I also snagged on Prime Day. My new Bluetti EB3A has a 200W capable input which will charge super quick using the paralleled Renogy panels. Will work great with my Rockpals 614wh Freeman too!
  27. Jul 14, 2022 at 7:58 AM
    #117
    Aurora CO
  28. Jul 14, 2022 at 8:21 AM
    #118
    Aurora CO
    I haven't ordered one yet but I think I'm gonna get it!
  29. Jul 14, 2022 at 9:54 AM
    #119
    BayRunner
    That’s a nice setup
  30. Jul 14, 2022 at 10:00 AM
    #120
    BayRunner
    I think it’s worth it. I don’t know if you saw my review on it but I’m fairly impressed, especially with how little power it uses.
    Even though I got 9 hours of use with my EcoFlow River Pro power station, the conditions were favored that night. In order to make sure I have enough power for the whole night of AC when I’m primitive camping, I just ordered the Bluetti AC200Max. Was on Prime Day sale and has good power to drive the air compressor ditikner.
