What engine oil/filter combo are you guys using?
Discussion in '1st Gen Tundras (2000-2006)' started by Alltimehigh, Mar 13, 2020.
  1. Nov 28, 2022 at 7:34 AM
    #91
    Punisher1
    Punisher1 New Member
    Dale
    2020 Tundra TRD PRO
    285/75R18 Goodyear Duratracs
    To OhWhendTRD.....So you use just the OE of Amsoil and at a much heavier weight than the owners manual states. How many miles have you got on that 21 model and did you notice any fuel mileage decrease with heavier oil? Pro's Cons'
  2. Nov 28, 2022 at 7:37 AM
    #92
    Punisher1
    Dale
    2020 Tundra TRD PRO
    Anyone using a heavier oil than 0W20 notice fuel mileage decrease? What benefits did you get and what negatives did you get along with how many miles you have on your truck and how long you ran that heavier weight?
  3. Nov 28, 2022 at 7:49 AM
    #93
    I run 5W30 as specified for heavier use such as towing. Mileage seems pretty much the same. 63k miles. Engine is much quieter.
    txagg and Punisher1[QUOTED] like this.
  4. Nov 28, 2022 at 6:44 PM
    #94
    Punisher1
    Dale
    2020 Tundra TRD PRO
    Thanks for the info...I may try it ....just have been apprehensive about changing since oil cap and owners manual states 0W20
  5. Nov 28, 2022 at 6:44 PM
    #95
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler
    I wouldn't consider it drastically heavier. Did 0w-20 at 5k and 10k, at 15k I switched to 5w-30 to see how the engine operated with OE Amsoil. I first tried Pennzoil 5w-30 on our Malibu (requires 0w-20 too) ran just fine - no issues or changes to mpg. On the Tundra, first 3 changes the oil resembled water and wanted to consider something thicker. Good portion of this forum uses 5w-30 or other variation from 0w-20, some are very drastic when compared. I'm at 16900 miles so far (1900 miles w/ 5w-30), no issues with a ton of smiles per gallon. Haven't paid close attention to the mpg, knew what I was getting when I bought it, just fill 'er up and enjoy what it was made for.
    Punisher1[QUOTED] likes this.
  6. Nov 28, 2022 at 6:49 PM
    #96
    OHwendTrd
    Josh
    21 SR5 3UR-FE
    ATF Cooler
    Few good hours of toilet reading material. Caution, leg failure when standing.
    Switching to 5w30.
    https://www.tundras.com/threads/switching-to-5w30.64203/
  7. Nov 28, 2022 at 6:52 PM
    #97
    OHwendTrd
    Josh
    21 SR5 3UR-FE
    ATF Cooler
    Literally just realized this is a 2000-2006 thread ... Damn, my bad! Now exiting.
    FrenchToasty likes this.
  8. Nov 28, 2022 at 6:53 PM
    #98
    Punisher1
    Dale
    2020 Tundra TRD PRO
    Thanks OhwendTRD for the link ...I'll check it out. @KNABORES I think you guys are gonna get me to change. :)
    OHwendTrd likes this.
  9. Nov 29, 2022 at 3:25 PM
    #99
    Dook55
    Dook55 RCLB Guy
    Montana
    2004 4x4 V8 RCLB 2006 4x4 V8 RCLB
    I just found this thread. I didn't realize you guys were using such low viscosity oils. I've been using Mobil 1 full synthetic for the last couple hundred miles and Wix filters. No problems cold starting down to zero. I think the 0-w30 is a good idea on a new engine for 40K miles or so, especially in the North. At 235K miles my oil still looks pretty clean at 10K miles when I change it, but it's almost all highway and I have a Frantz aux filter.
  10. Nov 29, 2022 at 3:31 PM
    #100
    This is the 1st Gen forum (2000-2006). Do you also have a 1st Gen truck? If not, you probably shouldn't listen to what we're saying in this thread. :rofl:
    Dook55[QUOTED] likes this.
  11. Nov 29, 2022 at 3:32 PM
    #101
    @Alltimehigh
    Just to avoid someone screwing up their truck later by putting the wrong oil weight in it, can you go back to your very 1st reply in this thread, and look above the top right corner of that 1st post, click the THREAD TOOLS button, and EDIT SUBJECT to say something about this being a 1st Gen / 2000-2006 thread in the title?
  12. Nov 29, 2022 at 3:34 PM
    #102
    Dook55
    Dook55 RCLB Guy
    Montana
    Yes. I have 2004 and 2006 LCLB. Both 4.7 and 4x4.
    shifty`[QUOTED] likes this.
  13. Nov 29, 2022 at 5:51 PM
    #103
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    I've been running 0w-20 in my 04 for 5 years and 50k on 10k oil changes. Just rolled over 214k.
  14. Nov 30, 2022 at 10:18 AM
    #104
    ericryder
    ericryder Nailbender
    Eric
    HILLSBOROUGH
    '04 SR5 3.4 5 speed access cab
    Head unit and door speakers aluminum ladder rack
    Getting ready for the first oil change in the new-to-me 5VZ-FE. Will be installing a Fumoto drain, Wix/NAPA Gold filter and whatever 5W-30 is in those jugs that I have leftover from my '95 K1500 (I put 230K miles on that over the years, so it'll be fine). Planning on 5K changes. The previous owner had oil changes done by Monroe or a local shop (gave me a folder with receipts for every service done to it).
  15. Nov 30, 2022 at 11:41 AM
    #105
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I can't believe we're up to 4 pages in this thread.
  16. Nov 30, 2022 at 12:23 PM
    #106
    Little lube goes a long way? :rofl:
  17. Nov 30, 2022 at 1:06 PM
    #107
    SES378
    SES378 New Member
    2015 Toyota Limited TRD Offroad 2WD
    Bilstein 6112/5160, Total Chaos UCA, Coachbuilder Shackles, Toyo AT2 295/70/18 tires
    5/30 synthetic with a Toyota oem filter
  18. Nov 30, 2022 at 1:52 PM
    #108
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    It's the Astroglide thread.
  19. Nov 30, 2022 at 2:07 PM
    #109
    Kentucky Jelly.
