  1. Oct 6, 2021 at 6:21 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    You’ve got a plainer right?!
  2. Oct 6, 2021 at 6:22 PM
    Cummins3500
    Cummins3500 Never finishes.....
    Logan
    Where you headed in Tn? @lsaami
  3. Oct 6, 2021 at 6:25 PM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    Franklin area for a wedding, then out east for a solo (me plus wife) camping trip in Cherokee national forest.
    KarmaKannon likes this.
  4. Oct 6, 2021 at 6:30 PM
    FirstGenVol
    East TN
    2002 AC
    @lsaami Why does your air compressor look so huge? Just a weird camera angle?
    lsaami and FrenchToasty like this.
  5. Oct 6, 2021 at 6:33 PM
    shifty` Oddfellows local 151 behind the firehouse
    This is why I'm not a carpenter. Measure once, then twice, then five more times, cut twice as many, then start over. The only thing I've ever had luck building is speaker enclosures, for whatever reason, but the software we used told you exactly what size to cut all the pieces, what angles to use.
    Sorry to hear about your luck! Just got back from Greenville SC here, packing tonight and heading TN also tomorrow, just west of Prentice-Cooper.
    FrenchToasty likes this.
  6. Oct 7, 2021 at 4:49 AM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    Partially a wierd angle, and partially, it’s just a big compressor. It’s the Viair 150PSI 2gallon air source kit.
    https://www.amazon.com/VIAIR-150-PS...ds=viair+air+source+kit&qid=1633607254&sr=8-5
    I decided it was too big for this and bought another one off Amazon. Holy crap is Amazon overnight a game changer! Ordered stuff at 9PM last night, it was sitting on my porch when I woke up at 5:30.
  7. Oct 7, 2021 at 12:27 PM
    Outbound
    Aaron
    Northern Alberta
    Apparently I'm the only one in town who has ever heard of axle shims. So much for the shops that call themselves "off road specialists" or "driveline experts". Clearly all they do is bolt on accessories or weld weights onto driveshafts.
    If I plugged the right numbers into the calculator @Desert Dog provided, then it would seem that I need 5 degree shims. Guess I'm tracking down the parts online and attempting the install myself. It doesn't seem like a huge job, so how hard can it be? Yeah...we all know how that works out.
    bmf4069, Darkness, RUSTYNUTS and 2 others like this.
  8. Oct 7, 2021 at 2:13 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    Need to find an oldschool shop that knows about pinion angle shims lol.
    Might be worth doing new U-bolts while you're at it.
    I'd pick up a digital angle gauge to get a more accurate reading, if you've been using one of those needle style ones.
  9. Oct 7, 2021 at 5:18 PM
    Openbaffle
    Openbaffle New Member
    2006 Phantom Gray Tundra X-SP DC
    Got it back from the shop today. Those 1.25" spacers make the stance look MINT in my opinion. Front end is all rebuilt. LBJs, LCAs and tie rods all OEM. Spidertrax 1.25" spacers on all four corners and the OME lift/level. Sitting a little tall right now. Center of hub to bottom of fender is 29.5" in rear and 30" in front. Should settle some and be level or raked about 1/4" in the front ideally. I still need to install my tough country bumper next week, so may end up lifting the back an inch in the near future. Getting closer. More to do. Only was able to drive it 10 mins or so tonight, but drives awesome thus far.
    ETA the actual measurements are 22.5” in the rear and 23” in the front center of hub to bottom of fender.
    freerider8, bmf4069, Darkness and 6 others like this.
  10. Oct 7, 2021 at 5:51 PM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    Are you sure your hub to fender measurements were around 30"? I was thinking my fully drooped rear was around 31-31.5" from center of hub to bottom of fender. Fully compressed on mine is about 17.5". Ride height on mine should be about 23-24" in the rear.
    Darkness likes this.
  11. Oct 7, 2021 at 5:54 PM
    Openbaffle
    Yea — just re checked not sure where I got that from. Long day. 23” in front, 22.5” in rear.
    CodyP and Darkness like this.
  12. Oct 7, 2021 at 5:56 PM
    FrenchToasty
    Mo
    Bone stock
    @shifty` I know it’s not perfect, but I tried a little harder, still not 100% done.
    @BubbaW do you have a recommended circuit to tap into at the interior lower fuse panel for ignition only power(relay trigger) I was planning on using one of those add a circuit fuse thingys, but open to suggestions.
    C3AE163F-E5F2-441E-8889-7470ACBB4328.jpg 6BB63229-0A2D-4602-9843-B359A302BB7C.jpg 6830C041-66DB-4DAD-B533-7DCFD7869200.jpg
    All airline is ran and tied in, waiting for pressure test
    bmf4069, Darkness, alb1k and 3 others like this.
  13. Oct 7, 2021 at 5:57 PM
    KarmaKannon
    Utah
    Some junk
    Oh yeah that sounds much better. I was just wondering. I was pretty sure I had my droop numbers right and I have about 7" up travel at ride height so if your numbers were right then I had no idea how much travel my rear has haha.
  14. Oct 7, 2021 at 6:02 PM
    KarmaKannon
    Utah
    Some junk
    If you have more electric planned you could do like I did and buy an amp wiring kit and run the power/ ground to a little fuse box under the cup holders or any wiring I suppose, but amp kits with inline fuses are pretty cheap. I fit a 6 blade under there if I recall. I tied into the radio ignition wire for my relayed stuff I just want hot if they key is on. It was the easiest to find and identify since it all was about the same area.
  15. Oct 7, 2021 at 6:55 PM
    Truckin' Girl 1117
    Truckin' Girl 1117 Custom
    Christine
    Grafton
    2003 Black Tundra Xtracab
    Is that a part you can buy? I have 2 broken ones. Annoying to have the dog sticking his head out the window, or hear the damn thing flapping around.
    Darkness and FrenchToasty like this.
  16. Oct 7, 2021 at 6:57 PM
    Truckin' Girl 1117
    Christine
    Grafton
    des2mtn likes this.
  17. Oct 7, 2021 at 7:00 PM
    Truckin' Girl 1117
    Christine
    Grafton
    LOL! i'd just be happy with an exhaust system that wasn't all patched together and didn't leak!
  18. Oct 7, 2021 at 9:58 PM
    Desert Dog
    Desert Dog Nobody rides for free
    2001 SR5 AC 2WD 4.7l
    Bilstein 5100's, SPC UCA's, ATS HD leaves
    Yes, unfortunately, many "off-road" shops are nothing more than parts-hangers and pre-made kit installers that can't assist a customer with an actual issue that's outside their box and that's OK too.
    Shims are typically sold in degrees of two (2,4,6, etc.). If you can't find 5* and dont have the wherewithall to have them made, I would try 4* shims since the natural tendency of the drive line is to point upward under load. Probably your safest, best bet if you can't find 5* or make them or have them made.
    Keep us posted. I wondered how things were going for you since you've been MIA for the most part. Lol.
    Outbound[QUOTED] likes this.
  19. Oct 8, 2021 at 12:05 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    toyotas with LSPV. so anything newer than 2004 or 1st gen tundras its useless
  20. Oct 8, 2021 at 12:06 AM
    empty_lord
    05 rollover special
    easy fix for that, just pull the assembly off like i did! (i really need to get an exhaust together for the truck...)
  21. Oct 8, 2021 at 5:22 AM
    robabeatle
    robabeatle New Member
    AZ
    2002 Tundra 4x4 LTD AC
    Bilstein 6112 & 5160, Katskinz, audio upgrades
    Yup, iirc I bought mine on Amazon.
  22. Oct 8, 2021 at 5:33 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    It is indeed….the below is an example from McGeorge Toyota for a 2003 AC in Oak. There are other places to purchase them that are cheaper if you wish.
    https://toyotaparts.mcgeorgetoyota....MIycLbk-i68wIV1cDICh1VGgQBEAQYASABEgIN6_D_BwE
    Also a howto thread….
    https://www.tundras.com/threads/access-cab-window-latch-repair.26105/
    Darkness and daveeasa like this.
  23. Oct 8, 2021 at 5:52 AM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    For my 04 it would be IGN1(10amp) or IGN2(20amp). In case it matters, what will the relay be triggering ?
  24. Oct 8, 2021 at 5:54 AM
    FrenchToasty
    Mo
    Bone stock
    Relay will trigger mamba air compressor, I believe they’re are 40 amp relays. I’ll take a look when I get to work, I had add a circuits but they might be the bigger style 0160E013-BDC9-49A9-BF96-2C9D16429F86.jpg
  25. Oct 8, 2021 at 5:57 AM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    In that case, wouldn’t underhood fuse panels be better with properly sized wire ? Don’t know anything about Mamba’s, so maybe others have suggestions !
  26. Oct 8, 2021 at 6:07 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    For high current stuff I've had better luck with contactors/solenoids a continuous duty one like this should last you a long time.
    https://www.waytekwire.com/item/80432/Trombetta-684-1221-012-02-12V-Powerseal-DC/
  27. Oct 8, 2021 at 6:23 AM
    FrenchToasty
    Mo
    Bone stock
    So the mamba has its own power supply, fused 10g I believe(from the factory) that will tie in straight to the battery.
    I then need keyed ignition source power; that will then be fed to a rocker isolation switch; I’m thinking of mounting it on the seat mount bolt closest to the hump on the driver side.
    So it’s just a relay trigger, no big power needed off the keyed ignition source
    Maybe a solid state relay?
    I’ll run what ARB supplied until it fails, and then do my own MOdifications
  28. Oct 8, 2021 at 6:26 AM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    Gotcha....the 2 fuses I mentioned would still be candidates then and others may have better preference.
  29. Oct 8, 2021 at 6:52 AM
    chunk
    chunk New Member
    110 miles north of Los Angeles, Ca.
    SR5 2001 Tundra, original owner
    Bone stock
    Yep, I'm pretty sure I bought it from ebay. I looked for a link, but ebay makes it hard to search old invoices going back a few years and I can't find the original invoice. I'm sure if you do a new search you can find them. I'll look some more and if I can find a link I'll post it. cheers.
  30. Oct 8, 2021 at 8:12 AM
    Outbound
    Aaron
    Northern Alberta
    I ended up ordering 6 degree shims since I kept coming up with 5 to 7 degrees on the calculator depending where I placed my angle finder and tape measure.
    I'll definitely report back once I get them installed.
    Desert Dog[QUOTED] likes this.
