  1. Jul 7, 2018 at 12:27 PM
    #631
    Afkouki
    Afkouki New Member
    2006 Natural White Limited
    I use superbrightleds.com for everything
    because_wumbo-truck and Outbound like this.
  2. Jul 7, 2018 at 12:43 PM
    #632
    Casper421
    In the woods
    06 DC
    I have leds in everything up front and back and haven’t had an issue with blowing fuses. Only issue I had was with the turn signals hyper flashing but I just corrected that issue this morning.
    Afkouki[QUOTED] likes this.
  3. Jul 7, 2018 at 12:45 PM
    #633
    Afkouki
    Afkouki New Member
    Interesting...what bulbs did you use for the side markers/blinkers
  4. Jul 7, 2018 at 12:50 PM
    #634
    Casper421
    In the woods
    06 DC
    Amazon specials. Cant remember which brands.
  5. Jul 7, 2018 at 1:47 PM
    #635
    Casper421
    In the woods
    06 DC
  6. Jul 7, 2018 at 4:49 PM
    #636
    Casper421
    In the woods
    06 DC
    Replaced all spark plug tube seals and valve cover gaskets.
    Passenger side:
    Driver side with leaking #5 seal:
    Cleaned up and with new seals, gasket. Punctured 2 of the blue seals so bought a few oem. Should’ve bought the full set from toyota but time will tell how they hold up.
  7. Jul 7, 2018 at 4:56 PM
    #637
    Professional Hand Model
    Hand Protectors
    Fit n’ Finish again today. Removed front grill and spray painted black and kept the chrome. Basically, factory look but new. Thats mucho work, but looks so fresh again. Put new licence plate frames on as the old were cracked and wobbly.
    Heads up that Advanced Auto Parts is having a sale on Mobil 1 ‘Advanced Full Synthetic’ (their top of the line 15k miles oil). Buy 5 quarts for $35 (normally $42) and get a free Mobil 1 extra performance oil filter ($15 value) free! Jumped on that deal and bought 2 deals at $70.
    Casper421 likes this.
  8. Jul 7, 2018 at 4:59 PM
    #638
    Hand Protectors
    Nice. How many hours job is this for you?
  9. Jul 7, 2018 at 5:03 PM
    #639
    Casper421
    In the woods
    06 DC
    Just over 5 hours with taking my time. Could do it much quicker now. Cleaning the drivers side valve cover was the most time consuming part.
  10. Jul 7, 2018 at 5:19 PM
    #640
    Hand Protectors
    You putting in a new PCV valve? How do your ignition coils look? I’ve seen pics of little pin hole blow outs on the bottom part of the shafts. Had to replace one at 140k miles. The other 7 doing fine right now. They are expensive at about $120 each as I priced them out yesterday from Toyota.
  11. Jul 7, 2018 at 5:29 PM
    #641
    Casper421
    In the woods
    06 DC
    Yes, put in a new PCV valve even though the old one was still operating properly. I like to start fresh plus they’re cheap. This whole job was because of the #5 ignition coil, other 7 were clean. Old vs new:
    I picked up the new one of Amazon for $90.
    https://www.amazon.com/gp/product/B00FZMYD7O/ref=oh_aui_detailpage_o09_s00?ie=UTF8&psc=1
    Dragracingdan and Jerry311SD like this.
  12. Jul 7, 2018 at 5:41 PM
    #642
    Casper421
    In the woods
    06 DC
    I also fixed my turn signal hyper flashing issue I got after converting them to LED with the SmartTap CF18 flasher relay.
    lc69hunter and Afkouki like this.
  13. Jul 7, 2018 at 5:46 PM
    #643
    Hand Protectors
    Ok. It was the #6? coil that went bad on mine. Drivers side 2nd one (from front of truck) or 3rd one (from drivers seat). What type plugs you using? Currently running NGK regulars. Thinking going with Iridiums next change.
  14. Jul 7, 2018 at 6:16 PM
    #644
    Casper421
    In the woods
    06 DC
    The cylinder you’re talking about is #3. 1,3,5,7 on driver/ 2,4,6,8 on passenger from front back. I’m running Denso SK20R11; coincidently what Haynes recommends. For your 02, Denso K20R-U or NGK BKR63YA(both regular) are recommended.
  15. Jul 7, 2018 at 9:34 PM
    #645
    Jerry311SD
    Jerry311SD New Member
    Jerry
    Ramona San Diego CA
    05 Tundra
    Blue LED in all four doors. Added blue LEDs in the front to lite up the floor and two blue LEDs in the rear next to the seats. Everything is soldered and heat shrinked and kinda hidden so you cant see it unless you look for it .
    Also in the map lights
    Totally better in person then the pictures but here ya go..
  16. Jul 10, 2018 at 4:18 AM
    #646
    Dragracingdan
    Dragracingdan New Member
    2003 Tundra Limited
    First time trying one of those headlight refresh kits
    Before
    After
  17. Jul 10, 2018 at 3:57 PM
    #647
    jhead7416
    jhead7416 New Member
    West Georgia
    2006 Tundra Limited DC
    Brush Guard, sprayed in bedliner, reverse camera, more to come
    Great job, looks like new. What kit did you use?
    Matty4wd and Dragracingdan like this.
  18. Jul 10, 2018 at 4:04 PM
    #648
    Dragracingdan
    2003 Tundra Limited
  19. Jul 10, 2018 at 5:44 PM
    #649
    jhead7416
    West Georgia
    I remember running across the application video while searching around for a restoration kit. Looked too easy but glad to know it actually works that well. Thanks
  20. Jul 11, 2018 at 5:00 AM
    #650
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Ran it through the car wash since this is my life all summer. Live on a dirt road and have no garage.
    Rex Kramer likes this.
  21. Jul 12, 2018 at 8:03 PM
    #651
    Jerry311SD
    Jerry
    Ramona San Diego CA
    05 Tundra
    Put in a 6 disk stock stereo in today.
  22. Jul 13, 2018 at 11:12 AM
    #652
    Casper421
    In the woods
    06 DC
    Got a check engine light after replacing the valve cover gaskets and spark tube seals. Code was p0020, camshaft position A actuator circuit(bank 2). Retraced my steps and sure enough, I forgot to plug in the sensor in bank 2. Made me feel like a dummy!
  23. Jul 13, 2018 at 1:32 PM
    #653
    Jerry311SD
    Jerry
    Ramona San Diego CA
    05 Tundra
    Back up camera today. 24.99 on Amazon
    Super easy.
  24. Jul 13, 2018 at 5:12 PM
    #654
    Afkouki
    Afkouki New Member
    Link? I would like one of these.
    Got the correct LED bulbs for the front. You do have to get the CK type bulbs. Never heard of them before now.. the more ya know. First pic is LED on passenger side. Second pic is both with blinker on.
  25. Jul 13, 2018 at 5:59 PM
    #655
    Festerw
    Festerw New Member
    04 Tundra DC
    Not the same camera but here's the one I did this spring.
    AUTO-VOX Dual Video Inputs 4.3" https://www.amazon.com/dp/B00J863EI2/ref=cm_sw_r_cp_apa_CPusBbZ3GVDRN
    AUTO-VOX Cam1 HD Car Rear View Backup Camera https://www.amazon.com/dp/B01DNMDVY8/ref=cm_sw_r_cp_apa_HQusBbZGQNAZ2
    Pics are in this post, wasn't the cheapest but it works great and the mirror goes on Lightning Deals for $80 frequently.
    https://www.tundras.com/threads/wha...1st-gen-tundra-today.2558/page-13#post-604317
  26. Jul 13, 2018 at 6:01 PM
    #656
    Festerw
    Festerw New Member
    04 Tundra DC
    Out with the old, took the golf cart at work and traded it in for a newer model.
  27. Jul 13, 2018 at 8:59 PM
    #657
    Jerry311SD
    Jerry
    Ramona San Diego CA
    05 Tundra
  28. Jul 13, 2018 at 9:53 PM
    #658
    Jerry311SD
    Jerry
    Ramona San Diego CA
    05 Tundra
    What bulbs did you throw in the fog lights??
    I need that.
    az chip likes this.
  29. Jul 14, 2018 at 5:11 AM
    #659
    Afkouki
    Afkouki New Member
    Jerry311SD[QUOTED] likes this.
  30. Jul 14, 2018 at 1:49 PM
    #660
    Festerw
    Festerw New Member
    04 Tundra DC
    Washed it! $20 for a foam cannon was well spent.
    Matty4wd and Casper421 like this.
