  1. Apr 25, 2025 at 8:55 AM
    Dakillacore
    Dakillacore This aggression will not stand, man.
    Georgia
    2006 Toyota Tundra Limited DC V8 2WD
    All physical repairs use bondo (body filler/mud) to help flatten out repairs. Metal panels very rarely can be beat out perfectly straight, so body filler is used to bridge that gap. There really isn't anything wrong with it if its prepared correctly with hardener and also prepped for paint right. The preparation phase is what causes the bondo cracks and failuers.
    Also, a lot of the bad bondo jobs that you have probably seen is from lower quality repair shops/techs that just put inches of bondo instead of even repairing the panel beforehand. They get paid the labor hours for the repairs but instead just throw a thick layer to save time. It's not meant to be used this way and only as a thin-ish layer to help with the metal smoothness. You probably haven't even noticed a good repair with body filler because it was done correctly.
    Hi06silver[QUOTED] likes this.
  2. Apr 25, 2025 at 9:14 AM
    Dblock500
    Dblock500 New Member
    DMV
    2002 SR5 AC 4.7 V8 4WD
    Drained the transmission for my very 1st time, pretty much filled up the entire 5qt bucket, and looks pretty clean.
    BroHon, Filthyphil, khooiii and 3 others like this.
  3. Apr 25, 2025 at 9:35 AM
    Hi06silver
    Hi06silver Fat. Thumbs.
    Ryan
    2006 DC 4x4 Waltrip
    5 inch TC Lift. Icon 2.5 Ext. travel coilovers- Icon Resi- shocks w/Firestrone air-ride 285/75/17 Toyo OC Ext. FN Overlander wheels Retrofit Projectors Kenwood H/U Natika Back-up camera
    That is one of the weirdest lines ever in a song.
    shifty`[QUOTED] likes this.
  4. Apr 25, 2025 at 11:21 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    I just fucking sent it. I drove it last week and didn't hear any wahwah sounds so I said fuck it. Got the brakes replaced Tuesday night with Casey, then lifted the driver front almost 2 inches. It's pretty well leveled out now, but I have a ton of caster now. I'm gonna give those uppers to Terry and let him work his magic.
    That work you did is holding up extremely well. I put it through some tough shit and it at it up. Thank you so, so much for what you built. It's amazing. The brakes are superbly amazing. I may need a bit more bias to the rear. I was able to lock the fronts up on pavement, but not the rears.
    805Tundra, KNABORES, BroHon and 10 others like this.
  5. Apr 25, 2025 at 12:43 PM
    Dblock500
    DMV
    So we've restested, all the other pins on the oem end of the harness you pictured are giving readings when using blinkers, pressing brakes, etc. However, only the center pin thats supposed to be the 12v isnt giving anything. We tested at the battery w/the 30a fuse harness and the grey connector, those also gave readings. Even tried testing to make sure the 3rd brake light and leds are working properly by connecting the loose wires to the battery terminal--they worked fine. Some reason the center pin or whatever wire running from the battery isn't giving constant hot/12v to the rear harness. Might just have to rerun a brand new line from the battery to the rear at this point
  6. Apr 25, 2025 at 12:51 PM
    Fragman
    Fragman New Member
    TX
    2006 Tundra DC SR5 2WD V8
    Bet you were sweating just a little as it got closer and closer to the top!
  7. Apr 25, 2025 at 12:57 PM
    Dblock500
    DMV
    Haha i was. I was like shit, let me grab the drain plug and get it ready just in case...
  8. Apr 25, 2025 at 1:19 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Just this week a 2001 owner dealt with this same issue regarding lack of voltage to that center pin and thankfully made a separate thread concerning his issue.
    If you feel like pursuing it further before running new wire, in link below, those are the connectors(IA4 and BB1) and location you can look for. Your 02 will be same as their 01.
    01 Access Cab Trailer lights wiring?
    shifty` and Dblock500[QUOTED] like this.
  9. Apr 25, 2025 at 2:30 PM
    Dblock500
    DMV
    Thank youu, you're right--perfect timing. The black wire at BB1 is good, at least right before the connector itself. Its hard to get to the actual BB1 connector under the seat, but able to access the wire from coming out of the loom and measure. Is there a way to get under the seat where those connectors are without just removing the entire seat? Update, actually able to test it at the connector too and got a reading. Which would mean its likely just failing somewhere along the frame
    BubbaW[QUOTED] likes this.
  10. Apr 25, 2025 at 2:39 PM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    As for your question about seat removal, I had to on my 04 when I needed to check a connection under carpet....pain in ass otherwise.
    Sounds logical if you have it after BB1 toward back, you're getting closer to open....less to splice in if need be.
    Dblock500[QUOTED] likes this.
  11. Apr 25, 2025 at 3:10 PM
    JakeJake
    JakeJake Slippery Snake
    2000 Tundra AC 4X4
    Fuck yeah! Glad everything is working well together.
    Play with the bias knob some. IIRC we are somewhere in the middle of the range and should have plenty of adjustment either way. I'd try two full turns, test, and repeat until satisfied. Just tell grill which way you went so you don't forget :rofl:
  12. Apr 25, 2025 at 3:22 PM
    Dblock500
    DMV
    Yessir, will have to get back at it another day though. But the plan now is to find the failure point along the framerail, and splice into it just before that, and run the new/hot wire towards the back to the harness/connector
  13. Apr 25, 2025 at 7:23 PM
    G_unit3000
    G_unit3000 New Member
    Gman
    North East
    2005 Tundra DC 4x4
    Any chance these didn't make it into the trash? I bought 2nd Gen Tundra Diode Dynamics install kit but I haven't been able to get it to work.
  14. Apr 25, 2025 at 8:02 PM
    Staring at a dogs ass
  15. Apr 25, 2025 at 9:42 PM
    805Tundra
    805Tundra New Member
    Ben
    Central Coast
    2004 White 4x4 Double Cab
    Toytec Aluma 2.0, Camburg UCA, 5160s and more.
    Decided to finally properly test fit these tires. At full bump this tire size will never fit with wheel spacers unless I cut the entire fender as well as modify a small section of the firewall. Going to extend the bumps maybe 1/4”. I did some trimming, hammering and grinding to make them fit at almost full bump
    Cleaned/refreshed the front end as well
