  1. Jun 7, 2019 at 8:38 AM
    #7531
    Jerry311SD
    Jerry311SD New Member
    Jerry
    Ramona San Diego CA
    05 Tundra
    Oh Yeah Made my old car much more fun to drive. lol
  2. Jun 7, 2019 at 8:39 AM
    #7532
    Professional Hand Model
    Hand Protectors
    Hows that Dr. Kevorkian grease kit working for you?
  3. Jun 7, 2019 at 8:44 AM
    #7533
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    :D Good one. I'm too cheap to pay for Prime so Amazon ships my stuff whenever they feel like it. It won't arrive until Tuesday.
    Amazon will give you free shipping on any order over $35, you just have to be patient. :)
  4. Jun 7, 2019 at 9:02 AM
    #7534
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Maybe they designed the joint to flush out, the mention of grease hints at that.
  5. Jun 7, 2019 at 9:12 AM
    #7535
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    I just watch the boot and stop when it starts to plump up. I've only done it once since I run 7.5-10k between oil changes and 2 was all it took.
    It should be due next week for the next change so we'll see if it holds.
  6. Jun 7, 2019 at 12:27 PM
    #7536
    SoCalPaul
    SoCalPaul New Member
    Paul
    San Fernando Valley, CA
    2006 Tundra Access Cab Limited 4wd.
    Front Bilstein 6112 shocks & Bilstein springs. Rear Bilstein 5160 remote Reservoir shocks, Wheeler’s Off-road add-a-leafs. LED lighting. Pioneer Avic 7200NEX Nav Head unit. Borla cat back exhaust.
    Ugh, looks like my blinker fluid is low.
  7. Jun 7, 2019 at 3:55 PM
    #7537
    because_wumbo-truck
    because_wumbo-truck TTC#036 & 1st Degenerate
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    flowmaster 40, DDI injectors, sliders, bumper
    Time to pick the truck up from the shop! :spending::goingcrazy:
  8. Jun 7, 2019 at 5:01 PM
    #7538
    because_wumbo-truck
    Jon
    Houston, Texas
    Well the truck runs great. My only concern is that it's running hotter than normal and if anything the URD 170°F thermostat should be just that right? It used to run 184-186°F and now it's going into the 190's
  9. Jun 7, 2019 at 5:10 PM
    #7539
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    air bubble? set the heat on high.
    I had an bubble in my system, lukewarm heat all winter, passed it the following summer - sudden drop in rad fluid, heat suddenly back to 'inferno'. That car just had an idiot light, so..
  10. Jun 7, 2019 at 5:11 PM
    #7540
    Hand Protectors
    You had a new thermostat installed?
    Edit: Went back and read all the stuff you had done. Maybe an air bubble like NutRat says?
    Did you do one of the oddball thermostats like you brought up a while back?
  11. Jun 7, 2019 at 5:39 PM
    #7541
    because_wumbo-truck
    Jon
    Houston, Texas
    It's the Underdog Racing Development 170°F T-stat
  12. Jun 7, 2019 at 5:40 PM
    #7542
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    Yours too? Mine was high and then I drilled a hole in the bottom and drained it. It just stays misty anyway. I need to replace the damn thing because my bottom blinker bulb keeps frying.
  13. Jun 7, 2019 at 5:45 PM
    #7543
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I think that's your problem. I think my truck has run cooler since I replaced my radiator and thermostat in April. It shouldn't be running hotter.
  14. Jun 7, 2019 at 5:46 PM
    #7544
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    I know new is cheap, but since you've drilled it anyway.. Why not try to seal it up for S's & G's. Can only be gasket around the bulb or a crack along the edge of the lens. See if you can figure out where they go bad, & let us know.
  15. Jun 7, 2019 at 5:48 PM
    #7545
    because_wumbo-truck
    Jon
    Houston, Texas
    Yeah that's why I thinking it's in the wrong position. URD it well known.and revered among the Tacoma, 4runner and fjc. communities seems they don't offer near as much for 1st gen tundras. But they are a reputable source for performance parts
  16. Jun 7, 2019 at 5:49 PM
    #7546
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Maybe they shipped the wrong T-stat?
  17. Jun 7, 2019 at 5:50 PM
    #7547
    because_wumbo-truck
    Jon
    Houston, Texas
    It said 4.7 on it. So at this time I'm going with air bubble or installed upside down.
    NUDRAT[QUOTED] likes this.
  18. Jun 7, 2019 at 5:59 PM
    #7548
    Hand Protectors
    Go drive up an incline and idle for a few minutes to work that bubble out. I know when I did my Pink Coolant Conversion that it took about a days driving to stabilize the proper level in the reservoir. It wasn’t until I drove on an inclined driveway and idled til the final air trap escaped. I was monitoring the res levels after each drive and could see when more needed to be added.
    Now the fluid sits at F line when at operating temp.
  19. Jun 7, 2019 at 6:04 PM
    #7549
    KarmaKannon
    Utah
    Some junk
    I think it's the housing to lense bond that's givin up. My fiberglass fender fits the marker light assembly tightly so I think it just pried the lense off. Just need to get a new one and make some clearance on the mount I guess. Then again the dry months are here haha!
    because_wumbo-truck likes this.
  20. Jun 7, 2019 at 7:39 PM
    #7550
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    It's very easy to check and see. Easy to reach.
  21. Jun 7, 2019 at 8:42 PM
    #7551
    because_wumbo-truck
    Jon
    Houston, Texas
    I'm gunna take it back because I went to go to work at 930 tonight and my headlights weren't working and I noticed a bolt that was about to fall off the alternator.
  22. Jun 8, 2019 at 5:32 AM
    #7552
    Hand Protectors
    Whoa! You are doing the right thing by taking it back. Make the top mechanic at the shop sign off on the redo of the dodo lack of attention.
  23. Jun 8, 2019 at 7:44 AM
    #7553
    fs007
    fs007 New Member
    04 tundra
    just ordered one of these. Anyone have any experience with them? im curious as to how it will fit and sound. I have some holes in my muffler and it sounds awful. I am not convinced that the noise im hearing isn't part of a exhaust manifold leak, but my mechanics think its the muffler...they did a dry ice test, so Im gonna see if this will fix it. Wanted a new one anyway so fingers crossed. Flowmaster 52571 70 Series Muffler - 2.50 Offset IN / 2.50 Center OUT - Mild Sound
  24. Jun 8, 2019 at 8:15 AM
    #7554
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    No experience with that one, but I ordered one of these to put in my truck.
    https://www.amazon.com/Aero-Turbine...0006577&s=gateway&sprefix=aero+turbine&sr=8-1
    fs007[QUOTED] likes this.
  25. Jun 8, 2019 at 8:54 AM
    #7555
    MDobb79
    MDobb79 New Member
    SLC, UT
    2006 Tundra DC TRD
    3.5" Lift, ICON Extended Travel 2.5" Coilovers, Camburg Upper Control Arms, Total Chaos Steering Rack Bushings and Differential Drop Kit. Rear ICON Add-A-Leafs, ICON 2.0 VS Extended Travel Shocks. 16x8 SCS Ray10's and BFG All Terrain KO2's 295/75/16s
    Well I got my new leafs with Icon AAL's and Icon shocks on last night. It was a major bitch! Had to cut the drivers side shock off top and bottom and the top of the passengers side. These were original from when I bought the truck new in 06. Anyways, I had a passenger side lean and it was about an 1" lower from center of hub to bottom side of flare. Now it is only about 1/2”. I suspect that the front passenger side is the cause of this but I'll know for certain in a couple of weeks when I get the Icon CO's on and adjusted. I am going to add a 1/4” shim on the driver's side CO to help with the known driver's side lean so I don't have to add additional pre-load to get each side to be leveled. The ride is now night and day difference, super plush and very very quiet compared to the old leafs, 1" block and original TRD bilstein's. Pretty happy with the outcome.
  26. Jun 8, 2019 at 9:17 AM
    #7556
    because_wumbo-truck
    Jon
    Houston, Texas
    Yeah I was.pissed.when I got it.the truck at night and the headlights.didnt come on. I popped the hood to check fuses and saw the loose bolt. That stuff plus the high coolant temp and today I noticed the reservoir.was almost empty.
    My family.has given this shop our business for decades. They will make.it.right monday
    NUDRAT likes this.
  27. Jun 8, 2019 at 9:20 AM
    #7557
    because_wumbo-truck
    Jon
    Houston, Texas
    :worthless:
    bmf4069 likes this.
  28. Jun 8, 2019 at 10:50 AM
    #7558
    MDobb79
    MDobb79 New Member
    SLC, UT
    2006 Tundra DC TRD
    Hahaha. Not much to really see. Looks like stock at this point. Slightly less rake than stock. Bilstein's set at 3rd notch. I'll get a picture when I have the icons CO's and Camburgs on.
    TX-TRD1stGEN likes this.
  29. Jun 8, 2019 at 12:44 PM
    #7559
    because_wumbo-truck
    Jon
    Houston, Texas
    What rear leafs did you go with?
  30. Jun 8, 2019 at 1:58 PM
    #7560
    Hny_Bdgr
    Hny_Bdgr New Member
    black 2000 toyota tundra sr5 v8 4x4
    If it fits it ships
    Not what I did to my truck today but what i have done in the last two weels to the truck
    • Wired all of my lights
    • Got tail light guards and welded my cb radio attena to them
    • mounted my reverse led pods on the roll bar
    • fully debadged the truck
    • In place of my sr5 badges I put snd gen tundra 4x4 badges
    • not pictured but I wrapped all of my o cr$p straps in paracord
    • not pictured but go my junk yard trailer hitch and vent visors on the truck
    Next projects:
    • get my snorkel on
    • fix my hvac unit
    • lift and tires
    speedtre, Acatlin96, NUDRAT and 2 others like this.
