  1. Jun 11, 2019 at 6:51 AM
    #7621
    MDobb79
    MDobb79 New Member
    SLC, UT
    2006 Tundra DC TRD
    3.5" Lift, ICON Extended Travel 2.5" Coilovers, Camburg Upper Control Arms, Total Chaos Steering Rack Bushings and Differential Drop Kit. Rear ICON Add-A-Leafs, ICON 2.0 VS Extended Travel Shocks. 16x8 SCS Ray10's and BFG All Terrain KO2's 295/75/16s
  2. Jun 11, 2019 at 8:04 AM
    #7622
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Well it was a Chrysler product!
  3. Jun 11, 2019 at 4:38 PM
    #7623
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Installed my stubby antenna today.
  4. Jun 11, 2019 at 4:40 PM
    #7624
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
  5. Jun 11, 2019 at 5:07 PM
    #7625
    JustGotDuals
    JustGotDuals New Member
    Tried out a cheap clay bar kit and wax on her today!...then it rained of course
    because_wumbo-truck likes this.
  6. Jun 11, 2019 at 5:20 PM
    #7626
    because_wumbo-truck
    because_wumbo-truck TTC#036 & 1st Degenerate
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    flowmaster 40, DDI injectors, sliders, bumper
    Sounds like Texas lol
    JustGotDuals[QUOTED] likes this.
  7. Jun 11, 2019 at 9:23 PM
    #7627
    SCRunner12
    SCRunner12 New Member
    Robert
    Santa Cruz, CA
    2015 SR5 Crewmax
    Well changed my oil for the first time since owning it. Went smooth till I tried to install a fumoto valve. Damn previous owner cross threaded the drain plug so the fumoto wouldn’t fit. Had to reinstall the plug and will try to rethread at the next oil change.
    Also removed the skid plate to find only 4/5 bolts holding it on and all 4 were different sizes, lengths types of bolts. Left it off so I can install new bolts that match. Anyone know the skid plate bolt sizes?
  8. Jun 11, 2019 at 10:21 PM
    #7628
    Need to know stuff
    Need to know stuff New Member
    2000 black Tundra TRD
    3 front 2 rear leveling
    20190610_164014.jpg 20190610_185521.jpg threw some 35x12.5r17 super swamper TSLs on her and hit some mud
    do i need to say anything more? It's badass:mudding::oldglory:
  9. Jun 12, 2019 at 12:26 AM
    #7629
    because_wumbo-truck
    Jon
    Houston, Texas
    How bad do they rub?
  10. Jun 12, 2019 at 6:22 AM
    #7630
    Need to know stuff
    Like rolling thunder
    I trimmed the bumper back about 3 inches cause its bashed up and im planning on doing a tube one. And I trimmed the fender well back on the bottom rear a little. Im planning on grinding the pinch weld i just bashed over all the way down and just putting a bead along there for more clearance
    Plus a uca and new bilstiens are coming for an extra inch of lift in the front. I may flip the rear shackles for more lift in the read or be lazy and do lift blocks. Definitly will post up wich path i go
  11. Jun 12, 2019 at 6:37 AM
    #7631
    because_wumbo-truck
    Jon
    Houston, Texas
    Do you already have an add a leaf? I highly recommend the wheelers progressive AAL. I've had it on all 3 of my yotas
  12. Jun 12, 2019 at 6:39 AM
    #7632
    Need to know stuff
    Nope, its stock rear hieghts and just a cheap 2 inch spacer in the front
  13. Jun 12, 2019 at 6:53 AM
    #7633
    Need to know stuff
    Plus I'm an ofroader, wont the AAL stiffen up the rear?
    I don't mind squaring with load for work at all so its not a problem.
    Here she20190611_103734.jpg is with a 700 lb fireplace above/behind the rear axle.
    NUDRAT likes this.
  14. Jun 12, 2019 at 7:08 AM
    #7634
    because_wumbo-truck
    Jon
    Houston, Texas
    I single AAL will.
    I have stock leafs with the overload removed and a 3 leaf progressive AAL with Bilstein 5160s and I've taken mine to a rocky off-road park. Had a blast with no issues.
    https://youtu.be/iCQH_FxgJLM
    https://youtu.be/3w9M0nu3xkI
    SoCalPaul likes this.
  15. Jun 12, 2019 at 7:14 AM
    #7635
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    That is how a truck should look. Awesome!
  16. Jun 12, 2019 at 7:21 AM
    #7636
    Hooptytrix
    Hooptytrix Squeaky Chicken
    Dirty South
    2000 AC 4x4, 2001 AC 4x4 Sold. 2005 DC SR5 2WD
    Electric impact guns will not budge that nut. Spend some time on craigslist or similar, you will find a decent air compressor and gun. I picked up a bostich gun and a small pancake compressor for $100, that had enough oomph to get that nut moved.
  17. Jun 12, 2019 at 7:26 AM
    #7637
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I think the Milwaukee Fuel series would have done it. The Mid Torque model is rated at 450 ft lbs. He just didn't rent one with enough power and I didn't bother to check it at the time. I'm just helping him out and assumed he had done his research. He's more of a "wing it" guy and I'm not. I won't make that mistake again.
    "Delivering 450 ft-lbs Fastening torque and 600 ft-lbs Nut-Busting torque, the M18 FUEL Mid-Torque Impact Wrench is more powerful while also being up to 4" shorter and up to 2 lbs lighter than many competitive impact wrenches."
    tvpierce likes this.
  18. Jun 12, 2019 at 7:27 AM
    #7638
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Where is that waterfall? Looks like the smokies. GA or TN?
    speedtre likes this.
  19. Jun 12, 2019 at 7:29 AM
    #7639
    speedtre
    speedtre New Member
    Inland Northwest
    I was thinking the same thing...
  20. Jun 12, 2019 at 7:35 AM
    #7640
    tvpierce
    tvpierce Formerly New Member
    Maine
    Wow. You indicated in an earlier post, the cordless impact drivers have come a long way, and indeed they have. I have an air-impact gun and a compressor, so it's hard for me to justify the expense of cordless, but it's good to know they're a legit option these days.
    Thanks!
  21. Jun 12, 2019 at 9:02 AM
    #7641
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Like he said that's the mid range too. They've got a 3/4" drive now that'll hit 1500 ft-lbs.
  22. Jun 12, 2019 at 12:44 PM
    #7642
    Need to know stuff
    Over in Washington southwest area near mount st Helens area. Hidden way down some abandoned road
    FirstGenVol[QUOTED] and speedtre like this.
  23. Jun 12, 2019 at 1:32 PM
    #7643
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    My Milwaukee would probably handle the axle nut but would be hitting forever before it broke loose. I would save time by doing a pipe on a breaker bar and be done.
    FirstGenVol likes this.
  24. Jun 12, 2019 at 2:46 PM
    #7644
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Do you guys think plastidip would come off after being stepped on?
    I'd like to dip the entire rear bumper but I'm afraid it will peel off the plastic. If I only do the chrome I'll have 2 different shades of black since the plastic is faded.
  25. Jun 12, 2019 at 3:06 PM
    #7645
    Festerw
    Festerw New Member
    04 Tundra DC
    More than likely. Some Krylon Fusion would be a better choice I think.
  26. Jun 12, 2019 at 3:17 PM
    #7646
    Professional Hand Model
    Hand Protectors
    Rear Diff test this week seems to confirm 2 things:
    1) The 3oz. of CRC Posi-lube for LSD that I put in last week has eliminated the occasional low speed slight grumble from stop while making sharp turns. I’ve had both Mobil1 for LS (grumbly/no bueno) and switched to the much less expensive Lucas (dino) for LS (nice but time has shown it needs a little more fortification).
    2) My LSD works fine on the loose gravel as both rear wheels foot prints burned out equally.
    Moving on to the 4Hi test, I went into some grass and gunned the engine trying to get all fours to peel. The truck grabbed and torqued with no peel marks. The torque was amazing and she really squats into the power.
    NUDRAT and because_wumbo-truck like this.
  27. Jun 12, 2019 at 3:22 PM
    #7647
    Hand Protectors
    Never used the Fusion.
    Rustoleum Industrial Enamel (matte) has worked well on all my truck trim. No primer. Just straight out of the can. Prep is necessary, though.
    The Industrial has a high output larger can. Makes for fast precision work versus some of these other dinky weak spray cans. Cost is $7?
  28. Jun 12, 2019 at 3:39 PM
    #7648
    Festerw
    Festerw New Member
    04 Tundra DC
    Any paint will work with proper prep, the Fusion just has some type of witchcraft in it that makes it more flexible on plastic and no prep besides cleaning.
  29. Jun 12, 2019 at 4:00 PM
    #7649
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Plastidip would do what it is meant to do, it would peel right off. I would just use it on the chrome and leave the plastic as is.
  30. Jun 12, 2019 at 5:05 PM
    #7650
    because_wumbo-truck
    Jon
    Houston, Texas
    Just paint the chrome with Rust-Oleum black.
    1. Remove bumper from truck and remove all plastic.
    2. scuff the chrome pretty good with sand paper. Clean with something like alcohol and let sit about 10 mins after you are done.
    3. Apply 2-3 coats of Rust-Oleum self-etching primer.
    4. Apply 3-5 coats Rust-Oleum black.
    5. (Optional) apply 1-3 coats of clear.
    6. Once cured, reinstall.
    I painted all the chrome parts on my two tacos. Remember to wait about 30 mins to an hour between coats to fully dry. And about 3 hours after final coat before reinstalling.
    FirstGenVol[QUOTED] likes this.
