  1. Nov 28, 2019 at 11:41 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Those Toro 2 stroke blowers are really under rated. Used to use them at work and up to 8 inches of snow they're awesome.
    KarmaKannon[QUOTED] likes this.
  2. Nov 28, 2019 at 12:59 PM
    bmf4069
    bmf4069 Something something Miller Lite
    Beau
    TX
    02 AC sr5 4wd v8
    Oh damn, I forgot to post the other day I tried stirring the pot. I got these the other day.
  3. Nov 28, 2019 at 2:33 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    What tool is it I need to replace those hubs? And is it the same one to do the UBJs? I'm gonna run to china freight tomorrow (after the madness dies down) and buy it. Ball joint press I believe?
  4. Nov 28, 2019 at 3:12 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    You can borrow a ball joint press from advance. I couldn't make it work but others have. It's a spacing issue. You have to swing the spindle out so you can fit the press.
    ESTundra937 and bmf4069[QUOTED] like this.
  5. Nov 28, 2019 at 3:34 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    I figure this will be the first of many times I need one so I'll buy one. Why I bought the rear bearing/axle separator thingy remains a mystery...
    Zjohn14 likes this.
  6. Nov 28, 2019 at 7:32 PM
    speedtre
    speedtre New Member
    Inland Northwest
    So what did you go with on the OME setup wise and how much was it?? I'm probably ordering from wheelers too, but I'm torn between an OME setup or a Bilstein 6112 w/Wheelers 700lb sorings and 5160s or an OME setup.
    because_wumbo-truck likes this.
  7. Nov 29, 2019 at 2:30 AM
    marbleville
    marbleville Agent Provocateur
    Yep, last name too.
    State of Confusion
    2002 Thunder Gray Metallic TRD.
    Air freshener died, washer fluid empty, wipers streak.
    After struggling with the harmonic balancer's removal this past weekend and getting nowhere without a puller, I did manage to remove it late Monday evening in the dark. My neighbor and I decided to wait until Friday to finish the timing belt and water pump replacement so I decided to clean up a couple parts and paint them along with a serpentine belt tensioner I purchased earlier. Primed and painted with POR 15 Blue, and with a new OEM thermostat and gasket installed.
    Actually the paint when on smoothly and evenly, the picture's lighting doesn't do it justice. You can believe it that I used wire brushes - wooden handled and drill mounted, 2" sanding discs, and wet or dry sandpaper on them suckers for at least 5 or 6 hours.
  8. Nov 29, 2019 at 4:53 AM
    imDementeD
    imDementeD New Member
    2003 Tundra Limited 4x4 Trd Supercharger
    I went with:
    • 90004 x2 front shocks
    • 60091 x2 rear shocks
    • 2886 springs (they are titled rear springs but someone mentioned they do not make 886 rears so probably just a mistake on wheeler's end)
    • Total: $687 shipped from Wheeler's
    • Energy Suspension Insulator kit - The OME springs are narrower so to reuse the top hats I bought these on Amazon for $17.32 (total for everything $705.73
    All of the "tundra" ome kits come with 885 springs which are 590lb so I went with 886 as they are 660lb rated for the extra weight of front bumper and winch. We'll see how it goes!
    speedtre[QUOTED] likes this.
  9. Nov 29, 2019 at 5:09 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    How much off roading do you plan on doing? I think the OME is designed for more frequent off road use. I almost went that route myself. I don't think you would be disappointed with either choice.
  10. Nov 29, 2019 at 5:41 AM
    Zjohn14
    Zjohn14 New Member
    Zachery
    2006 Tundra Limited Crew
    4" lift, 20" bead locks, 305/85 General Grabber A2, Bilstein shocks, 2" wheel spacers, nerf bars/step rails, bull bar w/ 11.5" led lightbar, replaced oem fog lights with LED cube lights, custom grill, tinted w/s, cold air intake, flow master Exhaust, rear brakes converted to disc, ARE hard shell bed cover, weather tech floor mats, pioneer touchscreen w/rear cam, bed has rhino liner & also under coated frame.
    Decided that I'm going go tmrw afternoon an have a set of the XD882 Monster wheels put on my DC Tundra. I'll post some pics tomorrow.
  11. Nov 29, 2019 at 5:52 AM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    Oooh - pretty. I didn't know they did blue. I love a clean sparkly engine bay. Nice work!
  12. Nov 29, 2019 at 5:59 AM
    Professional Hand Model
    Hand Protectors
    You can tell the prep work was done properly. Same here on not knowing about the blue. Looks nice!
    marbleville likes this.
  13. Nov 29, 2019 at 6:00 AM
    speedtre
    speedtre New Member
    Inland Northwest
    That was me that saw the Wheelers typo...:)
  14. Nov 29, 2019 at 6:06 AM
    speedtre
    speedtre New Member
    Inland Northwest
    Well, if we move out to the PNW, this spring/summer like planned it will basically become our camping rig and 3rd vehicle when needed...so hopefully a decent amount.
    FirstGenVol[QUOTED] likes this.
  15. Nov 29, 2019 at 6:35 AM
    imDementeD
    Perfect! I'm blaming you if it's wrong :D haha Appreciate it!!!!
  16. Nov 29, 2019 at 7:11 AM
    marbleville
    Yep, last name too.
    State of Confusion
    Sadly, as far as Washington state goes, the places to really kick it up are diminishing fast as the timber companies vast acreage and the state forests are increasingly being gated to trespass. Between the garbage dumping, to include sofas, mattresses and often enough, toxic chemicals from meth labs, to attempting to get ahead of terrorists that might set the forests on fire, and the fact that there is very little logging going on - which means next to zero oversight, its become cheaper manpower wise to just install the gates.
    Now should you move here as you stated and you like to hunt, I would be happy to put you on to some reasonably good bear hunting spots and clue you in on our elk herds and where they hang out, though the competition is pretty fierce with regards to the elk. Blacktail deer, a small subspecies of the mule deer, are everywhere and next to impossible to hunt as our timber and brush is so lavish and thick. On the east side of the Cascade mountains is open country with plenty of muleys, especially in the alfalfa fields and elk in spots. Under a lottery permit system a lucky hunter can hunt big horn sheep, and moose. And in those Cascade, and possibly the Olympic mountains, I believe there is still a season for mountain goats.
    Lastly the fishing can be quite good. And it can be quite poor. As most of our fisheries are anadromous fisheries, the sea conditions often take an extreme toll now with the global warming and changing pH. But when it does work, fingers crossed it can lead to some great fishing for 5 species of Pacific salmon plus my favorite, the steelhead trout. Our rivers don't hold a lot of trout as they typically go to sea, whether rainbows - to become steelhead, or cutthroat trout - to become sea run cutthroats. We do manage on some rivers to have a fair population of Dolly Varden - commonly called bull trout, though most rivers are closed to targeting them.
    The PNW is a fantastic place to live if you are into the great outdoors, but be aware that the greenery is a result of a fairly constant rainy season from September to the end of June, with October through March typically the rainiest period. I've travel through all the states except Maine, lived on both coast in various places, plus Hawaii and Alaska and I wouldn't trade Washington for any of them, rain or not.
  17. Nov 29, 2019 at 7:57 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    @bmf4069 if you're doing front bearings you'll just need a ball joint separator to get the spindles out. The leverage press kind works if you are keeping the ball joints, if not a pickle fork will do. If replacing ball joints, while you have the spindle out the ball joint press for the upper should be a breeze.
    For the bearing I'm not sure if 4wd is the same as 2wd but for 2wd you need a big special socket that has 4 pins that insert to the hub nut. I think that may be 2wd only though, I would imagine 4wd bearings might be held in by the axle nut instead.
    bmf4069 likes this.
  18. Nov 29, 2019 at 7:59 AM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    I only needed a tie rod puller, I used a ball P hammer on the LCA at the ball joint, then lightly tapped the ball joint with some wood and hammer
    bmf4069 and Darkness[QUOTED] like this.
  19. Nov 29, 2019 at 8:09 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    That works too but depends if there is rust involved, I've never been a fan of banging on parts. If he replaces his upper ball joints he will need a press.
    bmf4069 and FrenchToasty[QUOTED] like this.
  20. Nov 29, 2019 at 9:06 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    I don't have the UBJs yet, but if they're bad enough I'll just run and buy some. I believe it's just a hub nut on there. This is a 2 part project so I don't overwhelm myself again. Hubs/bearings today, UBJ/LBJ and axles later. And swaybar links sometime.
  21. Nov 29, 2019 at 10:17 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    • Cleaned MAF sensor
    • Went to remove the extra fuel vapor filter only to find it was already gone.
    • Dropped my spare tire and greased the rear cross member and hit the other areas I missed.
    NUDRAT, bmf4069 and Darkness like this.
  22. Nov 29, 2019 at 10:29 AM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Bought this cause it was stupid cheap. Meant for a 09-14 F150 but Amp doesn’t make one for our 1st gens anyways so figured I’d see if I Could make it work.
    KarmaKannon and bmf4069 like this.
  23. Nov 29, 2019 at 11:25 AM
    Hand Protectors
    Had two different people (passengers) comment on my lumbar support mod I posted about last week using the food insulation. They had no idea until getting in that anything was done. Both said, ‘Wow this lumbar support is nice!’. Pic #2
    I also said there was a bonus mod coming in which similar materials were to be used. I added insulation around the perimeter of the front seat cushions to bulk up the sides and leg edge. Pic #1
    Both mods make a huge difference in comfortability at zero cost. In retrospect, one could cut in half a pool spaghetti floaty or similar half round foam object and stuff in these areas.
    One more easy mod that makes the truck even better. Considering doing some seat track bushing cushions at a later date (for grins), as another mod.
  24. Nov 29, 2019 at 11:37 AM
    Hand Protectors
    When is the ‘Sham Pow!’ gonna happen? We are patiently waiting.
  25. Nov 29, 2019 at 12:31 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Was gonna be today, but I remembered my jack is in the shop. And it's a bit cold out side. I might get it tomorrow. On a side note, my brakes are doing the squeak in reverse thing again. I'm wondering what that is now....
  26. Nov 29, 2019 at 1:02 PM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    I started that yesterday. I was hoping it was just the weather and moisture because it wasn't there today. I did however get a strange rolling vibration (think rrrmmmmm ---------- rrrmmmmmm---------)in what I'm assuming was the front end at speeds under 40mph and it went away when I engaged 4wd. Strange stuff.
  27. Nov 29, 2019 at 1:33 PM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    Got the new u-joint installed today. It didn’t change much. It might have made it slightly better, but that could be placebo effect.
    I think I discovered what the actual cause of vibration is. My inner CVs have a TON of up/down play, meaning the bearings or whatever they ride inside the diff is shot. And time have part numbers in those? I’m trying to look at diagrams, but they Toyota diagram is a bit confusing.
  28. Nov 29, 2019 at 2:05 PM
    Hand Protectors
    My brakes have squealed in reverse ever since the first shoes were changed back there. Look at it as a ‘back up warning device’.
    KarmaKannon and marbleville like this.
  29. Nov 29, 2019 at 2:17 PM
    Hand Protectors
  30. Nov 29, 2019 at 2:29 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Man, you've been chasing that ghost all year. If it's a front diff issue, would you really feel that all the time, even in 2WD?
    lsaami[QUOTED] likes this.
