  1. Dec 22, 2019 at 10:44 AM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    My opinion, not that you asked. Go for the pump. As close to zero mess as you can get.
    I've used this one a few times for quart and gallon gear oil bottles. It even works for cold gear oil. Quick and easy. The gallon style doesn't thread into the quarts, but it still works fine for them. The pump is right up there with my vacuum pump for oil that allows me to suck hot engine oil out of the dipstick.
    https://www.amazon.com/Slippery-Pete-Fluid-GALLON-BOTTLES/dp/B07DTS8N7P
  2. Dec 22, 2019 at 10:53 AM
    because_wumbo-truck
    because_wumbo-truck TTC#036 & 1st Degenerate
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    flowmaster 40, DDI injectors, sliders, bumper
    May your stocking be abundant with moisturiser, gojo, germ-x, and Dawn.
  3. Dec 22, 2019 at 11:03 AM
    Professional Hand Model
    Hand Protectors
    Unscented!
    KarmaKannon likes this.
  4. Dec 22, 2019 at 11:05 AM
    Hand Protectors
    Edit PEX not PVC
  5. Dec 22, 2019 at 11:55 AM
    FirstGenVol
    East TN
    2002 AC
    You're saying this won't thread onto a qt container but still works? Does it let you get all the fluid and not leave some at the bottom?
  6. Dec 22, 2019 at 12:05 PM
    Army_of_One
    Army_of_One New Member
    2019 MGM 4X4 CrewMax, 2005 Cement 4x4 Double Cab
    OEM+
    I used a pump luke the one shown. It definitely leaves a couple of ounces in the bottle. I had a few bottles though, so pouring the left overs into another wasn't that big of a deal. Using it for the rear different took forever though.
  7. Dec 22, 2019 at 12:12 PM
    2000Strong
    2000Strong Just a dude and his truck
    Benjamin
    Washington
    2000 Maroon Tundra, AC, Premium Audio, SR5 4.7
    All LED Interior lights, New Headlights, Break Controler, LineX Bedliner.
    I tried but didn’t have the supplies. I ordered a white led and am going to replace the green led inside the drivers door for the light on auto for the window.
  8. Dec 22, 2019 at 1:16 PM
    KarmaKannon
    Utah
    Some junk
    The quart style one is supposed to take longer. The gallon version took me maybe 4 minutes of pumping slowly or less to fill the front diff with 30-40* gear oil
    It won't thread into the quarts, but will pump from them fine. I think I had to tilt it, but it got most of the oil out of the quart bottles and as army of one stated you can just combine your nearly empty quarts from there. He just must have been using a different pump than me because both of mine from slippery Pete have been pretty quick to fill a differential.
  9. Dec 22, 2019 at 2:21 PM
    jImmegart
    jImmegart Second Youngest tundra owner in the west!
    Jonah
    California
    2003 Tundra TRD Sport
    FN Counter steer type X w/ 285/70r17 Geolanders JBA y-pipe and pro street 6000 muffler 2.5 king coilovers w/ total chaos uca and custom 2.0 king rears Skidrow front plate TRD Sport package W/ Factory rear swaybar and LSD
    My glove box blub is out, what kinda bulb is it?
  10. Dec 22, 2019 at 2:28 PM
    2000Strong
    Benjamin
    Washington
    Pc74
  11. Dec 22, 2019 at 2:29 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    T5, 74 bulb.
  12. Dec 22, 2019 at 2:37 PM
    jImmegart
    Jonah
    California
    How the hell do I get the bulb out, my hands don't fit in the nest? Is there a secret method to this?
  13. Dec 22, 2019 at 2:38 PM
    2000Strong
    Benjamin
    Washington
    Any fix ideas?
    Happened after like 40 hours of nothing but medium to heavy rain.
  14. Dec 22, 2019 at 2:39 PM
    2000Strong
    Benjamin
    Washington
    I’m not shure, I think it pops open of you squeeze it but my plastic was so brittle it just broke so.
  15. Dec 22, 2019 at 2:42 PM
    FirstGenVol
    East TN
    2002 AC
    Be careful. I broke the bulb and now it's ruined. I can't dig out the remaining glass.
  16. Dec 22, 2019 at 2:44 PM
    jImmegart
    Jonah
    California
    should it just pop if I pull it down? or do I need to pinch something at the top. Its hard to see I might try taking out my glove box tomorrow.
  17. Dec 22, 2019 at 2:48 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    While it can be done without removing, for me it was much easier and less obtrusive to remove box. Can check a few other things while it's out.
  18. Dec 22, 2019 at 2:51 PM
    ESTundra937
    ESTundra937 All American Paratrooper
    Eddie
    San Diego
    2019 TRD Sport 4x4, 2003 SR5 Moto truck
    I watched a LED swap video and the guy was removing the old bulbs with a piece of tape. He would wrap as much as possible around the bulb and pull. Pretty neat trick.
    Edit: Here is the vid:
    https://youtu.be/HT8ZYEF4NDo
    because_wumbo-truck likes this.
  19. Dec 22, 2019 at 2:53 PM
    jImmegart
    Jonah
    California
    I will try it before I remove glovebox. For a t5 74 bulb, Do I need a new socket? Or will a led just fit?
  20. Dec 22, 2019 at 3:01 PM
    empty_lord
    05 rollover special
    Pop the cover tab, use pliers. Don’t push too hard on the bulb or you’ll shatter it
  21. Dec 22, 2019 at 3:04 PM
    jImmegart
    Jonah
    California
    I could only buy a back of ten bulbs, is 74 the size of the overhead lights also front and rear?
  22. Dec 22, 2019 at 3:06 PM
    empty_lord
    05 rollover special
    No. 74 bulb is the small bulbs in the dash and the foot bulb on the driver side though
    Overhead bulbs are festoon bulbs
  23. Dec 22, 2019 at 3:09 PM
    jImmegart
    Jonah
    California
    Im not a big fan of bright lights in dash, I have it very low so I will leave those but the foot well one sounds good. What about the door lights?
  24. Dec 22, 2019 at 3:19 PM
    Hand Protectors
  25. Dec 22, 2019 at 3:35 PM
    jImmegart
    Jonah
    California
  26. Dec 22, 2019 at 3:40 PM
    empty_lord
    05 rollover special
    194 bulb
    Leds in the dash are not too bright. Plus they’ll dim
  27. Dec 22, 2019 at 3:54 PM
    Hand Protectors
    Your door LED is circled in red. Your T-5 bag of LED lights will fit under as the footwell light as well. Your question was vague so hope this answers it.
    TX-TRD1stGEN and NUDRAT like this.
  28. Dec 22, 2019 at 4:02 PM
    empty_lord
    05 rollover special
    It’s pricey, but I kinda like this thing
  29. Dec 22, 2019 at 4:02 PM
    Hand Protectors
    I’d be leary of using LED bulbs in every light behind the instrument cluster as some of the warning lights act as a resistor from some readings I’ve done. An LED in those areas will impact negatively some things. Anybody with me or is this BS?
    The only bulbs I replaced in instrument cluster with LED are circled in red.
    NUDRAT likes this.
  30. Dec 22, 2019 at 4:04 PM
    KarmaKannon
    Utah
    Some junk
    You must tell me where!
