  1. Jul 25, 2020 at 3:10 PM
    Surf_spear_Mex
    Surf_spear_Mex New Member
    Patrick
    05 tundra ac
    5100 w/ dobinsons hd springs set at bottom circ ring. Freedom off road uca's
    Tundra2 likes this.
  2. Jul 25, 2020 at 3:16 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Couldn't you just buy new coil boots, or are the 2UZ-FE coils mucho different than the 5VZ-FE? I know I could have just gotten new boots, but after 18 years decided the $150 for new coils with boots were worth it.
    Thrussn[QUOTED] and NUDRAT like this.
  3. Jul 25, 2020 at 3:43 PM
    Casper421
    In the woods
    06 DC
    If the spring rate is high enough, you might not need your sway bar. I removed mine beginning of the year and didn’t notice a difference in body roll at all. Just a thought and could save you some cash.
  4. Jul 25, 2020 at 4:06 PM
    Surf_spear_Mex
    Patrick
    05 tundra ac
    Interesting, I have a 2005 ac 4x4. I will be driving 5k miles to and from Mexico (where I live in the winter) so not all offroad use. I'm getting the dobinsons hd springs due to the fact I'll have a steel front bumper and winch. If I could delete the sway bar with no adverse affects on the road I'm game but would have to get some good feed back to take her off. I'm a sheep when it comes to this stuff lol
    Darkness likes this.
  5. Jul 25, 2020 at 4:21 PM
    Casper421
    In the woods
    06 DC
    @Darkness @toyotech2016 @FirstGenVol
    Darkness and Tundra2 like this.
  6. Jul 25, 2020 at 4:46 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Loaded up the new fridge today which happens to fit perfectly. I'll eventually build a little platform for the slide. We went back to that old tunnel. I wanted to see how those Baja lights did. They are amazing. I just need to adjust them.
    There was even more water than last year.
    Halfway through the tunnel we came up on a Jeep going the opposite way. That was interesting. Thankfully we were able to hug the walls and squeeze past each other. I'll try to post that video later.
    https://youtu.be/vM8ksiKbjD0
    There were some huge mud pits I avoided.
    https://youtu.be/b3WQATUTPJM
  7. Jul 25, 2020 at 5:37 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    For some reason my dash cam either does really short clips or real long ones. Here is where I'm trying to hug the wall so we can get past that Jeep.
    https://www.youtube.com/watch?v=ikCHk8YS47o
    Here is a 5 minute video if anyone wants to see what East TN looks like in the summer. At the end of this video you can see where some rednecks flipped and burned an SUV. I couldn't even tell what it was but it really pissed me off. They have ruined this area with tons of trash and broken glass.
    https://www.youtube.com/watch?v=J-JQJ_UAaDw
  8. Jul 25, 2020 at 5:38 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    You could always remove the links temporarily and try it out. If the sway bothers you it's easy to put them back. I think Erik put his back.
    I took my swaybar completely off when I had 600lb springs and it leaned through turns for sure but never felt out of control. I run 650lb springs and aftermarket leaf springs now, I can force a lean if I pitch it but in normal driving it feels normal I guess, 8 years without a swaybar it's hard for me to say.
    @FirstGenVol is that in TN? Never mind, question answered. Beautiful
  9. Jul 25, 2020 at 5:42 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Yes, I didn't enjoy having my sway bar off. Chris has stiffer springs up front than me so that might have been the difference.
    And to answer your earlier question @Surf_spear_Mex I think you could run those Suspension Maxx links at stock height. Worst case you have to take them off until you lift the front.
    Yessir. This is part of the Obed Wild and Scenic River
    Surf_spear_Mex likes this.
  10. Jul 25, 2020 at 6:06 PM
    theblurry1
    theblurry1 ~
    David
    Castle Rock, CO
    2001 Thunder Grey Tundra AC Limited 4x4 V8
    (Camper conversion underway.) Rebuilt engine w/265K miles, A.R.E. camper shell (w/cab pass-through, rooftop fan, and side windows delete), bedlinered steel ladder rack (w/wooden rooftop deck and hammock mount), all LED lights (red dash, 4" side floods, 32" rear bar), Android head unit, 1.5" lift from Bilstein 5100 struts, 32" DuraTrac tires on factory rims, 1.5" wheel spacers, Moog suspension parts, SuperSprings leaf kit, diff drop, Reese trailer brake control, GoRhino Hitch Step, debadged, F-150 rear bumper, Sequoia center console unit upgrade, partial rear bench seat delete, dashcam, aftermarket speakers, 50% sound deadening coverage, custom tools unit.
    AC went out again. :(
    And the official diagnosis is, I need a new compressor.
    It was cool to have it work for a day before another clog. Shop says compressor's "binding" and struggling. Since I'm already $200 in the hole for their diagnostics, their $650 estimate for new compressor/labor isn't doable.
    I told them my plan at this point is to replace everything myself! Luckily, they'll kindly cover the refrigerant evacuation before I swap, as well as the recharge after.
    Has anyone replaced their compressor, and where'd you get yours?
    @Professional Hand Model will recommend OEM, but $775 isn't in the budget. ;)
    •This Denso one on Amazon is likely what I'll go with (comes pre-oiled and with O-rings).
    What other AC parts should I replace while I'm in there?
    Someone mentioned a few components before, but I can't find the post. So far I have:
    Denso receiver drier ("filter drier").
    Denso expansion valve. (Do I need two?)
    •Gaskets? Not sure which.
    •Condenser?
    •New high/low pressure switches not necessary (since the light is blinking, they're doing their jobs).
    Will definitely clean the evap core while it's out, too.
    Y'all, especially @shifty` , please let me know if I'm missing anything, and/or how hard this is. Although the compressor fits in/out through the wheel well, this sounds like a terrible job.
    Filthyphil likes this.
  11. Jul 25, 2020 at 6:22 PM
    Surf_spear_Mex
    Patrick
    05 tundra ac
    You are the man, thanks for getting back to me
  12. Jul 25, 2020 at 6:45 PM
    shifty` Night Train, Pine-Sol, and Kool-Aid buzz
    Seeing the pic from @Bulldog_tundra made me remember when I first got my truck. I was toying around with the idea of finding a white OEM grille chrome insert and using it with my non-chromed bumper like this, but I wasn't quite sure what it would look like until I finally wasted the 5 minutes to cobble something together.
    I really like it. Now to find a white chromed grille insert...
  13. Jul 25, 2020 at 8:50 PM
    MNtundra
    MNtundra New Member
    Tony
    Minnesnowta
    01' Tundra AC 4x4, 04' CRV 4WD
    Bilstein 5100's, 4runner Wheels 31" BFG, Rear Seat Delete
    What Leaf Springs You Running? Like’em?
  14. Jul 25, 2020 at 8:53 PM
    MNtundra
    MNtundra New Member
    Tony
    Minnesnowta
    Mind doing a write up if one doesn’t exist already?:worthless:
    bmf4069 and theblurry1[QUOTED] like this.
  15. Jul 25, 2020 at 10:28 PM
    Jake92
    Jake92 New Member
    2000 Toyota Tundra SR5 4x4 TRD
    Started doing the upper ball joint on the passenger side. It was a pain to get out. Started to press the new one in and it started pressing in crooked so I decided to call it a day and continue working on it in the morning. I also bought new Bilstein 5100s for it so those will be installed soon with Eibach Coils. I’m looking forward to taking her out on the dirt and off road with her and see how she feels with all the new parts. Also gonna do a total chaos front diff drop.
  16. Jul 26, 2020 at 12:12 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Custom Alcan, yup they've been good for several years.
  17. Jul 26, 2020 at 12:23 AM
    Thrussn
    Thrussn Plastidip Hoe
    Gabe
    NM
    Silver 2005 4.7L 4WD Access Cab
    Bilstein 5100s, SickHIDs projector housings, Plastidip everything, TRD Pro style rims, LEDs everywhere, SUPERBUMP bumpstops. Firestone Riderite air bag springs, Deaver G57s, Onboard VIAIR system, Backup Camera, light bar behind the bumper, CGS catback, Exhaust cutout after cats, JBA Shorty headers, JBA Y-Pipe, pioneer deck, pioneer speakers, kicker 10" sub w/ amp, door sound deadening, Dirtydeeds 12 pin injectors, UniChip, Skid Row Skidplate, EZ Oil Drain valve (Better than Fumoto), Oil Catch Can, & 4WD Conversion
    Looks like the coils are the same. I was trying to avoid the inevitable and do some preventative work. I'm moving soon and losing my job as of today, so I'm just scared to spend more than a dollar at a time. I think I'm gonna try out those msd coils when I either need them or can justify the money.
  18. Jul 26, 2020 at 12:57 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I'm sorry to hear that. Hopefully everything in the plan, or your plan works out.
    NUDRAT likes this.
  19. Jul 26, 2020 at 2:51 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Filled up with petrol at just below ½ tank mark. I mean like a blond "hair" just below. 194.9 miles to half a tank. Glad things are returning to normal. :D
    Checked all the dipsticks while at the servo.
    All things in spec except the power steering fluid. Was reading halfway up the "H" on the hot marking. Fluid looks kinda dingy too. May find a baster such as PHM, and change out slowly. Would like to do a full drain/fill but haven't worked out in my brain a good way even with suggestions.
  20. Jul 26, 2020 at 6:33 AM
    mcharfauros
    mcharfauros Hafa Adai
    MO
    06 AC SR5 4X4
    Dumb Truck Thangs
    Sweet Sway bar!:thumbsup:
  21. Jul 26, 2020 at 6:52 AM
    Hand Protectors
    Denso is OEM. You can go to their site and plug in your info to cross check all your necessary items, then shop out their part numbers. Some parts the Stealer might have a better price. Others not so. Shipping is a deal breaker on some heavy items so Big Gurrl usually wins there. Takes time, but you’ll figure out the best route.
    You can cross check quantities needed at online stealer sites.
    theblurry1[QUOTED] likes this.
  22. Jul 26, 2020 at 6:55 AM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    yikes. I get 150 to a half tank if I’m lucky.
    Thrussn and Tundra2[QUOTED] like this.
  23. Jul 26, 2020 at 7:02 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I'm free-wheeling at 55-75 most times on improved surfaces 98% of the time. I'm guessing you're doing more gravel, dirt roads than me.
  24. Jul 26, 2020 at 7:36 AM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    It’s interesting you say that. It’s pretty rare I see dirt or gravel in my tundra unless I’m hunting or on a job site.
    because I’m mainly an office guy now, and the office is less than 2 miles from my house, My mileage is pretty awful.
    Darkness and Tundra2[QUOTED] like this.
  25. Jul 26, 2020 at 7:40 AM
    theblurry1
    theblurry1 ~
    David
    Castle Rock, CO
    Sure thing, although hopefully I can learn how to do all the things right and thoroughly before teaching others. Really thought someone would have charted the waters by now...
    While Denso recommends replacing the drier too, still unclear on if the evaporator core and condenser should get switched as well. They have some detailed instructions on there, so I'll use those! I usually cross-check prices across Amazon, Toyota, and eBay. The Stealer is typically priciest, like in this case. What is "Big Gurrl?" And I hope you didn't mind the teasing.
  26. Jul 26, 2020 at 7:41 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    The short distance is hurting your mileage?
    I drive 100 miles a day. Since last Sunday, the 19th. I have driven around 650-660 miles.
    lsaami[QUOTED] likes this.
  27. Jul 26, 2020 at 7:43 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Same here, since I moved to a small town my mileage sucks. I try to only drive my truck on longer trips instead.
  28. Jul 26, 2020 at 7:44 AM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    Yeah, I drive like 5-6 miles a day on a normal day. There are days that there is more if I need to cover a job site, but it’s mainly short trips.
    Tundra2[QUOTED] likes this.
  29. Jul 26, 2020 at 7:46 AM
    Hand Protectors
    I relish in teasing. :rofl:
    Big Gurrl is the largest online retailer seller in the Wurrld. They know everything about you.
    Try using a local stealer that participates in the new online parts Programme. I have two stealers and one participates and the other doesn’t. Big difference in $. Local pick up makes pay online cheaper by eliminating shipping cost, as well.
    I’d replace all the parts if you are going this far. Eliminates another snafu.
  30. Jul 26, 2020 at 10:34 AM
    MNtundra
    MNtundra New Member
    Tony
    Minnesnowta
    If you don’t have a Factory Service Manual or Haynes, maybe @FirstGenVol will give you access to the digital version to aid in doing the A/C Replacement...
