  1. Nov 3, 2020 at 9:45 PM
    JSKOOL
    JSKOOL IG: @trd_jay_z06
    Jay
    Bay Area, CA
    2017 Black Tundra Limited
    3” BDS Suspension lift with Fox Coilovers with DSC. Fuel Shok wheels with 35 Nitto Ridge Grapplers03AE4607-A15D-4C50-9A65-54EE780F8F17.jpgD1D8E7E4-AD8E-4069-A856-9196E2771DC5.jpg
  2. Nov 3, 2020 at 9:54 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
  3. Nov 3, 2020 at 9:54 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
  4. Nov 3, 2020 at 9:56 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    whats up guys?
    have you seen my third gen?
    chrisb and TomGreen like this.
  5. Nov 3, 2020 at 9:57 PM
    empty_lord
    05 rollover special
    i like the 300zx i spy in the background.
  6. Nov 4, 2020 at 4:42 AM
    Professional Hand Model
    Hand Protectors
    Yep. Just cleaned up some pics out of the files. Reporting back on the longevity. So far so good.
  7. Nov 4, 2020 at 5:39 AM
    MrDirtjumper
    MrDirtjumper Ol’ dickhead
    Josh
    Slam Angelo, Texas
    06 DC TRD, 2wd to 4wd Conv.
    bassman417, oscardog86 and NUDRAT like this.
  8. Nov 4, 2020 at 7:15 AM
    TomGreen
    TomGreen New Member
    Nope
  9. Nov 4, 2020 at 7:18 AM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    @MrDirtjumper
    Pretty simple.
    Remove tailgate.
    Take their template and make the two marks.
    Drill two holes.
    Install into tailgate.
    Reinstall tailgate at a 45degree angle while putting the bar in 2nd hole.
    Bada-bing
    Bada-BOOM!
    chrisb, bassman417, NUDRAT and 2 others like this.
  10. Nov 4, 2020 at 7:44 AM
    oscardog86
    oscardog86 New Member
    Southern California
    2001 Toyota Tundra 4x4
    It says in the description that it works for 2004 -2007 Tundras. Any idea if this will work on 2000-2003 models as well? Im definitely doing this mod though if its compatible! Thanks for the heads up!
  11. Nov 4, 2020 at 8:03 AM
    Lil Steve
    Lil Steve Living the dream
    Gilbert, AZ
    2002 Tundra SR5 Access Cab 2WD V8
    It should, I installed it on my 2002 a few months ago with no trouble.
    oscardog86[QUOTED] likes this.
  12. Nov 4, 2020 at 8:33 AM
    Hand Protectors
    Hey guys. If you drill into your truck for that torsion thingy, then you might void your warranty.
    chrisb, GavinG83, bassman417 and 3 others like this.
  13. Nov 4, 2020 at 8:35 AM
    Hand Protectors
    Nice ankle socks! People with Cankles avoid that style.
    bassman417 and Darkness like this.
  14. Nov 4, 2020 at 8:40 AM
    Baller
    Baller New Member
    '05 Tundra SR5 DC
    :boink:
  15. Nov 4, 2020 at 8:43 AM
    Hand Protectors
    I think @Lil Steve said he should have drilled his hole a little higher than the template directed, but otherwise its a great mod. Costs less than my strut one, too. I wonder if I could do an extra rez mod on mine?:rofl:
    Lil Steve, theblurry1 and oscardog86 like this.
  16. Nov 4, 2020 at 8:53 AM
    oscardog86
    Southern California
    So this torsion bar would make the other strut style one not necessary correct? Sounds like the torsion bar helps with opening and closing, while the strut only helps with closing?
    @PHM: maybe both would be the best, do it!
    EDIT: Reading reviews on Amazon, it seems a lot of people use the torsion assist with the strut style assist and they work perfectly together. Maybe ill try that after i install this torsion version.
    theblurry1 likes this.
  17. Nov 4, 2020 at 9:13 AM
    Hand Protectors
    Yeah, the strut helps tremendously with opening gate. The gate opens into its normal free fall and then the strut catches the weight a little before halfway down slowing it to a soft landing. Right now I’m good with this set up because it was that drop before the strut install that I did not like. I have no problem with closing the gate, but that torsion assist up would be nice.
    I remember those reviewers you mention about using both.
  18. Nov 4, 2020 at 9:39 AM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    I think an issue you may run into would be that your overall height of tailgate and bed are shorter than ours but I’m not sure.
  19. Nov 4, 2020 at 9:40 AM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Wish I had a warranty haha
    They are actually water socks. Was out kayaking earlier in the day and decided it was mod time after I got home lol
  20. Nov 4, 2020 at 10:56 AM
    Brown Bear
    Brown Bear New Member
    Nor cal
    03 TRD offroad
    -6" RCD lift in front. -Custom leaf springs in rear 4" lift. -17" race line, raptor wheels. -35" Goodyear Duratrac. -4.88 gears. -ARB rear air locker. -ARB air compressor and tank. -Custom front sway bar quick disconnect -Custom one piece driveshaft -Black Oak Led 40 watt ditch lights.
    Finally got around to rebuilding my boat rack. I took apart the whole rack so I could scrap off all the old dupli color bed liner. I found a local shop to have it professionally bedlined. It only cost 100$ witch I thought was a pretty good price. I made new lower crossbars and reposioned the gas struts to get more lift out of them. Got it all done in time for a week long camping and fishing trip.20200809_160325.jpg 20200818_163811.jpg 20200830_145546.jpg 20201025_105008.jpg 20201025_120224.jpg 20201025_120409.jpg 20201021_113843.jpg 20201020_171526.jpg 20201022_092323.jpg IMG_2320.jpg 20201024_115412.jpg 20201022_104704.jpg20201021_184319.jpg
  21. Nov 4, 2020 at 2:13 PM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    W.I.P - FOX 2.5 with DSC, SCS F5 wheels with MT Baja ATZ 285s
    Cleaned up the new center console a little bit. Found a switch that fit for the ditch lights and found a usb plug for the audio.
    Before:
    After:
  22. Nov 4, 2020 at 2:19 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    I was rolling with that style for a year before I found a proper switch, but my dangle was next to the dimmer. Nice upgrade.
  23. Nov 4, 2020 at 2:19 PM
    270Fan
    270Fan New Member
    2004 Silver Tundra 4x4 DC
    This is really nice. Is that trim piece with the cutouts stock? Mine is just a flat trim piece and I'm going to have to cut holes for my USB and switches. Would really rather not do that because I'll probably goof it up.
  24. Nov 4, 2020 at 3:00 PM
    FirstGenVol
    FirstGenVol Ohio hater
    East TN
    2002 AC
    Got the GX460 calipers and rotors installed today. Based on other feedback I wasn't expecting I'd need to cut the dust shield so that was a surprise. I don't have a cutting tool so I had to use pliers. Haven't had a chance to drive it far but I now have a horribly soft pedal even though I bled them twice. I'm not sure what I'll try next.
    I may have to switch to banjo fittings unless I can faness that hard line further away from the suspension.
    ktundra, speedtre, oscardog86 and 2 others like this.
  25. Nov 4, 2020 at 3:06 PM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    Looks so purty!
    The soft pedal has been my big concern with doing this. Seems like mixed reviews on how bad it is and some trucks are worse than others. The preferred fix is the T100 brake master.
    speedtre and FrenchToasty like this.
  26. Nov 4, 2020 at 3:23 PM
    Hand Protectors
    This news absolutely sucks.
    TomGreen and theblurry1 like this.
  27. Nov 4, 2020 at 3:28 PM
    FirstGenVol
    East TN
    2002 AC
    People have claimed switching calipers lead to permanent soft pedal? I just assumed I still had some air in the lines I need to work out. The last time I replaced my brake lines it took a few attempts to get the pedal firm-ish again.
    FrenchToasty likes this.
  28. Nov 4, 2020 at 3:38 PM
    FrenchToasty
    FrenchToasty The Desert rat, 6 lug enthusiast
    Mo
    The SoAz….. big surprise
    Bone stock
    Softer is better? Maybe if the new calipers are working better than the old set up, the soft pedal might be a thing to learn to deal with?
    When I did a really rocky decent with rob, my abs pump? I assume was noisy AF most of the ride down and towards the bottom I kept getting soft/no pedal pressure!!!!! I topped off the Reservoir but it was still strange the pump was activating so much.
  29. Nov 4, 2020 at 3:53 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    14wa 1.89" pistons vs 13wl 1.81"
    1.81 dia. piston area is 2.57 in³. X 4 = 10.28 in³
    1.89 dia. piston area is 2.81 in³. X 4 = 11.24 in³
    So just about 1" in additional area the brake fluid presses against in total. Makes sense that the pedal would be softer, as your foot needs to travel further to make up the difference.
    oscardog86 and FirstGenVol like this.
  30. Nov 4, 2020 at 3:59 PM
    Hand Protectors
    Fluid was cooking/boiling. DOT3 boil temp is way lower than DOT5.1.
    Eriks case is a different problem.
    Lil Steve likes this.
