  1. Oct 14, 2019 at 6:38 PM
    TokerJoker
    TokerJoker ΜΟΛΩΝ ΛΑΒΕ
    Travis
    Nowhere, Specific
    2014 Black SR5 4.6 Dbl Cab
    None.....yet
    Couldn't have that kind of evidence as I did it in our hood, can't allow certain things to be made public.
  2. Oct 14, 2019 at 6:45 PM
    cforman61
    cforman61 Pupper
    Chuck
    Highlands Ranch, Colorado
    2019 Tundra SR5 TRD CrewMax
    What type and size tires are you running? Looks like you are still running the original suspension. Any rubbing issues?
  3. Oct 14, 2019 at 6:50 PM
    Bappa
    Bappa Off the grid
    Bo
    Arizona
    2018 Tundra CrewMax
    Coil overs (3”) and 295 tires, ESP storage, grab bar; RCI skids; tinted windows; rear air bags
    Would those chrome ends fit a 2018 CrewMax?
  4. Oct 14, 2019 at 7:01 PM
    Snowcat4360
    Snowcat4360 New Member
    Derek
    2018 TRD Sport Crewmax
    Century topper, bed rug, ultimate rod case
    Looks great! How do you like the fit? Any issues with gaps?
    Thanks
  5. Oct 14, 2019 at 7:36 PM
    Tchase
    Tchase MostlyLurk
    Buckley WA
    2019 White Tundra Limited
    In work
    Thanks!
    They fit really good no gaps to the body nice and snug., They have slots so there is room for adjustment. You can see the front is a little off, but I literally just slapped them on. I’ve got a list of things I need to go back and tweak, like the amp running boards etc.
    I could be wrong but I think these flairs are OEM accessories as they had Toyota part numbers and the instructions read like a shop manual.
  6. Oct 14, 2019 at 8:29 PM
    phabej
    phabej New Member
    NO LONGER HAVE A TUNDRA... Waiting
    Looks nice. Just curious how much did these set you back?
  7. Oct 14, 2019 at 8:50 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Nice job and good work with the torque wrench. Now you know you are capable of some DIY mods, good job getting your feet wet :thumbsup:
  8. Oct 14, 2019 at 8:57 PM
    Pudge
    CT
    They should depending on whether you have sonar sensors or not. But I think he still has the chrome caps on, and used white bumper shellz to cover over them
  9. Oct 14, 2019 at 9:12 PM
    Tchase
    Tchase MostlyLurk
    Buckley WA
    In work
    $585 :(
    I keep justifying the exterior as in it’s now or never if I want to color match because the paint loses pigment overtime. Same goes for the underneath it’s nice and clean. I’m really at the tipping point for an exhaust, but I told myself nothing to the engine as long as it’s under warranty although in the state’s they technically can’t gig me on it unless they can prove the mod caused the issue.
    I thought these style flairs was a happy medium and now I have an idea for offset when I get new tires.
    phabej[QUOTED] and Boerseun like this.
  10. Oct 15, 2019 at 3:57 AM
    Tmank87
    Tmank87 New Member
    Thank you, sir! Was actually much easier than I anticipated. Now I wonder how challenging the TRD fual exhaust will be!
    Pudge[QUOTED] likes this.
  11. Oct 15, 2019 at 6:39 AM
    Headlight Revolution
    Headlight Revolution New Member Vendor
    Atlanta, GA
    Haha tell you what, you pick me up a coffee this Tuesday morning and I'll have an order shipped out for you today. :rofl:Looking good my man!
    NCTundra18[QUOTED] likes this.
  12. Oct 15, 2019 at 6:51 AM
    NCTundra18
    NCTundra18 New Member
    Jeff
    Candler, NC
    2018 White Limited Crewmax
    TRD dual exhaust, Rough Country lift kit and too much money spent.
    Thanks, if i was heading to Atlanta today i sure would het you a coffee, lol.
  13. Oct 15, 2019 at 6:57 AM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Finished this up yesterday. JBL GTO609c components to replace the front and rear speakers. Once I figured out how to bypass the trash stock amp, everything sounded great!
    NeverB4 and Tchase like this.
  14. Oct 15, 2019 at 7:08 AM
    Atlanta, GA
    Haha all jokes my man, hope you're doing well! Appreciate the support!
  15. Oct 15, 2019 at 8:06 AM
    Pudge
    CT
    As long as your nuts and bolts are rust/heat seized It'll be a breeze. Just a bolt on kit, spray the nuts for a few days before you plan to do the job with some penetrating spray. Also purchase new gaskets if the kit doesn't include them, they are cheap and worth replacing while you're doing it
    NewImprovedRon likes this.
  16. Oct 15, 2019 at 8:08 AM
    Tchase
    Tchase MostlyLurk
    Buckley WA
    In work
    Plug and play? did you have to trim anything, splice any wires? Is this specific for the Tundra?
  17. Oct 15, 2019 at 8:19 AM
    Tchase
    Tchase MostlyLurk
    Buckley WA
    In work
    Just a heads up on this, the center console would not work for my wireless charger, after testing with these particular USB ports that have an on off switch. If you have something plugged in prior to turning the key on it will not power on. I found this one installed and tested last night and it works fine https://www.amazon.com/gp/product/B07MNM7F8S/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1
    Drk_Jdi likes this.
  18. Oct 15, 2019 at 8:50 AM
    ShooterReady
    ShooterReady New Member
    Joseph
    2017 Cement Tundra TRD PRO
    Got new coilovers, wheels and tires 3F3DFAAA-4ED0-46E0-9E96-8ED77ECE027C.jpg
  19. Oct 15, 2019 at 9:14 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Far from plug and play... I've already swapped out the headunit for a Pioneer AVH-W4400NEX and added a sub/amp previously. I was able to reuse the door woofer wiring, though, so just had to run a new wire up to the dash location for the tweeters, which is a mild pain in the ass. I've got a wiring harness kit coming to clean up the amp bypass I did. I had to remove the stock amp because it has a low pass filter built into it, or so it seems.
    Here's the part list:
    Speakers: https://www.amazon.com/gp/product/B00ANI3LAK/ x2
    Tweeter adapters: https://www.amazon.com/gp/product/B01BLMBHPW/
    Front door speaker adapters: https://www.amazon.com/gp/product/B06XB9XM7V/
    Rear door speaker adapters: https://www.amazon.com/gp/product/B00IIC63P8/
    Speaker wire adapters: https://www.amazon.com/gp/product/B01GEIP7RW/
    Wiring harness for amp bypass: https://www.autoharnesshouse.com/41112.html
  20. Oct 15, 2019 at 9:30 AM
    vl184009
    vl184009 Cheers Boys!
    Vicky
    Southern, Ca.
    2016 MGM CM SR5 4x4 w/Tow Pkg
    Lovin that look..
    ShooterReady[QUOTED] likes this.
  21. Oct 15, 2019 at 9:44 AM
    Tmank87
    Tmank87 New Member
    Awesome. Appreciate the guidance.
  22. Oct 15, 2019 at 9:44 AM
    Tchase
    Tchase MostlyLurk
    Buckley WA
    In work
    Thank you, with this I can at least start with the door speakers :)
  23. Oct 15, 2019 at 2:09 PM
    UPDave
    UPDave New Member
    PA soon to be Texas
    2019 Tundra SR 4X4 White
    Added the Intermittent Wipers stalk. Only one clip to disconnect now. Easy peezy.
    Just as I finished that the FexEx truck pulled up with the new Ionx 5 premium Nerf Bars. Installed in an hour. Now the wife can climb aboard without pulling and straining.
  24. Oct 15, 2019 at 2:31 PM
    Pudge
    CT
    Removed tonneau and drop in liner, cleaned the steel bed, sprayed with fluid film, installed weathertech underliner, reinstalled bed liner, installed swing case, reinstalled tonneau cover. Time consumer but easy and gives me piece of mind there is ZERO rust in the bed and it'll be good for many years to come.
  25. Oct 15, 2019 at 6:59 PM
    whiskeydrink
    whiskeydrink Asst to the Regional Manager
    West TN
    2019 QS SR5 Offroad
    added the color matched mirror caps from sparks parts. Pretty affordable and super easy mod! Gotta have more QS :spending:
    NeverB4, mgm16trdpro, Drk_Jdi and 9 others like this.
  26. Oct 15, 2019 at 7:14 PM
    Stocky Balboa
    Stocky Balboa New Member
    OC , CA
    2018 Limited TRD 4x4 CM - Cement
    Minor stuff- Tint, rear sway bar , pedal commander, TRD drop in filter DD Exhaust, Bilstein 6112/5160, stealth 32” lightbar, Cali Raised Offroad fog light replacements.
    Added these red 5.7 decals... not sure if I like them yet.
  27. Oct 15, 2019 at 7:54 PM
    Blueknights75
    Ron
    Clayton, NC
    I love them!! Link? Just need to fill in the other letters in white maybe....
    Stocky Balboa[QUOTED] likes this.
  28. Oct 15, 2019 at 8:01 PM
    I like!
  29. Oct 15, 2019 at 8:04 PM
    bigblue14
    bigblue14 New Member
    Craig
    2022 1794 Advanced Package
    TRD lift and AFE airbag arms, 285/65 Cooper AT3s
    Why this instead of Line-X or other spray in bed line?
  30. Oct 15, 2019 at 8:45 PM
    Pudge
    CT
    I don't have the money for a spray in liner. I would certainly love to have that done but can't justify the cost. I used about $5 worth of fluid film and came across that bed liner protector mat thing for cheap on craigslist, it came with the swing case.
    I also really like the durability and strength of the plastic drop in liner. I have used it to haul firewood, gravel, bricks, mulch, my old honda ATC 3 wheeler and the usual bed for the truck stuff.
    I justify my cheapness too lol. I don't use my bed too often but when I do I don't wanna worry about scratching, denting, chipping an expensive liner. I have the tonneau in a place 99% of the time and it stays very dry under there.
    I was pleasantly surprised by the fact there was zero rust and minimal paint wear under the bed liner which has been in there for 5 years and 40k miles. A lot of that can probably be attributed to the fact the truck has always had a tonneau and has been garage kept.
