  1. Mar 19, 2021 at 4:38 PM
    jonclark96
    jonclark96 Not so new member
    Jon
    Maryland
    2021 Army Green SR5
    Looks great. Anything special you did to prep the hooks before painting?
  2. Mar 19, 2021 at 4:43 PM
    DCB500
    DCB500 New Member
    David
    Oklahoma City
    2019 Tundra SR5 TSS Double Cab
    Wheels, sound system, antenna, tailgate letter inserts, Grill/Hood Bulge, Exhaust, Leather
    not like I should have. They were already painted but had some chips in them and I just scuffed it up and did a quick repaint. The next time they need it I will do better prep for sure.
  3. Mar 19, 2021 at 5:11 PM
    TNTundra16
    TNTundra16 YOU BIG DUMMY!
    Cam
    Amish Country, TN
    2016 CM SR5 4x4 SSM
    Went to check the water level at the pond after the storms passed yesterday. The road leading back to it is dozer cut and banked up on one side with some tree roots sticking out. Got a little too close and rubbed hard. No damage to my steps as far as I can tell. They sure saved my rocker and doors.
  4. Mar 19, 2021 at 5:32 PM
    Ltaco17
    Ltaco17 New Member
    NC
    2023 TRD Pro
    285/75/18 Falken Wildpeak R/T color matched handles and mirrors.
    Finished some wiring and made a had a new hose made for the air compressor to manifold.
    78BACB18-19F6-47C2-97CE-3CF2930FCA7A.jpg C3425B97-5804-4D88-8ACD-6B2F233B96CB.jpg 0D0606E7-8C66-4D11-A57C-8CFE4962329B.jpg
  5. Mar 19, 2021 at 6:17 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Clean choice!:smokertransformer:
    Ltaco17[QUOTED] likes this.
  6. Mar 19, 2021 at 6:53 PM
    Boisefly
    Boisefly New Member
    Boise, ID
    2014 Crewmax 1794 4WD
    Depends on your needs. I have a Jeep that I regeared for 37s. I don’t think the tundra needs it...personal opinion.
  7. Mar 19, 2021 at 6:54 PM
    Boisefly
    Boisefly New Member
    Boise, ID
    It’s fine. Still scoots when you need it to. I have experience regearing vehicles and don’t think the tundra needs it.
    CorsoTundra likes this.
  8. Mar 19, 2021 at 6:55 PM
    Boisefly
    Boisefly New Member
    Boise, ID
    Factory. Thanks
  9. Mar 19, 2021 at 8:19 PM
    Will1606
    Will1606 New Member
    Will
    NJ
    2019 TRD DCLB
    Do you have any TSS sensor issues so far? Can I also ask for a link? I have been looking for an option that allows sensor to still work, was not sure there was one out there.
    Love the Raptor Liner idea. I had one on my old truck and it rusted down low from all the road salt they use here in winter. But it save me from Bambi in the past. (the politicians have issues in my area letting some good hunters take care of the constant deer issue, they prefer we control population with vehicle strikes, ........ idiots :frusty:)
  10. Mar 19, 2021 at 8:20 PM
    eick
    eick New Member
    2020 CrewMax TRD Off Road
    Diamondback HD cover put on. Looks good.
    no pic yet, I’ll take some this weekend
  11. Mar 19, 2021 at 8:32 PM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    2021 Tundra DC
    Not sure at this point.
    Completed my ditch light install today!
  12. Mar 19, 2021 at 8:34 PM
    Otanguma
    Otanguma New Member
    Omar
    SR5 CrewMax 4x4
    6" Pro-Comp Lift, Catskinz leather seat covers, Rigid 30" Light Bar mounted on TRD PRO Grill 35" Nitto Ridge Grapplers mounted on 20" LRG rims
    Personally changed my front/rear differential oils and actually easy. Changed the engine oil last week and also easy. Transfer case oil is next on my list,, along with a new leather cover for steering wheel from Loncky that I'm pretty sure to remove the steering wheel to install/stitch.
  13. Mar 19, 2021 at 9:56 PM
    Aggiesdm
    Aggiesdm New Member
    Derek
    2016 Crew Max Platinum 4X4; '22 Platinum 4X4
    2" lift and Retrax bed cover
    Thanks man. Very nice!
    1lowlife[QUOTED] likes this.
  14. Mar 20, 2021 at 2:16 AM
    TimberToy20
    TimberToy20 New Member
    East Texas
    2020 Super White Crewmax
    612 Old Man Emu coilovers, Old Man Emu rear shocks, 1” rear block, diff drop.
    I went with the lighter spring rate because I do not plan on running a huge bumper winch combo any time soon. I couldn’t find a ton of info on the OME set ups before I got mine but I will say that even the lighter springs will give you over 3” of lift in the front and a 1” block in the back will not compensate to make the truck truly level. I ended up closer to 3.5” front and will be going to a 2” rear block at some point. I guess I could also add a winch to bring the front down a half inch or so too. I think the springs would be completely adequate to handle it. Someone please correct me me if I am wrong on that. I am however completely satisfied with the OME setup. The ride is firm but chews up big bumps. Seems like you feel more small bumps but the big holes that would unsettle the whole truck are now a non issue. I am using the OME rear shocks as well.
  15. Mar 20, 2021 at 9:56 AM
    TrenThom86
    TrenThom86 New Member
    Trent
    NW Louisiana
    2021 TRD Pro Lunar Rock
    B07AD10E-FF12-465A-9671-249A229A2619.jpg 4DA044BA-783E-47F8-9290-0AE0ECD3161A.jpg
    most expensive mod so far.
    1lowlife, GAknight, Ostrich and 16 others like this.
  16. Mar 20, 2021 at 10:06 AM
    eightbitstar
    eightbitstar New Member
    Ben
    2018 Platinum
    1st post! Removed badging. Wasn't fun. Worse than expected. Probably an hour and a half. Probably didn't help that it was only about 34° when I started. Installed color matched handles and mirror covers from Sparks. Easier than expected. Maybe 20 minutes, if that. Also installed Westin HDX drop step nerf bars. No problems with install. Took about 30 minutes for removal of the old pair and install of the new pair. Hoping to find wheels and tires next weekend.
  17. Mar 20, 2021 at 10:07 AM
    Phrog Driver
    Phrog Driver New Member
    2021 Silver Sky Crew Max TRD Off Road
  18. Mar 20, 2021 at 10:10 AM
    eightbitstar
    Ben
    2018 Platinum
    There are four (I think it was four) tabs at the bottom of the cover that you should insert first, and then work your way around the mirror snapping the rest in. Looks like that corner tab didn't get inserted properly.
  19. Mar 20, 2021 at 10:30 AM
    BWPRO
    BWPRO New Member
    Bryce
    2021 Tundra TRD PRO
    Finished with some interior trim pieces and completed the rear window switch relocate along with re wiring my light bar as well. Shout out @Rocfrog for the 3 switch panel!
  20. Mar 20, 2021 at 10:39 AM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    2021 Tundra DC
    Did you purposely flip the rear window switch?
  21. Mar 20, 2021 at 11:24 AM
    Tundra pi
    Tundra pi New Member
    2021 TSS Metallic Black
    Nice! My DB supposed to get here around April 25th. I hope removing the bed caps goes ok, I usually tear something up
    Phrog Driver[QUOTED] likes this.
  22. Mar 20, 2021 at 11:41 AM
    Terndrerrr
    Terndrerrr 928000 miles to go
    Music City
    6UR-FE
    If I move mine, I would do it that way. Same way the switch is oriented in the 4Runner.
    pvn.beluga[QUOTED] likes this.
  23. Mar 20, 2021 at 11:47 AM
    BWPRO
    BWPRO New Member
    Bryce
    2021 Tundra TRD PRO
    Yes because it's harder to roll rear window down when it's in the normal position. It's more natural the way it sits right now
  24. Mar 20, 2021 at 12:32 PM
    Badknees
    Badknees New Member
    South Carolina
    2016 White Tundra 1794 CM 4X4
    TRD Pro BBS Wheels, TRD LED Headlights, Rigid LED Fog lights, 040 TRD Grille, 040 Hood Bulge, Black Center Valence, Driver's Grab Handle, TRD Pro Fox Suspension, 1.00" BORA Wheel Spacers, 1.5" Rear Shackles, TRD Front and Rear Sway bars, 295/70 R18 Cooper Discoverer AT3 XLTs, Full Size Spare, TRD Dual Exhaust, Console cover, Console Organizer, Husky Liner X-act Contours, Tinted Front Windows, Stubby Antenna, Autoventshade Deflectors, Duplicolor Painted Calipers, 040 Painted Front End Caps, Undercover Armor Flex Bed Cover
    Replaced front chrome end caps with painted white ones. Had installed the TRD skid plate a couple weeks ago:
    GAknight, Astom22, Ostrich and 12 others like this.
  25. Mar 20, 2021 at 12:35 PM
    JerryH
    JerryH Gravy Boatin, I don’t park I dock.
    SOMD
    2020 Crewmax Limited Cement
    How was this process?
  26. Mar 20, 2021 at 12:41 PM
    TheBubbaDude
    TheBubbaDude New Member
    2020 Tundra TRD Pro
    AJT Blackout Kit 1.25" Wheel Spacers NRG 285/70/18 Meso Customs TRD Start Button
    I had mine done Wednesday. Definitely noticed a difference and well worth it! Hope you like it
  27. Mar 20, 2021 at 12:44 PM
    Badknees
    Badknees New Member
    South Carolina
    Takes a while to remove and reinstall all the parts and front bumper, but it wasn’t a terrible job. A lot of guys install the bumpershellz caps over the chrome. I tried these but there’s just a cut out for the fog lights and I like seeing the complete bezel so I went with full replacement caps. The skid plate install was ok, but a little harder to install than I anticipated.
  28. Mar 20, 2021 at 1:00 PM
    JerryH
    SOMD
    I like that option better also for the end caps. Thanks for the info!
    Badknees[QUOTED] likes this.
  29. Mar 20, 2021 at 1:09 PM
    Phrog Driver
    Yeah, we were worried about that. Took it slow, and they came off OK. Put the shims on and the rail caps popped right back on.
    Tundra pi[QUOTED] likes this.
  30. Mar 20, 2021 at 1:12 PM
    DCB500
    DCB500 New Member
    David
    Oklahoma City
    I do definitely see a difference even over and above the rear that I added a few weeks ago. And maybe it’s because I had the U mounts tightened down to much on the factory bar but it seems to ride a little better with the proper torque specs on the new one allowing it to articulate a little more...or maybe it just wishful thinking lol.
    TheBubbaDude[QUOTED] likes this.
