  1. Dec 31, 2018 at 4:57 PM
    KFed
    KFed New Member
    East Tennessee
    2018 Tundra Crewmax TRD Sport
    Tinted windows, Black badge overlays, ProZ hard bed cover, 32" grille light, 30" lower bumper light,...
    Not too bad.. does lose a little bit from the grille but. still pretty bright...
    Tried to get a straight on shot but whites out the pic. I'll have to update with pics from inside the cab at night
    cjmay13, SoCal619, Hammerhead and 2 others like this.
  2. Dec 31, 2018 at 8:18 PM
    cd121082
    cd121082 New Member
    chris
    Washington State
    2016 Silver Tundra TRD OffRoad
    none yet
    Stopped at the mail box and picked up this bad boy that came in today.
    Drk_Jdi, Ostrich, cjmay13 and 11 others like this.
  3. Dec 31, 2018 at 8:55 PM
    bmcdds
    bmcdds New Member
    CA
    2019 Barcelona Platinum
    Replaced zinc “bead lock” bolts with black ones.
    Installed Leer Ricochet tonneau cover.
    GAknight, JoshuaA, cjmay13 and 7 others like this.
  4. Jan 1, 2019 at 5:36 AM
    boomer8
    boomer8 New Member
    Evan
    Cincinnati
    2018 Platinum
    Thanks!
  5. Jan 1, 2019 at 8:34 AM
    tundracap
    tundracap New Member
    NC
    2017 CM Limited 4x4 Silver Sky Metallic
    Installed my Supernova's this morning. Fairly easy installation after watching the Headlight Revolution Youtube video of installation on a Gen 3 Tundra. The only additional thing I would add is be sure you have some nylon zip ties to secure the ballast/relay that comes with it. I wrestled with that as much as anything in the entire process.
    What the!? likes this.
  6. Jan 1, 2019 at 10:16 AM
    mgm16trdpro
    Northern NJ
    2016 mgm trd pro crewmax
    WolfPac_Outdoors likes this.
  7. Jan 1, 2019 at 4:23 PM
    TundraTSS19
    TundraTSS19 New Member
    San Antonio, TX
    2020 Tundra TSS SR5 Crewmax 5.7L
    LED step bar light strips
    Did the under seat storage mod. Went to Ross and got these 3 cake pans and proceeded to cut them in.
    Installed Auxbeam NF-S1 fanless led bulbs in headlights and fog lights. Very impressed with light output and excellent beam pattern. Just like stock with brighter light.
  8. Jan 1, 2019 at 5:05 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Very innovative with the pans. Nice job
    TundraTSS19[QUOTED] likes this.
  9. Jan 1, 2019 at 5:36 PM
    What the!?
    What the!? New Member
    2017 Pro
    First time taking her out to the dirt. Might as well start the year off right!
    Nickj619, Sas, OR18TRD and 17 others like this.
  10. Jan 1, 2019 at 6:15 PM
    Upgrayedd
    Upgrayedd Toyotaholic
    Josh
    Northern Virginia
    2015 DC MGM SR5 4x4
    Got some Husky liners for Christmas. The stock rubber fronts just weren’t cutting it.
    GAknight, Okietundra, Rica25 and 13 others like this.
  11. Jan 1, 2019 at 9:05 PM
    Upgrayedd
    Josh
    Northern Virginia
    2015 DC MGM SR5 4x4
    They were so tiny and the dead pedal area was getting dirt ground into it. These fit really well and they stay in place nicely. I’m happy with them.
  12. Jan 1, 2019 at 9:43 PM
    bmcdds
    bmcdds New Member
    CA
    I bought the black bolts that Method makes from Summit Racing. I think I may paint the zinc bolts 3R3 red from the same can we used to paint my door handles.
    JoshuaA and Hammerhead like this.
  13. Jan 2, 2019 at 7:34 AM
    mgm16trdpro
    Northern NJ
    Would love to see it.
  14. Jan 2, 2019 at 8:12 AM
    Jleebo77
    Jleebo77 New Member
    Lee
    2015 trdpro crewmax
    I like the underseat storage. As soon as the carseats come out I'm doing this.
  15. Jan 2, 2019 at 8:20 AM
    Jleebo77
    Jleebo77 New Member
    Lee
    2015 trdpro crewmax
    With the bed all folded up does it press against the window?
  16. Jan 2, 2019 at 8:56 AM
    vl184009
    vl184009 Cheers Boys!
    Vicky
    Southern, Ca.
    2016 MGM CM SR5 4x4 w/Tow Pkg
    What did those run you? I am looking for something easy like this to install as well, were they pretty easy to swap?
    Hammerhead likes this.
  17. Jan 2, 2019 at 9:36 AM
    boomer8
    boomer8 New Member
    Evan
    Cincinnati
    2018 Platinum
    Yes. There is some foam that protects the cover and the window. It rests against the window and has little "kickstands" to hold the cover in place.
  18. Jan 2, 2019 at 9:42 AM
    boomer8
    boomer8 New Member
    Evan
    Cincinnati
    2018 Platinum
    Picked up my wheels from the local powder coating shop and my tires got delivered today! Waiting on one order to come in and off to the shop it goes to have the following installed: 6112's, 5160's, Spidertraxx 1.25" spacers, Coachbuilder 1" rear shackle, Coachbuilder shim, TRD front sway bar, TRD Rear Sway bar, Black TRD Pro look wheels, Nitto Terra Grapplers 295/70/18. Also have color matched door handles and mirror caps going on in the near future!
    Planning on starting a build thread this week to post all the pictures!
    GAknight, Nickj619, Sas and 14 others like this.
  19. Jan 2, 2019 at 11:10 AM
    TundraTSS19
    San Antonio, TX
    So easy and so simple to do. The pans were $6 each. I just couldn't see myself paying $225 for ESP kit and the storage space isn't that big. Doing it this way gives you options on the size you want to go. I was thinking about going a little bigger in the middle but decided to stay all the same. Place the pan face down where you want it. Once you have the pan where you want it, outline it with a paint marker or some chalk. I used a box cutter. Cut 1/4" inside of the outline so it's not too big and should fit really good. Now this may not be for everyone but to secure it I took 1/8" drill bit in 2 places and pop riveted it down. Won't hurt anything or leak. The foam is very thick so you'll have to keep slicing all the way around to get to the bottom. I then too a big screw driver and broke out a piece in the corner of the cut out so I could get my hand under the big piece and put out the entire foam basically as one piece. Make sure you have a shop vac and trash bag handy. The foam will be eveywhere.
  20. Jan 2, 2019 at 11:23 AM
    TundraLuv
    TundraLuv New Member
    Kent
    IA
    2018 Midnight Black Metallic Limited Crewmax
    Great mod. Any issues with the pans rattling?
  21. Jan 2, 2019 at 12:39 PM
    TundraTSS19
    San Antonio, TX
    No rattling at all. Won't happen if they're pop riveted to the floor. If you don't want to do that then you can just use the carpet cut out and place underneath it. I prefer mine to be secured to the bottom so it's not bouncing out of the cutout and also looks better..
    Hammerhead and TokerJoker like this.
  22. Jan 2, 2019 at 12:51 PM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    That's a helluva list!
  23. Jan 2, 2019 at 1:00 PM
    vader7071
    vader7071 New Member
    Dothan, AL
    2018 SR5
  24. Jan 2, 2019 at 3:13 PM
    Chuck1188
    Chuck1188 New Member
    Charles
    2016 TUNDRA BLACK SR5 CM 4WD
    9E4EEDF3-776E-4489-84C5-CDA42B7AEE99.jpg Put a 2019 pro grille on. Next is bulge...Baby steps
  25. Jan 2, 2019 at 3:22 PM
    bdpeelgren
    bdpeelgren New Member
    Round Rock, TX
    2014 Tundra CrewMax Super White
    Readylift 3/1, Rigid D-series fog lights, Supernova V.4, F/R Coverking covers.
    Got a readylift 3/1 installed and an alignment.
  26. Jan 2, 2019 at 3:38 PM
    SpacecoastHusker
    SpacecoastHusker New Member
    Brevard County, FL
    2014 Toyota Tundra Limited CM
    I installed the center console gun safe this morning. This afternoon, I replaced the dome and map lights with VLED. I’m very happy with both.
    WolfPac_Outdoors and Hammerhead like this.
  27. Jan 2, 2019 at 3:48 PM
    DJFaninTN
    DJFaninTN New Member
    Panama City Beach, FL
    2018 Super White 1794
    I took the little useless shelf out of the glove box. Now you can actually get something in there. Not much but it's better than it was.
  28. Jan 2, 2019 at 3:54 PM
    tundracap
    NC
    Interesting. Hadn't thought about that.
    How is it held in place. I haven't looked at it that much. May go look.
  29. Jan 2, 2019 at 5:04 PM
    Phadedbeard
    Phadedbeard New Member
    Ma
    16 Quicksand TRD Pro
    Got the latest care package from @Wheeler's Off-Road Inc @ragofabrication @Baja Designs :yes:20190102_194925.jpg
    Rago rail pod brackets and extenders
    Squadron sports and s2 sports and amber lenses to finish off the sides and backwards lighting
    And some sweet Baja swag packs to start the patch collection
    1"bora wheel spacers to complete the puzzle for the 295/70/18 Cooper STT Pros Ive been staring at for over a week20181221_215158.jpg
    GAknight, KTJO 4x4, Sas and 15 others like this.
  30. Jan 2, 2019 at 5:19 PM
    lionix
    lionix The Grey Moose!
    Cape May, New Jersey
    2017 Tundra TRD Pro CM Cement
    BD Lights, Any Time Fog, Coachbuilder, Pelfreybilt, Bakflip, Custom Bed Rack w/ Tent
    Nice!
    Phadedbeard[QUOTED] likes this.
