What have you done to your 2nd gen Tundra today?
Discussion in '2nd Gen Tundras (2007-2013)' started by T-Rex266, Jan 7, 2014.
  1. Jul 12, 2021 at 10:00 AM
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
    Just bleed my brakes today. Not sure if I got all of the old fluid out since it was super hard to tell from the color and I did not see any air bubbles come out. I used a turkey baster to squeeze out the old fluid in the reservoir and then bled about 16 ounces from all 4 brakes. Most of the 16 ounces are the rear brakes. Once I pressurized the reservoir, the brake fluid started to bleed out when I loosened the bleeder valve on the brake calipers. I would go back to the reservoir to check brake fluid level and top it off whenever I changed to do the next caliper. I didn't remove the wheels, I was able to get to all 4 wheels by crawling under the car. The front wheels were a little tight but doable.
  2. Jul 12, 2021 at 10:05 AM
    81 TOY
    81 TOY New Member
    Larry
    Vermont
    2008 Limited Crew Max
    That's sweet!
    Mountun Goat likes this.
  3. Jul 12, 2021 at 10:07 AM
    SouthWestGA
    SouthWestGA New Member
    Looked at a few Sequoias and sent out feelers
    But at this point,you’re just putting money into a new rig on maintenance since it has an unknown history. You could end up doing the same things to it,you never know!
    So better to save on ADValorem taxes and payments and just keep what Ive got
    And when the kids get a few years older and aren’t as rough on a vehicle then get something else
    At least that’s what I tell myself
    Don’t get another vehicle until it’s an absolute “Need”
  4. Jul 12, 2021 at 7:54 PM
    Retroboy1989
    Northern Utah
    2025 TRD Rally
    The hell is that big bellow?
  5. Jul 12, 2021 at 9:09 PM
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    Got the stock bumper and valence off (damn that’s annoying), hopefully be able to get an extra set of hands here tomorrow to get the new one on!
  6. Jul 12, 2021 at 9:22 PM
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
    Got any tips for removing the eyelids under the headlights…got a headlight project in the works and don’t want to snap any plastic
  7. Jul 12, 2021 at 10:29 PM
    TG705
    TG705 Braaaap
    Tony
    San Jose, CA
    2011 super white Tundra double cab
    King 2.5 coilovers, King 3.0 rear bypasses, Camburg uniball UCAs, RCI skid plates, Camburg front bumper, warn zeon 10s platinum winch, monster hook reaper shackles, Rigid Industries lights, SDHQ sliders, SDHQ A-pillar brackets, SPOD, 17" Method standard wheels, 315/70/17 Cooper STT tires, Morimoto XB LED headlights, Boon dock steel rear bumper, Durobumps front bumpstops, Deaver U748 with MCM shackles
    Take the 2 plastic clips out and pull straight out in the direction your headlights face. If your worried about the pins breaking from pulling then a plastic upholstery remover will work great!
    zcarpenter92 likes this.
  8. Jul 13, 2021 at 4:15 AM
    omgboost
    East Coast
    Air suspension on my Sequoia?
  9. Jul 13, 2021 at 6:16 AM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    Looks like a dust cover over the bag :smokertransformer:
    omgboost[QUOTED] likes this.
  10. Jul 13, 2021 at 7:03 AM
    zcarpenter92
    Zach
    NE Colorado
    In sig
    Exactly. I had to jimmy the pins on the outer side a fair amount, since I don’t have the remover tool. I angled it to where I could get a finger under the upper corner, and it came out.
    TG705[QUOTED] likes this.
  11. Jul 13, 2021 at 8:25 AM
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    3/1 Lift, 35s, Front Bumper, etc etc
    what sub is that?
  12. Jul 13, 2021 at 9:14 AM
    speckmon
    speckmon Must. Have. Pow.
    Thornton, CO
    '07 mountain road bomber
    Why would you want to illuminate your plate? I took one of mine out to dim it. FTP.
    slowpokepete likes this.
  13. Jul 13, 2021 at 9:16 AM
    WVI
    WVI New Member
    @008 Tundra Limited
    Cleaned out the bottom rear corner of the front fender, removing all the debris trapped by the fender liner.
    I did one side last week when I installed the new antenna boot/grommet.
  14. Jul 13, 2021 at 9:46 AM
    zachzap361
    zachzap361 MEAN GREEN MACHINE
    Zach
    San Antonio
    2010 Green Tundra CrewMax
    Toytec Aluma 2.5 Coilovers and Toytec rear shocks, Method NV 17", Nitto Ridge Grappler 35", RCI Skid Plate, Dirtydeeds Dual Dumped Exhaust, Volant Cold Air Intake and Throttle Body Spacer, SDHQ Ditch Mount Brackets, Rigid Blackout Spot Lights, Stampede Fender Flares, N-Fab Nerf Bars, Morimoto Fog Lights, 55 watt HID's, AJT Design Climate Knobs, Ellis Precision Shift Knob, Coverking Seat Covers, Husky Floor Liner's,Demello Off-road Bumper, Rigid and Baja Designs Lights, Jomax ABS Sensor covers
    Didn't realize how much I miss this site until I start doing mods again on my truck.
    So to catch up I installed new wheels and tires, finally got the methods and the Nitto Ridge put on back in March and love them!!!!! Recommend this set up to anyone and shout out to @t4r2tundra for the pictures on his dad bod dad rod thread. His pictures sold me on the set up and couldn't be happier.
  15. Jul 13, 2021 at 9:51 AM
    zachzap361
    Zach
    San Antonio
    Since then I've also done a few other things to the Tundra
    Had hyper flashing going on in both sides of turn signals so I bought some built in resistor lights from @Headlight Revolution BUT they didnt work as planned. Put all 4 on but my rear turn signals wont work so having to send 2 back. They said issue was the rear is pulling to much amps so they are gonna help me out with some other lights to see if those work.
    Then I finally also installed my rear seat covers, I gotta say they came out alright, was hoping for a tighter fit but cant complain since I never have anyone back there.
  16. Jul 13, 2021 at 9:56 AM
    zachzap361
    Zach
    San Antonio
    Now for the fun stuff, I'll have to upload the video when I can but finally finally FINALLY swapped out my Gibson Metal Mulisha exhaust for.........YES YOU GUESSED IT @dirtydeeds Dual Dumped Exhaust and HOT DAMN DOES IT SOUND WAYYYYYYYY BETTER!!!!
    Now the install did actually take some time due to the bolts being beat to shit from the last install years ago and also rusted out as can be. Had to go to Lowes to get a bolt extractor kit and new bolts but need to get another set of new bolts cause the ones I got unfortunately are a 17mm head so I need to get some 14mm's. Also couldn't replace the nut's cause all the nut's were pretty much heat welded on to the damn flange's so I will have to cut them off later.
  17. Jul 13, 2021 at 10:27 AM
    wv00097
    wv00097 New Member
    Wes
    AZ > GA
    2011 SR5 TRD OR
    BDS 7 w/ Fox 2.5 OME Dakar leaf pack CB +2 shackles 18x9 Method 308 +18mm 37x12.5 Toyo AT3 TRD intake/exhaust Infinity Kappa w/ Pioneer HU
    Infinity reference 8" powered sub. I think its called basslink or something like that. I'm just not a fan (anymore) of the full sub systems. I wanted minimum wiring and not have to worry about capacitor, amp, etc. It does the job, maybe similar to the JBL system (although I've never heard it). Definitely a budget and low power option. Sounds fine to me!
    joseph_womack[QUOTED] likes this.
  18. Jul 13, 2021 at 10:50 AM
    aelarson
    aelarson New Member
    AZ
    2011 SR5 Tundra (Silver Sky Metallic)
    I am upgrading all of the lights on the truck to LED, so I bought these. I can't stand halogen bulbs. I wish they weren't as bright, but oh well. I also don't have anything to hide, so I'm not too concerned.
    joseph_womack likes this.
  19. Jul 13, 2021 at 11:43 AM
    hotchops777
    hotchops777 New Member
    Matthew
    EAST TEXAS
    2011 5.7 Silver Sky DC
    6" Procomp Stage 2 lift Black Rhino Sierra 20x10 0 offset on 325x65x20 Nitto Ridge Grapplers Smitty Built M1 front grill
    Any links to your ditch light brackets would be super helpful. Hard to find low profile ditch brackets for the gen2 i like.
    zachzap361[QUOTED] likes this.
  20. Jul 13, 2021 at 12:06 PM
    Bikeric
    Bikeric New Member
    Eric
    2007 DC 5.7
    Blown Engine.....
    Finally got around to installing my Super Swamper 35x10R17 "pizza cutter" tires on my Vision beadlock wheels. What a pain.... The first wheel/tire took me 3 hours. I had to go to Northern tool and buy a "bead blasting" air tank to seat the rear of the tire after torqueing the 28 bolts. I was able to get a rhythm and finish the last wheel/tire combo in 45 minutes. I mistakenly thought I could drive to the woods aired down to 15psi (No f'N Way!!). These tires were sketchy on the road and I turned around and went back to air up 35psi front 30psi rear. I headed back to the trails (pinstripe alley) but stayed off the highway. I would be white knuckling it to go 65mph. Oh well, I think I'll take them off now and have them balanced, then keep them for the next off-road adventure but install them at the trail-head.
  21. Jul 13, 2021 at 12:31 PM
    GravityGear
    GravityGear Parking Lot Prerunner
    Aurora, CO
    2014 Black DC TSS Off Road 4x4 5.7
    Transfer Flow tank, Pinstripe Suit
    oooohhhh boi. Are those the -15 offset? They look good.
    Mountun Goat and Bikeric[QUOTED] like this.
  22. Jul 13, 2021 at 12:39 PM
    Bikeric
    Bikeric New Member
    Eric
    2007 DC 5.7
    Blown Engine.....
    Thank you, and Yes. I kinda wished I had gotten 37x12.5 tires though. I would have had to do the CMC, but they might have filled the wheel wells better.
    joseph_womack and Mountun Goat like this.
  23. Jul 13, 2021 at 12:40 PM
    GravityGear
    Aurora, CO
    Very VERY nice. I was looking at those when the cast versions were MAD cheap. I kinda regret not pulling that trigger.
  24. Jul 13, 2021 at 12:50 PM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Sweet! We’ve been waiting for those to go on. Looks awesome. Let’s see some shots of the front or back of the truck with those thin crust pizzas
  25. Jul 13, 2021 at 12:54 PM
    Silverghost
    Silverghost New Member
    13 tundra 4x4
    Love the goat!!
  26. Jul 13, 2021 at 1:03 PM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    :fistbump::fistbump::fistbump:
  27. Jul 13, 2021 at 1:23 PM
    Punisher17
    Punisher17 New Member
    This is my P2440 story:
    Put on the Hewitt gen 2 bypass kit right away when I received the code and it went into limp mode and the kit fixed it right away. Brought in for smog the other day and my mechanic said it failed visual inspection so they wouldn’t smog it. Replaced the bank 1 air injection valve and removed the bypass kit. Went to smog today and the O2 sensors weren’t ready since I hadn’t driven it since putting the new valve on. So he told me to drive it around and I did and went back and passed smog today. I came home right after and put the bypass kit right back on just got done. At least I know replacing the bank 1 valve fixes it for smog so now I’ll just remove the bypass kit for smog and put it right back on afterwards whenever I have to smog it. Also mine is a 2007 4.7 and it is really easy to install the block off plates and/or replace the air injection check valves because they are accessible without taking off the intake manifold or any additional part for that matter. So relieved smog is done for another 2 years lol. :thumbsup:
  28. Jul 13, 2021 at 6:03 PM
    zcarpenter92
    Zach
    NE Colorado
    In sig
    Really wishing I’d of bought that 20V impact wrench or the pneumatic one when I had the chance…these tow hooks suck!
    D4x4TRD, Prostar 190, wv00097 and 3 others like this.
  29. Jul 13, 2021 at 8:25 PM
    Punisher17
    I am a firm believer of not buying unnecessary tools. A 1/2 inch socket wrench or breaker bar should be able to get that done without the electric tools. If not, PB blaster it over night. Sucks waiting over night but it works 100%. I have saved stripped bolts using that stuff. Also I have used a 1/2 socket wrench and mini sledge hammer to break it free and haven’t broken a 1/2 socket wrench yet with that kinda use. I use craftsman tool usually too
    WVI and zcarpenter92[QUOTED] like this.
  30. Jul 13, 2021 at 9:05 PM
    zcarpenter92
    Zach
    NE Colorado
    In sig
    I feel ya, but pneumatic wrenches made life a hell of a lot easier when we did my suspension a few years ago. I got it loosened ok with a breaker bar, just took way longer than it should’ve.
    Punisher17[QUOTED] likes this.
