What kind of camper do you have???
Discussion in 'Towing & Hauling' started by Muleycrazy13, Feb 12, 2017.
  1. Jan 14, 2025 at 7:46 PM
    #1201
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Not sure it you know but the mirror glass is released by prying straight up from the bottom of the mirror.
    koditten likes this.
  2. Jan 16, 2025 at 5:21 PM
    #1202
    carn_dogg
    carn_dogg i don't think so
    Pat
    Eastern Shore MD
    2013 Black Tundra Platinum
    Good to know, but I didn't need to remove the glass at all. I used weedwacker string to fish the wiring through the mirror's bottom cap, up and through the arm, then back into the inside of the door where the N5 connector is on the drivers side and the M6 connector is on the passenger side. I stopped for the evening, only had about 30 min to mess around with it. VLED's came today so I'll finish up tomorrow.
    Pin 6 on each connector is (+) and Pin 5 on each connector is (-)
    I'll tap into those to feed the puddle lights and use the VLED hardnesses so I can connect/disconnect as required if I ever need to remove the BAP mirrors. And the stock mirrors will retain all functionality.
  3. Jan 16, 2025 at 9:30 PM
    #1203
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    When I wired my puddle light up I used the wire that powers the rear cargo light. I have control from the switch to turn them on and off and when I unlock the truck the lights come on. The wire is easy to get to because it’s under the driver’s side kick panel right were your working.
  4. Jan 17, 2025 at 4:47 AM
    #1204
    carn_dogg
    Pat
    Eastern Shore MD
    Oh that's good to know. My platinum came standard with puddle lights so the wiring is already there. No need to manual control of it, I'll just let it come on when I unlock the truck and then the light fades after a certain amount of time if the door hasn't been opened. I won't need to go into the truck, I'm able to use the M6 and N5 connectors that plug directly into the mirror harness at near the tweeter.
    Ruggybuggy[QUOTED] likes this.
  5. Jan 17, 2025 at 5:11 PM
    #1205
    carn_dogg
    Pat
    Eastern Shore MD
    All finished up. They fit well. They work just like the OEM puddle lights. Fading off when they turn off. On right away when you click unlock.
  6. Jan 17, 2025 at 5:42 PM
    #1206
    Tundra family
    Tundra family New Member
    Nice work.
    carn_dogg[QUOTED] likes this.
  7. Jan 17, 2025 at 6:02 PM
    #1207
    Tundra family
    I remember asking about slide ins but don't think I ever actually shared mine.
    2001 StarCraft Starblazer, dry weight was around 1500 lbs before i took out some cabinets that weren't being used and a 12 gal water tank. Yes, I know the straps are kinda janky but it's old and id rather break a strap than have the mounts get ripped out of my camper when I'm on some rough stuff, so that's how I did it. Currently working on replacing the screens and doing a lil restoration/remodel.
  8. Jan 25, 2025 at 9:07 AM
    #1208
    2025 Campsite Ultra
    22.4 feet, 5140 lbs
    2025_forest_river_campsite_ultra_19kb_hdy2450790_impel-capture_close-up_srp.jpg 2025_forest_river_campsite_ultra_19kb_hdy2450790_impel-capture_close-up_living-area-main-1.jpg 2025_forest_river_campsite_ultra_19kb_hdy2450790_impel-capture_close-up_bathroom-1.jpg 2025_forest_river_campsite_ultra_19kb_hdy2450790_impel-capture_close-up_bedroom-1.jpg
  9. Jan 25, 2025 at 9:22 AM
    #1209
    2000 Limited TRD AC 4X4 Thunder Grey 277k miles. *SOLD* 2019 Limited TRD CM 4x4
    Heavy for a 22’er
    ah, you got that nice bathroom though
    JMGmanAZ and Cpl_Punishment like this.
  10. Jan 25, 2025 at 6:56 PM
    #1210
    16MagSR5
    16MagSR5 New Member
    Buffalo
    2016 Magnetic SR5, leveled and capped
    Boost tow Mirrors, TRD rear sway, Rough Country Duals, Bilstein 5100's, diff breather mod, more that I'm forgetting...
    Man I hate this thread sometimes, I get the itch. That is the perfect camper for 2! And it'd fit in my barn for winter storage :D
    Congrats and enjoy :)
