What oil do you guys all put in your 1st gen tundras?
Discussion in '1st Gen Tundras (2000-2006)' started by jackcrab, Oct 29, 2022.
  1. Oct 30, 2022 at 3:19 AM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    You guys are using oil?
    this is my first truck to use synthetic, it's got mobil 1 its whole life, so i'll continue. 5k changes so i dont have to write the milage on a piece of tape, and about 100 miles before its due i give it a swig of MMO.
    Amsoil or redline for the bikes, supertech for the titan.
  2. Oct 30, 2022 at 6:27 AM
    MartinBlank
    MartinBlank New Member
    Bruce
    Loveland CO
    2008 Crew Cab Limited
    TRD Sway Bars, TRD CAI, Bilstein 5100's, LED's, plus LED rear Plate backup light, Aluminum oil filter housing, ECGS Needle Bearing upgrade.
    I was a die hard Mobile1 guy for years, in my track cars and DD's. I have since switched to Walmart Supertech High Mileage and get Blackstone reports. The oil holds up very well (I do add BG MOA with each change). My '01 Tacoma (SC and Meth) with 400K on it doesn't burn a drop, nor does the Ridgeline with 170k. All Blackstone reports are good. I change the Tacoma every 5,000 and just follow the maintenance minder on the Honda. Just picked up an '08 CM and changed the oil to Supertech last week (with MOA) It has almost 250k so I'll be interested to get the Blackstone report back on it. I did notice that the price of Supertech has gone up substantially and is only roughly $5 less than Mobile1 now, so for $5 I may move back. I think you can basically run whatever oil you want. I did a ton of research on Supertech before I moved over to it. My Blackstone reports didn't show much if any difference in the levels of additives from Mobile1 to ST. I'm comfortable with it. The Blackstone report for me is the key.
    Dannydirtyfingers likes this.
  3. Oct 30, 2022 at 10:08 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    I think this is the take-away. Change it on time, and pretty much any brand will be fine.
  4. Oct 30, 2022 at 10:35 AM
    I think the real argument to be made is how one defines "on time".
    "On time" varies based on an array of factors, this list is sorted (IMHO) in order of most important to least important:
    • If you've had any event requiring break-in or earlier maintenance, i.e. some work would create debris in oil
    • Type & frequency of driving you do: Mostly short tips vs. mostly long trips vs. mix of both
    • Type, weight, composition of oil used
    • Whether or not you applied additives to oil
    • Age of oil
    Clearly the first point isn't going to impact much of anyone, it's so rare we're doing anything in our engines that'll make shavings etc. Which means the type of driving you do and how often you do it are totally critical. We've seen how damn sludged up and/or varnished a couple of the low-mile member's engines are, it's no secret: Short trip driving is horrible for these engines.
    To that point, I've read more than one study indicating full synthetic oils leave less varnish on internals when used the exact same ways as dino oils, though. But I've also read anecdotes about how this is negated either because (A) the driver is waiting longer between changes due to full syn's claims, which could be years in some cases, and (B) dino oil is changed more frequently, due to lower life expectancy.
  5. Oct 30, 2022 at 11:53 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    On time =5000 miles
    5N0W808 and Mr.bee like this.
  6. Oct 30, 2022 at 12:29 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
  7. Oct 30, 2022 at 1:28 PM
    Roborob70
    Roborob70 New Member
    Robert
    18 Toyota Tundra TRD
    Canola
    hagrid and artsr2002 like this.
  8. Oct 30, 2022 at 3:23 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    I hope it’s non-GMO. o_O
  9. Oct 30, 2022 at 5:03 PM
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    South of ATL
    2006 Tundra 4X4 Limited Dbl Cab
    Mobile 1 every 4k miles or once a year; whichever comes first (usually the latter).
    When I get her out to drive I make sure I get a good mix of driving in usually including the interstate.
  10. Oct 30, 2022 at 5:12 PM
    Cummins3500
    Cummins3500 Never finishes.....
    Logan
    Castrol high mileage full synthetic @ 5k intervals. K&N filter or AFE power filter. Wife’s Sequoia gets the same treatment
    163k on tundra
    243k on sequoia
  11. Nov 9, 2022 at 10:36 AM
    DesertRoads
    DesertRoads Telecom Guy
    Utah's West Desert
    2005 DC SR5 V8 4WD LSD & TOW PKG
    LED Lights Galore. Mostly Stock
    Mobil 1 synthetic 5w30 high mileage, and Fram Ultra Synthetic oil filter. Thankfully, oil and filter changes on our trucks are VERY easy to do.
  12. Nov 9, 2022 at 11:09 AM
    jamess28
    jamess28 New Member
    Tulsa, OK
    2005 DC SR5 TRD Off-road 4x4
    Mobil 1 Full Synthetic High Mileage. 5W-30. K&N HP-1002 filter
  13. Nov 9, 2022 at 3:55 PM
    Riverdale21
    Riverdale21 Speed seeker
    OTP ATL
    06 SR5 Tundra TRD Off Road
    Dirt Deeds injectors, Addco rear sway, AEM dry flow air filter, last ever set of Stan's Try-Y headers, Borla full custom exhaust, front level, wheel spacers, and lots of electronics.
    I get Mobil1 5w20 full synthetic from work for free, so I use that. Also use the larger Wix 51515XP oil filter. Almost 2" larger in every dimension vs. standard 2UZFE sized filter.
    Redline in diff, trans, and power steering. No other addatives.
    Dannydirtyfingers, Mr.bee and abcinv like this.
  14. Nov 9, 2022 at 4:04 PM
    Riverdale21
    OTP ATL
    No Fram. Do your engine a favor and only use OEM, Wix, or Napa.
    https://youtu.be/iTNJLEV8CG8
    HBTundra likes this.
  15. Nov 9, 2022 at 4:37 PM
    I've seen time and time again in shootouts and videos where the performance of Toyota's OEM filters (oil and air) stomp other major names' dick in the dirt. The oil filters do a better job of screening and are more substantial, and the air filters clean with less restrictions plus less dust than bullshit K&N pumps out, dyno tests done by a couple of different publishers show performance loss in dyno tests happens with K&N while the OEM air filters tend to place in the top 3.
    Outside of that, why should you buy OEM? Toyota designed their filters with longevity of their engines in mind, you're literally not going to find a better filter out there. They're not in the business to make a buck. They want the reputation. OEM all the way. I would never consider it with other brands, I had my favorites and stuck with them. Nothing but OEM after all the reading and watching I've done. And you can buy in bulk from the dealer pretty cheap, shipped free, no tax at some places.
  16. Nov 9, 2022 at 4:45 PM
    Jack McCarthy
    Bill
    North of Boston
    The Mobil 1 filters are supposedly better than OEM but I cannot justify the price since they’re more expensive.
  17. Nov 9, 2022 at 4:56 PM
    I couldn't manage to get any under $3 like I have in the past, I was pressed knowing I had several short-interval OC coming to clean out my top-end. But this was the last order I placed for pickup at my local dealership. I usually swap washers every 3rd OC, hence adding them. I think half a dozen filters for around $25 is pretty damn good, but I dunno. If you can't got anything local, I'll order from a dealership that doesn't charge tax and gives you free shipping.
  18. Nov 9, 2022 at 5:55 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    All synthetic, OEM filter:
    0w-20 mobil 1
    5w-20 quaker state
    5w-20 penzoil
    Trans has:
    Valvoline Maxlife (syn)
    Diff has:
    Motul 90pa (non-syn, due to OEM clutch type LSD)
    shifty` likes this.
  19. Nov 10, 2022 at 5:39 PM
    #49
    AV8R4AA
    AV8R4AA New Member
    Greg
    Justin Texas
    2005 Tundra XSP
    Not sure what the PO was using. I think it was black candle wax.
  20. Nov 10, 2022 at 5:43 PM
    #50
    Huh, looks like drivers side is better than the passenger side, I think, if I'm remembering correctly? That's a positive thing!
  21. Nov 11, 2022 at 6:59 AM
    #51
    DesertRoads
    Utah's West Desert
    It's so interesting seeing folks oil filter preferences. I've run Fram oil filters in my vehicles for years without issue. But everyone has their preferences. Next time I'm in the city, I'll have to pick up some genuine Toyota and Subaru oil filters. I had been taking my Subaru and Toyota's to the dealers for oil changes up until 6 months ago when oil change prices went from $60-70 to $120.
