What was your OEM Battery Replacement?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Bulldogs001, Aug 21, 2023.
  1. Aug 23, 2023 at 12:56 PM
    Moe2o4
    Moe2o4 New Member
    Corey
    2020 Tundra SR5 Extended Cab TRD Offroad Package 8ft. Bed
    Bilsten 6112's with 2.5" Front Lift w/Bilstein 5160 Rear Shocks
    Northstar X2 Power AGM!!!
    RitcheyRch likes this.
  2. Aug 23, 2023 at 1:03 PM
    EmergencyMaximum
    EmergencyMaximum New Member
    @dkrou , You could always make one. There's not much to it really..
    @BrewBabe, you could always upgrade when it gets colder if battery doesn't seem up to the task. As long as its not leaking excessively and starts fine, there is no problem.
  3. Aug 23, 2023 at 1:14 PM
    NewImprovedRon
    NewImprovedRon New Old Guy
    Ron
    NW Arkansas
    2015 Radiant Red Tundra
    How old is your current battery? If you have an Auto Zone parts store, they can do a load test on your battery to tell you for sure if it is bad or going downhill.
    WILLINH likes this.
  4. Aug 23, 2023 at 1:28 PM
    BrewBabe
    BrewBabe New Member
    Sybil
    Tampa, FL
    2020 Tundra CrewMax Cavalry Blue
    Predator Pkg, Leather Seats, Hooker Road bumpers both front and back, carbon fiber covers on inside chrome detail, custom lady liberty coin shifter
    @ NewImprovedRon
    " How old is your current battery? If you have an Auto Zone parts store, they can do a load test on your battery to tell you for sure if it is bad or going downhill."
    2020 stock battery, so its 3 years old, 30k checkup.
    You think the AutoZone test is a different test than the store that specializes in truck batteries?
  5. Aug 23, 2023 at 3:39 PM
    WILLINH
    WILLINH New Member
    BILL
    NEW HAMPTON, NH
    2019 TUNDRA
    I don’t trust the dealers. My daughters tundra tested at 580 at a independent shop last November and they said it was fine and we get -0 temps here. So this fall I’ll replace it at 4 1/2 old.
  6. Aug 23, 2023 at 3:47 PM
    seydou
    seydou Distinguished Member
    There are a couple of tests and the more important one is the load test.
    You could calm your fears by either getting a new battery and/or by getting a jump box, which everyone should have anyway.
    Mike59, NewImprovedRon and WILLINH like this.
  7. Aug 23, 2023 at 5:32 PM
    737fixer
    737fixer New Member
    And since its Costco anything......ANYTHING happens in the first 3 years and they hand you a new one.
  8. Aug 23, 2023 at 6:01 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    Id carry a JNC660, new battery or not, always good to have a solid jumper pack just incase.
  9. Aug 23, 2023 at 6:29 PM
    IsaiahCanada
    IsaiahCanada New Member
    Isaiah
    Calgary, Alberta
    2021 Tundra SR5 Crewmax 4x4
    2.5 inch lift, TRD front and rear sway bars, 33 inch Open Country AT3 305/55R20 and dual TRD exhaust.
    My OEM battery was replaced with another OEM battery under warranty.
    Mike59 likes this.
  10. Aug 23, 2023 at 6:35 PM
    NewImprovedRon
    Ron
    NW Arkansas
    Since I don't know what tests were performed, I can't speculate. If the local battery shop told me it was "good" though' and didn't try to sell me a replacement battery, I would probably believe them more than the dealership.
  11. Aug 23, 2023 at 6:45 PM
    biebs96
    PA
    Replaced OEM 17, 30 months after date on battery with another OEM.
    Replaced that second OEM from 2020, exactly 30 months after date on battery with the highest level Duralast battery from Autozone.
    I have zero complaints with the non-OEM battery. Higher cranking amps and cheaper.
    IsaiahCanada likes this.
  12. Aug 24, 2023 at 7:45 AM
    fyrfytr26
    fyrfytr26 New Member
    Eastern PA
    2021 DC SR
    Just make sure to keep it charged up. Even from new I had to charge mine every 2-3 months.
    I eventually went with a NOCO GB70. Much smaller and lighter, and I check it every 3 months, and top it off maybe once a year. I’ve used it a couple times and it has plenty of power.
  13. Aug 24, 2023 at 8:02 AM
    Shifless Joe
    Shifless Joe New Member
    Mesa AZ
    2016 TRD Off-Road
    Most people are just simply too lazy to take the time to maintain their batteries (simple monthly fluid level check and trickle charge).
    The original Motorcraft battery in my 92 Ford lasted 11 years (still working when I changed it), got another 12 years out of the Motorcraft replacement (still working), sold the truck with the third battery when it was 30 years old.
    Have the original in my '16 Tundra, still going strong, but people on the forum say their junk.
  14. Aug 24, 2023 at 8:10 AM
    SD Surfer
    Bruce
    So Cal
    Tell me about these terminals please.
    Mike59 and chugs like this.
  15. Aug 24, 2023 at 8:11 AM
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    Sequoia
    Duracell (East Penn) AGM from Batteries Plus. 48 month free replacement. I also did the GM diode/7.5 amp fuse mod for AGM charging.
  16. Aug 24, 2023 at 8:12 AM
    BlueCrushSC16
    BlueCrushSC16 New Member
    Charleston, SC
    NewImprovedRon likes this.
  17. Aug 24, 2023 at 8:19 AM
    BlueCrushSC16
    Charleston, SC
  18. Aug 24, 2023 at 8:24 AM
    Rodtheviking
    Vancouver, WA
    Sequoia
  19. Aug 24, 2023 at 8:44 AM
    #49
    Joe333x
    Joe333x Member
    Boston
    I used to carry a similar lithium pack from Battery Tender. It did work well, right up until it didnt. I dont trust the lithium packs anymore since the cold and heat kills them and eventually the entire thing will expand and stop working. The lead acid battery in the JNC is a little better dealing with temperature swings and i do top it off every three months. If you sign up for their emails they send you a reminder to do so. Plus once the battery inside goes you can just replace it rather than buy an entire new pack like the lithium units.
    fyrfytr26[QUOTED] likes this.
  20. Aug 24, 2023 at 8:47 AM
    #50
    NewImprovedRon
    Ron
    NW Arkansas
    I bought a set of these before they started putting the set screws on them and they were too big for my battery posts. Contacted GPAudio and they would not exchange them for the new style product. I was never able to use the ones I have and they are still sitting in my garage. Swore off GPAudio for any future business because of that.
  21. Aug 24, 2023 at 8:57 AM
    #51
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    drpheta, WILLINH and SD Surfer like this.
  22. Aug 25, 2023 at 9:19 AM
    #52
    seydou
    Just about everyone has stories of batteries that went well beyond their expected lifespans and also ones that shit the bed well before.
    You check your battery's water and put it on a trickle charger every month? Not lazy, also not OCD, but no way am I wasting my time doing that. And shouldn't your battery be charged every time you drive it?
  23. Aug 25, 2023 at 11:11 AM
    #53
    Joe333x
    Joe333x Member
    Boston
    You don't need to check water levels every month, I check mine once a year and I have a quick disconnect for my Optimate charger that takes a me maybe an extra 5 minutes to plug in overnight once a month. Smart chargers like an Optimate do more than just charge they also help condition the battery with electric pulses as well and tell you the health of the battery. I have a trolling motor that I already needed the optimate 7 charger for so it wasnt an extra cost but I have also used smaller Optimate chargers for 24/7 storage connected to my motorcycle and I got over 10 years out of my last battery. Your alternator does charge your battery but not all the way. I dont have time to get stuck with a dead battery so I make sure to keep mine healthy and my charger will let me know when its starting to go bad and it's time to replace it.
    WILLINH likes this.
  24. Sep 15, 2023 at 1:36 PM
    #54
    Joe333x
    Joe333x Member
    Boston
    Just coming back since I jinxed myself. My OEM battery in my 2019 with 48,000 just died today. Picked up a replacement interstate from Costco for $109+$15 core charge. So wierd, I had just got home to change and head back out and it died on my way back out but started just fine an hour before. Wouldn't even crank, just nothing when turning the key. Read 8.3 Volts!
  25. Sep 16, 2023 at 4:21 AM
    #55
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    When my OEM died a premature death my first stop was WalMart. The WalMart where I live quit carrying 27s in the proper post configuration for a Tundra. I went to AutoZone and bought one. My thought on WalMart is a lot of people shop there for the prices so they probably were selling a lot more 24s. Not a fan of Batterries Plus.
    WILLINH likes this.
  26. Sep 16, 2023 at 12:35 PM
    #56
    Joe333x
    Joe333x Member
    Boston
    I learned yesterday that a regular 27 battery is the same size as a 27F but the terminals are reversed
    ConcordCarlos likes this.
  27. Sep 16, 2023 at 5:11 PM
    #57
    agrestic1
    agrestic1 New Member
    2016 CrewMax
    AMP Research PowerStep, AMP BedStep Bumper Step, BedRug Carpet Bed Mat, Bazooka Powered Subwoofer Tube
    2016 here, replaced battery 1 year ago with a NAPA battery.
  28. Sep 17, 2023 at 1:45 PM
    #58
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    My OEM on the 2018 lasted just beyond the 36 mos warranty. Bought a 24F AGM on sale at Advance on sale for under $200. Has same CCA as 27F flooded. I'm a fan of AGMs after flooded batteries in my old Suburban leak when side terminal fell out melting the pos lead to started and in my Porsche leaked around terminal melting hole in trunk floor. I also bought one of @Coupe's custom hold down. I've use OEM terminals but if you have extra lighting or a big amp get aftermarket billet terminals.
    Coupe and NewImprovedRon like this.
  29. Oct 2, 2023 at 9:33 AM
    #59
    KSTNTUNDA
    KSTNTUNDA New Member
    Nashville
    2020 LIMITED TRD OFF ROAD
    I wound up going with the Autozone Duralast Platinum EFB 27F for several reasons
    - Didn't want any possible issues with the AGM/GM diode route
    - Don't have any extreme loads that would require a AGM battery
    - EFB is the same technology as the OEM
    - CCA 810A (vs OEM 710A)
    - No Maintenance required
    - More durable and longer lasting than traditional flooded cell battery. I looked at Interstate but they don't currently make a 27F EFB (MTX in Interstate terms)
    - EFB batteries are better suited for off road/rough terrain that I find myself on often
    - Previous positive experience with the AZ EFB on my wives Armada
    - Battery is readily available and easily replaceable under warranty if I have any issues
    The Autozone EFB battery may not be as sexy at the X2 but it fills the gap between traditional batteries and AGM's and overall seems like a more logical for my situation.
    RitcheyRch, TXBrit and Lug Nut like this.
  30. Oct 2, 2023 at 11:43 AM
    #60
    WILLINH
    WILLINH New Member
    BILL
    NEW HAMPTON, NH
    2019 TUNDRA
    I replaced the battery in my daughters Tundra with a Napa 27F this weekend as I was putting on the terminals I saw it stamped made in Mexico. I almost took it back.
    Sierradevil likes this.
