What was your OEM Battery Replacement?
Discussion in '2.5 Gen Tundras (2014-2021)' started by geno0506, Nov 13, 2018.
  1. Mar 28, 2019 at 10:38 AM
    #91
    careyrob
    careyrob In the field
    Carey
    Massachusetts
    2008 Crewmax TRD 4x4 Silver
    LRO 3/1 leveling lift 35x12.50's on 20x9's Hellwig rear sway bar B&M 70264 SuperCooler Transmission Cooler Firestone airbags Daystar cradles Air Lift WirelessONE Compressor System
  2. Mar 28, 2019 at 11:59 AM
    #92
    Outbound
    Aaron
    Northern Alberta
  3. Mar 28, 2019 at 4:24 PM
    #93
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    2022 CMLB TRD OR Prem. 4X4 and 2002 RCLBV65Spd
    After almost 5yrs oem took a dump. Had to extend wires because a reverse post wasn't available. Works great.
    Twinky and Berdine like this.
  4. Mar 28, 2019 at 6:04 PM
    #94
    Twinky
    07 double cab work horse
    Thats how you do it. You make it work.
    When i got my tundra it had one of the more common walmart/autozone batts. It looked old and it was actually still working properly but i hate trusting something you nothing about.
    I got an exide extreme from home depot. I would guess they are owned by Johnson C. now. Either way, had to make it fit. For $100 and a decent warranty (which i cant remember) im happy.
  5. Mar 28, 2019 at 6:17 PM
    #95
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    I agree. I was going to get a NSB but they weren't in production at the time and my stock needed jumping off to start.
  6. Mar 29, 2019 at 8:20 AM
    #96
    dandailey
    dandailey King Tundra
    Dan D
    Newport News Va.
    2015 TRD 4x4 DC Tundra 5.7 Blue Ribbon
    Bakflip Revolver X2 ,Nestahedition Firestalk antenna, TRD dual exhaust, WeatherTech liners, in channel deflectors, 20% tint front, Tundra bed mat.AFE pro dry s filter,SA XDM 3.8 compact 9mm., Wheel to wheel N-Fab 3 steps.Lamin-X yellow on fogs, Bilstein 6112's top setting, BFG KO2's 275/70-18.Pioneer HU, JL RD amp, Focal speakers everywhere.
    All this talk of OEM battery failures made me think i better replace my 4 year old one.
    Just ordered one of these. Always had great success with Advanced Auto.
  7. Mar 29, 2019 at 8:42 AM
    #97
    Berdine
    Berdine Voodoo Sport
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    That's the one I was looking into. Also the napa legend agm, $129 out the door with discounts
    https://www.napaonline.com/en/p/NBE9834R?ref=MA==
  8. May 3, 2019 at 10:27 AM
    #98
    boneless
    boneless New Member
    2016 Black Tundra Platinum
    Thought I would hook into this topic. Looking at a battery to replace the OEM, Toyota quoted me OEM replacement for $172. Batteries+ had a Duracell for $139, just noticed Sam's Club had the exact same model for $99 (including the 36 month warranty). Seems to be a very competitive price, but not convinced about the build quality. Then again, it does have the 36 month warranty.
    Alternative for me would be Interstate MTP-27F but they are $149.
    Anyone bad experiences with Duracell?
  9. May 3, 2019 at 10:44 AM
    #99
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    I love the Northstar and the GP Audio terminals. Cleaned everything up nicely.
    TRDblvd, afbatts, hi_rawb and 3 others like this.
  10. May 3, 2019 at 10:55 AM
    #100
    CenTexTundra
    CenTexTundra New Member
    2017 Tundra Limited
    BDS 7" Coilover lift; BDS UCAs 37" Nitto Ridge Grapplers; 20" Fuel Tactic Wheels Smittybilt 10k Winch; Smittybilt M1 Bumpers WeatherTech Mats; EPS Rear Vault, TRD Pro Grille Genesis Offroad Dual Battery (Optimas)
    IMG_6931.jpg IMG_3694.jpg I'm also running the Odyssey Dual battery with two Optima red tops.
    aperezsh and Toyotoholic like this.
  11. May 3, 2019 at 11:01 AM
    #101
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Remove the Allen bolt and grease the bolt and the socket of the terminal where the head of the Allen sits into. This made all the difference for me to "cinch" it down tight. The grease allows the bolt to turn and not bind on the terminal, thus easier to tighten. I also cut the terminals down to four taps so it fit better.
    UTTundra and Wynnded like this.
  12. May 3, 2019 at 6:46 PM
    #102
    Haggis777
    Haggis777 I.L.J.C.M.L.
    SW Michigan
    2015 Silver SR5 TRD Tundra Canadian Model
    LEDs interior & exterior, stubby antenna, Bak-Flip cover, 285's, AGM battery, block heater, Pine tree air freshener
    Put the same one from Advance Auto in my 2015.
    AGM is THE way to go, particularly for off-roading...or driving down my road with tons of potholes....
  13. May 11, 2019 at 9:53 PM
    #103
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    I’m about ready to dump my stock battery. I’m leaning towards the X2. I’m just bouncing back and forth wondering if it’s worth spending the amount on a battery? There are not a ton of 27f AGM options that I can find.
  14. May 12, 2019 at 5:16 AM
    #104
    NH2BV
    NH2BV Daily drivers!
    Las Cruces, NM
    2024 Tundra TRD Off Road
    Rock Stock OEM beast
    All I know for sure is that if you use a battery for more than 3 years out here in the high desert, you are on borrowed time. I have been lucky. I have used the Autozone brand with the 36 month warranty. Anything beyond that is pro rated at failure.
  15. May 12, 2019 at 6:03 AM
    #105
    PermaFrostTRD
    Northern NY
    The truck got 4 years out of the OEM (I got 2). Put an interstate in and expect 4 out of it
  16. May 13, 2019 at 8:21 PM
    #106
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
  17. May 13, 2019 at 8:30 PM
    #107
    What the!?
    What the!? New Member
    2017 Pro
    That’s the same one I went with too. Beefy battery and it started the Tundra like a champ! My pos oem only lasted a little over a year. It wasn’t worth it for me to get it warrantied only to have it die again. I’d rather have long lasting piece of mind.
    BTBAKER[QUOTED] and ColoradoTJ like this.
  18. May 13, 2019 at 9:04 PM
    #108
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    My OEM is still ok but I can’t run my ditch lights/rock lights and the radio for 30 min w/o my truck going dead (to start) so upgraded to the Optima
    aperezsh and Black Wolf like this.
  19. May 13, 2019 at 9:17 PM
    #109
    flyfisher
    flyfisher Member
    David
    Firestone, CO
    2005 Tundra SR5 Double Cab 4x4
    Northstar's are what the Navy uses in many applications. A gel battery with a lot of upsides. Frequent Northstar group buys on TacomaWorld or T4R websites. I've had two of them over the years. Exceptional!
  20. May 13, 2019 at 9:23 PM
    #110
    Tierhog
    Tierhog SIG-AHOLIC
    2016 Tundra Crewmax Limited 4WD
    Mostly stock/TRD accessories/Morimoto XBs
  21. May 14, 2019 at 5:22 AM
    #111
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    X2 is the same battery as the Northstar just rebranded. Plus, it comes with an extra 1 year warranty.
  22. May 14, 2019 at 5:25 AM
    #112
    TXDrifter
    TXDrifter BlueGrass Crew
    Jeff
    Louisville, KY
    2017 Tundra MGM DC
    I want to add those terminals soooo badly even tho I don't have anything other than stock battery cables to attach to them. It looks so clean!
    Toyotoholic[QUOTED] and BTBAKER like this.
  23. May 14, 2019 at 5:34 AM
    #113
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Thanks! I used the stock cables. The only modifications were: I cut the terminals down to 4 posts instead of 6, and I just drilled the negative bar so that it spanned across 2 of the post lugs. The other wiring is stereo and lights.
  24. May 14, 2019 at 5:42 AM
    #114
    TXDrifter
    Jeff
    Louisville, KY
    2017 Tundra MGM DC
    What did you use to cut the terminal down?
    Toyotoholic[QUOTED] likes this.
  25. May 14, 2019 at 7:10 AM
    #115
    flyfisher
    flyfisher Member
    David
    Firestone, CO
    Good to know. Thanks!
    BTBAKER[QUOTED] likes this.
  26. May 14, 2019 at 10:09 AM
    #116
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    I put it in a vice and used a jigsaw with a fresh blade, on a slow speed. It took about 5-7 minutes for each terminal.
    aperezsh and NewImprovedRon like this.
  27. May 14, 2019 at 10:11 AM
    #117
    TXDrifter
    Jeff
    Louisville, KY
    2017 Tundra MGM DC
    Gotcha... I will have to try this myself now.. Thanks for the info.
  28. May 14, 2019 at 10:14 AM
    #118
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    No prob, good luck. GO SLOW!
  29. May 15, 2019 at 7:37 PM
    #119
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    This just happened! I got quite an education on the evolution of Northstar/XS batteries and what makes them so good.
    What the!? likes this.
  30. May 18, 2019 at 5:52 PM
    #120
    RJN55
    RJN55 New Member
    2018 Tundra LIMITED DC (Flares, Rear Sway Bars, Timbrens, B&W Gooseneck Hitch, Running Boards, Visors, 18 inch rims with 10 ply Michelin AT/2's, Bed Lights, Tow Mirrors
    I like Costco... great customer service if there are any issues.
