What's the best head unit out there?
Discussion in '2nd Gen Tundras (2007-2013)' started by Ninjagoblin1, Jul 3, 2021.
  1. Jan 30, 2022 at 9:49 AM
    audiowize
    audiowize New Member
    Paul B.
    2008 Tundra SR-5 4x4 5.7
    I put in my Dasaita yesterday.
    This is where I drilled out the factory bracket to mount to the Dasaita, and a pair of M4x8mm screws are required to connect the two. I also filed down the upper nib so the bracket would fit flush against the chassis of the radio. There's a grid of vent holes on the side of the radio, and you should be able to see the top row through the upper stock mounting hole on the bracket just as a reference for the position, or just align the "LH" and "RH" lettering to be parallel with the body of the head unit.
  2. Jan 30, 2022 at 9:51 AM
    BoysandHisToys
    BoysandHisToys New Member
    Central Virginia
    2013 Tundra Crewmax Limited
    12” Bulletproof Lift, AFE CAI, AFE Exhaust, rock lights, Fas-Top tonneau and soft topper, Dasaita 10.2” radio, light bar, ditch lights, LED headlights and fog lights, LED interior lights, Amp Research rear bumper step, dashcam, BT ODBII reader and Torque app on radio
    Looks very similar hardware like the Dasaita and Joying units. Probably the same hardware but different software. I would base it on others experience with the user interface and support.
    I’ve had no real issues with my Dasaita to comment on the support.
  3. Jan 30, 2022 at 10:04 AM
    Landodnal
    Landodnal New Member
    Ryan
    2008 Toyota Tundra Limited Slate Grey 4WD
    2" Leveling Kit
    Do all years need to be drilled for the Dasaita unit? Here is a video of a guy installing the Dasiata in a 2010 tundra. He didn't drill anything or mention drilling. What am I missing?
    https://www.youtube.com/watch?v=oDOz6tVkP88
  4. Jan 30, 2022 at 10:05 AM
    audiowize
    Paul B.
    Compared to the Pioneer HU and PAC steering wheel controls I tried to put in, this installation is rather simple. I got the canbus adapter for the JBL system, and it plugs into two of the original HU plugs directly, then that plug goes into the back of the HU. The GPS antenna and microphone can be run together up to the A-pillar and front driver's corner of the dash. The 34mmx24mm USB jack for Toyota fits the lower HVAC controls perfectly. I think I will buy two more to fill the emtpy holes I have.
    I've seen some people post about having difficulty with the steering wheel controls, but with this particular unit you can go into the settings and they have you hold down the button you want to program, then tell the HU what you want it to do, so it wasn't a problem at all.
    Ohannon7 likes this.
  5. Jan 30, 2022 at 10:07 AM
    audiowize
    Paul B.
    The stock radio has a bracket on each side so that it can be bolted into the dash which helps support the weight of those units. In the video you posted, the creator had an aftermarket head unit already and had decided to discard those brackets entirely. That's an option, but I'll take the extra metal personally.
    If you still have the stock HU, that video is a horrible guide and should be 100% ignored in favor of a more complete approach that gives you access to the mounting screws.
  6. Jan 30, 2022 at 10:09 AM
    Landodnal
    Ryan
    2" Leveling Kit
    Gotcha. So with the factory metal brackets, the radio is more secure? Without them, it will work, but may have a little play or might sag over time?
  7. Jan 30, 2022 at 10:17 AM
    audiowize
    Paul B.
    Yeah the brackets will make things more secure I suspect, and without them the junction of the HVAC panel and the radio itself might be able to move a little bit.
    Landodnal likes this.
  8. Jan 30, 2022 at 10:31 AM
    BoysandHisToys
    Central Virginia
    I don’t recall the instructions for my Dasaita mentioning anything about the brackets. But I could have overlooked them. I mean, what man uses directions, right? Unless the install goes wrong!
    But I did the install like the video and my radio and AC controls all seem very well supported.
  9. Jan 30, 2022 at 10:34 AM
    audiowize
    Paul B.
    You got installation instructions with your Dasaita?
  10. Jan 30, 2022 at 10:35 AM
    BoysandHisToys
    Central Virginia
    Haha. I may have been stretching there. I honestly don’t recall but I know I didn’t use any brackets.
  11. Jan 31, 2022 at 11:31 AM
    NueveTundra
    NueveTundra Mod list in Bio
    Planet Earth
    07, Black Tundra SR5 CrewMax
    I recommend the Alpine 650 its a great shallow mount with pretty dang good mini DSP function. Also can get it with or with out a piggy back amp (running piggy back amp will make it a full size depth mount) also has Apple Carplay and Android auto.
    Stainlesst and KJJ2007 like this.
  12. Jan 31, 2022 at 3:22 PM
    BoysandHisToys
    Central Virginia
    This is the unit I just got my daughter for Christmas. Definitely took me by surprise when I opened it. Not use to those shallow units. I come from the CD era!
    Ohannon7 and NueveTundra[QUOTED] like this.
  13. Mar 2, 2022 at 9:30 AM
    MonteSTL
    MonteSTL New Member
    Monte
    2007 Tundra SR5 black
    stock
    these are the components I used in my Tundra. the head unit has subwoofer RCA outputs and when activated it cuts the lows from the factory speakers and the sound is awesome. It wont rattle the doors off but 500% better bass.
    Alpine HU- has Apple carplay and Android auto... NO CD player..
    https://www.amazon.com/Alpine-iLX-W650-Mech-Less-Receiver-Compatible/dp/B07NQ2BRFM?crid=3IM31F6940F30&keywords=alpine+car+stereo&qid=1646240084&refinements=p_89%3AAlpine&rnid=2528832011&s=electronics&sprefix=alpine%2Caps%2C170&sr=1-3
    dash kit
    https://www.amazon.com/Scosche-TA2073B-Single-Pocket-Installation/dp/B000Z4G4H4?crid=1WEXUPYWA5UIF&keywords=toyota+tundra+double+din+dash+kit&qid=1646240244&s=electronics&sprefix=2007+toyota+tundra+double+din+%2Celectronics%2C82&sr=1-3
    wiring harness
    https://www.amazon.com/SCOSCHE-TA02BCB-Vehicles-Pre-terminated-Connectors/dp/B004W34BYM?crid=2SB4NCDI29A4O&keywords=toyota+tundra+radio+wiring+harness&qid=1646241029&sprefix=toyota+tundra+radio+w%2Caps%2C85&sr=8-3
    MicroBypass parking brake override for Alpine.. ordered mine from Amazon but since they have stopped selling them.
    https://www.ebay.com/itm/2837764131...ywC8xT9lObob1lQHBMdY99FaD3U1sEuRoCQaAQAvD_BwE
    Rear camera
    https://www.amazon.com/Tailgate-Replace-Camera-Backup-Replacement/dp/B07WR9C3M4
    subwoofer fits perfectly under the rear single seat.
    https://www.amazon.com/Cerwin-Mobil...c0e7b30e2a5&pd_rd_wg=xrIFj&pd_rd_i=B075FPTWS1
    juanpsi, frieselu and Kwe1982 like this.
  14. Mar 7, 2022 at 8:05 AM
    MilesToEmpty
    MilesToEmpty New Member
    Charles
    2007 DC 4x4 Linited
    So I’ll throw something out here.
    I upgraded my limited to a kenwood and it was great. But the glare was awful since the screen can’t be tilted. And I hate to say it, but the 7” screen was just too small to easily reach. My kenwood failed exactly a week after the warranty went out, it kenwood is replacing it for me anyway. This was January 14 when it failed.
    I’m still waiting for a replacement unit, and they said it could be another 45-70 days.
    So I’m looking to go with a 9” Sony simply so I can tilt it so the screen doesn’t have so much glare lol.
  15. Mar 13, 2022 at 11:26 AM
    Musicmasterd12
    Musicmasterd12 New Member
    Southern Louisiana
    2011 4.6 Silver Sky Metallic DC
    I prefer pioneer HUs. Grab one with CarPlay function and you’ll be good to go
  16. Mar 16, 2022 at 7:00 PM
    MilesToEmpty
    Charles
    2007 DC 4x4 Linited
    Just got the new Sony 8100 installed.
    Capacitive screen, and a lower resolution, but I can actually read the thing without leaning forward.
    PhotoNerd likes this.
  17. Jun 8, 2022 at 2:53 PM
    TundraTRD08
    TundraTRD08 Somehow I fit 37s on a level
    Wesley
    08 Super White TRD Off-Road on 37s
    3.5' RC lifted struts with RC UCA Alcan rear leaf spring upgrade with 300lbs added weight+1" lift built in. Adjustable Alcan Shackles set to add an extra inch which equals to a 2" lift in the rear. 37” Maxxis RAZR M/Ts with 1.5” spacers 8” BAMuffler Tuned by Bully Dog Tuner
    My JVC just went out and when I click the reset button it just flashes, then, it goes back off. Do you, or anyone else, have opinions on one that kind of peeks over the dash a little? Also I want one that has good audio quality, as well as an equalizer in it like the JVC or Kenwood.
  18. Jun 8, 2022 at 4:14 PM
    MilesToEmpty
    Charles
    2007 DC 4x4 Linited
    Ive been very happy with my Sony that I posted in the comment above yours. Sound quality is great, radio is a bit slow for animations between menu's and the screen isnt HD but for its price point being a 8.9" you cant beat it.
  19. Jun 8, 2022 at 4:42 PM
    #49
    pyrite808
    pyrite808 Real TRD Pros are built not bought
    Anthony
    Mid Tennessee
    08 DBL Cab Pyrite
    If you can be patient (shipping directly from China wait approx 2 months) here’s my recommendation it is a really solid unit. Price/features/quality is unbeatable in comparison to the $1000 plus domestic units available here.
    Teyes CC3 android head unit installed
    https://www.aliexpress.com/item/100...o.store_pc_groupList.8148356.2.21644ab96a1gPv
    To get carplay to work w/ this unit you'll need to download the AutoKit app to the head unit and purchase a carplay adapter, I used (which works wired and wireless): https://www.amazon.com/dp/B08G1F11GP?ie=UTF8
    red_5ive likes this.
  20. Jun 9, 2022 at 2:17 PM
    #50
    jggeere
    jggeere New Member
    jared
    2002 toyota tundra 4.7 4x4
    What’s the first one?
  21. Jun 9, 2022 at 2:19 PM
    #51
    BoysandHisToys
    Central Virginia
    Either Dasaita or Joying or maybe a few other brands. They seem to have similar hardware so it comes down to the OS and support. They’re all Chinese Android based systems.
  22. Jan 2, 2023 at 6:59 AM
    #52
    red_5ive
    red_5ive Jedi Knight and friend of Cpt. Solo
    Southern California
    2008 4.7L CrewMax
    • 3.5" Maxtrac Spindle Lift • 2.5" Spacer • Monster XD778 18 x 9 wheels, +18 Offset • Nitto Ridge Grappler 325/65 R18 (34.6 x 12.8 - temporarily back on the 32s until I can decide on gears) • Nitro 5:29 Gears (awaiting installation - on hold for now) • Black/smoke headlights • Clazzio custom leather seats • Boss Wireless Android Auto head-unit • Backup camera
    Just found this thread. How is the brightness on the Teyes CC3 in the day? Does it get washed out? Also, has anyone tested the connect time with wireless Android Auto?
  23. Jul 11, 2023 at 6:52 PM
    #53
    jgonza46
    jgonza46 New Member
    How were you able to get the back up oem back up camera to hook up to the unit. I have a non JBL and the oem back up plug from the HU has nowhere to plug with my oem harness wiring
    Any help would be appreciated
  24. Jul 11, 2023 at 6:53 PM
    #54
    jgonza46
    jgonza46 New Member
    did your HU have apple car play dongle or car play in unit?
